USB mass storage for the NRF7002DK development board using on board chip
Hello everyone,
As the title suggests, we're trying to get the on board flash (mx25r64 as far as I can tell) of the nrf7002dk devboard working as a USB mass storage device (should be visible when connecting to Windows and MacOS).
Doing a bit of googling, I've found that a good starting point is the sample from:
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/
I started from there and tried various bits and pieces from different posts in the Nordic DevZone to try and get it working. Sadly it doesn't wanna yield and the most common error is either the partition manager not recognising the label put in the overlay or something else related to the partition manager not accepting/ initialising the disk.
Latest build log:
root@Tudors-MacBook mass # west build -b nrf7002dk/nrf5340/cpuapp/ns --pristine
-- west build: making build dir /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/homebrew/opt/[email protected]/bin/python3.13 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /Users/tudor/Library/Caches/zephyr
-- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
-- Board: nrf7002dk, qualifiers: nrf5340/cpuapp/ns
Parsing /opt/nordic/ncs/v3.0.0/zephyr/share/sysbuild/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/empty.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/sysbuild.conf'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/autoconf.h'
   * Running CMake for mass *
-- Application: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass
-- CMake version: 4.0.2
-- Found Python3: /opt/homebrew/bin/python3 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr)
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Found toolchain: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Could NOT find Dtc (missing: DTC) (Required is at least version "1.4.6")
Hint: The project() command has not yet been called.  It sets up system-specific search paths.
-- Found BOARD.dts: /opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
-- Found devicetree overlay: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay
-- Generated zephyr.dts: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/zephyr.dts
-- Generated pickled edt: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/edt.pickle
-- Generated devicetree_generated.h: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/dts.cmake
warning: DISK_DRIVER_SDMMC (defined at
boards/shields/adafruit_2_8_tft_touch_v2/Kconfig.defconfig:37, drivers/disk/Kconfig.sdmmc:7) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: ((DISK_DRIVERS
&& (SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2 || SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2_NANO)) ||
((DT_HAS_ZEPHYR_SDMMC_DISK_ENABLED || DT_HAS_ST_STM32_SDMMC_ENABLED) && DISK_DRIVERS)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_DISK_DRIVER_SDMMC and/or look up
DISK_DRIVER_SDMMC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: NORDIC_QSPI_NOR (defined at /opt/nordic/ncs/v3.0.0/nrf/Kconfig.nrf:95,
drivers/flash/Kconfig.nordic_qspi_nor:4) was assigned the value 'y' but got the value 'n'. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NORDIC_QSPI_NOR and/or look up
NORDIC_QSPI_NOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: SDMMC_STM32_HWFC (defined at drivers/disk/Kconfig.sdmmc:47) was assigned the value 'y' but
got the value 'n'. Check these unsatisfied dependencies: SDMMC_STM32 (=n), (SOC_SERIES_STM32H5X ||
SOC_SERIES_STM32H7X || SOC_SERIES_STM32F7X || SOC_SERIES_STM32L4X || SOC_SERIES_STM32L5X) (=n),
DISK_DRIVER_SDMMC (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SDMMC_STM32_HWFC and/or look up
SDMMC_STM32_HWFC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/prj.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config.sysbuild'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
  CONFIG_USB_DEVICE_VID has default value 0x2FE3.
  This value is only for testing and MUST be configured for USB products.
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Using ccache: /opt/homebrew/bin/ccache
-- Configuring done (5.7s)
-- Generating done (0.4s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass
-- Found partition manager static configuration : /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/pm_static.yml
-- Configuring done (9.1s)
-- Generating done (0.0s)
[5/10] Performing build step for 'mass'
[1/278] Preparing syscall dependency handling
[6/278] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr), build: v4.0.99-ncs1
[8/278] Generating ../../tfm/CMakeCache.txt
-- Found Git: /usr/bin/git (found version "2.39.5 (Apple Git-154)")
-- Found Python3: /opt/homebrew/bin/python3 (found version "3.13.3") found components: Interpreter
CMake Warning (dev) at /opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf5340_cpuapp/CMakeLists.txt:21 (install):
  Policy CMP0177 is not set: install() DESTINATION paths are normalized.  Run
  "cmake --help-policy CMP0177" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Configuring done (0.9s)
-- Generating done (0.1s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm
[17/278] Performing build step for 'tfm'
[135/139] Linking C executable bin/tfm_s.axf
           FLASH:       32100 B        32 KB     97.96%
             RAM:       10404 B        32 KB     31.75%
[139/139] Linking C static library secure_fw/libtfm_s_veneers.a
[19/278] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
----- Installing platform NS -----
[89/278] Building C object CMakeFiles/app.dir/src/main.c.obj
In file included from /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:29:
/opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:37:17: warning: 'littlefs_storage' defined but not used [-Wunused-variable]
   37 | #define storage littlefs_storage
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/fs/littlefs.h:91:35: note: in definition of macro 'FS_LITTLEFS_DECLARE_CUSTOM_CONFIG'
   91 |         static struct fs_littlefs name = {                                                \
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:1: note: in expansion of macro 'FS_LITTLEFS_DECLARE_DEFAULT_CONFIG'
   30 | FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:36: note: in expansion of macro 'storage'
[159/278] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
FAILED: zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
ccache /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr -I/opt/nordic/ncs/v3.0.0/zephyr/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/nrf53/. -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/common/. -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device -I/opt/nordic/ncs/v3.0.0/zephyr/drivers/usb/common/nrf_usbd_common/. -I/opt/nordic/ncs/v3.0.0/nrf/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm/api_ns/interface/include -I/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -I/opt/nordic/ncs/v3.0.0/nrf/include/tfm -I/opt/nordic/ncs/v3.0.0/nrf/tests/include -I/opt/nordic/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v3.0.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v3.0.0/nrf/modules/hal_nordic/. -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem /opt/nordic/ncs/v3.0.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -imacros /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: return type defaults to 'int' [-Werror=implicit-int]
  533 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: storage class specified for parameter 'flash_disks'
  572 | static struct flashdisk_data flash_disks[] = {
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:15: error: parameter 'flash_disks' is initialized
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
  573 |         PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: note: each undeclared identifier is reported only once for each function it appears in
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:582:1: error: expected declaration specifiers before 'PM_FOREACH_AFFILIATED_TO_disk'
  582 | PM_FOREACH_AFFILIATED_TO_disk(VERIFY_CACHE_SIZE_IS_NOT_ZERO_IF_NOT_READ_ONLY)
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/gcc.h:98,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain.h:50,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/__assert.h:11,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:10:
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: storage class specified for parameter '__init_disk_flash_init'
  141 | #define Z_INIT_ENTRY_NAME(init_id) _CONCAT(__init_, init_id)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
  137 | #define _DO_CONCAT(x, y) x ## y
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:36: note: in expansion of macro '_CONCAT'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:17: note: in expansion of macro 'Z_INIT_ENTRY_NAME'
  241 |                 Z_INIT_ENTRY_NAME(name) = {.init_fn = {.sys = (init_fn_)},                \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:223:9: note: in expansion of macro 'SYS_INIT_NAMED'
  223 |         SYS_INIT_NAMED(init_fn, init_fn, level, prio)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:1: note: in expansion of macro 'SYS_INIT'
  612 | SYS_INIT(disk_flash_init, POST_KERNEL, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: error: parameter '__init_disk_flash_init' is initialized
  239 |         static const Z_DECL_ALIGN(struct init_entry)                                      \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:195:55: note: in definition of macro 'Z_DECL_ALIGN'
  195 | #define Z_DECL_ALIGN(type) __aligned(__alignof(type)) type
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: section attribute not allowed for '__init_disk_flash_init'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: warning: 'used' attribute ignored [-Wattributes]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: alignment may not be specified for '__init_disk_flash_init'
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/device.h:13,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sw_isr_table.h:18,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/irq.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/arch.h:24,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/cpu.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel_includes.h:36,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel.h:17,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/drivers/disk.h:30,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:12:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:10: error: 'disk_flash_init' undeclared (first use in this function)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:64: note: in definition of macro 'SYS_INIT_NAMED'
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: type of 'DEFINE_FLASHDISKS_CACHE' defaults to 'int' [-Werror=implicit-int]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: declaration for parameter '__init_disk_flash_init' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: declaration for parameter 'flash_disks' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: error: expected '{' at end of input
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: warning: control reaches end of non-void function [-Wreturn-type]
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: At top level:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:464:37: warning: 'flash_disk_ops' defined but not used [-Wunused-const-variable=]
  464 | static const struct disk_operations flash_disk_ops = {
cc1: some warnings being treated as errors
[168/278] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
FAILED: _sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build
cd /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass && /opt/homebrew/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build
The whole sample project folder:
8686.mass.zip
Any and all help is gladly welcome! :)
  • Hi, and sorry about the wait Tudor! I have been OOO for a while, and assumed this would be picked up by someone else.
    I'll try to get back to you on your questions later this week. Seems like a you've gone through a lot here, though I am glad you've gotten help from Alexander while I was away. Is everything really working the way it should now?
    Elfving
  • ELFVIIIING! Welcome back!
    A succinct answer:
    But memes aside, here's the sample that Alexander sent me:
    7282.mass.zip
    I have a few notes regarding it:
    - when connecting it to Windows, if you copy a file to it and then decide to delete it, the file doesn't go to my computer's Recycle Bin, but rather a hidden folder is created that's named ".Trashed". To truly delete the file; you must delete it from inside the .Trashed folder. Is this a bug or a feature?
    - if you restart/ power on your Windows machine and left the usb mass storage connected, the explorer.exe doesn't start correctly until you unplug the devkit.
    - for the life of me, I can't get it to expose the full 8MB of flash as a mass storage. I tried modifying the related register in the overlay file into: reg = <0x00000000 0x00800000>; but to no effect. I also tried "nrfjprog --eraseall" and "nrfjprog --recover" but whatever I do, the usb mass storage created is always 2MB in size.
    - also we'd like to access it from the code as to be able to read/ write those files. I assume that'll be possible, right?
    Further points we can discuss after we wrap the above up.
    Have a great day/ night and hope to hear from you soon! :)
  • HAhah gotya
    Hehe a strange feature I guess. Sounds a bit confusing, though I guess windows doesn't want to just move any file to its own recycle bin. This soft delete function in the app should be possible to simply remove though.
    Odd. Though the machine does otherwise start up? Is it set to boot from USB? It looks like this is a general issue others have faced as well. You could try delaying opening the MSD interface until after explorer.exe presumably starts.
    That is interesting. I assume the issue is related to something like this and this. Does changing the size change anything? Could you make sure that your changes to that parameter are having an effect?
    Yeah, though you might have to turn off this interface for the computer while doing it. See here and here.
    Elfving
  • Thank you for the hasty reply Elfving!
    I'll check those points out and get back to you in 1H tops.
    Edit: I'll try once again: is it possible to have a short call please so that we can quickly sort these kinks out and test really fast?
  • I found the related .dts. Path: /opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf5340_cpuapp_common.dtsi
    What we're interested in:
    &spi4 {
    	status = "okay";
    	pinctrl-0 = <&spi4_default>;
    	pinctrl-1 = <&spi4_sleep>;
    	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
    	mx25r64: mx25r6435f@0 {
    		compatible = "jedec,spi-nor";
    		reg = <0>;
    		spi-max-frequency = <33000000>;
    		jedec-id = [c2 28 17];
    		sfdp-bfp = [
    			e5 20 f1 ff ff ff ff 03 44 eb 08 6b 08 3b 04 bb
    			ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52
    			10 d8 00 ff 23 72 f5 00 82 ed 04 cc 44 83 68 44
    			30 b0 30 b0 f7 c4 d5 5c 00 be 29 ff f0 d0 ff ff
    		size = <67108864>;
    		has-dpd;
    		t-enter-dpd = <10000>;
    		t-exit-dpd = <5000>;
    As far as I can tell, "size = <67108864>;" is technically correct since based on the memory's datasheet (which can be found here: https://www.macronix.com/Lists/Datasheet/Attachments/8868/MX25R6435F,%20Wide%20Range,%2064Mb,%20v1.6.pdf), we have:
    1. FEATURES
    GENERAL
    • Supports Serial Peripheral Interface -- Mode 0 and Mode 3
    • 67,108,864 x 1 bit structure or 33,554,432 x 2 bits (two I/O mode) structure or 16,777,216 x 4 bits (four I/O mode) structure
    So, I suspect that <size> isn't the problem.
