USB mass storage for the NRF7002DK development board using on board chip
Hello everyone,
As the title suggests, we're trying to get the on board flash (mx25r64 as far as I can tell) of the nrf7002dk devboard working as a USB mass storage device (should be visible when connecting to Windows and MacOS).
Doing a bit of googling, I've found that a good starting point is the sample from:
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/
I started from there and tried various bits and pieces from different posts in the Nordic DevZone to try and get it working. Sadly it doesn't wanna yield and the most common error is either the partition manager not recognising the label put in the overlay or something else related to the partition manager not accepting/ initialising the disk.
Latest build log:
root@Tudors-MacBook mass # west build -b nrf7002dk/nrf5340/cpuapp/ns --pristine
-- west build: making build dir /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/homebrew/opt/[email protected]/bin/python3.13 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /Users/tudor/Library/Caches/zephyr
-- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
-- Board: nrf7002dk, qualifiers: nrf5340/cpuapp/ns
Parsing /opt/nordic/ncs/v3.0.0/zephyr/share/sysbuild/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/empty.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/sysbuild.conf'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/autoconf.h'
   * Running CMake for mass *
-- Application: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass
-- CMake version: 4.0.2
-- Found Python3: /opt/homebrew/bin/python3 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr)
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Found toolchain: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Could NOT find Dtc (missing: DTC) (Required is at least version "1.4.6")
Hint: The project() command has not yet been called.  It sets up system-specific search paths.
-- Found BOARD.dts: /opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
-- Found devicetree overlay: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay
-- Generated zephyr.dts: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/zephyr.dts
-- Generated pickled edt: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/edt.pickle
-- Generated devicetree_generated.h: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/dts.cmake
warning: DISK_DRIVER_SDMMC (defined at
boards/shields/adafruit_2_8_tft_touch_v2/Kconfig.defconfig:37, drivers/disk/Kconfig.sdmmc:7) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: ((DISK_DRIVERS
&& (SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2 || SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2_NANO)) ||
((DT_HAS_ZEPHYR_SDMMC_DISK_ENABLED || DT_HAS_ST_STM32_SDMMC_ENABLED) && DISK_DRIVERS)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_DISK_DRIVER_SDMMC and/or look up
DISK_DRIVER_SDMMC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: NORDIC_QSPI_NOR (defined at /opt/nordic/ncs/v3.0.0/nrf/Kconfig.nrf:95,
drivers/flash/Kconfig.nordic_qspi_nor:4) was assigned the value 'y' but got the value 'n'. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NORDIC_QSPI_NOR and/or look up
NORDIC_QSPI_NOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: SDMMC_STM32_HWFC (defined at drivers/disk/Kconfig.sdmmc:47) was assigned the value 'y' but
got the value 'n'. Check these unsatisfied dependencies: SDMMC_STM32 (=n), (SOC_SERIES_STM32H5X ||
SOC_SERIES_STM32H7X || SOC_SERIES_STM32F7X || SOC_SERIES_STM32L4X || SOC_SERIES_STM32L5X) (=n),
DISK_DRIVER_SDMMC (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SDMMC_STM32_HWFC and/or look up
SDMMC_STM32_HWFC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/prj.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config.sysbuild'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
  CONFIG_USB_DEVICE_VID has default value 0x2FE3.
  This value is only for testing and MUST be configured for USB products.
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Using ccache: /opt/homebrew/bin/ccache
-- Configuring done (5.7s)
-- Generating done (0.4s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass
-- Found partition manager static configuration : /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/pm_static.yml
-- Configuring done (9.1s)
-- Generating done (0.0s)
[5/10] Performing build step for 'mass'
[1/278] Preparing syscall dependency handling
[6/278] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr), build: v4.0.99-ncs1
[8/278] Generating ../../tfm/CMakeCache.txt
-- Found Git: /usr/bin/git (found version "2.39.5 (Apple Git-154)")
-- Found Python3: /opt/homebrew/bin/python3 (found version "3.13.3") found components: Interpreter
CMake Warning (dev) at /opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf5340_cpuapp/CMakeLists.txt:21 (install):
  Policy CMP0177 is not set: install() DESTINATION paths are normalized.  Run
  "cmake --help-policy CMP0177" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Configuring done (0.9s)
-- Generating done (0.1s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm
[17/278] Performing build step for 'tfm'
[135/139] Linking C executable bin/tfm_s.axf
           FLASH:       32100 B        32 KB     97.96%
             RAM:       10404 B        32 KB     31.75%
[139/139] Linking C static library secure_fw/libtfm_s_veneers.a
[19/278] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
----- Installing platform NS -----
[89/278] Building C object CMakeFiles/app.dir/src/main.c.obj
In file included from /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:29:
/opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:37:17: warning: 'littlefs_storage' defined but not used [-Wunused-variable]
   37 | #define storage littlefs_storage
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/fs/littlefs.h:91:35: note: in definition of macro 'FS_LITTLEFS_DECLARE_CUSTOM_CONFIG'
   91 |         static struct fs_littlefs name = {                                                \
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:1: note: in expansion of macro 'FS_LITTLEFS_DECLARE_DEFAULT_CONFIG'
   30 | FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:36: note: in expansion of macro 'storage'
[159/278] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
FAILED: zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
ccache /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr -I/opt/nordic/ncs/v3.0.0/zephyr/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/nrf53/. -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/common/. -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device -I/opt/nordic/ncs/v3.0.0/zephyr/drivers/usb/common/nrf_usbd_common/. -I/opt/nordic/ncs/v3.0.0/nrf/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm/api_ns/interface/include -I/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -I/opt/nordic/ncs/v3.0.0/nrf/include/tfm -I/opt/nordic/ncs/v3.0.0/nrf/tests/include -I/opt/nordic/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v3.0.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v3.0.0/nrf/modules/hal_nordic/. -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem /opt/nordic/ncs/v3.0.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -imacros /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: return type defaults to 'int' [-Werror=implicit-int]
  533 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: storage class specified for parameter 'flash_disks'
  572 | static struct flashdisk_data flash_disks[] = {
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:15: error: parameter 'flash_disks' is initialized
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
  573 |         PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: note: each undeclared identifier is reported only once for each function it appears in
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:582:1: error: expected declaration specifiers before 'PM_FOREACH_AFFILIATED_TO_disk'
  582 | PM_FOREACH_AFFILIATED_TO_disk(VERIFY_CACHE_SIZE_IS_NOT_ZERO_IF_NOT_READ_ONLY)
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/gcc.h:98,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain.h:50,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/__assert.h:11,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:10:
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: storage class specified for parameter '__init_disk_flash_init'
  141 | #define Z_INIT_ENTRY_NAME(init_id) _CONCAT(__init_, init_id)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
  137 | #define _DO_CONCAT(x, y) x ## y
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:36: note: in expansion of macro '_CONCAT'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:17: note: in expansion of macro 'Z_INIT_ENTRY_NAME'
  241 |                 Z_INIT_ENTRY_NAME(name) = {.init_fn = {.sys = (init_fn_)},                \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:223:9: note: in expansion of macro 'SYS_INIT_NAMED'
  223 |         SYS_INIT_NAMED(init_fn, init_fn, level, prio)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:1: note: in expansion of macro 'SYS_INIT'
  612 | SYS_INIT(disk_flash_init, POST_KERNEL, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: error: parameter '__init_disk_flash_init' is initialized
  239 |         static const Z_DECL_ALIGN(struct init_entry)                                      \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:195:55: note: in definition of macro 'Z_DECL_ALIGN'
  195 | #define Z_DECL_ALIGN(type) __aligned(__alignof(type)) type
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: section attribute not allowed for '__init_disk_flash_init'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: warning: 'used' attribute ignored [-Wattributes]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: alignment may not be specified for '__init_disk_flash_init'
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/device.h:13,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sw_isr_table.h:18,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/irq.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/arch.h:24,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/cpu.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel_includes.h:36,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel.h:17,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/drivers/disk.h:30,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:12:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:10: error: 'disk_flash_init' undeclared (first use in this function)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:64: note: in definition of macro 'SYS_INIT_NAMED'
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: type of 'DEFINE_FLASHDISKS_CACHE' defaults to 'int' [-Werror=implicit-int]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: declaration for parameter '__init_disk_flash_init' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: declaration for parameter 'flash_disks' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: error: expected '{' at end of input
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: warning: control reaches end of non-void function [-Wreturn-type]
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: At top level:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:464:37: warning: 'flash_disk_ops' defined but not used [-Wunused-const-variable=]
  464 | static const struct disk_operations flash_disk_ops = {
cc1: some warnings being treated as errors
[168/278] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
FAILED: _sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build
cd /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass && /opt/homebrew/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build
The whole sample project folder:
8686.mass.zip
Any and all help is gladly welcome! :)
  • Sorry about the wait again, this time I've been OOO sick. Though I am very glad that Alexander can once again swoop in and help out when I'm unable to Stuck out tongue
    Tudor B. said:
    The sample as Alex gave me (with 2MB) works exactly as intended for both me and him. Our issue is that I tried increasing it to 8MB and it stayed at 2MB, then I gave it to a colleague and told him to increase it to 8MB and for him it worked.
    Tudor B. said:
    Alexander returned to the office and after presenting the current state of things to him, he suggested that I simply format the mass storage when I connect it to my PC. -> it worked perfectly!
    Heheh perfect! I wouldn't have thought of that myself. Though I guess it would have to be something silly at fault when it works on your coworkers side and not yours.
    Tudor B. said:
    The only question that remains: can we get it working using LittleFS also? :)
    Hopefully you just need an additional config and some dts changes for that to work (see here)
    Tudor B. said:
    Currently our architect and CEO are pushing for LittleFS for both File System and USB Mass Storage since it's more reliable and has error correction (theoretically). There's something called LittleFS FUSE that helps OSes recognise disks that have the LittleFS File System. I've played with it a bit but at this point I'm not sure if LFS FUSE ain't working correctly or if my config of the sample project is erroneous so LFS FUSE won't read the disk correctly.
    I see that you have some arguments for littleFS here, though consider whether it would actually work with the OS you are using first. I've seen a lot of people claiming that Fat has more native OS support.
    Elfving
  • Hello and welcome back once again Elfving! Glad to hear you're better!
    Things have evolved yet again since our last chat here. I'll paste the mail that I've sent to Alexander here:
    Me and two colleagues have tried to integrate the sample that you provided into our project. Although the sample that you provided works perfectly as a standalone project, I think it's impossible for us to integrate it since we're building for non secure and implicitly using a small TFM partition to store some data. This implicitly requires SB_CONFIG_PARTITION_MANAGER to be enabled. By leaving it disabled (as it is in the sample), we get a plethora of TFM partition issues (the attached build log).
    In essence, could you provide a sample that has this TFM configuration enabled, together with the USB mass storage?:
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    Thanks for the support Elfving. Hope we can sort it out fast. :)
  • Heheh okay. Things are always moving fast here, though that is a good thing.
    So this is referring to the/a sample that Alex provided you with which works, but does not with TFM.
    Yeah, I guess it makes sense that you can not use TFM with dts partitioning. If you are new to partition manager you can for instance see here, though the general idea is that you enable CONFIG_PARTITION_MANAGER_ENABLED (which will also overwrite dts partitions), which will let it choose the partition sizes dynamically. You'll then be able to tweak this yourself by having a look at the resulting partitions.yaml file, move it out to the project folder, tweak it, and name it pm_static.yaml.
    So I wouldn't expect this to lead to any major issues. Could you see if you are able to do this?
    Elfving
  • Hey Elfving.
    I tried what you suggested and it didn't work.
    At first I got these build errors:
    [25/287] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
    FAILED: [code=1] zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
    ccache /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=65536 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_DOUBLE_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/include/generated/zephyr -I/opt/nordic/ncs/v3.0.0/zephyr/include -I/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/include/generated -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic -I/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/posix -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/nrf53/. -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/common/. -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device -I/opt/nordic/ncs/v3.0.0/zephyr/drivers/usb/common/nrf_usbd_common/. -I/opt/nordic/ncs/v3.0.0/nrf/include -I/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/interface/include -I/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -I/opt/nordic/ncs/v3.0.0/nrf/include/tfm -I/opt/nordic/ncs/v3.0.0/nrf/tests/include -I/opt/nordic/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v3.0.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v3.0.0/nrf/modules/hal_nordic/. -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -I/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/certs -I/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem /opt/nordic/ncs/v3.0.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -flto=auto -imacros /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -mtp=soft --sysroot=/Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c
    [36/287] Generating genhdr/moduledefs.split
    FAILED: [code=1] _sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build
    cd /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr && /Applications/CMake.app/Contents/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /Applications/CMake.app/Contents/bin/cmake --build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build
    Note: I got the partitions.yml, renamed it to pm_static.yml, put it in the project folder, and added the final segment ("external_storage:") to have an external storage. The file itself (had to change extension to .txt to be able to upload):
    app:
      address: 0x8000
      end_address: 0x100000
      region: flash_primary
    otp:
      address: 0xff8100
      end_address: 0xff83fc
      region: otp
    rpmsg_nrf53_sram:
      address: 0x20070000
      end_address: 0x20080000
      placement:
        before:
        - end
      region: sram_primary
    sram_nonsecure:
      address: 0x20008000
      orig_span: &id001
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id001
    sram_primary:
      address: 0x20008000
      end_address: 0x20070000
    sram_secure:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id002
      - tfm_sram
      span: *id002
    tfm:
      address: 0x0
      end_address: 0x8000
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x8000
      orig_span: &id003
      - app
      span: *id003
    tfm_secure:
      address: 0x0
      end_address: 0x8000
      orig_span: &id004
      - tfm
      span: *id004
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    external_storage:
      address: 0x0
      end_address: 0x800000
      device: MX25R64
      label: "storage"
      region: external_flash
      affiliation: disk
      extra_params:
        disk_name: "NAND"
        disk_cache_size: 4096
        disk_sector_size: 512
        erase_sector_size: 4096
        disk_flash_start_offset: 0
        disk_read_only: 0
      placement:
        before:
          - end
    Then I added these to the board_ns.conf:
    CONFIG_FILE_SYSTEM=y
    CONFIG_FAT_FILESYSTEM_ELM=y
    CONFIG_MASS_STORAGE_DISK_NAME="NAND"
    Which brings out a new error:
    thon.dir/nvmc.c.obj -c /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nvmc.c
    In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/util_macro.h:34,
                     from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/util.h:17,
                     from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/atomic.h:18,
                     from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel_includes.h:25,
                     from /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nvmc.c:32:
    /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nvmc.c: In function 'nvmc_init':
    /opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:56:18: error: 'PM_PM_PM_storage_partition_ID_LABEL_OFFSET' undeclared (first use in this function)
       56 |         UTIL_CAT(PM_, UTIL_CAT(UTIL_CAT(PM_, UTIL_CAT(PM_ID(label), _LABEL)), x))
    /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in definition of macro 'UTIL_PRIMITIVE_CAT'
      105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
    /opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:56:9: note: in expansion of macro 'UTIL_CAT'
    /opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:59:39: note: in expansion of macro 'FIXED_PARTITION_DATA_FIELD'
       59 | #define FIXED_PARTITION_OFFSET(label) FIXED_PARTITION_DATA_FIELD(label, _OFFSET)
    /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nvmc.c:46:33: note: in expansion of macro 'FIXED_PARTITION_OFFSET'
       46 | #define NVS_PARTITION_OFFSET    FIXED_PARTITION_OFFSET(NVS_PARTITION)
    /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nvmc.c:74:26: note: in expansion of macro 'NVS_PARTITION_OFFSET'
       74 |         nvmc_fs.offset = NVS_PARTITION_OFFSET;
    /opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:56:18: note: each undeclared identifier is reported only once for each function it appears in
    [62/178] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mqueue.c.obj
    Although, I personally suspect that the new error doesn't fix the previous flash_disks error, but rather masks it because it appears before the "flash_disks" error in the build process.
    This brings me back to my request: could you get Alex's sample that's attached above, and make it work  for _ns; having these three CONFIG_ options enabled and then send it my way? :) :
  • Sorry to keep you hanging here, though I tried to do it myself but I am running into some issues here. I'll have to continue this next week.
    Btw, what is with the micropython path? Are you running micropython on the chip as well?
    Elfving
