nRF5340 - using NVS and LittleFS
Hi
I can run the sample application for NVS, on the nF5340 DK (SDK 2.9.0)
I can run the sample application for LittleFS, also on the nRF5340 DK
Now I would like to see if I can use both, and share the flash partition - maybe 50/50.
Is this possible.
I read Case ID: 257332 but that is from a few years back.
I tried to set up an overlay and split the partition but I ran in to lots of issues.
Regards
Garrett
  • Also, along the way I now seem to have 'bricked' the nRF5340 DK - i.e. corrupted the network core? How do I reprogram this?
    Please try to recover the network core by using:
    nrfjprog --recover --coprocessor CP_NETWORK
    You may want to recover the application core as well
    nrfjprog --recover --coprocessor CP_APPLICATION
    Which error do you have when you enable both NVS and LittleFS  ?
    Have you defined a parttition for littlefs ? You can make a pm_static.yml file (copy from a partitions.yml in build folder in littlefs sample for example, and modify it as you wish) to force a partition configuration. You can find the use of pm_static.yml in \nrf\applications\nrf_desktop\configuration\nrf52kbd_nrf52832 for example.
    It should be in the project folder.
  • I have it working now.
    I just have a basic version working which uses the code from the NVSA and the LittleFS sample applications.
    My prj.conf file includes these settings:
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_SETTINGS=y
    #CONFIG_REBOOT=y
    CONFIG_NVS=y
    CONFIG_NVS_LOG_LEVEL_DBG=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_LOG_MODE_MINIMAL=y
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    My pm_static.yml:
    user_littlefs_storage:
    address: 0xfc000
    end_address: 0xfe000
    placement:
    before:
    - end
    region: flash_primary
    user_nvs_storage:
    address: 0xfe000
    end_address: 0x100000
    placement:
    before:
    - end
    So now I can use both, it seems.
    One thing I don't understand.
    If I am correct, this storage area is also used by Bluetooth, for storig pairing/bonding and other information.
    Is this correct?
    If so, how much of this storage area is it safe to re-assign to either NVS or LittleFS?
    Yes, Bluetooth stack uses the settings_storage to store data (by default). I believe it's about 80 bytes per bonding. Please be noted that there is at least one page needed for garbage collection.
