COAP_CLIENT_LIB request issue
Hi.
I'm using nrf Connect SDK v3.0.1 and Zephyr v4.0.99 to implement a IoT device which connects to a Thingsboard server with CoAP. With the COAP_CLIENT Lib I want to download data in 945 chunks of 512 byte size.
I've used the coap_download example as a template for my implementation. I create the request and send it to the library with coap_client_req(). When the server responds, the callback function gets called in which I process the data (copy it to a queue in my case) and give a sem to tell the coap thread to cancel the request (coap_client_cancel_request()). This works as many times as I have configured in CONFIG_COAP_CLIENT_MAX_REQUESTS. After that the lib reports an error "No more free requests".
It looks for me that the cancel of the request didn't work. But maybe I didn't understand the usage of the COAP_CLIENT lib.
Are there any hints to use it correctly?
Thanks
BR
Christian
  • Hi Christian,
    Thanks for reaching out!
    CONFIG_COAP_CLIENT_MAX_REQUESTS is not a counter of how many requests you may send during the program’s lifetime. It is the number of simultaneous exchanges a single coap_client instance is allowed to keep in its internal array (client->requests[]).
    If every time you call coap_client_req() the previous exchange has not been released yet, a new slot is taken.
    When all CONFIG_COAP_CLIENT_MAX_REQUESTS slots are still marked as “busy”, the library prints “No more free requests” .
    A slot is released after the library has delivered the last fragment of the response to the application and
    your response-callback has returned.
    Without looking at you code I guess the main thing you are not doing correctly is that you start a new request for every 512-byte chunk?
    I hope this helps push you in the right direction.
    Benjamin
  • Hi Benjamin.
    Thanks for the help.
    You are right. I start a new request for every chunk because the path changes (....&chunk=1 => ....&chunk=2 and so on).
    So I need to change the path in the existing request without calling coap_client_req() and the lib handles this correctly? Or how does the correct way look like?
    Thanks in advance.
    Best regards.
    Christian
  • Well, since the path changes, you need to send a different request per chunk as you said. It indeed looks like the cancellation fails. Exactly where do you call coap_client_cancel_request() and what are your parameters? If you'd like, you could upload your source file or your callback function and I can have a look at it.
    It should look something like this:
    static void on_coap_response()
        /* 1. Copy payload to your queue */
        copy_to_queue();
        /* 2. Free the slot immediately */
        coap_client_cancel_request();
        /* 3. Wake up the thread that will launch the next chunk */
        k_sem_give(&ready_sem);
  • Hello.
    This is the callbackfunction:
    static void on_coap_download_chunk_response(int16_t result_code, size_t offset, const uint8_t *payload, size_t len, bool last_block, void *user_data)
        coap_payload_t data;
        // Something was received, so restart keep alive timer.
        k_timer_start(&keep_alive_timer, K_MSEC(TX_KEEP_ALIVE_INTERVAL), K_MSEC(TX_KEEP_ALIVE_INTERVAL));
        LOG_INF("CoAP download chunk response, result_code=%d, offset=%u, len=%u, last_block=%d", result_code, offset, len, last_block);
        if (result_code == COAP_RESPONSE_CODE_CONTENT && last_block)
            memcpy(data.payload, payload, MIN(len, CONFIG_COAP_CLIENT_BLOCK_SIZE));
            data.len = len;
            // Send it to the update task.
            k_msgq_put(&coap_payload_msgq, &data, K_FOREVER);
        k_sem_give(&coap_download_chunk_done);
    And this is the function for the request. It is called in a for loop with counting up chunk number in a thread:
    static int client_download_software_chunk(uint8_t *new_sw_title, uint8_t *new_sw_version, uint16_t chunkSize, uint16_t chunkNumber)
        int ret;
        char path[100];
        /* Prepare the path for the request. */
        snprintf(path, sizeof(path), "sw/Fsau7Dg9Adfg4d?title=%s&version=%s&size=%d&chunk=%d", new_sw_title, new_sw_version, chunkSize, chunkNumber);
        LOG_INF("Download path: %s", path);
        /* Prepare the request parameters. */
        struct coap_client_request request = {.method = COAP_METHOD_GET,
                                              .fmt = COAP_CONTENT_FORMAT_TEXT_PLAIN,
                                              .confirmable = true,
                                              .path = path,
                                              .payload = NULL,
                                              .len = 0,
                                              .cb = on_coap_download_chunk_response,
                                              .options = NULL,
                                              .num_options = 0,
                                              .user_data = NULL};
        /* Make the request. It will be added to the coap_client_rcv thread and handled by that. */
        ret = coap_client_req(&client, sock, NULL, &request, NULL);
        if (ret)
            LOG_ERR("Failed to send CoAP request, err %d", ret);
            return ret;
        /* Wait for CoAP request to complete */
        k_sem_take(&coap_download_chunk_done, K_FOREVER);
        /* Cancel this request because in the next request the path will change (because of chunknumber) and there are only a few
         * different requests possible. */
        coap_client_cancel_request(&client, &request);
        // k_sleep(K_MSEC(200));
        return 0;
    Tell me if you need more information.
    Thank you.
    Best Regards
    Christian
  • Not sure to which example you stick, I don't see any reason to call "coap_client_cancel_request". As long as it's no "blockwise" transfer nor a "observe" request, the "release_internal_request" is called in "handle_response" after the user callback. But I also don't see, why that "coap_client_cancel_request" harms.
    Do you have some logs?
