To preface (My setup):
- nRF9151DK
- Modem firmware: mfw_nrf91x1_2.0.2
- nRF Connect SDK / Toolchain: 2.9.0
- Terminal app: PuTTY
- Application: HTTPS Client Sample: docs.nordicsemi.com/.../README.html
- Carrier: Verizon
I have a Verizon CAT-1 SIM that oddly works in my nRF9151DK. However, I just activated service on a Verizon CAT-M SIM and attempted to use it. It registers on the network fine (+CEREG: 1) but every time I attempt to open a socket I receive error 116.
Thus, I went back to basics and loaded the HTTPS Client sample linked above. The sample won't work with my SIM either. See log below:
*** Booting nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** HTTPS client sample started Bringing network interface up Provisioning certificate Certificate match Connecting to the network +CGEV: EXCE STATUS 0 +CEREG: 2,"9B01","025EC901",7 %MDMEV: PRACH CE-LEVEL 0 %MDMEV: PRACH CE-LEVEL 1 +CSCON: 1 +CGEV: ME PDN ACT 0 %MDMEV: SEARCH STATUS 2 +CEREG: 1,"9B01","025EC901",7,0,18,"11100000","11100000" [00:00:06.764,770] <wrn> lte_lc: Registration rejected, EMM cause: 18, Cell ID: 39766273, Tracking area: 39681, LTE mode: 7 Network connectivity established and IP address assigned Looking up example.com +CGEV: IPV6 0 Resolved 23.215.0.138 (AF_INET) Connecting to example.com:443 connect() failed, err: 111 +CEREG: 0 +CGEV: ME DETACH +CSCON: 0 Network connectivity lost Disconnected from the network
Per C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\arm-zephyr-eabi\include\sys\errno.h, error code 111 means
... Resolved 93.184.215.14 (AF_INET) Connecting to example.com:443 ...
static void send_http_request(void)
int err;
int fd;
char *p;
int bytes;
size_t off;
struct addrinfo *res;
struct addrinfo hints = {
.ai_family = AF_INET, <---------------------------------------- ADDED THIS
.ai_flags = AI_NUMERICSERV, /* Let getaddrinfo() set port */
.ai_socktype = SOCK_STREAM,
};*** Booting nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** HTTPS client sample started Bringing network interface up Provisioning certificate Certificate match Connecting to the network +CGEV: EXCE STATUS 0 +CEREG: 2,"9B01","025ECB03",7 %MDMEV: PRACH CE-LEVEL 0 %MDMEV: PRACH CE-LEVEL 1 +CSCON: 1 +CGEV: ME PDN ACT 0 %MDMEV: SEARCH STATUS 2 +CEREG: 1,"9B01","025ECB03",7,0,18,"11100000","11100000" [00:00:04.368,835] <wrn> lte_lc: Registration rejected, EMM cause: 18, Cell ID: 39766787, Tracking area: 39681, LTE mode: 7 Network connectivity established and IP address assigned Looking up example.com +CGEV: IPV6 0 Resolved 96.7.128.198 (AF_INET) Connecting to example.com:443 +CSCON: 0 %MDMEV: PRACH CE-LEVEL 0 %MDMEV: PRACH CE-LEVEL 1 +CSCON: 1 connect() failed, err: 116 +CEREG: 0 +CGEV: ME DETACH +CSCON: 0 Network connectivity lost Disconnected from the network
*** Booting nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** HTTPS client sample started Bringing network interface up [00:00:00.552,276] <inf> nrf_modem_lib_trace: Trace thread ready [00:00:00.560,333] <inf> nrf_modem_lib_trace: Trace level override: 2 Provisioning certificate Certificate match Connecting to the network +CGEV: EXCE STATUS 0 +CEREG: 2,"9B01","025ECB03",7 %MDMEV: PRACH CE-LEVEL 0 +CSCON: 1 +CGEV: ME PDN ACT 0 %MDMEV: SEARCH STATUS 2 +CEREG: 1,"9B01","025ECB03",7,0,18,"11100000","11100000" [00:00:02.873,870] <wrn> lte_lc: Registration rejected, EMM cause: 18, Cell ID: 39766787, Tracking area: 39681, LTE mode: 7 Network connectivity established and IP address assigned Looking up example.com +CGEV: IPV6 0 Resolved 23.215.0.136 (AF_INET) Connecting to example.com:443 connect() failed, err: 111 +CEREG: 0 +CGEV: ME DETACH +CSCON: 0 Network connectivity lost Disconnected from the network [00:00:05.829,833] <inf> nrf_modem_lib_trace: Modem was turned off, no more traces
+CGDCONT: 1,"IPV4V6","ims","",0,0,0,0
+CGDCONT: 2,"IPV4V6","vzwadmin","",0,0,0,0
+CGDCONT: 3,"IPV4V6","REDACTED","",0,0,0,0
+CGDCONT: 4,"IPV4V6","vzwapp","",0,0,0,0
+CGDCONT: 5,"IPV4V6","","",0,0,0,1
+CGDCONT: 6,"IPV4V6","vzwclass6","",0,0,0,0
+CGDCONT: 1,"IPV4V6","vzwadmin","10.129.48.244 2600:1004:F007:DF0A:0000:0046:5761:3101",0,0
OK
