Channel sounding parameters
I’m trying to understand the following parameters in the nRF54L15 channel sounding configuration, because their function is not clear to me. I added my questions as comments to the code:
Everything i srelated to this: BLE CS specification
struct bt_le_cs_create_config_params config_params = {
	// I think T_FCS steps are repeated, but I don't understand what this parameter does and how important it is to set. What exactly does main_mode_repetition control?
	.main_mode_repetition = 0,
	// Does this mean the measurement is repeated 3 times for each channel?
	.channel_map_repetition = 3,
And in the other structure:
Here I only understand how to set the length of the whole procedure, but:
  • Where can I set how many events and subevents are used in one procedure?
  • Is the number of events and subevents always calculated automatically by BLE?
const struct bt_le_cs_set_procedure_parameters_param procedure_params = {
	.config_id = CS_CONFIG_ID,
	// This sets the total procedure length, so 800 * 0.625 ms = 500 ms
	.max_procedure_len = 800,
	// Interval between procedures, 10 = 6.25 ms
	.min_procedure_interval = 10,
	.max_procedure_interval = 30,
	// Here, do these values set the time limits for each subevent?
	// Does BLE then automatically decide how many subevents fit into the procedure?
	// I assume subevent length (50-60 ms) decides how many subevents will fit, but where can I set the number of events?
	.min_subevent_len = 50000,
	.max_subevent_len = 60000,
One last thing I don’t understand - how many RF channels will be used for the channel sounding measurement?
Should I set this explicitly, for example by using bt_le_cs_set_valid_chmap_bits, or is the channel map always chosen automatically in the background?
Example of what I’m trying to achieve:
  • I set the procedure length to 500 ms.
  • Under this, there will be 1-N events (I don’t know how many, is this calculated automatically?)
  • Each event is divided into subevents (length 50-60 ms), and T_FCS steps per subevent will depend on how many fit?, and on the main/sub mode settings. Is this understanding correct?
I understand that my questions may not be easy to understand, but at least a closer explanation would be good.
Thank you, Jan
  • What I do not understand also:
    I set max_procedure_len to 100 ms and min_procedure_interval to 1000 ms. I also set continuous measurement (max_procedure_count = 0). But in the log, the CS result has a period of 210 ms. Should not the period of the procedures be 1000ms + up to100 ms?
    Also, for the maximum procedure length (100 ms), I set min_subevent_len to 500 ms. I expected, for example, a problem during compilation - that the parameter is invalid. Or can I set the subevent to be longer than the procedure?
    Thank you.
  • Hi
    I numbered the questions as I could find them. That is easier to refer to when answering multiple questions.
    1. main_mode_repetition is the number of main mode steps taken between substeps. main mode here is one of the mode-1 to mode-3 steps used for actual distance measuring doing channel sounding.
    2. The number of times the channel map field will be cycled to for the non-mode 0 steps.
    3. The number of subevents set is set with the subevents_per_event; in bt_conn_le_cs_procedure_enable_complete struct.
    4. After that the number of events and subevents are decided by the other parameters set I believe.
    5. For channel selection in Channel Sounding, you can use the bt_le_cs_set_channel_classification function. Note that this is currently experimental as far as I know. You could also alternatively use the "normal" way of channel mapping if you'd like, but that's up to you. If not, channel selection is just done "automagically" I think.
    Simon
