Coded PHY support in nrf52833 in NCS
I am trying to adding a coded phy support on my device in NCS project.
once I added CONFIG_BT_CTLR_PHY_CODED=y in my config , the ROM size will add more than 7kB , it over my expected.
does any small size option I can using for it?
I only need to change the phy during the connection, no advertising in coded phy,
Thanks
  • Hi Wu Ka Wing,
    Have you tried to set
    CONFIG_BT_CTLR_ADV_EXT=n
    CONFIG_BT_EXT_ADV=n
    CONFIG_BT_EXT_ADV_CODING_SELECTION=n
    To see if it reduce the size of the flash ?
    The issue is that there is only a few options with the controller. When you turn on CODED PHY most likely it would include also the code for extended advertising (in the controller).
