Visual Studio Code - unable to update SDK, or access previous SDKs
I'm having some pretty significant issues with Visual Studio Code and the nRF Connect SDK/Toolchain installation.
I'm on Windows 10, and have been running V2.6.1 of the SDK for a year or so now, but needed to update to a more recent one to access some features not available in V2.6.1.  Went through the usual process within Visual Studio Code when I can install a toolchain, and install an SDK.  The toolchain for v3.0.1 seems to download and install correctly.  But when I went to install the V3.0.1 SDK, it downloaded, unpacked and then the final step failed with some random error code:
[15:13:35] nrfutil-sdk-manager sdk,install,v3.0.1,--sdk-path,c:\ncs\v3.0.1: Download SDK v3.0.1
[15:36:38] nrfutil-sdk-manager sdk,install,v3.0.1,--sdk-path,c:\ncs\v3.0.1: null: success
[15:36:38] nrfutil-sdk-manager sdk,install,v3.0.1,--sdk-path,c:\ncs\v3.0.1: Calculating SDK checksum
[15:36:44] nrfutil-sdk-manager sdk,install,v3.0.1,--sdk-path,c:\ncs\v3.0.1: Verified download: success
[15:36:44] nrfutil-sdk-manager sdk,install,v3.0.1,--sdk-path,c:\ncs\v3.0.1: Unpack SDK v3.0.1
[west]: exited with code -4058.
And now, Visual Studio Code seems almost completely broken.  If I open up an existing Workspace, then attempt to click on the nRF Connect icon on the left, it just sits there looking like this:
I've left it sitting there like this for > 30mins and nothing seems to change.  Shutting down Visual Studio Code, restarting my machine, and restarting VSC doesn't seem to fix things.  I've even attempted a complete uninstall of nRF Command Line Tools and Visual Studio Code, then reinstalling, but it is still showing this behaviour.
I'm now at the point where I basically can't do any further development, nor program any boards I have going through production, so I'm pretty stuck.
Is there something I am supposed to be doing different from what is described in this tutorial video when installing nRF Command Line Tools, VSC, Toolchains and SDK's now?
www.youtube.com/watch
I'm pretty desperate to get this issue resolved
Mike
  • Hi Dejan,
    I'm getting this error when I try and run that command:
    Error: nrfutil command `sdk-manager` not found. See `nrfutil list` for full list of installed commands, `nrfutil search` for installable commands, and `nrfutil install` for installation of new commands.
    Caused by:
    Subcommand nrfutil-sdk-manager.exe not found
    If I run nrfutil device --version, this is what I get:
    PS C:\> nrfutil device --version
    nrfutil-device 2.8.4 (3a563c3 2025-03-24)
    commit-hash: 3a563c3538e0aa0e767a844dcb2a9d18d35a1125
    commit-date: 2025-03-24
    host: x86_64-pc-windows-msvc
    build-timestamp: 2025-03-24T14:01:51.338001900Z
    classification: nrf-external
    Detected SEGGER J-Link version: JLink_V8.46
    Mike
  • Hi Mike,
    Have you tried to install sdk-manager using "nrfutil install sdk-manager"?
    Have you tried to install NCS using nrfutil sdk-manager install vX.Y.Z command (where X.Y.Z is your NCS version)? For example, for NCS v3.0.1, you can use "nrfutil sdk-manager install v3.0.1".
    Can you see installed version when you use "nrfutil sdk-manager list" and "nrfutil sdk-manager search"?
    Dejan
  • HI Dejan,
    Tried this:
    nrfutil sdk-manager install v2.9.2 --sdk-path c:\ncs\v2.9.2 --install-dir c:\ncs --log-level trace
    [00:05:05] #-----  14% [Download toolchain v2.9.2] Downloading toolchain
    Error: Failed to download tarball from any of the available sources:
    - https://publicburan.blob.core.windows.net/artifactory/NCS/external/bundles/v3/ncs-toolchain-x86_64-windows-b620d30767.tar.gz
    - https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/ncs-toolchain-x86_64-windows-b620d3076
    Attached is the log file
    Cheers,
    Mike
    nrfutil-sdk-manager.log
  • Hi Mike,
    You could check that you do not have any partial downloads in your Downloads folder. If you do, you can try to remove all of them.
    Can you check if your Internet connection is stable?
    Dejan
  • Hi Dejan,
    Removed all downloads.
    Tried to install v2.9.2
    [00:07:55] ###### 100% [Download toolchain v2.9.2] Toolchain downloaded
    [00:00:57] ###### 100% [Unpack toolchain v2.9.2] Toolchain unpacked to c:\ncs\tmp\.tmpDaqjlp
    [00:00:00] ###### 100% [Install toolchain v2.9.2] Toolchain installed at c:\ncs\toolchains\b620d30767
    [00:27:49] ###### 100% [Download SDK v2.9.2] Download SDK v2.9.2
    [00:00:10] ###### 100% [Calculating SDK checksum] Verified download
    [00:02:44] #####-  79% [Unpack SDK v2.9.2] Unpacking
    Error: Subprocess C:\Users\mikea.SURFACE-PRO-7\.nrfutil\bin\nrfutil-sdk-manager.exe failed with unexpected exit code Some(5)
    Again, here is the log file
    Mike
    2845.nrfutil-sdk-manager.log
