nRF52840-QIAA-R vs nRF52840-QIAA-F-R
Hi
We are using the nRF52840-QIAA-R in a lot of PCBA, now I see there is a new revision nRF52840-QIAA-F-R and the old type is not recommended for new design.
What is the difference between the 2 types and are they 100% compatible? Where can I see the difference between the old and the new type?
Thank you
  • ok, but when I have nRF52 like in my picture which work-around I have to do or which I have to keep in mind regarding the difference to the -F version? We have a running production with the "old chips" which are like in my picture. The next production we can use the -F version but the actual stock we have to use.
    I can't find the issues in the errata with the version D0 compared to -F, can you please highlight this.
    Thanks a lot
    coming back to this topic, I saw in this article how we should handle the APPPROTECT:
    Working with the nRF52 Series' improved APPROTECT
    So my understanding is the following:
    The -F revisoon of the nRF52840 is enabling this in hardware?
    The old revision we are using this feature we have to enable in Firmware. We are running the system with a boatloader and in the production flashing we use this line:
    nrfjprog --rbp ALL
    We are using the nRF secure_ble_bootloader.
    There i saw this line function, enabled when NRF_BL_DEBUG_PORT_DISABLE is true:
    void nrf_bootloader_debug_port_disable(void)
        if (NRF_UICR->APPROTECT != 0x0)
            nrf_nvmc_write_word((uint32_t)&NRF_UICR->APPROTECT, 0x0);
            NVIC_SystemReset();
    #if (!defined (NRF52810_XXAA) && !defined (NRF52811_XXAA) && !defined (NRF52832_XXAA) && !defined (NRF52832_XXAB))
        if (NRF_UICR->DEBUGCTRL != 0x0)
            nrf_nvmc_write_word((uint32_t)&NRF_UICR->DEBUGCTRL, 0x0);
            NVIC_SystemReset();
    So if I enable NRF_BL_DEBUG_PORT_DISABLE in SDK config of the bootloader, the chip is staring the bootloader, checking if NRF_UICR->APPROTECT is not 0x0 and will set NRF_UICR->APPROTECT to 0x0 followed by a NVIC_SystemReset.
    The MCU is restarting, check the NVIC_SystemReset again, the value is 0, the bootloader is checking for a new bootloader file and if there is nothing to do it will switch to the application.
    I modified the booloader to flash from an external QSPI flash in parallel with the original BLE bootloader.
    In case of a firmware update the register nrf_power_gpregret_get is used. After resetting the device the value in this register is getting lost. Is the setting in nrf_nvmc_write_word((uint32_t)&NRF_UICR->APPROTECT, 0x0); permanent? (after a system reset?)
    For sure I will add the AppProtect in the application:
    -> The most effective way to ensure that UICR.APPROTECT is set correctly is probably to verify it in the application. For example, the following code snippet could be added to the top of main:
    #ifdef ENABLE_APPROTECT
    	if ((NRF_UICR->APPROTECT & UICR_APPROTECT_PALL_Msk) !=
    		(UICR_APPROTECT_PALL_Enabled << UICR_APPROTECT_PALL_Pos)) {
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
            while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
            NRF_UICR->APPROTECT = ((NRF_UICR->APPROTECT & ~((uint32_t)UICR_APPROTECT_PALL_Msk)) |
    		    (UICR_APPROTECT_PALL_Enabled << UICR_APPROTECT_PALL_Pos));
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
    #else
    		(UICR_APPROTECT_PALL_HwDisabled << UICR_APPROTECT_PALL_Pos)) {
    		    (UICR_APPROTECT_PALL_HwDisabled << UICR_APPROTECT_PALL_Pos));
    Is there something to add in the bootloader aswell expection enabling the NRF_BL_DEBUG_PORT_DISABLE in SDK_config?
    Is this how the protection should be implemented on nRF52840-QIAA-R and nRF52840-QIAA-F?
    Thank you for clarification
  • For the already done products, you don't need to do any changes.
    The only difference between the versions, as mentioned before, is the APPROTECT enabled in hardware and software too for the QIAA-F series. So for the new series, you will have to recover the chip each time before you re-flash the chip. So from the next production onward, you can use the QIAA-F series.
    No problem in using the old chips in your current production.
    -Priyanka
  • But if we are using:
    nrfjprog --rbp ALL
    in the old chip revisions, this additional function is "nice to have" and not necessary?
    #else
  • Yes, that should be right. For new devices, both hardware and software methods are recommended, but for old devices, the hardware method alone is enough.
    You can go through the following references too:
    https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/working-with-the-nrf52-series-improved-approtect#mcetoc_1fr480n9d1
     Implentation of Read-back protection on nRF52840
    -Priyanka
