Failed to flash Zephyr sample Blinky application to nRF52840 Dongle
I am using nRF52840dongle and trying to flash the Blinky sample application provided in Zephyr.
Blinky: docs.zephyrproject.org/.../README.html
I had referred the programming instruction mentioned at given link https://docs.zephyrproject.org/latest/boards/nordic/nrf52840dongle/doc/index.html
I had tried to program the dongle by using method mentioned in option 1 which uses nrfutil. Successfully able to complete at Step 3 which is "Package the application for the bootloader using nrfutil". It failed at step 4
Issue:
Flashing Failed by giving below command
nrfutil nrf5sdk-tools dfu usb-serial -pkg blinky.zip -p COM22
Error:
zephyrproject>nrfutil nrf5sdk-tools dfu usb-serial -pkg zephyr\blinky.zip -p COM22
[------------------------------------] 0%
File "nordicsemi\__main__.py", line 1555, in <module>
File "click\core.py", line 1137, in __call__
File "click\core.py", line 1062, in main
File "click\core.py", line 1668, in invoke
File "click\core.py", line 1404, in invoke
File "click\core.py", line 763, in invoke
File "nordicsemi\__main__.py", line 1032, in usb_serial
File "nordicsemi\__main__.py", line 988, in do_serial
File "nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
File "nordicsemi\dfu\dfu.py", line 100, in _dfu_send_image
File "nordicsemi\dfu\dfu_transport_serial.py", line 300, in send_firmware
File "nordicsemi\dfu\dfu_transport_serial.py", line 400, in __create_data
File "nordicsemi\dfu\dfu_transport_serial.py", line 405, in __create_object
File "nordicsemi\dfu\dfu_transport_serial.py", line 504, in __get_response
pc_ble_driver_py.exceptions.NordicSemiException: Response Code OperationNotPermitted
[6640] Failed to execute script '__main__' due to unhandled exception!
The response code does not give much information. What could be the reason ?
Additionally, Tried to flash using command west flash. That also failed with an FATAL ERROR: required program nrfjprog not found; install it or add its location to PATH
