When building a tfm setting with nrf54l15, an error occurs during Matter commissioning.
If you use the following settings, an error will occur during commissioning.
Board: Custom board
SDK:ncsv2.9.2
OS: Windows10
Sample code:Matter Lock
bord target:nrf54l15dk/nrf54l15/cpuapp/ns
Border router: Home pod mini
iphone:ios 18.5
The serial log during commissioning is as follows:
I: 110374 [DIS]Updating services using commissioning mode 1
E: 110380 [DIS]Failed to remove advertised services: 3
I: 110385 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
E: 110394 [DIS]Failed to advertise commissionable node: 3
E: 110399 [DIS]Failed to finalize service update: 3
I: 110405 [DL]CHIPoBLE advertising started
I: 140409 [DL]CHIPoBLE advertising mode changed to slow
I: 140415 [DL]CHIPoBLE advertising started
・*** Booting My Application v2.9.2-8c3b414bb1e8 ***
*** Using nRF Connect SDK v2.9.2-4ab7b98fc76f ***
*** Using Zephyr OS v3.7.99-aa34a5632971 ***
I: 1412 [DL]BLE address: F4:F9:24:5F:02:AD
I: No users indexes stored
I: No stored indexes for credential of type: 1
I: 1426 [DL]CHIP task running
I: Init CHIP stack
I: 1431 [DL]OpenThread started: OK
I: 1435 [DL]Setting OpenThread device type to SLEEPY END DEVICE
I: 1441 [DL]The device does not support hardware protection against write.
I: 1447 [SVR]Subscription persistence not supported
I: 1452 [SVR]Server initializing...
I: 1455 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 1460 [DMG]AccessControl: initializing
I: 1464 [DMG]Examples::AccessControlDelegate::Init
I: 1469 [DMG]AccessControl: setting
I: 1472 [DMG]DefaultAclStorage: initializing
I: 1476 [DMG]DefaultAclStorage: 0 entries loaded
E: 1480 [IN]IPV6_PKTINFO failed: 109
uart:~$ I: 1485 [ZCL]Using ZAP configuration...
I: 1490 [DMG]AccessControlCluster: initializing
I: 1494 [ZCL]Initiating Admin Commissioning cluster.
I: 1499 [ZCL]Door Lock server initialized
I: 1502 [ZCL]Door Lock cluster initialized at endpoint #1
I: 1508 [ZCL]0xdabb2 ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported
E: 1514 [ZCL]Failed to set DoorLock number of RFID users: 86
I: 1519 [DIS]Updating services using commissioning mode 0
E: 1525 [DIS]Failed to remove advertised services: 3
E: 1529 [DIS]Failed to finalize service update: 3
I: 1534 [IN]CASE Server enabling CASE session setups
I: 1539 [SVR]Joining Multicast groups
I: 1542 [SVR]Server Listening...
I: 1545 [DL]Device Configuration:
I: 1548 [DL]  Serial Number: 11223344556677889900
I: 1553 [DL]  Vendor Id: 65521 (0xFFF1)
I: 1556 [DL]  Product Id: 32774 (0x8006)
I: 1560 [DL]  Product Name: not-specified
I: 1564 [DL]  Hardware Version: 0
I: 1567 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 1572 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 1579 [DL]  Manufacturing Date: 2022-01-01
I: 1583 [DL]  Device Type: 65535 (0xFFFF)
I: 1586 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00]
I: 1591 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 1597 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00
I: 1606 [SVR]Manual pairing code: [34970112332]
E: 1610 [DL]Long dispatch time: 181 ms, for event type 2
I: 147476 [DIS]Updating services using commissioning mode 1
E: 147481 [DIS]Failed to remove advertised services: 3
I: 147486 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
E: 147496 [DIS]Failed to advertise commissionable node: 3
E: 147501 [DIS]Failed to finalize service update: 3
I: 147506 [DL]CHIPoBLE advertising started
I: 147576 [DL]Current number of connections: 1/1
I: 147581 [DL]BLE connection established (ConnId: 0x00)
I: 147586 [DL]CHIPoBLE advertising stopped
I: 148316 [BLE]local and remote recv window sizes = 5
I: 148321 [BLE]selected BTP version 4
I: 148324 [BLE]using BTP fragment sizes rx 182 / tx 182.
I: 148436 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 185)
I: 148499 [EM]>>> [E:21625r S:0 M:137350978] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
I: 148515 [EM]<<< [E:21625r S:0 M:37729224] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
I: 148530 [SVR]Commissioning session establishment step started
I: 148739 [EM]>>> [E:21625r S:0 M:137350979] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
I: 148777 [EM]<<< [E:21625r S:0 M:37729225] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
I: 148828 [EM]>>> [E:21625r S:0 M:137350980] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
I: 148843 [EM]<<< [E:21625r S:0 M:37729226] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
I: 148859 [SC]SecureSession[0x20014088, LSID:39875]: State change 'kEstablishing' --> 'kActive'
I: 148868 [SVR]Commissioning completed session establishment step
I: 148874 [DIS]Updating services using commissioning mode 0
E: 148879 [DIS]Failed to remove advertised services: 3
E: 148884 [DIS]Failed to finalize service update: 3
I: 148889 [SVR]Device completed Rendezvous process
I: 148949 [EM]>>> [E:21626r S:39875 M:205759558] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 148964 [EM]<<< [E:21626r S:39875 M:241130563] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:68)
I: 149069 [EM]>>> [E:21627r S:39875 M:205759559] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 149084 [EM]<<< [E:21627r S:39875 M:241130564] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:96)
I: 149189 [EM]>>> [E:21628r S:39875 M:205759560] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
I: 149204 [EM]<<< [E:21628r S:39875 M:241130565] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
I: 149309 [EM]>>> [E:21629r S:39875 M:205759561] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 149324 [EM]<<< [E:21629r S:39875 M:241130566] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
I: 149488 [EM]>>> [E:21630r S:39875 M:205759562] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
I: 149503 [EM]<<< [E:21630r S:39875 M:241130567] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
I: 149669 [EM]>>> [E:21631r S:39875 M:205759563] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:54)
E: 149683 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x1349_FC00, attributeId: 0x0000_0001err = 5c3
I: 149695 [EM]<<< [E:21631r S:39875 M:241130568] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
I: 149789 [EM]>>> [E:21632r S:39875 M:205759564] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
E: ***** SECURE FAULT *****
E:   Address: 0x2b
E:   Attribution unit violation
E: r0/a1:  0x20010dcc  r1/a2:  0x20036a00  r2/a3:  0x00000000
E: r3/a4:  0x00000000 r12/ip:  0x20036af8 r14/lr:  0x00094a9b
E:  xpsr:  0x81000000
E: Faulting instruction address (r15/pc): 0x00094ad4
E: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
E: Current thread: 0x2001ed40 (CHIP)
E: Halting system
If the board target is nrf54l15dk/nrf54l15/cpuapp, no error occurs.
Also, no commissioning errors occurred with nrf54l15dk/nrf54l15/cpuapp/ns on Google Nest Hub.
best regards,
Hiroki
  • Hi,Elfving
    I checked with addr2line.
    Setting up addr2line on Windows takes some time, so I checked the elf address on Linux.
    The result is below.
    hosi2ng4@hosi2ng4-ThinkBook-14-G4-IAP:~/lock2/build/lock2/zephyr$ addr2line -e zephyr.elf 0x00094a9b
    /home/hosi2ng4/ncs/v2.9.2/zephyr/include/zephyr/net/net_if.h:1095
    hosi2ng4@hosi2ng4-ThinkBook-14-G4-IAP:~/lock2/build/lock2/zephyr$ addr2line -e zephyr.elf 0x00094ad4
    /home/hosi2ng4/lock2/build/lock2/modules/connectedhomeip/../../../../../ncs/v2.9.2/modules/lib/matter/src/inet/InetInterface.cpp:943
    This is occurring in the same file as denghongyan.
    I think the address is different because denghongyan is doing it in the template sample code.
    best regards,
    Hiroki
  • Hi,Elfving
    I understood that it's experimental.
    Does this mean that it's currently impossible to release a product with TFM for Matter?
    Also, when do you plan to resolve this bug?
    best regards,
    Hiroki
    No that just means that it hasn't gone through production testing. We're expecting it to work, though it hasn't been tested in any rigorous way, so there might be some bugs and high power draws that haven't been noticed before.
    We are looking into fixing it, though it is hard to give you a timeframe for when it will be solved. If this is urgent for you, please contact your local regional sales manager, who might be able to speed things up (or let me know if you need his contact details).
    Elfving
  • Hi again guys,
    There seems to be a bug in TFM in this NCS version, and we can not connect to the Apple ecosystem because of it.
    Unfortunately, it is hard to provide a simple workaround or fix for NCS 2.9, because there were many changes in our security modules. What I can suggest is to update to NCS 3.1.0 once it is released, to use it with the Apple ecosystem. There were some updates for in NCS recently, and we checked that NCS 3.1.0 should be ready to be used in the Apple ecosystem - Everything works properly on NCS 3.1.0-RC2.
    Elfving
