When building a tfm setting with nrf54l15, an error occurs during Matter commissioning.
If you use the following settings, an error will occur during commissioning.
Board: Custom board
SDK:ncsv2.9.2
OS: Windows10
Sample code:Matter Lock
bord target:nrf54l15dk/nrf54l15/cpuapp/ns
Border router: Home pod mini
iphone:ios 18.5
The serial log during commissioning is as follows:
I: 110374 [DIS]Updating services using commissioning mode 1
E: 110380 [DIS]Failed to remove advertised services: 3
I: 110385 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
E: 110394 [DIS]Failed to advertise commissionable node: 3
E: 110399 [DIS]Failed to finalize service update: 3
I: 110405 [DL]CHIPoBLE advertising started
I: 140409 [DL]CHIPoBLE advertising mode changed to slow
I: 140415 [DL]CHIPoBLE advertising started
・*** Booting My Application v2.9.2-8c3b414bb1e8 ***
*** Using nRF Connect SDK v2.9.2-4ab7b98fc76f ***
*** Using Zephyr OS v3.7.99-aa34a5632971 ***
I: 1412 [DL]BLE address: F4:F9:24:5F:02:AD
I: No users indexes stored
I: No stored indexes for credential of type: 1
I: 1426 [DL]CHIP task running
I: Init CHIP stack
I: 1431 [DL]OpenThread started: OK
I: 1435 [DL]Setting OpenThread device type to SLEEPY END DEVICE
I: 1441 [DL]The device does not support hardware protection against write.
I: 1447 [SVR]Subscription persistence not supported
I: 1452 [SVR]Server initializing...
I: 1455 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 1460 [DMG]AccessControl: initializing
I: 1464 [DMG]Examples::AccessControlDelegate::Init
I: 1469 [DMG]AccessControl: setting
I: 1472 [DMG]DefaultAclStorage: initializing
I: 1476 [DMG]DefaultAclStorage: 0 entries loaded
E: 1480 [IN]IPV6_PKTINFO failed: 109
uart:~$ I: 1485 [ZCL]Using ZAP configuration...
I: 1490 [DMG]AccessControlCluster: initializing
I: 1494 [ZCL]Initiating Admin Commissioning cluster.
I: 1499 [ZCL]Door Lock server initialized
I: 1502 [ZCL]Door Lock cluster initialized at endpoint #1
I: 1508 [ZCL]0xdabb2 ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported
E: 1514 [ZCL]Failed to set DoorLock number of RFID users: 86
I: 1519 [DIS]Updating services using commissioning mode 0
E: 1525 [DIS]Failed to remove advertised services: 3
E: 1529 [DIS]Failed to finalize service update: 3
I: 1534 [IN]CASE Server enabling CASE session setups
I: 1539 [SVR]Joining Multicast groups
I: 1542 [SVR]Server Listening...
I: 1545 [DL]Device Configuration:
I: 1548 [DL]  Serial Number: 11223344556677889900
I: 1553 [DL]  Vendor Id: 65521 (0xFFF1)
I: 1556 [DL]  Product Id: 32774 (0x8006)
I: 1560 [DL]  Product Name: not-specified
I: 1564 [DL]  Hardware Version: 0
I: 1567 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 1572 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 1579 [DL]  Manufacturing Date: 2022-01-01
I: 1583 [DL]  Device Type: 65535 (0xFFFF)
I: 1586 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00]
I: 1591 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 1597 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00
I: 1606 [SVR]Manual pairing code: [34970112332]
E: 1610 [DL]Long dispatch time: 181 ms, for event type 2
I: 147476 [DIS]Updating services using commissioning mode 1
E: 147481 [DIS]Failed to remove advertised services: 3
I: 147486 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
E: 147496 [DIS]Failed to advertise commissionable node: 3
E: 147501 [DIS]Failed to finalize service update: 3
I: 147506 [DL]CHIPoBLE advertising started
I: 147576 [DL]Current number of connections: 1/1
I: 147581 [DL]BLE connection established (ConnId: 0x00)
I: 147586 [DL]CHIPoBLE advertising stopped
I: 148316 [BLE]local and remote recv window sizes = 5
I: 148321 [BLE]selected BTP version 4
I: 148324 [BLE]using BTP fragment sizes rx 182 / tx 182.
I: 148436 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 185)
I: 148499 [EM]>>> [E:21625r S:0 M:137350978] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
I: 148515 [EM]<<< [E:21625r S:0 M:37729224] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
I: 148530 [SVR]Commissioning session establishment step started
I: 148739 [EM]>>> [E:21625r S:0 M:137350979] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
I: 148777 [EM]<<< [E:21625r S:0 M:37729225] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
I: 148828 [EM]>>> [E:21625r S:0 M:137350980] (U) Msg RX from 0:60521467054A5DC3 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
I: 148843 [EM]<<< [E:21625r S:0 M:37729226] (U) Msg TX from 0000000000000000 to 0:60521467054A5DC3 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
I: 148859 [SC]SecureSession[0x20014088, LSID:39875]: State change 'kEstablishing' --> 'kActive'
I: 148868 [SVR]Commissioning completed session establishment step
I: 148874 [DIS]Updating services using commissioning mode 0
E: 148879 [DIS]Failed to remove advertised services: 3
E: 148884 [DIS]Failed to finalize service update: 3
I: 148889 [SVR]Device completed Rendezvous process
I: 148949 [EM]>>> [E:21626r S:39875 M:205759558] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 148964 [EM]<<< [E:21626r S:39875 M:241130563] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:68)
I: 149069 [EM]>>> [E:21627r S:39875 M:205759559] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 149084 [EM]<<< [E:21627r S:39875 M:241130564] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:96)
I: 149189 [EM]>>> [E:21628r S:39875 M:205759560] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
I: 149204 [EM]<<< [E:21628r S:39875 M:241130565] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
I: 149309 [EM]>>> [E:21629r S:39875 M:205759561] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
I: 149324 [EM]<<< [E:21629r S:39875 M:241130566] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
I: 149488 [EM]>>> [E:21630r S:39875 M:205759562] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
I: 149503 [EM]<<< [E:21630r S:39875 M:241130567] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
I: 149669 [EM]>>> [E:21631r S:39875 M:205759563] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:54)
E: 149683 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x1349_FC00, attributeId: 0x0000_0001err = 5c3
I: 149695 [EM]<<< [E:21631r S:39875 M:241130568] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
I: 149789 [EM]>>> [E:21632r S:39875 M:205759564] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
E: ***** SECURE FAULT *****
E:   Address: 0x2b
E:   Attribution unit violation
E: r0/a1:  0x20010dcc  r1/a2:  0x20036a00  r2/a3:  0x00000000
E: r3/a4:  0x00000000 r12/ip:  0x20036af8 r14/lr:  0x00094a9b
E:  xpsr:  0x81000000
E: Faulting instruction address (r15/pc): 0x00094ad4
E: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
E: Current thread: 0x2001ed40 (CHIP)
E: Halting system
If the board target is nrf54l15dk/nrf54l15/cpuapp, no error occurs.
Also, no commissioning errors occurred with nrf54l15dk/nrf54l15/cpuapp/ns on Google Nest Hub.
best regards,
Hiroki
  • Hi Elfving
    this is the completely unmodified sample?
    I didn't change it because I wanted to verify the problem with the sample code base.
    I see you say that the DK is the board target, but it is also the physical board that you are using for this test, right?
    I confirmed this phenomenon in a custom product equipped with an nRF54l15 SoC. The custom product has the same external flash as the nrf54ldk, so the sample code works as is.
    Could you try looking at these addresses it fails at with addr2line for me? Could be worth checking both r15/pc and r14/l5. There are some guides in devacademy (here and here).
    I'll check it out, but I'm not sure if I'll get a reply right away.
    best regards,
    Hiroki
  • here is my log and addr-line, I tested with default factory data:
  • Did you use a DK for this denghongyan?
    Elfving
  • Yeah, for addr2line, I opened some log, if not, cannot use addr2lie:
    here is my prj_conf:
  • Hi EIfving,
    I build a pure verison, just prj.conf add rtt log:
    here is my commissiong log txt:
    *** Booting My Application v2.9.0-e3a4c1a2b782 ***
    *** Using nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    I: 1680 [DL]BLE address: FE:EF:E5:5C:34:F9
    I: 1683 [DL]CHIP task running
    I: Init CHIP stack
    I: 1684 [DL]OpenThread started: OK
    I: 1684 [DL]Setting OpenThread device type to MINIMAL END DEVICE
    I: 1685 [DL]Found DAC Private Key in factory data set. Copying to secure storage...
    I: 1689 [DL]The device does not support hardware protection against write.
    D: Registered new test event: 0xffffffff00000000
    D: Registered new test event: 0xffffffff10000000
    I: 1689 [SVR]Subscription persistence not supported
    I: 1689 [SVR]Server initializing...
    I: 1689 [TS]Last Known Good Time: [unknown]
    I: 1689 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48
    I: 1691 [DMG]AccessControl: initializing
    I: 1691 [DMG]Examples::AccessControlDelegate::Init
    I: 1691 [DMG]AccessControl: setting
    I: 1691 [DMG]DefaultAclStorage: initializing
    I: 1691 [DMG]DefaultAclStorage: 0 entriI: 31708 [DL]CHIPoBLE advertising mode changed to slow
    I: 31709 [DL]CHIPoBLE advertising started
    I: 51672 [DL]Current number of connections: 1/1
    I: 51673 [DL]BLE connection established (ConnId: 0x00)
    I: 51673 [DL]CHIPoBLE advertising stopped
    D: 52447 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52447 [BLE]local and remote recv window sizes = 5
    I: 52447 [BLE]selected BTP version 4
    I: 52447 [BLE]using BTP fragment sizes rx 182 / tx 182.
    D: 52567 [DL]ConnId: 0x00, New CCCD value: 0x0002
    D: 52567 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
    D: 52567 [IN]BLE EndPoint 0x2001d650 Connection Complete
    I: 52568 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 185)
    D: 52627 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52630 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52630 [EM]>>> [E:28929r S:0 M:161786240] (U) Msg RX from 0:AED83A1987C1EA0B [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
    I: 52632 [EM]<<< [E:28929r S:0 M:378125] (U) Msg TX from 0000000000000000 to 0:AED83A1987C1EA0B [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
    D: 52632 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 159)
    I: 52632 [SVR]Commissioning session establishment step started
    D: 52687 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52690 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52690 [EM]>>> [E:28929r S:0 M:161786241] (U) Msg RX from 0:AED83A1987C1EA0B [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
    I: 52713 [EM]<<< [E:28929r S:0 M:378126] (U) Msg TX from 0000000000000000 to 0:AED83A1987C1EA0B [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
    D: 52714 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
    D: 52807 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52809 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52809 [EM]>>> [E:28929r S:0 M:161786242] (U) Msg RX from 0:AED83A1987C1EA0B [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
    I: 52810 [EM]<<< [E:28929r S:0 M:378127] (U) Msg TX from 0000000000000000 to 0:AED83A1987C1EA0B [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
    D: 52810 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
    I: 52812 [SC]SecureSession[0x200137e8, LSID:2324]: State change 'kEstablishing' --> 'kActive'
    D: 52813 [IN]SecureSession[0x200137e8]: Activated - Type:1 LSID:2324
    D: 52813 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:2324 PSID:1566!
    I: 52813 [SVR]Commissioning completed session establishment step
    I: 52813 [DIS]Updating services using commissioning mode 0
    E: 52814 [DIS]Failed to remove advertised services: 3
    E: 52814 [DIS]Failed to finalize service update: 3
    D: 52814 [DL]CHIPoBLE advertising set to off
    I: 52814 [SVR]Device completed Rendezvous process
    D: 52897 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52899 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52900 [EM]>>> [E:28930r S:2324 M:72307863] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
    D: 52900 [IM]Received Read request
    I: 52902 [EM]<<< [E:28930r S:2324 M:116060134] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
    D: 52902 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 53017 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 53019 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53020 [EM]>>> [E:28931r S:2324 M:72307864] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
    D: 53020 [IM]Received Read request
    I: 53022 [EM]<<< [E:28931r S:2324 M:116060135] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:86)
    D: 53022 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 91)
    D: 53137 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 53139 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53140 [EM]>>> [E:28932r S:2324 M:72307865] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
    D: 53140 [IM]Received Read request
    I: 53142 [EM]<<< [E:28932r S:2324 M:116060136] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
    D: 53142 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 53257 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 53259 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53260 [EM]>>> [E:28933r S:2324 M:72307866] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
    D: 53260 [IM]Received Read request
    I: 53262 [EM]<<< [E:28933r S:2324 M:116060137] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
    D: 53262 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 53377 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 53379 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53380 [EM]>>> [E:28934r S:2324 M:72307867] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52)
    D: 53380 [IM]Received Read request
    I: 53382 [EM]<<< [E:28934r S:2324 M:116060138] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67)
    D: 53382 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 53497 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 53499 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53500 [EM]>>> [E:28935r S:2324 M:72307868] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:54)
    D: 53500 [IM]Received Read request
    E: 53501 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x1349_FC00, attributeId: 0x0000_0001err = 5c3
    I: 53502 [EM]<<< [E:28935r S:2324 M:116060139] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66)
    D: 53502 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 53619 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 53620 [EM]>>> [E:28936r S:2324 M:72307869] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51)
    D: 53620 [IM]Received Read request
    E:   Address: 0x2b
    E: r0/a1:  0x20010ddc  r1/a2:  0x20034f80  r2/a3:  0x00000000
    E: r3/a4:  0x00000000 r12/ip:  0x20035078 r14/lr:  0x0008f8b7
    E:  xpsr:  0x81000000
    E: Faulting instruction address (r15/pc): 0x0008f8f0
    E: Current thread: 0x2001e510 (CHIP)
    E: Halting system
    here is the error address to line:
