BLE MCUBOOT issue with nrf54L15
I wanted the zigbee firmware to support BLE OTA. so I downloaded the latest zigbee SDK from the following link "">github.com/.../pulls".But the compilation encountered problems, the following is my conf file
Application : light_switch
SDK :  nRF Connect SDK V2.9.0*
Toolchain : nRF Connect SDK Toolchain V2.9.0
compilation error:
 undefined reference to `__device_dts_ord_114'
prj.conf
# Copyright (c) 2024 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_ZIGBEE_ADD_ON=y
CONFIG_ZIGBEE_APP_UTILS=y
CONFIG_ZIGBEE_ROLE_END_DEVICE=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Enable API for powering down unused RAM parts
CONFIG_RAM_POWER_DOWN_LIBRARY=y
# Networking
CONFIG_NET_IPV6=n
CONFIG_NET_IP_ADDR_CHECK=n
CONFIG_NET_UDP=n
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
overlay-multiprotocol_ble.conf
# BLE configuration
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Zigbee_Switch"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_PHY_UPDATE=n
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_SETTINGS=y
CONFIG_BT_SETTINGS=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
sysbuild.conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
