Hello
I'm working on a custom electronics board with an nrf54L15 (QFAA). This MCU is interfaced with an EEPROM memory (24FC16T) via an I2C bus connected on P1.03(SCL) and P1.02(SDA).
I'm trying to use I2C22 instance to communicate with the eeprom memory currently without success.
When I try to read or write the eeprom, i2c functions return always error code -5.
I'm currently using SDK 3.0.1 with zephyr.
I added in my device tree the I2C22 enable and its pin mapping has follow :
#include <nordic/nrf54l15_cpuapp.dtsi>
&i2c22 {
status = "okay";
clock-frequency = <I2C_BITRATE_STANDARD>;
pinctrl-0 = <&i2c22_default>;
pinctrl-1 = <&i2c22_sleep>;
eeprom: eeprom@50 {
compatible = "i2c-device";
status = "okay";
reg = <0x50>;
&pinctrl {
i2c22_default: i2c22_default {
group1 {
psels = <NRF_PSEL(TWIM_SCL, 1, 3)>,
<NRF_PSEL(TWIM_SDA, 1, 2)>;
bias-pull-up;
i2c22_sleep: i2c22_sleep {
group1 {
low-power-enable;
bias-pull-up;
const struct i2c_dt_spec eeprom_i2c = I2C_DT_SPEC_GET(DT_NODELABEL(eeprom));
if (!device_is_ready(eeprom_i2c.bus)) { // <-- Device is ready
LOG_ERR("I2C bus %s is not ready!\n", eeprom_i2c.bus->name);
uint8_t tx[8] = {0x00};
uint8_t rx[8] = {0x00};
tx[0] = 0x12; //write start @ 0x12
tx[1] = 0x01;
tx[2] = 0x23;
tx[3] = 0x45;
tx[4] = 0x67;
int err;
err = i2c_write_dt(&eeprom_i2c, tx, 5); // <-- always return -5
if(err < 0) {
LOG_WRN("Fail to write EEPROM\n");
err = i2c_write_read_dt(&eeprom_i2c, tx, 1, rx, 4); // <-- always return -5
if(err < 0) {
LOG_WRN("Fail to read EEPROM\n");
}The read and write functions always return -5
When I check signals with a scope, both SCL and SDA stay to Vcc.
When I check the exactly same code on I2C30 (SCL=P0.03 and SDA=P0.04) it's working (but don't match my board custom layout...)
Did I miss something in my configuration to make it work over I2C22?
Or, are there any limitations on the NRF54L15 that might prevent it from working over I2C22?
Thank you in advance, regards
