ADC Oversample with Scan - sanity check question
I just want to double check something before I optimise an implementation.
If burst is enabled on multiple channels, let's say x256 for two channels, internally is the process doing:
Read first channels x256 times then read second channels x256 times
or
Read first channel, Read second channel, repeat 256 times
The documentation suggests it is the prior method however the implementation under-the-hood would give the same outcome just with the reads being done in or out of order.
docs.nordicsemi.com/.../saadc.html
(Obviously I can just use the scan feature and am doing so but it's a memory hog.)
    Both quotes below, i.e "Read first channels x256 times then read second channels x256 times should be correct" and the comments from Carstein are coming from a discussion with engineers who are familiar with the adc hardware implementation on the nrf52810
    Let me know if you have any follow up questions or if that answer keeps both of us on the sane side of the sanity check!
    Andreas
