WiFi shell ,SCAN ,STA/AP sample fails on v3.0.2 for nrf7002EK with external host(stm32) 'RDSR2 failed' error
I'm trying to run Wi-Fi scanning or AP/STA mode examples on the NUCLEO-U575ZI-Q board with the nRF7002EK shield, but I keep getting an "RDSR2 register failed" error. I've tried with zephyr version also, but so far, I haven't found a solution. Interestingly, I tested the same shield with the STM32H747I Discovery board, and everything works perfectly — examples like the shell, AP/STA mode, and scan run without issues. However, on the NUCLEO board:
  • The shell example fails.
The Wi-Fi interface shows as down.When I try to bring the interface up, I get the following error:
uart:~$ net iface up 1 Cannot take interface 1 up (-120)
If anyone has managed to get this setup working or has suggestions. Thanks!
[00:00:00.487,884] <err> wifi_nrf_bus: Error: RDSR2 failed
[00:00:00.487,945] <err> wifi_nrf: zep_shim_bus_qspi_dev_add: RPU enable failed with error -1
[00:00:00.488,006] <err> wifi_nrf: nrf_wifi_bus_qspi_dev_add: nrf_wifi_osal_bus_qspi_dev_add failed
[00:00:00.488,067] <err> wifi_nrf: nrf_wifi_bal_dev_add: Bus dev_add failed
[00:00:00.488,128] <err> wifi_nrf: nrf_wifi_hal_dev_add: nrf_wifi_bal_dev_add failed
[00:00:00.488,250] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
[00:00:00.488,281] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
[00:00:00.488,281] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
  • Hi
    How have you connected the nRF7002 EK to the Nucleo board here, and have you made sure to configure the board file to fit the nRF7002 EK pinout? The last time I saw this error message, it was due to the config and board not being set up correctly, so I think the first step is to double check the connection between the Nucleo board and nRF7002 EK to make sure it is connected correctly, as well as double check the EK is powered correctly. You can use the nRF7002 EK development guide here for reference: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/device_guides/nrf70/nrf7002ek_dev_guide.html
    Simon
  • Thanks for the reply. I had two evaluation kits (EK); one wasn't working, so I switched to the other, and it's powering up correctly now. However, I'm now encountering a different error, which I believe might be related to something else. My hardware  team is currently investigating it.
    Anyway, let's set that aside — I have some other errors I need help with.
    00> [00:00:00.002,000] <inf> wifi_nrf_bus: SPIM spi@40003800: freq = 8 MHz
    00> [00:00:00.002,000] <inf> wifi_nrf_bus: SPIM spi@40003800: latency = 0
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_hal_fw_chk_boot: Boot_sig check failed for RPU(0), Expected: 0x5A5A5A5A, Actual: 0x0
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_fmac_fw_boot: LMAC processor ROM boot check failed
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_fmac_fw_load: FW boot failed
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_fw_load: nrf_wifi_fmac_fw_load failed
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fw_load failed
    00> [00:00:01.112,000] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    00> *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
    00> *** Using Zephyr OS v4.0.99-f791c49f492c ***
  • Strange, can you confirm you've done the OTP memory programming on the nRF7002 EK on your end, which is needed to set the device up the first time used. Please check out the Device commissioning and Characterization app note in our documentation here: https://docs.nordicsemi.com/bundle/nan_043/page/APP/nan_043/otp_programming.html
    Simon
  • Thanks, Simonr.
    I'm not sure how to connect the nRF7002 EK standalone. Is it possible to use it with my setup—specifically, can I run the nRF Desktop Programmer with a J-Link connected to the STM32 and nRF7002?
  • I successfully compiled the multidomain radio sample for OTP programming. However, when I tried to run and update it, I encountered some new errors.
    00> rtt:~$ [00:00:00.002,000] <inf> wifi_nrf_bus: SPIM spi@40003800: freq = 8 MHz
    00> rtt:~$ [00:00:00.002,000] <inf> wifi_nrf_bus: SPIM spi@40003800: latency = 0
    00> rtt:~$ rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_hal_fw_chk_boot: Boot_sig check failed for RPU(0), Expected: 0x5A5A5A5A, Actual: 0x0
    00> rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_fmac_fw_boot: LMAC processor ROM boot check failed
    00> rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_fmac_fw_load: FW boot failed
    00> rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_fw_load: nrf_wifi_fmac_fw_load failed
    00> rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fw_load failed
    00> rtt:~$ [00:00:01.131,000] <err> wifi_nrf: nrf_wifi_drv_main_zep: nrf_wifi_fmac_dev_add_zep failed
    00> rtt:~$ n
    00>
    00> rtt:~$
      < wifi
    00> wifi
    00> wifi: command not found
    00> rtt:~$
      < help
    00> help
    00> Please press the <Tab> button to see all available commands.
    00> You can also use the <Tab> button to prompt or auto-complete all commands or its subcommands.
    00> You can try to call commands with <-h> or <--help> parameter for more information.
    00>
    00> Shell supports following meta-keys:
    00>   Ctrl + (a key from: abcdefklnpuw)
    00>   Alt  + (a key from: bf)
    00> Please refer to shell documentation for more details.
    00>
    00> Available commands:
    00>   clear                 : Clear screen.
    00>   date                  : Date commands
    00>   device                : Device commands
    00>   devmem                : Read/write physical memory
    00> Usage:
    00> Read memory at address with optional width:
    00> devmem <address> [<width>]
    00> Write memory at address with mandatory width and
    00> value:
    00> devmem <address> <width> <value>
    00>   help                  : Prints the help message.
    00>   history               : Command history.
    00>   kernel                : Kernel commands
    00>   rem                   : Ignore lines beginning with 'rem '
    00>   retval                : Print return value of most recent command
    00>   shell                 : Useful, not Unix-like shell commands.
    00>   wifi_radio_ficr_prog  : nRF Wi-Fi radio FICR commands
    00>   wifi_radio_test       : nRF Wi-Fi radio test commands
    00> rtt:~$
      < wifi_radio_ficr_prog help
    00> wifi_radio_ficr_prog help
    00> wifi_radio_ficr_prog - nRF Wi-Fi radio FICR commands
    00> Subcommands:
    00>   otp_get_status            : Read OTP status
    00>   otp_read_params           : Read User region status and information on
    00> programmed fields
    00>   otp_read_retrim_version   : Read Retrim Version
    00>   otp_read_retrim_params    : Read Retrim Params
    00>   otp_write_params          : Write OTP Params
    00> otp_write_params <addr offset> [arg1]
    00> [arg2]...[argN]
    00>   otp_write_retrim_version  : Write OTP Retrim Version
    00> otp_write_retrim_version <retrim version>
    00>   otp_write_retrim_params   : Write OTP Retrim Params
    00> otp_write_params <retrim index> [retrim data]
    00> rtt:~$
      < wifi_radio_ficr_prog otp_get_status
    00> wifi_radio_ficr_prog otp_get_status
    00> [00:01:22.200,000] <err> os: ***** BUS FAULT *****
    00> [00:01:22.200,000] <err> os:   Instruction bus error
    00> [00:01:22.200,000] <err> os: r0/a1:  0x0001b804  r1/a2:  0x2400722c  r2/a3:  0x00000004
    00> [00:01:22.200,000] <err> os: r3/a4:  0x07bfc87b r12/ip:  0x08018420 r14/lr:  0x080028df
    00> [00:01:22.200,000] <err> os:  xpsr:  0x41000000
    00> [00:01:22.200,000] <err> os: Faulting instruction address (r15/pc): 0x07bfc87a
    00> [00:01:22.200,000] <err> os: >>> ZEPHYR FATAL ERROR 27: Unknown error on CPU 0
    00> [00:01:22.200,000] <err> os: Current thread: 0x240030c8 (shell_rtt)
    00> [00:01:22.403,000] <err> coredump: #CD:BEGIN#
    00> [00:01:22.430,000] <err> coredump: #CD:5a450200030005001b000000
    00> [00:01:22.465,000] <err> coredump: #CD:4102004400
    00> [00:01:22.498,000] <err> coredump: #CD:04b801002c720024040000007bc8bf0720840108df2800087ac8bf0700000041
    00> [00:01:22.541,000] <err> coredump: #CD:2872002400000000000000000000000000000000000000000000000000000000
    00> [00:01:22.584,000] <err> coredump: #CD:00000000
    00> [00:01:22.612,000] <err> coredump: #CD:4d0100c830002480310024
    00> [00:01:22.646,000] <err> coredump: #CD:281900240c5000240000000000800e0000000000000000000000000000000000
    00> [00:01:22.689,000] <err> coredump: #CD:b539010800000000000000000000000001000000ffffffffffffffffc8300024
    00> [00:01:22.732,000] <err> coredump: #CD:5c3f002403000000100000000000000000760024000000002031002420310024
    00> [00:01:22.775,000] <err> coredump: #CD:00010000b15d0008444c01080100000004000000300800247368656c6c5f7274
    00> [00:01:22.817,000] <err> coredump: #CD:7400000000000000000000000000000000000000000000008066002400100000
    00> [00:01:22.860,000] <err> coredump: #CD:100000000000000070760024000000000000000000000000
    00> [00:01:22.902,000] <err> coredump: #CD:4d01008066002480760024
    00> [00:01:22.936,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:22.979,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.022,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.065,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.107,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.150,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.193,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.236,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.279,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.322,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.365,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.408,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.451,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.493,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.536,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.579,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.622,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.665,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.708,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.751,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.794,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.837,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.879,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.922,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:23.965,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.008,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.051,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.094,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.137,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.180,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.222,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.265,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.308,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.351,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.394,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.437,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.480,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.523,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.566,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.608,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.651,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.694,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.737,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.780,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.823,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.866,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.909,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.951,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:24.994,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.037,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.080,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.123,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.166,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.209,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.252,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.295,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.337,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.380,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.423,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.466,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.509,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.552,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.595,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.638,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.681,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.723,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.766,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.809,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.852,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.895,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.938,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:25.981,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.024,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.066,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.109,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.152,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.195,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.238,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.281,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.324,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.367,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.410,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.452,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.495,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.538,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.581,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.624,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.667,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.710,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.753,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.795,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:26.838,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa0000000004000000
    00> [00:01:26.881,000] <err> coredump: #CD:04b801002c72002404b801002c720024040000007bc8bf0720840108df280008
    00> [00:01:26.924,000] <err> coredump: #CD:7ac8bf0700000041000000000000000080000000444c010880000000df2e0008
    00> [00:01:26.967,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa444c0108883c002401000000
    00> [00:01:27.010,000] <err> coredump: #CD:fdffffffdc740024d45101080100000000000000d3240008aaaaaaaaaaaaaaaa
    00> [00:01:27.053,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:27.096,000] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    00> [00:01:27.139,000] <err> coredump: #CD:aaaaaaaaaaaaaaaa8900000047ab00089e03000047ab00080000000004000000
    00> [00:01:27.181,000] <err> coredump: #CD:1e000000595000245b50002430730024883c0024040000001e0000005f520008
    00> [00:01:27.224,000] <err> coredump: #CD:44050024010000001e0000001e000000444c0108000000005b5000240d520008
    00> [00:01:27.267,000] <err> coredump: #CD:b7850108638b01089f850108ef1901081e00000078730024883c002404000000
    00> [00:01:27.310,000] <err> coredump: #CD:c05401086f000000c054010878000000780000004d130108d873002445130108
    00> [00:01:27.353,000] <err> coredump: #CD:c0540108851301084d1301082d000000207400240123010802000000c0540108
    00> [00:01:27.396,000] <err> coredump: #CD:0a000000651301084d130108010000004074002401230108af03000047ab0008
    00> [00:01:27.439,000] <err> coredump: #CD:000000000400000002000000595000245b500024f8730024883c002404000000
    00> [00:01:27.482,000] <err> coredump: #CD:02000000c05401080a000000651301084d130108010000008874002401230108
    00> [00:01:27.524,000] <err> coredump: #CD:e503000047ab0008000000000400000002000000595000245b50002440740024
    00> [00:01:27.567,000] <err> coredump: #CD:883c002404000000020000005f52000844050024010000000200000002000000
    00> [00:01:27.610,000] <err> coredump: #CD:444c0108000000005b5000240d520008080000000000000000000000ef190108
    00> [00:01:27.653,000] <err> coredump: #CD:444c01082967000830000000f0dd0124cc51010864740024cc51010823160108
    00> [00:01:27.696,000] <err> coredump: #CD:a8740024de830108f3830108d05101080000000000000000183f0024444c0108
    00> [00:01:27.739,000] <err> coredump: #CD:444c0108883c002401000000695600085b500024d87400240000000000000000
    00> [00:01:27.782,000] <err> coredump: #CD:010000000200000001000000010000000100000001000000444c010800000000
    00> [00:01:27.825,000] <err> coredump: #CD:118401082084010800000000c124000801000000f63c00240b3d002400000000
    00> [00:01:27.868,000] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000000000000
    00> [00:01:27.910,000] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000000000000
    00> [00:01:27.953,000] <err> coredump: #CD:000000000000000000000000444c0108883c002400000000f55600080b110108
    00> [00:01:27.996,000] <err> coredump: #CD:080000000000000000000000b358000844050024000000000300000003000000
    00> [00:01:28.039,000] <err> coredump: #CD:444c0108000000005b5000240d5200080800000a0100000000000000ef190108
    00> [00:01:28.082,000] <err> coredump: #CD:03000000f922010800000000000000004d130108c0540108c0540108e4750024
    00> [00:01:28.125,000] <err> coredump: #CD:14760024f55600080b11010845130108444c01087b170108c0540108c8750024
    00> [00:01:28.168,000] <err> coredump: #CD:ad620008014e010800000000c03700249835002461be000898350024f44f0024
    00> [00:01:28.211,000] <err> coredump: #CD:ffffffffd5b80008f44f0024c8300024c0060024f5380108f44f002400000000
    00> [00:01:28.253,000] <err> coredump: #CD:0000000000ed00e0f44f00240000000000000000444c01081c3f0024f5560008
    00> [00:01:28.296,000] <err> coredump: #CD:f55600080b110108080000000000000000000000811001080100000000000000
    00> [00:01:28.339,000] <err> coredump: #CD:444c010800000000d5520008555e000870760024b15d0008444c010801000000
    00> [00:01:28.382,000] <err> coredump: #CD:040000009337000800000000aaaaaaaaaaaaaaaaaaaaaaaac830002400000000
    00> [00:01:28.425,000] <err> coredump: #CD:END#
    00> [00:01:28.453,000] <err> os: Halting system
