nRF9151 SMA DK locked
I'm facing a persistent issue with my nRF9151-SMA-DK kit when trying to perform USB debugging, uploading, recovering, or erasing.
Interestingly, other boards (nRF9151-SMA-DK and nRF9151-DK) work fine with the identical setup.
I've attached five log files that capture the error messages I'm encountering.
Has anyone else experienced this problem or have insights into a potential fix? Any advice from the community or technical support would be greatly appreciated!
2025-06-18T14:22:58.709Z INFO Initialising the bundled nrfutil device
2025-06-18T14:22:58.731Z DEBUG Application data folder: C:\Users\abdukhair\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2025-06-18T14:22:58.773Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:22:58.774Z DEBUG App pc-nrfconnect-programmer v4.6.0 (official)
2025-06-18T14:22:58.774Z DEBUG App path: C:\Users\abdukhair\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2025-06-18T14:22:58.774Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
2025-06-18T14:22:58.774Z DEBUG nRFConnect path: C:\Users\abdukhair\AppData\Local\Programs\nrfconnect\resources\app.asar
2025-06-18T14:22:58.774Z DEBUG HomeDir: C:\Users\abdukhair
2025-06-18T14:22:58.774Z DEBUG TmpDir: C:\Users\ABDUKH~1\AppData\Local\Temp
2025-06-18T14:22:58.912Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:22:59.485Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:22:59.497Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:22:59.602Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-06-18T14:22:59.636Z INFO Using nrfutil-device version: 2.10.2
2025-06-18T14:22:59.636Z INFO Using nrf-device-lib version: 0.17.71
2025-06-18T14:22:59.637Z INFO Using nrf-probe version: 0.38.0
2025-06-18T14:22:59.637Z INFO Using JLink version: JLink_V8.34
2025-06-18T14:22:59.637Z INFO Your version of SEGGER J-Link (8.34) is newer than the one this app was tested with (8.18). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
2025-06-18T14:22:59.700Z INFO Getting serial port options from the persistent store for 001052034638.pc-nrfconnect-programmer
2025-06-18T14:22:59.700Z INFO Device connected with the serial number 001052034638
2025-06-18T14:22:59.701Z DEBUG Sending event "programmer: device connected"
2025-06-18T14:23:04.443Z INFO Selecting device with the serial number 001052034638
2025-06-18T14:23:04.465Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:23:05.167Z ERROR Error: Failed with exit code 1.
One or more device info tasks failed:
 * 1052034638: Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1) (Generic).
Message: Operation device-info failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1).
2025-06-18T14:23:05.168Z INFO Selected device with the serial number 001052034638
2025-06-18T14:23:05.168Z INFO Using nrfutil device to communicate with target via JLink
2025-06-18T14:23:05.203Z DEBUG Sending event "programmer: device selected"
2025-06-18T14:23:05.203Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:23:05.405Z DEBUG Sending event "programmer: running nrfutil device"
2025-06-18T14:23:05.798Z INFO Reading readback protection status for Application core
2025-06-18T14:23:05.798Z INFO Reading readback protection status for Application core 0%
2025-06-18T14:23:05.940Z ERROR Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
2025-06-18T14:23:05.971Z ERROR Error: Failed with exit code 1.
One or more batch tasks failed:
Message: Batch task protection-get failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1).
2025-06-18T14:56:11.363Z INFO Initialising the bundled nrfutil device
2025-06-18T14:56:11.383Z DEBUG Application data folder: C:\Users\abdukhair\AppData\Roaming\nrfconnect\pc-nrfconnect-serial-terminal
2025-06-18T14:56:11.442Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:11.442Z DEBUG App pc-nrfconnect-serial-terminal v1.5.0 (official)
2025-06-18T14:56:11.442Z DEBUG App path: C:\Users\abdukhair\.nrfconnect-apps\node_modules\pc-nrfconnect-serial-terminal
2025-06-18T14:56:11.442Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
2025-06-18T14:56:11.442Z DEBUG nRFConnect path: C:\Users\abdukhair\AppData\Local\Programs\nrfconnect\resources\app.asar
2025-06-18T14:56:11.442Z DEBUG HomeDir: C:\Users\abdukhair
2025-06-18T14:56:11.442Z DEBUG TmpDir: C:\Users\ABDUKH~1\AppData\Local\Temp
2025-06-18T14:56:11.563Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:12.321Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:12.322Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:12.337Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:12.462Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-06-18T14:56:12.543Z INFO Using nrfutil-device version: 2.10.2
2025-06-18T14:56:12.543Z INFO Using nrf-device-lib version: 0.17.71
2025-06-18T14:56:12.544Z INFO Using nrf-probe version: 0.38.0
2025-06-18T14:56:12.544Z INFO Using JLink version: JLink_V8.34
2025-06-18T14:56:12.544Z INFO Your version of SEGGER J-Link (8.34) is newer than the one this app was tested with (8.18). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
2025-06-18T14:56:12.598Z INFO Getting serial port options from the persistent store for 001052034638.pc-nrfconnect-serial-terminal
2025-06-18T14:56:12.598Z INFO Device connected with the serial number 001052034638
2025-06-18T14:56:12.599Z DEBUG Sending event "serial-terminal: device connected"
2025-06-18T14:56:13.309Z INFO Selecting device with the serial number 001052034638
2025-06-18T14:56:13.327Z DEBUG Sending event "serial-terminal: running nrfutil device"
2025-06-18T14:56:13.871Z ERROR Error: Failed with exit code 1.
2025-06-18T14:56:13.872Z INFO Selected device with the serial number 001052034638
2025-06-18T14:56:13.874Z DEBUG Sending event "serial-terminal: device selected"
2025-06-18T14:56:13.878Z INFO Opened port with options: {"baudRate":115200,"path":"COM26"}
2025-06-18T14:56:13.891Z INFO Get terminal settings from the persistent store for 001052034638.vCom-0.TerminalSettings
2025-07-04T07_51_50.328Z.log
[2025-Jul-07 08:53:47] [debug] --------------------------------------------------------------------------------
[2025-Jul-07 08:53:47] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe -s 1052034638 -f nrf91 --recover --log
[2025-Jul-07 08:53:47] [debug] nrfjprog version 10.24.2 external
[2025-Jul-07 08:53:47] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2025-Jul-07 08:53:47] [ info] Library loaded, loading member functions.
[2025-Jul-07 08:53:47] [ info] Member functions succesfully loaded.
[2025-Jul-07 08:53:47] [debug] [ Client] - open
[2025-Jul-07 08:53:47] [debug] [ Client] - start
[2025-Jul-07 08:53:47] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence a8e83119-06c2-478c-aecc-7a476b91f0fa.
[2025-Jul-07 08:53:47] [trace] [ Client] - Command open executed for 66 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [ Client] - config
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2025-Jul-07 08:53:47] [debug] [  JLink] - Logger sink registered in JLink logger
[2025-Jul-07 08:53:47] [debug] [  nRF91] - open
[2025-Jul-07 08:53:47] [debug] [  nRF91] - just_check_family
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - open_dll
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2025-Jul-07 08:53:47] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V834\JLink_x64.dll.
[2025-Jul-07 08:53:47] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2025-Jul-07 08:53:47] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2025-Jul-07 08:53:47] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Set batch mode
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - dll_version
[2025-Jul-07 08:53:47] [ info] [SeggerBackend] - Segger dll version 8.34.  loaded.
[2025-Jul-07 08:53:47] [debug] [ Client] - enum_emu_snr
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [  nRF91] - config
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - enum_emu_snr
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command config executed for 5 milliseconds with result 0
[2025-Jul-07 08:53:47] [trace] [ Client] - Command enum_emu_con_info executed for 14 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [ Client] - connect_to_emu_with_snr
[2025-Jul-07 08:53:47] [debug] [  nRF91] - enum_emu_con_info
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - is_connected_to_emu
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - enum_emu_con_info
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command enum_emu_con_info executed for 5 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [  nRF91] - connect_to_emu_with_snr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_get_num_emus
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Segger logging enabled.
[2025-Jul-07 08:53:47] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr  1 2025 10:13:35
[2025-Jul-07 08:53:47] [trace] [  JLink] - Hardware: V1.00
[2025-Jul-07 08:53:47] [trace] [  JLink] - S/N: 1052034638
[2025-Jul-07 08:53:47] [trace] [  JLink] - OEM: SEGGER
[2025-Jul-07 08:53:47] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2025-Jul-07 08:53:47] [trace] [  JLink] - Bootloader: 2021 May 18
[2025-Jul-07 08:53:47] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2025-Jul-07 08:53:47] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2025-Jul-07 08:53:47] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2025-Jul-07 08:53:47] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2025-Jul-07 08:53:47] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V834\JLinkGUIServer.exe
[2025-Jul-07 08:53:47] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V834\JLinkGUIServer.exe
[2025-Jul-07 08:53:47] [trace] [ Client] - Command connect_to_emu_with_snr executed for 93 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [ Client] - read_connected_emu_snr
[2025-Jul-07 08:53:47] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [ Client] - recover
[2025-Jul-07 08:53:47] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.34 "
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 61.956ms returns "O.K."
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_HasError()
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_Lock()
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.001ms returns 0x01
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.002ms returns 0x00
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.003ms returns 0x00
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.008ms returns 0
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.660ms returns 0x00
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2025-Jul-07 08:53:47] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.007ms
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.112ms
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_GetSpeed()
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.003ms returns 2000
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_GetSN()
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.003ms returns 1052034638
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.004ms
[2025-Jul-07 08:53:47] [debug] [  nRF91] - read_device_family
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 91 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [  nRF91] - read_connected_emu_snr
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_IsOpen()
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.013ms returns 0x01
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - read_connected_emu_snr
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [  nRF91] - recover
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.006ms returns 0x01
[2025-Jul-07 08:53:47] [debug] [  nRF91] - just_recover
[2025-Jul-07 08:53:47] [debug] [  nRF91] - Just_enable_coprocessor
[2025-Jul-07 08:53:47] [debug] [  nRF91] - Just_is_eraseprotect_enabled
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - read_access_port_register
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_read_access_port_register
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - coresight_configure
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.335ms returns 0
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 102.352ms returns 0
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - read_debug_port_idr
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - read_debug_port_register
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.951ms returns -1
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_abort_debug_action
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.846ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.946ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.952ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.825ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.820ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.858ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.724ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.818ms returns -1
[2025-Jul-07 08:53:47] [error] [ Client] - Encountered error -21: Command recover executed for 141 milliseconds with result -21
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.762ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.754ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.639ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.676ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.591ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.529ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.727ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.657ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.535ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.531ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.545ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.561ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.478ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.543ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.624ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.645ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.567ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.503ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.518ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.811ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.526ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.615ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.485ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.651ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.603ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.630ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.542ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.587ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.499ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.533ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.550ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.097ms
[2025-Jul-07 08:53:47] [error] [ Worker] - An unknown error.
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command recover executed for 132 milliseconds with result -21
[2025-Jul-07 08:53:47] [debug] [  nRF91] - close
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - close
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - disconnect_from_emu
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - is_connected_to_device
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_IsConnected()
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.007ms returns FALSE
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.655ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.560ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.564ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.520ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.539ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.547ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.586ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.548ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.558ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.544ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.588ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.555ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.552ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.621ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.664ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.510ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.534ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.731ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.585ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.741ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.596ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.549ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.554ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.541ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.598ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.522ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.617ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.619ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.638ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.608ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.551ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.703ms returns -1
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.570ms returns -1
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2025-Jul-07 08:53:47] [trace] [  JLink] - - 0.071ms
[2025-Jul-07 08:53:47] [trace] [  JLink] - JLINK_Close()
[2025-Jul-07 08:53:47] [debug] [SeggerBackend] - Segger Backend closed.
[2025-Jul-07 08:53:47] [debug] [  nRF91] - nRF family DLL closed
[2025-Jul-07 08:53:47] [trace] [ Client] - Command close executed for 93 milliseconds with result 0
[2025-Jul-07 08:53:47] [debug] [ Client] - terminate
[2025-Jul-07 08:53:47] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command close executed for 91 milliseconds with result 0
[2025-Jul-07 08:53:47] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:47] [trace] [ Worker] - Executed 8 commands for 329 milliseconds
[2025-Jul-07 08:53:47] [debug] [ Client] - Worker process exited with code: 0
[2025-Jul-07 08:53:47] [debug] [ Client] - Child process terminated with result 0
[2025-Jul-07 08:53:47] [trace] [ Client] - Executed 8 commands for 422 milliseconds
[2025-Jul-07 08:53:07] [debug] --------------------------------------------------------------------------------
[2025-Jul-07 08:53:07] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe -s 1052034638 -f nrf53 --recover --log
[2025-Jul-07 08:53:07] [debug] nrfjprog version 10.24.2 external
[2025-Jul-07 08:53:07] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2025-Jul-07 08:53:07] [ info] Library loaded, loading member functions.
[2025-Jul-07 08:53:07] [ info] Member functions succesfully loaded.
[2025-Jul-07 08:53:07] [debug] [ Client] - open
[2025-Jul-07 08:53:07] [debug] [ Client] - start
[2025-Jul-07 08:53:07] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence a07e5542-16ec-4fbd-b705-4855452c8772.
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2025-Jul-07 08:53:07] [debug] [  JLink] - Logger sink registered in JLink logger
[2025-Jul-07 08:53:07] [debug] [  nRF53] - open
[2025-Jul-07 08:53:07] [debug] [  nRF53] - just_check_family
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - open_dll
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2025-Jul-07 08:53:07] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V834\JLink_x64.dll.
[2025-Jul-07 08:53:07] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2025-Jul-07 08:53:07] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Set batch mode
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - dll_version
[2025-Jul-07 08:53:07] [ info] [SeggerBackend] - Segger dll version 8.34.  loaded.
[2025-Jul-07 08:53:07] [trace] [ Client] - Command open executed for 39 milliseconds with result 0
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [ Client] - config
[2025-Jul-07 08:53:07] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [ Client] - enum_emu_snr
[2025-Jul-07 08:53:07] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [  nRF53] - config
[2025-Jul-07 08:53:07] [debug] [ Client] - connect_to_emu_with_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - enum_emu_snr
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [  nRF53] - enum_emu_con_info
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - is_connected_to_emu
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - enum_emu_con_info
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [  nRF53] - connect_to_emu_with_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_get_num_emus
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Segger logging enabled.
[2025-Jul-07 08:53:07] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr  1 2025 10:13:35
[2025-Jul-07 08:53:07] [trace] [  JLink] - Hardware: V1.00
[2025-Jul-07 08:53:07] [trace] [  JLink] - S/N: 1052034638
[2025-Jul-07 08:53:07] [trace] [  JLink] - OEM: SEGGER
[2025-Jul-07 08:53:07] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2025-Jul-07 08:53:07] [trace] [  JLink] - Bootloader: 2021 May 18
[2025-Jul-07 08:53:07] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2025-Jul-07 08:53:07] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2025-Jul-07 08:53:07] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2025-Jul-07 08:53:07] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2025-Jul-07 08:53:07] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V834\JLinkGUIServer.exe
[2025-Jul-07 08:53:07] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V834\JLinkGUIServer.exe
[2025-Jul-07 08:53:07] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.34 "
[2025-Jul-07 08:53:07] [trace] [ Client] - Command connect_to_emu_with_snr executed for 127 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [ Client] - read_connected_emu_snr
[2025-Jul-07 08:53:07] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [ Client] - recover
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 83.080ms returns "O.K."
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_HasError()
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_Lock()
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.001ms returns 0x01
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.002ms returns 0x00
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.003ms returns 0x00
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.012ms returns 0
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.795ms returns 0x00
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2025-Jul-07 08:53:07] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.010ms
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.111ms
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_GetSpeed()
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.003ms returns 2000
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_GetSN()
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.004ms returns 1052034638
[2025-Jul-07 08:53:07] [debug] [  nRF53] - read_device_family
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 112 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [  nRF53] - read_connected_emu_snr
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_IsOpen()
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.015ms returns 0x01
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - read_connected_emu_snr
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.006ms
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:07] [debug] [  nRF53] - recover
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.005ms returns 0x01
[2025-Jul-07 08:53:07] [debug] [  nRF53] - just_recover
[2025-Jul-07 08:53:07] [debug] [  nRF53] - Just_is_eraseprotect_enabled
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - read_access_port_register
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_read_access_port_register
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - coresight_configure
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.231ms returns 0
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 102.409ms returns 0
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - read_debug_port_idr
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - read_debug_port_register
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.728ms returns -1
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_abort_debug_action
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.702ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.800ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.782ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.773ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.803ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.626ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.809ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.784ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.802ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.711ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.620ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.597ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.710ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.622ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.632ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.651ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.657ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.671ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.658ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.790ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.696ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.628ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.664ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.672ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.731ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.681ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.705ms returns -1
[2025-Jul-07 08:53:07] [error] [ Client] - Encountered error -21: Command recover executed for 139 milliseconds with result -21
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.771ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.670ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.665ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.578ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.652ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.679ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.667ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.685ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.694ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.666ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.669ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.746ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.163ms
[2025-Jul-07 08:53:07] [error] [ Worker] - An unknown error.
[2025-Jul-07 08:53:07] [trace] [ Worker] - Command recover executed for 134 milliseconds with result -21
[2025-Jul-07 08:53:07] [debug] [  nRF53] - close
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.012ms returns 0x01
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - close
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - disconnect_from_emu
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - is_connected_to_device
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_IsConnected()
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.006ms returns FALSE
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.562ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.580ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.587ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.650ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.633ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.703ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.637ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.713ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.700ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.602ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.523ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.634ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.545ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.512ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.559ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.823ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.557ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.693ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.614ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.645ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.558ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.598ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.609ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.577ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.532ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.533ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.627ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.594ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.565ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.553ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.550ms returns -1
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.778ms returns -1
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2025-Jul-07 08:53:07] [trace] [  JLink] - - 0.091ms
[2025-Jul-07 08:53:07] [trace] [  JLink] - JLINK_Close()
[2025-Jul-07 08:53:07] [debug] [SeggerBackend] - Segger Backend closed.
[2025-Jul-07 08:53:07] [debug] [  nRF53] - nRF family DLL closed
[2025-Jul-07 08:53:08] [trace] [ Worker] - Command close executed for 93 milliseconds with result 0
[2025-Jul-07 08:53:08] [trace] [ Client] - Command close executed for 109 milliseconds with result 0
[2025-Jul-07 08:53:08] [debug] [ Client] - terminate
[2025-Jul-07 08:53:08] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:08] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2025-Jul-07 08:53:08] [trace] [ Worker] - Executed 8 commands for 346 milliseconds
[2025-Jul-07 08:53:08] [debug] [ Client] - Worker process exited with code: 0
[2025-Jul-07 08:53:08] [debug] [ Client] - Child process terminated with result 0
[2025-Jul-07 08:53:08] [trace] [ Client] - Executed 8 commands for 444 milliseconds
    log says you are using JLink version 8.34. Can you try v8.18 instead? It is the recommended version to use and have been tested by Nordic.
    Thank you for the quick feedback.
    I have reinstalled JLink with the suggested version v8.18.
    I am still facing the same issue
    PS C:\Program Files\SEGGER\JLink> .\JLink.exe -device nrf9151_xxca -if SWD -speed 1000
    SEGGER J-Link Commander V8.18 (Compiled Mar  5 2025 14:43:35)
    DLL version V8.18, compiled Mar  5 2025 14:42:43
    Connecting to J-Link via USB...O.K.
    Hardware version: V1.00
    J-Link uptime (since boot): 0d 00h 09m 22s
    S/N: 1052034638
    License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    VTref=3.300V
    Type "connect" to establish a target connection, '?' for help
    J-Link>connect
    Device "NRF9151_XXCA" selected.
    Connecting to target via SWD
    ConfigTargetSettings() start
    ---Setting ROM table---
    ConfigTargetSettings() end - Took 734us
    InitTarget() start
    InitTarget() end - Took 112ms
    ConfigTargetSettings() end - Took 16.9ms
    InitTarget() start
    InitTarget() end - Took 9.83ms
    Error occurred: Could not connect to the target device.
    I also added logs
    [2025-Jul-07 14:15:58] [debug] --------------------------------------------------------------------------------
    [2025-Jul-07 14:15:58] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --snr 1052034638 -f nrf91 --recover --log
    [2025-Jul-07 14:15:58] [debug] nrfjprog version 10.24.2 external
    [2025-Jul-07 14:15:58] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-Jul-07 14:15:58] [ info] Library loaded, loading member functions.
    [2025-Jul-07 14:15:58] [ info] Member functions succesfully loaded.
    [2025-Jul-07 14:15:58] [debug] [ Client] - open
    [2025-Jul-07 14:15:58] [debug] [ Client] - start
    [2025-Jul-07 14:15:58] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence eb9094e8-e759-4a60-882a-75daa9b44d29.
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command open executed for 61 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-Jul-07 14:15:59] [debug] [ Client] - config
    [2025-Jul-07 14:15:59] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - open
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - just_check_family
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - open_dll
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-Jul-07 14:15:59] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
    [2025-Jul-07 14:15:59] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-Jul-07 14:15:59] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Set batch mode
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - dll_version
    [2025-Jul-07 14:15:59] [ info] [SeggerBackend] - Segger dll version 8.18.  loaded.
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - enum_emu_snr
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - config
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - enum_emu_snr
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command config executed for 6 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - enum_emu_con_info
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr  1 2025 10:13:35
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Hardware: V1.00
    [2025-Jul-07 14:15:59] [trace] [  JLink] - S/N: 1052034638
    [2025-Jul-07 14:15:59] [trace] [  JLink] - OEM: SEGGER
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Bootloader: 2021 May 18
    [2025-Jul-07 14:15:59] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-Jul-07 14:15:59] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink\JLinkGUIServer.exe
    [2025-Jul-07 14:15:59] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink\JLinkGUIServer.exe
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command connect_to_emu_with_snr executed for 126 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - read_connected_emu_snr
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - recover
    [2025-Jul-07 14:15:59] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.18 "
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 83.563ms returns "O.K."
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_HasError()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_Lock()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.002ms returns 0x01
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.001ms returns 0x00
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.003ms returns 0x00
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.012ms returns 0
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.844ms returns 0x00
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.104ms
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.008ms returns 2000
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_GetSN()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.004ms returns 1052034638
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.006ms
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - read_device_family
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 115 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - read_connected_emu_snr
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_IsOpen()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.008ms returns 0x01
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - read_connected_emu_snr
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - recover
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.007ms returns 0x01
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - just_recover
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - Just_enable_coprocessor
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - Just_is_eraseprotect_enabled
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - read_access_port_register
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - coresight_configure
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.244ms returns 0
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 102.093ms returns 0
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - read_debug_port_register
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.932ms returns -1
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.832ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.858ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.825ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.835ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.816ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.837ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.765ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.859ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.752ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.761ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.553ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.643ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.648ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.720ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.631ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.604ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.802ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.728ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.701ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.615ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.554ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.607ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.538ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.658ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.596ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.574ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.682ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.601ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.521ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.598ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.709ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.619ms returns -1
    [2025-Jul-07 14:15:59] [error] [ Client] - Encountered error -21: Command recover executed for 143 milliseconds with result -21
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.558ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.590ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.595ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.501ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.520ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.594ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.546ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.145ms
    [2025-Jul-07 14:15:59] [error] [ Worker] - An unknown error.
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command recover executed for 133 milliseconds with result -21
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - close
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - close
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - is_connected_to_device
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_IsConnected()
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.002ms returns FALSE
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.661ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.694ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.584ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.534ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.641ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.659ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.713ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.602ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.568ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.613ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.603ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.673ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.676ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.552ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.565ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.597ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.563ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.530ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.472ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.513ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.468ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.621ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.465ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.515ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.526ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.482ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.517ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.527ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.548ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.539ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.592ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.571ms returns -1
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.586ms returns -1
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2025-Jul-07 14:15:59] [trace] [  JLink] - - 0.116ms
    [2025-Jul-07 14:15:59] [trace] [  JLink] - JLINK_Close()
    [2025-Jul-07 14:15:59] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-Jul-07 14:15:59] [debug] [  nRF91] - nRF family DLL closed
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command close executed for 76 milliseconds with result 0
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command close executed for 93 milliseconds with result 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - terminate
    [2025-Jul-07 14:15:59] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:59] [trace] [ Worker] - Executed 8 commands for 341 milliseconds
    [2025-Jul-07 14:15:59] [debug] [ Client] - Worker process exited with code: 0
    [2025-Jul-07 14:15:59] [debug] [ Client] - Child process terminated with result 0
    [2025-Jul-07 14:15:59] [trace] [ Client] - Executed 8 commands for 453 milliseconds
    [2025-Jul-07 14:14:03] [debug] --------------------------------------------------------------------------------
    [2025-Jul-07 14:14:03] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --snr 1052034638 -f nrf53 --recover --log
    [2025-Jul-07 14:14:03] [debug] nrfjprog version 10.24.2 external
    [2025-Jul-07 14:14:03] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-Jul-07 14:14:03] [ info] Library loaded, loading member functions.
    [2025-Jul-07 14:14:03] [ info] Member functions succesfully loaded.
    [2025-Jul-07 14:14:03] [debug] [ Client] - open
    [2025-Jul-07 14:14:03] [debug] [ Client] - start
    [2025-Jul-07 14:14:03] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence c1fc8ec9-c616-4972-ae78-ef513044c540.
    [2025-Jul-07 14:14:03] [trace] [ Client] - Command open executed for 48 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [ Client] - config
    [2025-Jul-07 14:14:03] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-Jul-07 14:14:03] [debug] [ Client] - enum_emu_snr
    [2025-Jul-07 14:14:03] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - open
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - just_check_family
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - open_dll
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-Jul-07 14:14:03] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
    [2025-Jul-07 14:14:03] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-Jul-07 14:14:03] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - Set batch mode
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - dll_version
    [2025-Jul-07 14:14:03] [ info] [SeggerBackend] - Segger dll version 8.18.  loaded.
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - config
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - enum_emu_snr
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
    [2025-Jul-07 14:14:03] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - enum_emu_con_info
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Command enum_emu_con_info executed for 5 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - close
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - close
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-Jul-07 14:14:03] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-Jul-07 14:14:03] [debug] [  nRF53] - nRF family DLL closed
    [2025-Jul-07 14:14:03] [trace] [ Client] - Command close executed for 30 milliseconds with result 0
    [2025-Jul-07 14:14:03] [debug] [ Client] - terminate
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Command close executed for 14 milliseconds with result 0
    [2025-Jul-07 14:14:03] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:14:03] [trace] [ Worker] - Executed 5 commands for 25 milliseconds
    [2025-Jul-07 14:14:03] [debug] [ Client] - Worker process exited with code: 0
    [2025-Jul-07 14:14:03] [debug] [ Client] - Child process terminated with result 0
    [2025-Jul-07 14:14:03] [trace] [ Client] - Executed 5 commands for 108 milliseconds
    [2025-Jul-07 14:15:11] [debug] --------------------------------------------------------------------------------
    [2025-Jul-07 14:15:11] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --snr 1052034638 -f nrf53 --recover --log
    [2025-Jul-07 14:15:11] [debug] nrfjprog version 10.24.2 external
    [2025-Jul-07 14:15:11] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-Jul-07 14:15:11] [ info] Library loaded, loading member functions.
    [2025-Jul-07 14:15:11] [ info] Member functions succesfully loaded.
    [2025-Jul-07 14:15:11] [debug] [ Client] - open
    [2025-Jul-07 14:15:11] [debug] [ Client] - start
    [2025-Jul-07 14:15:11] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 0856d200-119a-4e13-9e87-8592431f52b7.
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command open executed for 61 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-Jul-07 14:15:12] [debug] [ Client] - config
    [2025-Jul-07 14:15:12] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - open
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - just_check_family
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - open_dll
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-Jul-07 14:15:12] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
    [2025-Jul-07 14:15:12] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-Jul-07 14:15:12] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Set batch mode
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - dll_version
    [2025-Jul-07 14:15:12] [ info] [SeggerBackend] - Segger dll version 8.18.  loaded.
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command config executed for 14 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [ Client] - enum_emu_snr
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - config
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - enum_emu_snr
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [ Client] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - enum_emu_con_info
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr  1 2025 10:13:35
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Hardware: V1.00
    [2025-Jul-07 14:15:12] [trace] [  JLink] - S/N: 1052034638
    [2025-Jul-07 14:15:12] [trace] [  JLink] - OEM: SEGGER
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Bootloader: 2021 May 18
    [2025-Jul-07 14:15:12] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-Jul-07 14:15:12] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink\JLinkGUIServer.exe
    [2025-Jul-07 14:15:12] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink\JLinkGUIServer.exe
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command connect_to_emu_with_snr executed for 109 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.18 "
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 71.550ms returns "O.K."
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_HasError()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_Lock()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.001ms returns 0x01
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.000ms returns 0x00
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.002ms returns 0x00
    [2025-Jul-07 14:15:12] [debug] [ Client] - read_connected_emu_snr
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.010ms returns 0
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 2.139ms returns 0x00
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.008ms
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.065ms
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.004ms returns 2000
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_GetSN()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.002ms returns 1052034638
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.003ms
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - read_device_family
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 99 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - read_connected_emu_snr
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_IsOpen()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.010ms returns 0x01
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - read_connected_emu_snr
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [ Client] - recover
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - recover
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.015ms returns 0x01
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - just_recover
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - Just_is_eraseprotect_enabled
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - read_access_port_register
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - coresight_configure
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.453ms returns 0
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 101.946ms returns 0
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - read_debug_port_register
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.869ms returns -1
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.708ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.777ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.820ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.809ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.725ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.769ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.688ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.664ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.684ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.490ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.554ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.568ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.531ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.581ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.549ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.636ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.574ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.586ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.595ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.575ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.563ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.680ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.580ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.536ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.598ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.539ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.610ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.543ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.623ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.663ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.512ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.561ms returns -1
    [2025-Jul-07 14:15:12] [error] [ Client] - Encountered error -21: Command recover executed for 143 milliseconds with result -21
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.672ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.661ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.525ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.540ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.639ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.597ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.117ms
    [2025-Jul-07 14:15:12] [error] [ Worker] - An unknown error.
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command recover executed for 131 milliseconds with result -21
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - close
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.005ms returns 0x01
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - close
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - is_connected_to_device
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_IsConnected()
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.002ms returns FALSE
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.498ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.510ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.518ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.573ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.657ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.571ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.566ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.584ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.616ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.534ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.578ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.541ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.517ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.502ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.542ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.651ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.515ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.706ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.558ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.565ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.557ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.626ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.602ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.526ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.462ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.505ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.547ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.473ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.599ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.587ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.596ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.550ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.511ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.523ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.503ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.600ms returns -1
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.548ms returns -1
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2025-Jul-07 14:15:12] [trace] [  JLink] - - 0.045ms
    [2025-Jul-07 14:15:12] [trace] [  JLink] - JLINK_Close()
    [2025-Jul-07 14:15:12] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-Jul-07 14:15:12] [debug] [  nRF53] - nRF family DLL closed
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command close executed for 62 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command close executed for 78 milliseconds with result 0
    [2025-Jul-07 14:15:12] [debug] [ Client] - terminate
    [2025-Jul-07 14:15:12] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jul-07 14:15:12] [trace] [ Worker] - Executed 8 commands for 304 milliseconds
    [2025-Jul-07 14:15:12] [debug] [ Client] - Worker process exited with code: 0
    [2025-Jul-07 14:15:12] [debug] [ Client] - Child process terminated with result 0
    [2025-Jul-07 14:15:12] [trace] [ Client] - Executed 8 commands for 435 milliseconds
    2025-07-07T12:28:44.700Z INFO Initialising the bundled nrfutil device
    2025-07-07T12:28:44.724Z DEBUG Application data folder: C:\Users\abdukhair\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2025-07-07T12:28:44.754Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:44.754Z DEBUG App pc-nrfconnect-programmer v4.6.0 (official)
    2025-07-07T12:28:44.754Z DEBUG App path: C:\Users\abdukhair\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2025-07-07T12:28:44.754Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
    2025-07-07T12:28:44.754Z DEBUG nRFConnect path: C:\Users\abdukhair\AppData\Local\Programs\nrfconnect\resources\app.asar
    2025-07-07T12:28:44.754Z DEBUG HomeDir: C:\Users\abdukhair
    2025-07-07T12:28:44.754Z DEBUG TmpDir: C:\Users\ABDUKH~1\AppData\Local\Temp
    2025-07-07T12:28:44.846Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:45.136Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:45.148Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:45.186Z INFO Using the bundled core version for nrfutil device: 8.0.0
    2025-07-07T12:28:45.205Z INFO Using nrfutil-device version: 2.10.2
    2025-07-07T12:28:45.205Z INFO Using nrf-device-lib version: 0.17.71
    2025-07-07T12:28:45.205Z INFO Using nrf-probe version: 0.38.0
    2025-07-07T12:28:45.205Z INFO Using JLink version: JLink_V8.18
    2025-07-07T12:28:45.277Z INFO Getting serial port options from the persistent store for 001052034638.pc-nrfconnect-programmer
    2025-07-07T12:28:45.278Z INFO Device connected with the serial number 001052034638
    2025-07-07T12:28:45.279Z DEBUG Sending event "programmer: device connected"
    2025-07-07T12:28:46.634Z INFO Selecting device with the serial number 001052034638
    2025-07-07T12:28:46.652Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:47.185Z ERROR Error: Failed with exit code 1.
    One or more device info tasks failed:
     * 1052034638: Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1) (Generic).
    Message: Operation device-info failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1).
    2025-07-07T12:28:47.185Z INFO Selected device with the serial number 001052034638
    2025-07-07T12:28:47.185Z INFO Using nrfutil device to communicate with target via JLink
    2025-07-07T12:28:47.201Z DEBUG Sending event "programmer: device selected"
    2025-07-07T12:28:47.201Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:47.281Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:28:47.594Z INFO Reading readback protection status for Application core
    2025-07-07T12:28:47.594Z INFO Reading readback protection status for Application core 0%
    2025-07-07T12:28:47.757Z ERROR Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
    2025-07-07T12:28:47.769Z ERROR Error: Failed with exit code 1.
    One or more batch tasks failed:
    Message: Batch task protection-get failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1).
    2025-07-07T12:28:47.770Z ERROR Error: Failed with exit code 1.
    2025-07-07T12:29:24.129Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:29:24.655Z ERROR Error: Failed with exit code 1.
    2025-07-07T12:29:24.668Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:29:24.782Z DEBUG Sending event "programmer: running nrfutil device"
    2025-07-07T12:29:25.103Z INFO Reading readback protection status for Application core
    2025-07-07T12:29:25.103Z INFO Reading readback protection status for Application core 0%
    2025-07-07T12:29:25.245Z ERROR Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
    2025-07-07T12:29:25.268Z ERROR Error: Failed with exit code 1.
  • Are you able to flash and recover the DK with another working DK using a 10-pin connector?
  • Hi Hakon,
    I did not try to do that. I would like to proceed with this.
    I have couple questions regarding connections.
    1.  Locked DK (DEBUG OUT) -> Working DK (DEBUG IN)?
    2. Connect only working DK using usb to laptop?
    3. Do i need to remove nRF Current Measurement Jumper from any of the DK?
    4. Will both locked and working DK detected in laptop? nrfutil.exe device list
    5. Should i use this command to recover? nrfjprog.exe --snr 1052034638 -f nrf91 --recover --log
    No, the working DK should use the DEBUG OUT connector, and the other one I believe should use DEBUG IN.
    Both DKs should of course be powered, so if you don't have an external power supply you should connect both DKs with usb.
    That should not be necessary.
    I don't think so.
    Yes, or nrfutil.
