Update issue with bootloader chain
Hi everyone, I'm trying to set up a bootloader chain using sysbuild (NSIB → MCUboot → APP) so that MCUboot can act as an upgradable bootloader. I'm working with the nRF54L15 and followed the guides:
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_adding_sysbuild.html
https://docs.nordicsemi.com/bundle/ncs-3.0.1/page/nrf/applications/nrf_desktop/bootloader_dfu.html
With the firmware flashed, the full boot chain works fine. However, when I attempt to update the application using dfu_application.zip via the nRF Connect Device Manager, after the upload and test, the device reboots, but MCUboot can't find a bootable image.
Here's the relevant log output before and after the DFU update:
00> Booting nRF Connect SDK v3.0.1-9eb5615da66b
00> Using Zephyr OS v4.0.99-77f865b8f8d0
00> Fprotect disabled. No protection applied.
00> Attempting to boot slot 0.
00> Attempting to boot from address 0x10800.
00> I: Trying to get Firmware version
00> I: Firmware signature verified.
00> Firmware version 1
00> I: Setting monotonic counter (version: 1, slot: 0)
00> Booting (0x10800).
00> Booting MCUboot v2.1.0-dev-ae1ee57f3906
00> Using nRF Connect SDK v3.0.1-9eb5615da66b
00> I: Starting Direct-XIP bootloader
00> I: Primary slot: version=0.2.1+0
00> I: Secondary slot: version=0.2.1+0
00> I: Image 1 Primary slot: Image not found
00> I: Image 0 loaded from the primary slot
00> I: Image 1 loaded from the secondary slot
00> I: Bootloader chainload address offset: 0x2b000
00> I: Image version: v0.2.1
00> I: Jumping to the image slot
00> Booting My Application v0.2.1-475bc1ecb46c
(Connection lost)
00> I: Secondary slot: version=0.2.2+0
00> I: No slot to load for image 1
00> E: Unable to find bootable image
    I'm not sure if the nRF connec tDevice Manager application is the one you should be using. Do you see the same with the "nRF Connect" mobile application? Have you made sure that the new image has a newer version than the previous image? dfu_application.zip should work via the application. For other purposes you should use zephyr.signed.bin generated within <build/<your_app>/zephyr/zephyr.signed.bin> instead https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_sysbuild.html
    Andreas
  • Do you see the same with the "nRF Connect" mobile application?
    Yes
    Yes
    Adding more context, previously a bootloader system using direct-XIP with revert and a simple single-stage bootloader (MCUboot) was working perfectly. However, since the intention was to have an upgradable bootloader, we migrated from a single-stage to a two-stage bootloader setup, as described. To support this the following configuration were added:
    SB_CONFIG_SECURE_BOOT_APPCORE=y
    SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="${ZEPHYR_BASE}/../m_band/ota/keys/secure_boot_ed25519_priv_key.pem"
    SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=1
    SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES=y
    SB_CONFIG_SECURE_BOOT_MCUBOOT_VERSION="2.1.0+0"
    Noted, could you share the build logs and the partition map? Curious to check the application size(s) to see if there's any mismatches in the partition sizes and application sizes.
    Are you using a static partitioning map? If so, please share that as well
    Andreas
  • Build logs:
    -- west build: making build dir /home/tcunha/zp/m_band/app/build pristine
    -- Found Python3: /home/tcunha/miniconda3/bin/python (found suitable version "3.12.8", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /home/tcunha/.cache/zephyr
    -- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
    -- Board: mband, Revision: v1, qualifiers: nrf54l15/cpuapp
    Parsing /home/tcunha/zp/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/tcunha/zp/m_band/app/build/_sysbuild/empty.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/build/_sysbuild/empty.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/sysbuild_release.conf'
    Configuration saved to '/home/tcunha/zp/m_band/app/build/zephyr/.config'
    Kconfig header saved to '/home/tcunha/zp/m_band/app/build/_sysbuild/autoconf.h'
    -- SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES: y
    -- DEFAULT_IMAGE: app
    -- SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES is enabled
    -- CONFIG_UPDATEABLE_IMAGE_NUMBER:
       * Running CMake for mcuboot *
    -- Application: /home/tcunha/zp/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.31.4
    -- Zephyr version: 4.0.99 (/home/tcunha/zp/zephyr)
    -- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
    -- Found host-tools: zephyr 0.16.3 (/home/tcunha/zephyr-sdk-0.16.3)
    -- Found toolchain: zephyr 0.16.3 (/home/tcunha/zephyr-sdk-0.16.3)
    -- Found Dtc: /home/tcunha/zephyr-sdk-0.16.3/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: /home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp_v1.overlay
    -- Found devicetree overlay: /home/tcunha/zp/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/mcuboot/zephyr/dts.cmake
    Parsing /home/tcunha/zp/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp_defconfig'
    Merged configuration '/home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp_v1_defconfig'
    Merged configuration '/home/tcunha/zp/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/sysbuild/mcuboot_release.conf'
    Merged configuration '/home/tcunha/zp/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/home/tcunha/zp/m_band/app/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/home/tcunha/zp/m_band/app/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/tcunha/zephyr-sdk-0.16.3/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/tcunha/zephyr-sdk-0.16.3/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Configuring done (7.2s)
    -- Generating done (0.4s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/mcuboot
       * Running CMake for b0 *
    -- Application: /home/tcunha/zp/nrf/samples/bootloader
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/b0/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/b0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/b0/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/b0/zephyr/dts.cmake
    Parsing /home/tcunha/zp/zephyr/Kconfig
    Merged configuration '/home/tcunha/zp/nrf/samples/bootloader/prj.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/sysbuild/b0_release.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/build/b0/zephyr/.config.sysbuild'
    Configuration saved to '/home/tcunha/zp/m_band/app/build/b0/zephyr/.config'
    Kconfig header saved to '/home/tcunha/zp/m_band/app/build/b0/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done (9.5s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/b0
       * Running CMake for app *
    -- Application: /home/tcunha/zp/m_band/app
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/app/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/app/zephyr/dts.cmake
    Parsing /home/tcunha/zp/m_band/app/Kconfig
    Merged configuration '/home/tcunha/zp/m_band/app/prj.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/sysbuild/app_release.conf'
    Merged configuration '/home/tcunha/zp/m_band/app/build/app/zephyr/.config.sysbuild'
    Configuration saved to '/home/tcunha/zp/m_band/app/build/app/zephyr/.config'
    Kconfig header saved to '/home/tcunha/zp/m_band/app/build/app/zephyr/include/generated/zephyr/autoconf.h'
    -- Including signing script: /home/tcunha/zp/nrf/cmake/sysbuild/image_signing.cmake
    -- Found Nanopb: /home/tcunha/zp/modules/lib/nanopb
    -- Found protoc: /home/tcunha/zp/modules/lib/nanopb/generator/protoc
    -- Configuring done (8.6s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/app
       * Running CMake for s1_image *
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/s1_image/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/s1_image/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/s1_image/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/s1_image/zephyr/dts.cmake
    -- Configuring done (6.6s)
    -- Generating done (0.2s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/s1_image
       * Running CMake for mcuboot_secondary_app *
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/dts.cmake
    -- Configuring done (6.9s)
    -- Generating done (0.5s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app
    -- Found partition manager static configuration : /home/tcunha/zp/m_band/app/pm_static_release.yml
    Partition 'b0' is not included in the dynamic resolving since it is statically defined.
    Partition 'b0_container' is not included in the dynamic resolving since it is statically defined.
    Partition 's0' is not included in the dynamic resolving since it is statically defined.
    Partition 's0_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 's0_image' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 's1' is not included in the dynamic resolving since it is statically defined.
    Partition 's1_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 's1_image' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'app_image' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
    -- Configuring done (47.7s)
    -- Generating done (0.1s)
    [0/69] Creating public key from private key used for signing
    [25/69] No configure step for 'mcuboot_secondary_app'
    [26/69] Performing build step for 'app'
    [0/1] Re-running CMake...
    Loaded configuration '/home/tcunha/zp/m_band/app/build/app/zephyr/.config'
    No change to configuration in '/home/tcunha/zp/m_band/app/build/app/zephyr/.config'
    No change to Kconfig header in '/home/tcunha/zp/m_band/app/build/app/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done (6.5s)
    [1/451] Preparing syscall dependency handling
    [2/451] Generating nanopb/generator/nanopb_generator.py, nanopb/generator/proto/nanopb.proto
    [3/451] Generating ../../zephyr/include/generated/zephyr_commit.h
    [4/451] Generating ../../zephyr/include/generated/ncs_commit.h
    [5/451] Generating ../../zephyr/include/generated/app_commit.h
    [6/451] Generating ../../zephyr/include/generated/ncs_version.h
    [7/451] Generating include/generated/zephyr/app_version.h
    [8/451] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/home/tcunha/zp/zephyr), build: v4.0.99-ncs1-1
    [9/451] Generating misc/generated/syscalls_subdirs.trigger
    [10/451] Generating nanopb/generator/proto/nanopb_pb2.py
    [11/451] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [12/451] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [13/451] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [14/451] Running C++ protocol buffer compiler using nanopb plugin on src/protobuf_msg/mband.proto
    [15/451] Generating include/generated/zephyr/driver-validation.h
    [16/451] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [17/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs12.c.obj
    [18/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkparse.c.obj
    [19/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/dhm.c.obj
    [20/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pem.c.obj
    [21/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs5.c.obj
    [22/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/md.c.obj
    [23/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [24/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [25/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher.c.obj
    [26/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkwrite.c.obj
    [27/451] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [28/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [29/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum.c.obj
    [30/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum_core.c.obj
    [31/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [32/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/nist_kw.c.obj
    [33/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [34/451] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [35/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/version.c.obj
    [36/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1parse.c.obj
    [37/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [38/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/padlock.c.obj
    [39/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [40/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/constant_time.c.obj
    [41/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/base64.c.obj
    [42/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/psa_util.c.obj
    [43/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.c.obj
    [44/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [45/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.c.obj
    [46/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1write.c.obj
    [47/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/threading/threading_alt.c.obj
    [48/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/block_cipher.c.obj
    [49/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [50/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/oid.c.obj
    [51/451] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [52/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmmask.c.obj
    [53/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.c.obj
    [54/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/keyref.c.obj
    [55/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/aead.c.obj
    [56/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmdma.c.obj
    [57/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hash.c.obj
    [58/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/chachapoly.c.obj
    [59/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmac.c.obj
    [60/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/blkcipher.c.obj
    [61/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/blind.c.obj
    [62/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/mac.c.obj
    [63/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/trng.c.obj
    [64/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/interface/sxbuf/sxbufops.c.obj
    [65/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/iomem.c.obj
    [66/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/interrupts.c.obj
    [67/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/montgomery.c.obj
    [68/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed25519.c.obj
    [69/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/statuscodes.c.obj
    [70/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/cmddefs_ik.c.obj
    [71/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed448.c.obj
    [72/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/sha3.c.obj
    [73/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/cmdma_hw.c.obj
    [74/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hmac.c.obj
    [75/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ec_curves.c.obj
    [76/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecc.c.obj
    [77/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_srp.c.obj
    [78/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ba414_status.c.obj
    [79/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_modmath.c.obj
    [80/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecjpake.c.obj
    [81/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/coprime_check.c.obj
    [82/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecc.c.obj
    [83/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto.c.obj
    [84/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [85/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hkdf.c.obj
    [86/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/pkhardware_ba414e.c.obj
    [87/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/mem.c.obj
    [88/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hmac.c.obj
    [89/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519.c.obj
    [90/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/baremetal_ba414e_with_ik/pk_baremetal.c.obj
    [91/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/montgomery.c.obj
    [92/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/ikhardware.c.obj
    [93/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rndinrange.c.obj
    [94/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hash.c.obj
    [95/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/pbkdf2.c.obj
    [96/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsamgf1xor.c.obj
    [97/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sicrypto.c.obj
    [98/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519ph.c.obj
    [99/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_pkcs1v15.c.obj
    [100/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_oaep.c.obj
    [101/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sig.c.obj
    [102/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed448.c.obj
    [103/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsassa_pkcs1v15.c.obj
    [104/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/iksig.c.obj
    [105/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecdsa.c.obj
    [106/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mem_helpers.c.obj
    [107/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ec_helpers.c.obj
    [108/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/util.c.obj
    [109/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsa_keygen.c.obj
    [110/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsapss.c.obj
    [111/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecc.c.obj
    [112/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mac.c.obj
    [113/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/lib_kmu.c.obj
    [114/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/rndinrange.c.obj
    [115/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/cracen.c.obj
    [116/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/key_management.c.obj
    [117/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ed25519.c.obj
    [118/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/blkcipher.c.obj
    [119/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecdsa.c.obj
    [120/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/prng_pool.c.obj
    [121/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/kmu.c.obj
    [122/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ctr_drbg.c.obj
    [123/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/common.c.obj
    [124/451] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/cracen/libcracen_psa_driver.a
    [125/451] Linking C static library modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a
    [126/451] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [127/451] Generating include/generated/zephyr/offsets.h
    [128/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [129/451] Building C object CMakeFiles/app.dir/src/protobuf_msg/mband.pb.c.obj
    [130/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [131/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [132/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [133/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [134/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [135/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [136/451] Building C object CMakeFiles/app.dir/src/main.c.obj
    [137/451] Linking C static library app/libapp.a
    [138/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [139/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [140/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/poweroff.c.obj
    [141/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [142/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [143/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [144/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [145/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [146/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [147/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [148/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [149/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
    [150/451] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [151/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [152/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [153/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [154/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_append.c.obj
    [155/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [156/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_getnext.c.obj
    [157/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_walk.c.obj
    [158/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [159/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [160/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [161/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_rotate.c.obj
    [162/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [163/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [164/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_elem_info.c.obj
    [165/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
    [166/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [167/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [168/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [169/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb.c.obj
    [170/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [171/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [172/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [173/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [174/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [175/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sword_ir_temp_sensor/ir_temp_sensor.c.obj
    [176/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/lib/boot_banner/banner.c.obj
    [177/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sword_ktd2026/ktd2026.c.obj
    [178/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sensirion_sts4x/sts4x.c.obj
    [179/451] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [180/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [181/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/services/cts_client.c.obj
    [182/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/lib/fcb_storage_manager/fcb_storage_manager.c.obj
    [183/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/gatt_dm.c.obj
    [184/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/hci_vs_sdc.c.obj
    [185/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/host_extensions/host_extensions.c.obj
    [186/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/lib/mband_pbcodec/mband_pbcodec.c.obj
    [187/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/sensors_ble.c.obj
    [188/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/commands_ble.c.obj
    [189/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/grtc/grtc_handler.c.obj
    [190/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/ppg/ppg_app.c.obj
    [191/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/haptic/haptic_app.c.obj
    [192/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/record_storage/record_manager.c.obj
    [193/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/temperature/temperature_app.c.obj
    [194/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/bt_module.c.obj
    [195/451] Generating linker_zephyr_pre0.cmd
    [196/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/controller/sensor_config.c.obj
    [197/451] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [198/451] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [199/451] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [200/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/ktd2026/ktd2026_app.c.obj
    [201/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/interaction/interaction.c.obj
    [202/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/controller/asm.c.obj
    [203/451] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [204/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [205/451] Linking C static library zephyr/arch/common/libisr_tables.a
    [206/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/record_storage/dispatcher.c.obj
    [207/451] Linking C static library zephyr/arch/common/libarch__common.a
    [208/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/pmic/pmic.c.obj
    [209/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bmi270/bmi270.c.obj
    [210/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [211/451] Linking C static library zephyr/libzephyr.a
    [212/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [213/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [214/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [215/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [216/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [217/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [218/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [219/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [220/451] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [221/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [222/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [223/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [224/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [225/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [226/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [227/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [228/451] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [229/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [230/451] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [231/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [232/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [233/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [234/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [235/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [236/451] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [237/451] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [238/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [239/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [240/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [241/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [242/451] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [243/451] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [244/451] Building C object zephyr/lib/smf/CMakeFiles/lib__smf.dir/smf.c.obj
    [245/451] Linking C static library zephyr/lib/smf/liblib__smf.a
    [246/451] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [247/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [248/451] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [249/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [250/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [251/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [252/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_rram_partitions.c.obj
    [253/451] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [254/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [255/451] Building C object zephyr/subsys/mgmt/mcumgr/util/CMakeFiles/subsys__mgmt__mcumgr__util.dir/src/zcbor_bulk.c.obj
    [256/451] Linking C static library zephyr/subsys/mgmt/mcumgr/util/libsubsys__mgmt__mcumgr__util.a
    [257/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/nrf54l/soc.c.obj
    [258/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/poweroff.c.obj
    [259/451] Building C object zephyr/subsys/mgmt/mcumgr/smp/CMakeFiles/subsys__mgmt__mcumgr__smp.dir/src/smp.c.obj
    [260/451] Linking C static library zephyr/subsys/mgmt/mcumgr/smp/libsubsys__mgmt__mcumgr__smp.a
    [261/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/zephyr_basic/CMakeFiles/subsys__mgmt__mcumgr__grp__zephyr_basic.dir/src/basic_mgmt.c.obj
    [262/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/zephyr_basic/libsubsys__mgmt__mcumgr__grp__zephyr_basic.a
    [263/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_util.c.obj
    [264/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt.c.obj
    [265/451] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [266/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [267/451] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [268/451] Linking C static library zephyr/soc/soc/nrf54l15/libsoc__nordic.a
    [269/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
    [270/451] Building C object zephyr/subsys/mgmt/mcumgr/mgmt/CMakeFiles/subsys__mgmt__mcumgr__mgmt.dir/src/mgmt.c.obj
    [271/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj
    [272/451] Linking C static library zephyr/subsys/mgmt/mcumgr/mgmt/libsubsys__mgmt__mcumgr__mgmt.a
    [273/451] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_xoshiro128.c.obj
    [274/451] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [275/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_state.c.obj
    [276/451] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [277/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/libsubsys__mgmt__mcumgr__grp__img_mgmt.a
    [278/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
    [279/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp.c.obj
    [280/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__os_mgmt.dir/src/os_mgmt.c.obj
    [281/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_reassembly.c.obj
    [282/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/libsubsys__mgmt__mcumgr__grp__os_mgmt.a
    [283/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [284/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
    [285/451] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    [286/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.obj
    [287/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_bt.c.obj
    [288/451] Linking C static library zephyr/subsys/mgmt/mcumgr/transport/libsubsys__mgmt__mcumgr__transport.a
    [289/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
    [290/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/data.c.obj
    [291/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [292/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [293/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [294/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [295/451] Building C object zephyr/subsys/zbus/CMakeFiles/subsys__zbus.dir/zbus.c.obj
    [296/451] Building C object zephyr/subsys/dfu/boot/CMakeFiles/subsys__dfu__boot.dir/mcuboot.c.obj
    [297/451] Linking C static library zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a
    [298/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [299/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp_null.c.obj
    [300/451] Building C object zephyr/subsys/zbus/CMakeFiles/subsys__zbus.dir/zbus_iterable_sections.c.obj
    [301/451] Linking C static library zephyr/subsys/zbus/libsubsys__zbus.a
    [302/451] Building C object zephyr/drivers/cache/CMakeFiles/drivers__cache.dir/cache_nrf.c.obj
    [303/451] Linking C static library zephyr/drivers/cache/libdrivers__cache.a
    [304/451] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [305/451] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [306/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [307/451] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto.c.obj
    [308/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [309/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
    [310/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [311/451] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [312/451] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [313/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [314/451] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_npm1300.c.obj
    [315/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [316/451] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_bt_hci.c.obj
    [317/451] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [318/451] Building C object zephyr/drivers/haptics/CMakeFiles/drivers__haptics.dir/drv2605.c.obj
    [319/451] Linking C static library zephyr/drivers/haptics/libdrivers__haptics.a
    [320/451] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [321/451] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [322/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [323/451] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [324/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf_rram.c.obj
    [325/451] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [326/451] Building C object zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj
    [327/451] Linking C static library zephyr/drivers/mfd/libdrivers__mfd.a
    [328/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [329/451] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_common.c.obj
    [330/451] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [331/451] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [332/451] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_npm1300.c.obj
    [333/451] Linking C static library zephyr/drivers/regulator/libdrivers__regulator.a
    [334/451] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [335/451] Building C object zephyr/drivers/sensor/nordic/npm1300_charger/CMakeFiles/drivers__sensor__nordic__npm1300_charger.dir/npm1300_charger.c.obj
    [336/451] Linking C static library zephyr/drivers/sensor/nordic/npm1300_charger/libdrivers__sensor__nordic__npm1300_charger.a
    [337/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim_common.c.obj
    [338/451] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [339/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270_trigger.c.obj
    [340/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/sword_ppg_as7058a_hrm_cfg.c.obj
    [341/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [342/451] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_grtc_timer.c.obj
    [343/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270_i2c.c.obj
    [344/451] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    [345/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270.c.obj
    [346/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/vital_signs_acc_sword_imu.c.obj
    [347/451] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [348/451] Linking C static library modules/m_band/drivers/sword_bmi270/lib..__m_band__drivers__sword_bmi270.a
    [349/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_agc_hal.c.obj
    [350/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_bioz_measurement.c.obj
    [351/451] Building C object modules/m_band/lib/sword_imu/CMakeFiles/..__m_band__lib__sword_imu.dir/sword_imu.c.obj
    [352/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_extract.c.obj
    [353/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_extract2.c.obj
    [354/451] Linking C static library modules/m_band/lib/sword_imu/lib..__m_band__lib__sword_imu.a
    [355/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_chiplib.c.obj
    [356/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_pd_offset_calibration.c.obj
    [357/451] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [358/451] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
    [359/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_interface.c.obj
    [360/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_eda_scaling.c.obj
    [361/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/src/as7058_osal_chiplib_zephyr.c.obj
    [362/451] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [363/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/sword_ppg_as7058a.c.obj
    [364/451] Linking C static library modules/m_band/lib/sword_ppg/lib..__m_band__lib__sword_ppg.a
    [365/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal_wrappers.c.obj
    [366/451] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
    [367/451] Linking C static library modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
    [368/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [369/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [370/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [371/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/lib/agc/src/agc.c.obj
    [372/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [373/451] Linking C static library modules/as7058a-algo-sdk/lib..__modules__lib__as7058a-algo-sdk__zephyr.a
    [374/451] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [375/451] Linking C static library modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a
    [376/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_common.c.obj
    [377/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/entropy_poll.c.obj
    [378/451] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [379/451] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [380/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [381/451] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [382/451] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [383/451] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
    [384/451] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
    [385/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/mdk/system_nrf54l.c.obj
    [386/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_encode.c.obj
    [387/451] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [388/451] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [389/451] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [390/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [391/451] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
    [392/451] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [393/451] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [394/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_decode.c.obj
    [395/451] Linking C static library modules/nanopb/libmodules__nanopb.a
    [396/451] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [397/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [398/451] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tcunha/zp/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [399/451] Linking C static library modules/segger/libmodules__segger.a
    [400/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_common.c.obj
    [401/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [402/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [403/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_rramc.c.obj
    [404/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [405/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [406/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [407/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [408/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [409/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [410/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_encode.c.obj
    [411/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [412/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [413/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [414/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [415/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [416/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_grtc.c.obj
    [417/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [418/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [419/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [420/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [421/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [422/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [423/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [424/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_decode.c.obj
    [425/451] Linking C static library modules/zcbor/libmodules__zcbor.a
    [426/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [427/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [428/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [429/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [430/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [431/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [432/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [433/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [434/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [435/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [436/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [437/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [438/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [439/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/events.c.obj
    [440/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [441/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [442/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [443/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [444/451] Linking C static library zephyr/kernel/libkernel.a
    [445/451] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [446/451] Linking C executable zephyr/zephyr_pre0.elf
    [447/451] Generating linker.cmd
    [448/451] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [449/451] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [450/451] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [451/451] Linking C executable zephyr/zephyr.elf
               FLASH:      287760 B       514 KB     54.67%
                 RAM:      116828 B       188 KB     60.69%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/tcunha/zp/m_band/app/build/app/zephyr/zephyr.elf for board: mband
    image.py: sign the digest
    [27/69] Performing build step for 'mcuboot'
    [1/303] Preparing syscall dependency handling
    [2/303] Generating ../../zephyr/include/generated/ncs_commit.h
    [3/303] Generating ../../zephyr/include/generated/app_commit.h
    [4/303] Generating ../../zephyr/include/generated/zephyr_commit.h
    [5/303] Generating include/generated/zephyr/app_version.h
    [6/303] Generating ../../zephyr/include/generated/ncs_version.h
    [7/303] Generating include/generated/zephyr/version.h
    [8/303] Generating misc/generated/syscalls_subdirs.trigger
    [9/303] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [10/303] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [11/303] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [12/303] Generating include/generated/zephyr/driver-validation.h
    [13/303] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [14/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs12.c.obj
    [15/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pem.c.obj
    [16/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher.c.obj
    [17/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkparse.c.obj
    [18/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs5.c.obj
    [19/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/dhm.c.obj
    [20/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkwrite.c.obj
    [21/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/md.c.obj
    [22/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [23/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [24/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [25/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [26/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum.c.obj
    [27/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [28/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/psa_util.c.obj
    [29/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum_core.c.obj
    [30/303] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [31/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [32/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/nist_kw.c.obj
    [33/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [34/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/padlock.c.obj
    [35/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/block_cipher.c.obj
    [36/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/version.c.obj
    [37/303] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [38/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1parse.c.obj
    [39/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/constant_time.c.obj
    [40/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [41/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/base64.c.obj
    [42/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.c.obj
    [43/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.c.obj
    [44/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [45/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1write.c.obj
    [46/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/oid.c.obj
    [47/303] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [48/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmac.c.obj
    [49/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.c.obj
    [50/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/chachapoly.c.obj
    [51/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmmask.c.obj
    [52/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/keyref.c.obj
    [53/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hash.c.obj
    [54/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/blkcipher.c.obj
    [55/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/aead.c.obj
    [56/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmdma.c.obj
    [57/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/interface/sxbuf/sxbufops.c.obj
    [58/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/blind.c.obj
    [59/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed448.c.obj
    [60/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [61/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/iomem.c.obj
    [62/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed25519.c.obj
    [63/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/montgomery.c.obj
    [64/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/interrupts.c.obj
    [65/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/statuscodes.c.obj
    [66/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/cmddefs_ik.c.obj
    [67/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ba414_status.c.obj
    [68/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hmac.c.obj
    [69/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ec_curves.c.obj
    [70/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecc.c.obj
    [71/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_modmath.c.obj
    [72/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_srp.c.obj
    [73/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecjpake.c.obj
    [74/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/mac.c.obj
    [75/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/baremetal_ba414e_with_ik/pk_baremetal.c.obj
    [76/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/cmdma_hw.c.obj
    [77/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/ikhardware.c.obj
    [78/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecc.c.obj
    [79/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/coprime_check.c.obj
    [80/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519.c.obj
    [81/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/sha3.c.obj
    [82/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/trng.c.obj
    [83/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/mem.c.obj
    [84/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hkdf.c.obj
    [85/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hash.c.obj
    [86/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/pkhardware_ba414e.c.obj
    [87/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519ph.c.obj
    [88/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecdsa.c.obj
    [89/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/montgomery.c.obj
    [90/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed448.c.obj
    [91/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hmac.c.obj
    [92/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsamgf1xor.c.obj
    [93/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/pbkdf2.c.obj
    [94/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sicrypto.c.obj
    [95/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rndinrange.c.obj
    [96/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/util.c.obj
    [97/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_pkcs1v15.c.obj
    [98/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sig.c.obj
    [99/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/iksig.c.obj
    [100/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ec_helpers.c.obj
    [101/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsassa_pkcs1v15.c.obj
    [102/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mem_helpers.c.obj
    [103/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_oaep.c.obj
    [104/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsa_keygen.c.obj
    [105/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/rndinrange.c.obj
    [106/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/blkcipher.c.obj
    [107/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecc.c.obj
    [108/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/lib_kmu.c.obj
    [109/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/sign.c.obj
    [110/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsapss.c.obj
    [111/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto.c.obj
    [112/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ed25519.c.obj
    [113/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hmac.c.obj
    [114/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hash.c.obj
    [115/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecdsa.c.obj
    [116/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/prng_pool.c.obj
    [117/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/cracen.c.obj
    [118/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ctr_drbg.c.obj
    [119/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/common.c.obj
    [120/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/key_management.c.obj
    [121/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/kmu.c.obj
    [122/303] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/cracen/libcracen_psa_driver.a
    [123/303] Linking C static library modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a
    [124/303] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [125/303] Generating include/generated/zephyr/offsets.h
    [126/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [127/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [128/303] Building C object CMakeFiles/app.dir/os.c.obj
    [129/303] Building C object CMakeFiles/app.dir/keys.c.obj
    [130/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    [131/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [132/303] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [133/303] Building C object CMakeFiles/app.dir/io.c.obj
    [134/303] Building C object CMakeFiles/app.dir/main.c.obj
    [135/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [136/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [137/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [138/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [139/303] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [140/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [141/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [142/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [143/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [144/303] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [145/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c: In function 'nsib_swap_run':
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c:62:10: warning: implicit declaration of function 'swap_erase_trailer_sectors' [-Wimplicit-function-declaration]
       62 |     rc = swap_erase_trailer_sectors(state, fap_sec);
    [146/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [147/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [148/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [149/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/ed25519_psa.c.obj
    [150/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [151/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [152/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [153/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [154/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [155/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [156/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [157/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [158/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [159/303] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [160/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [161/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [162/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [163/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [164/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [165/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [166/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [167/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [168/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [169/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/loader.c:87:13: warning: 'owner_nsib' defined but not used [-Wunused-variable]
       87 | static bool owner_nsib[BOOT_IMAGE_NUMBER] = {false};
    [170/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [171/303] Generating linker_zephyr_pre0.cmd
    [172/303] Linking C static library app/libapp.a
    [173/303] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [174/303] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [175/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [176/303] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/lib/boot_banner/banner.c.obj
    [177/303] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [178/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [179/303] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [180/303] Linking C static library zephyr/arch/common/libisr_tables.a
    [181/303] Linking C static library zephyr/arch/common/libarch__common.a
    [182/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [183/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [184/303] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [185/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [186/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [187/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [188/303] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [189/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [190/303] Linking C static library zephyr/libzephyr.a
    [191/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [192/303] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [193/303] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [194/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [195/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [196/303] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [197/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [198/303] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [199/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [200/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [201/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [202/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [203/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [204/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [205/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [206/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [207/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [208/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [209/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [210/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [211/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [212/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [213/303] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [214/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [215/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [216/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [217/303] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [218/303] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [219/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [220/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [221/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [222/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [223/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/localtime_r_utc.c.obj
    [224/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/gmtime_r.c.obj
    [225/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/ctime.c.obj
    [226/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [227/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/string/strnlen.c.obj
    [228/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [229/303] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [230/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/asctime.c.obj
    [231/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [232/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [233/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [234/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [235/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_rram_partitions.c.obj
    [236/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [237/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [238/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [239/303] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [240/303] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [241/303] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [242/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [243/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/nrf54l/soc.c.obj
    [244/303] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [245/303] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [246/303] Building C object zephyr/drivers/cache/CMakeFiles/drivers__cache.dir/cache_nrf.c.obj
    [247/303] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [248/303] Linking C static library zephyr/drivers/cache/libdrivers__cache.a
    [249/303] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_grtc_timer.c.obj
    [250/303] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [251/303] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [252/303] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [253/303] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [254/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [255/303] Linking C static library zephyr/soc/soc/nrf54l15/libsoc__nordic.a
    [256/303] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [257/303] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [258/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/mdk/system_nrf54l.c.obj
    [259/303] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf_rram.c.obj
    [260/303] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [261/303] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [262/303] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [263/303] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [264/303] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [265/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [266/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [267/303] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [268/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [269/303] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [270/303] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tcunha/zp/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [271/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_rramc.c.obj
    [272/303] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [273/303] Linking C static library modules/segger/libmodules__segger.a
    [274/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [275/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [276/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [277/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [278/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [279/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [280/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [281/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [282/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_grtc.c.obj
    [283/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [284/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [285/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [286/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [287/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [288/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [289/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [290/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [291/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [292/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [293/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [294/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [295/303] Linking C static library zephyr/kernel/libkernel.a
    [296/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [297/303] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [298/303] Linking C executable zephyr/zephyr_pre0.elf
    [299/303] Generating linker.cmd
    [300/303] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [301/303] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [302/303] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [303/303] Linking C executable zephyr/zephyr.elf
               FLASH:       41156 B        52 KB     77.29%
                 RAM:       18408 B       188 KB      9.56%
    Generating files from /home/tcunha/zp/m_band/app/build/mcuboot/zephyr/zephyr.elf for board: mband
    [33/69] Generating ../app_image.hex
    [34/69] Performing build step for 'b0'
    [1/253] Preparing syscall dependency handling
    [2/253] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/253] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/253] Generating ../../zephyr/include/generated/ncs_version.h
    [5/253] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/home/tcunha/zp/zephyr), build: v4.0.99-ncs1-1
    [6/253] Generating misc/generated/syscalls_subdirs.trigger
    [7/253] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [8/253] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [9/253] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [10/253] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [11/253] Generating include/generated/zephyr/driver-validation.h
    [12/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs5.c.obj
    [13/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pem.c.obj
    [14/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/dhm.c.obj
    [15/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs12.c.obj
    [16/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkparse.c.obj
    [17/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [18/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkwrite.c.obj
    [19/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher.c.obj
    [20/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/md.c.obj
    [21/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [22/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [23/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [24/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [25/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/psa_util.c.obj
    [26/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum.c.obj
    [27/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/nist_kw.c.obj
    [28/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/block_cipher.c.obj
    [29/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum_core.c.obj
    [30/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/padlock.c.obj
    [31/253] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [32/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/version.c.obj
    [33/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1parse.c.obj
    [34/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [35/253] Building C object modules/nrf/subsys/nrf_security/src/core/lite/CMakeFiles/oberon_psa_core.dir/psa_core_lite.c.obj
    [36/253] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [37/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/base64.c.obj
    [38/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/constant_time.c.obj
    [39/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/oid.c.obj
    [40/253] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1write.c.obj
    [41/253] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [42/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmac.c.obj
    [43/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/keyref.c.obj
    [44/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmdma.c.obj
    [45/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hash.c.obj
    [46/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmmask.c.obj
    [47/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/mac.c.obj
    [48/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/chachapoly.c.obj
    [49/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/trng.c.obj
    [50/253] Building C object modules/nrf/subsys/nrf_security/src/core/lite/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [51/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/interface/sxbuf/sxbufops.c.obj
    [52/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/blind.c.obj
    [53/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/cmdma_hw.c.obj
    [54/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/aead.c.obj
    [55/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hmac.c.obj
    [56/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/sha3.c.obj
    [57/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/montgomery.c.obj
    [58/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/cmddefs_ik.c.obj
    [59/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/iomem.c.obj
    [60/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed448.c.obj
    [61/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ba414_status.c.obj
    [62/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ec_curves.c.obj
    [63/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed25519.c.obj
    [64/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecc.c.obj
    [65/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/interrupts.c.obj
    [66/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_modmath.c.obj
    [67/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecjpake.c.obj
    [68/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_srp.c.obj
    [69/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/statuscodes.c.obj
    [70/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/blkcipher.c.obj
    [71/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/coprime_check.c.obj
    [72/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hash.c.obj
    [73/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecc.c.obj
    [74/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519.c.obj
    [75/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hkdf.c.obj
    [76/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/mem.c.obj
    [77/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed448.c.obj
    [78/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/pkhardware_ba414e.c.obj
    [79/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519ph.c.obj
    [80/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/montgomery.c.obj
    [81/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hmac.c.obj
    [82/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/ikhardware.c.obj
    [83/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/pbkdf2.c.obj
    [84/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsamgf1xor.c.obj
    [85/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/baremetal_ba414e_with_ik/pk_baremetal.c.obj
    [86/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecdsa.c.obj
    [87/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rndinrange.c.obj
    [88/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sicrypto.c.obj
    [89/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_oaep.c.obj
    [90/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sig.c.obj
    [91/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_pkcs1v15.c.obj
    [92/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ec_helpers.c.obj
    [93/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mem_helpers.c.obj
    [94/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/util.c.obj
    [95/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/iksig.c.obj
    [96/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecc.c.obj
    [97/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsassa_pkcs1v15.c.obj
    [98/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ctr_drbg.c.obj
    [99/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/prng_pool.c.obj
    [100/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/rndinrange.c.obj
    [101/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsa_keygen.c.obj
    [102/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/lib_kmu.c.obj
    [103/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/common.c.obj
    [104/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/blkcipher.c.obj
    [105/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/sign.c.obj
    [106/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsapss.c.obj
    [107/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/cracen.c.obj
    [108/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecdsa.c.obj
    [109/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ed25519.c.obj
    [110/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hmac.c.obj
    [111/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hash.c.obj
    [112/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/key_management.c.obj
    [113/253] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/kmu.c.obj
    [114/253] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/cracen/libcracen_psa_driver.a
    [115/253] Linking C static library modules/nrf/subsys/nrf_security/src/core/lite/liboberon_psa_core.a
    [116/253] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [117/253] Generating include/generated/zephyr/offsets.h
    [118/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [119/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [120/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [121/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [122/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [123/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [124/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [125/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [126/253] Building C object CMakeFiles/app.dir/src/main.c.obj
    [127/253] Linking C static library app/libapp.a
    [128/253] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [129/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [130/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [131/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [132/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [133/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [134/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [135/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [136/253] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [137/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [138/253] Generating linker_zephyr_pre0.cmd
    [139/253] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [140/253] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [141/253] Linking C static library zephyr/arch/common/libisr_tables.a
    [142/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [143/253] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [144/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [145/253] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [146/253] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [147/253] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [148/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [149/253] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [150/253] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [151/253] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [152/253] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/lib/boot_banner/banner.c.obj
    [153/253] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [154/253] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [155/253] Linking C static library zephyr/arch/common/libarch__common.a
    [156/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [157/253] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [158/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [159/253] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [160/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [161/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [162/253] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [163/253] Linking C static library zephyr/libzephyr.a
    [164/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [165/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [166/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [167/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [168/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [169/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [170/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [171/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [172/253] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [173/253] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [174/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [175/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [176/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [177/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [178/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [179/253] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [180/253] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [181/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [182/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [183/253] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [184/253] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [185/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [186/253] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [187/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_rram_partitions.c.obj
    [188/253] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [189/253] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [190/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/nrf54l/soc.c.obj
    [191/253] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [192/253] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [193/253] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [194/253] Linking C static library zephyr/soc/soc/nrf54l15/libsoc__nordic.a
    [195/253] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
    [196/253] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_grtc_timer.c.obj
    [197/253] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [198/253] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf_rram.c.obj
    [199/253] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_ed25519.c.obj
    [200/253] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [201/253] Linking C static library modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a
    [202/253] Building C object zephyr/drivers/cache/CMakeFiles/drivers__cache.dir/cache_nrf.c.obj
    [203/253] Linking C static library zephyr/drivers/cache/libdrivers__cache.a
    [204/253] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [205/253] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [206/253] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [207/253] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [208/253] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [209/253] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [210/253] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
    [211/253] Linking C static library modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a
    [212/253] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [213/253] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [214/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/mdk/system_nrf54l.c.obj
    [215/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [216/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [217/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [218/253] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
    [219/253] Linking C static library modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a
    [220/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [221/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [222/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [223/253] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [224/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [225/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [226/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [227/253] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
    [228/253] Linking C static library modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a
    [229/253] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tcunha/zp/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [230/253] Linking C static library modules/segger/libmodules__segger.a
    [231/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [232/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [233/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [234/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [235/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_rramc.c.obj
    [236/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [237/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [238/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [239/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [240/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [241/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [242/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [243/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [244/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [245/253] Linking C static library zephyr/kernel/libkernel.a
    [246/253] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_grtc.c.obj
    [247/253] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [248/253] Linking C executable zephyr/zephyr_pre0.elf
    [249/253] Generating linker.cmd
    [250/253] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [251/253] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [252/253] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [253/253] Linking C executable zephyr/zephyr.elf
               FLASH:       35428 B        64 KB     54.06%
                 RAM:        5952 B       188 KB      3.09%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/tcunha/zp/m_band/app/build/b0/zephyr/zephyr.elf for board: mband
    [37/69] cd /home/tcunha/zp/m_band/app/build/_sysbuild && /home/tcunha/miniconda3/lib/python3.12/site-packages/cmake/data/bin/cmake -E true
    [38/69] Creating signature of application
    [42/69] Generating ../b0_container.hex
    [43/69] Creating data to be provisioned to the Bootloader, storing to app_provision.hex
    [44/69] Creating validation for zephyr.hex, storing to signed_by_b0_mcuboot.hex
    [45/69] Performing build step for 's1_image'
    [1/303] Preparing syscall dependency handling
    [2/303] Generating ../../zephyr/include/generated/ncs_commit.h
    [3/303] Generating ../../zephyr/include/generated/app_commit.h
    [4/303] Generating include/generated/zephyr/app_version.h
    [5/303] Generating ../../zephyr/include/generated/zephyr_commit.h
    [6/303] Generating ../../zephyr/include/generated/ncs_version.h
    [7/303] Generating include/generated/zephyr/version.h
    [8/303] Generating misc/generated/syscalls_subdirs.trigger
    [9/303] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [10/303] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [11/303] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [12/303] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [13/303] Generating include/generated/zephyr/driver-validation.h
    [14/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pem.c.obj
    [15/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs12.c.obj
    [16/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkparse.c.obj
    [17/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs5.c.obj
    [18/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher.c.obj
    [19/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkwrite.c.obj
    [20/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [21/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/dhm.c.obj
    [22/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [23/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [24/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [25/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/md.c.obj
    [26/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [27/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum_core.c.obj
    [28/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [29/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum.c.obj
    [30/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1write.c.obj
    [31/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/nist_kw.c.obj
    [32/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/block_cipher.c.obj
    [33/303] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [34/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/version.c.obj
    [35/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/padlock.c.obj
    [36/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1parse.c.obj
    [37/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/psa_util.c.obj
    [38/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [39/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/constant_time.c.obj
    [40/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [41/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.c.obj
    [42/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.c.obj
    [43/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/base64.c.obj
    [44/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/oid.c.obj
    [45/303] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [46/303] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [47/303] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [48/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmac.c.obj
    [49/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/chachapoly.c.obj
    [50/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [51/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/keyref.c.obj
    [52/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/aead.c.obj
    [53/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmdma.c.obj
    [54/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmmask.c.obj
    [55/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.c.obj
    [56/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/blkcipher.c.obj
    [57/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/interface/sxbuf/sxbufops.c.obj
    [58/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/blind.c.obj
    [59/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/trng.c.obj
    [60/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/cmdma_hw.c.obj
    [61/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/iomem.c.obj
    [62/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed25519.c.obj
    [63/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hmac.c.obj
    [64/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/montgomery.c.obj
    [65/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed448.c.obj
    [66/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hash.c.obj
    [67/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/interrupts.c.obj
    [68/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/mac.c.obj
    [69/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/cmddefs_ik.c.obj
    [70/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/statuscodes.c.obj
    [71/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecc.c.obj
    [72/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_modmath.c.obj
    [73/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ba414_status.c.obj
    [74/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ec_curves.c.obj
    [75/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecjpake.c.obj
    [76/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_srp.c.obj
    [77/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/baremetal_ba414e_with_ik/pk_baremetal.c.obj
    [78/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecc.c.obj
    [79/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/ikhardware.c.obj
    [80/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519ph.c.obj
    [81/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/coprime_check.c.obj
    [82/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/sha3.c.obj
    [83/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/mem.c.obj
    [84/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hash.c.obj
    [85/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hkdf.c.obj
    [86/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecdsa.c.obj
    [87/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/montgomery.c.obj
    [88/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed448.c.obj
    [89/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519.c.obj
    [90/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hmac.c.obj
    [91/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rndinrange.c.obj
    [92/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/pkhardware_ba414e.c.obj
    [93/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsamgf1xor.c.obj
    [94/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/pbkdf2.c.obj
    [95/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sig.c.obj
    [96/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sicrypto.c.obj
    [97/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/util.c.obj
    [98/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsassa_pkcs1v15.c.obj
    [99/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ec_helpers.c.obj
    [100/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_oaep.c.obj
    [101/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mem_helpers.c.obj
    [102/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/iksig.c.obj
    [103/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_pkcs1v15.c.obj
    [104/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsa_keygen.c.obj
    [105/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecc.c.obj
    [106/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/rndinrange.c.obj
    [107/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/blkcipher.c.obj
    [108/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/lib_kmu.c.obj
    [109/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsapss.c.obj
    [110/303] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto.c.obj
    [111/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/common.c.obj
    [112/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ctr_drbg.c.obj
    [113/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecdsa.c.obj
    [114/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/prng_pool.c.obj
    [115/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/cracen.c.obj
    [116/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ed25519.c.obj
    [117/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hash.c.obj
    [118/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/hmac.c.obj
    [119/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/sign.c.obj
    [120/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/key_management.c.obj
    [121/303] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/kmu.c.obj
    [122/303] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/cracen/libcracen_psa_driver.a
    [123/303] Linking C static library modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a
    [124/303] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [125/303] Generating include/generated/zephyr/offsets.h
    [126/303] Building C object CMakeFiles/app.dir/keys.c.obj
    [127/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [128/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    [129/303] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [130/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [131/303] Building C object CMakeFiles/app.dir/main.c.obj
    [132/303] Building C object CMakeFiles/app.dir/os.c.obj
    [133/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [134/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [135/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [136/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [137/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [138/303] Building C object CMakeFiles/app.dir/io.c.obj
    [139/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [140/303] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [141/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c: In function 'nsib_swap_run':
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c:62:10: warning: implicit declaration of function 'swap_erase_trailer_sectors' [-Wimplicit-function-declaration]
       62 |     rc = swap_erase_trailer_sectors(state, fap_sec);
    [142/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [143/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/loader.c:87:13: warning: 'owner_nsib' defined but not used [-Wunused-variable]
       87 | static bool owner_nsib[BOOT_IMAGE_NUMBER] = {false};
    [144/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [145/303] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [146/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [147/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [148/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [149/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [150/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [151/303] Building C object CMakeFiles/app.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/ed25519_psa.c.obj
    [152/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [153/303] Linking C static library app/libapp.a
    [154/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [155/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [156/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [157/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [158/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [159/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [160/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [161/303] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [162/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [163/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [164/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [165/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [166/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [167/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [168/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [169/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [170/303] Generating linker_zephyr_pre0.cmd
    [171/303] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [172/303] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [173/303] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [174/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [175/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [176/303] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [177/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [178/303] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [179/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [180/303] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [181/303] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/lib/boot_banner/banner.c.obj
    [182/303] Linking C static library zephyr/arch/common/libisr_tables.a
    [183/303] Linking C static library zephyr/arch/common/libarch__common.a
    [184/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [185/303] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [186/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [187/303] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [188/303] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [189/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [190/303] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [191/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [192/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [193/303] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [194/303] Linking C static library zephyr/libzephyr.a
    [195/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [196/303] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [197/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [198/303] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [199/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [200/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [201/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [202/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [203/303] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [204/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [205/303] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [206/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [207/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [208/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [209/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [210/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [211/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [212/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [213/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [214/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [215/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [216/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [217/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [218/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [219/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [220/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/asctime.c.obj
    [221/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [222/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/gmtime_r.c.obj
    [223/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/ctime.c.obj
    [224/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/localtime_r_utc.c.obj
    [225/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [226/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/string/strnlen.c.obj
    [227/303] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [228/303] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [229/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [230/303] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [231/303] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [232/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [233/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [234/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [235/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_rram_partitions.c.obj
    [236/303] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [237/303] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [238/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [239/303] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [240/303] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [241/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [242/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [243/303] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [244/303] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [245/303] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/nrf54l/soc.c.obj
    [246/303] Linking C static library zephyr/soc/soc/nrf54l15/libsoc__nordic.a
    [247/303] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [248/303] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [249/303] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [250/303] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [251/303] Building C object zephyr/drivers/cache/CMakeFiles/drivers__cache.dir/cache_nrf.c.obj
    [252/303] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [253/303] Linking C static library zephyr/drivers/cache/libdrivers__cache.a
    [254/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/mdk/system_nrf54l.c.obj
    [255/303] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [256/303] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [257/303] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf_rram.c.obj
    [258/303] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [259/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [260/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [261/303] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [262/303] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [263/303] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_grtc_timer.c.obj
    [264/303] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [265/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [266/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [267/303] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [268/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_rramc.c.obj
    [269/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [270/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [271/303] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [272/303] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [273/303] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [274/303] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [275/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [276/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [277/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [278/303] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tcunha/zp/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [279/303] Linking C static library modules/segger/libmodules__segger.a
    [280/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [281/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [282/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [283/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [284/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_grtc.c.obj
    [285/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [286/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [287/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [288/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [289/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [290/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [291/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [292/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [293/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [294/303] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [295/303] Linking C static library zephyr/kernel/libkernel.a
    [296/303] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [297/303] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [298/303] Linking C executable zephyr/zephyr_pre0.elf
    [299/303] Generating linker.cmd
    [300/303] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [301/303] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [302/303] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [303/303] Linking C executable zephyr/zephyr.elf
               FLASH:       41156 B        52 KB     77.29%
                 RAM:       18408 B       188 KB      9.56%
    Generating files from /home/tcunha/zp/m_band/app/build/s1_image/zephyr/zephyr.elf for board: mband
    [48/69] Generating ../signed_by_mcuboot_and_b0_mcuboot.bin
    image.py: sign the digest
    [50/69] Generating ../signed_by_mcuboot_and_b0_mcuboot.hex
    [51/69] Performing build step for 'mcuboot_secondary_app'
    [0/1] Re-running CMake...
    -- Application: /home/tcunha/zp/m_band/app
    -- CMake version: 3.31.4
    -- Cache files will be written to: /home/tcunha/.cache/zephyr
    -- Zephyr version: 4.0.99 (/home/tcunha/zp/zephyr)
    -- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
    -- Board: mband, Revision: v1, qualifiers: nrf54l15/cpuapp
    -- Found host-tools: zephyr 0.16.3 (/home/tcunha/zephyr-sdk-0.16.3)
    -- Found toolchain: zephyr 0.16.3 (/home/tcunha/zephyr-sdk-0.16.3)
    -- Found BOARD.dts: /home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: /home/tcunha/zp/m_band/boards/sword/mband/mband_nrf54l15_cpuapp_v1.overlay
    -- Generated zephyr.dts: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/zephyr.dts
    -- Generated pickled edt: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/dts.cmake
    -- Including signing script: /home/tcunha/zp/nrf/cmake/sysbuild/image_signing.cmake
    -- Found protoc: /home/tcunha/zp/modules/lib/nanopb/generator/protoc
    -- Configuring done (4.2s)
    -- Generating done (0.3s)
    -- Build files have been written to: /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app
    [1/451] Generating nanopb/generator/nanopb_generator.py, nanopb/generator/proto/nanopb.proto
    [2/451] Preparing syscall dependency handling
    [3/451] Generating ../../zephyr/include/generated/zephyr_commit.h
    [4/451] Generating ../../zephyr/include/generated/app_commit.h
    [5/451] Generating include/generated/zephyr/app_version.h
    [6/451] Generating ../../zephyr/include/generated/ncs_commit.h
    [7/451] Generating ../../zephyr/include/generated/ncs_version.h
    [8/451] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/home/tcunha/zp/zephyr), build: v4.0.99-ncs1-1
    [9/451] Generating misc/generated/syscalls_subdirs.trigger
    [10/451] Generating nanopb/generator/proto/nanopb_pb2.py
    [11/451] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [12/451] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [13/451] Running C++ protocol buffer compiler using nanopb plugin on src/protobuf_msg/mband.proto
    [14/451] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [15/451] Generating include/generated/zephyr/driver-validation.h
    [16/451] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [17/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkparse.c.obj
    [18/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs5.c.obj
    [19/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkcs12.c.obj
    [20/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/dhm.c.obj
    [21/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher.c.obj
    [22/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pkwrite.c.obj
    [23/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [24/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pem.c.obj
    [25/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [26/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/md.c.obj
    [27/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [28/451] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [29/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum.c.obj
    [30/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [31/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1parse.c.obj
    [32/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/nist_kw.c.obj
    [33/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/base64.c.obj
    [34/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [35/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/bignum_core.c.obj
    [36/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/asn1write.c.obj
    [37/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/padlock.c.obj
    [38/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/version.c.obj
    [39/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [40/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/constant_time.c.obj
    [41/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.c.obj
    [42/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [43/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/block_cipher.c.obj
    [44/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/tcunha/zp/modules/crypto/mbedtls/library/psa_util.c.obj
    [45/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/threading/threading_alt.c.obj
    [46/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.c.obj
    [47/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [48/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [49/451] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [50/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.c.obj
    [51/451] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/tcunha/zp/modules/crypto/mbedtls/library/oid.c.obj
    [52/451] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [53/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/blkcipher.c.obj
    [54/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/keyref.c.obj
    [55/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmac.c.obj
    [56/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hash.c.obj
    [57/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/hmac.c.obj
    [58/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/chachapoly.c.obj
    [59/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmmask.c.obj
    [60/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/aead.c.obj
    [61/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/mac.c.obj
    [62/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/cmdma.c.obj
    [63/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/blind.c.obj
    [64/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/sha3.c.obj
    [65/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/interface/sxbuf/sxbufops.c.obj
    [66/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/iomem.c.obj
    [67/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/montgomery.c.obj
    [68/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed448.c.obj
    [69/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/statuscodes.c.obj
    [70/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/trng.c.obj
    [71/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/src/ed25519.c.obj
    [72/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/cmdma_hw.c.obj
    [73/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/cmddefs_ik.c.obj
    [74/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.c.obj
    [75/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_modmath.c.obj
    [76/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecc.c.obj
    [77/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ec_curves.c.obj
    [78/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sxsymcrypt/src/platform/baremetal/interrupts.c.obj
    [79/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_ecjpake.c.obj
    [80/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/cmddefs_srp.c.obj
    [81/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/ba414_status.c.obj
    [82/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/coprime_check.c.obj
    [83/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ik/ikhardware.c.obj
    [84/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecc.c.obj
    [85/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519.c.obj
    [86/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed25519ph.c.obj
    [87/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ecdsa.c.obj
    [88/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hash.c.obj
    [89/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/ed448.c.obj
    [90/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/mem.c.obj
    [91/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hmac.c.obj
    [92/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/baremetal_ba414e_with_ik/pk_baremetal.c.obj
    [93/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/pbkdf2.c.obj
    [94/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/hkdf.c.obj
    [95/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/montgomery.c.obj
    [96/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rndinrange.c.obj
    [97/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsamgf1xor.c.obj
    [98/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/silexpk/target/hw/ba414/pkhardware_ba414e.c.obj
    [99/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sig.c.obj
    [100/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_pkcs1v15.c.obj
    [101/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsaes_oaep.c.obj
    [102/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/util.c.obj
    [103/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ec_helpers.c.obj
    [104/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mem_helpers.c.obj
    [105/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsa_keygen.c.obj
    [106/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/iksig.c.obj
    [107/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/sicrypto.c.obj
    [108/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecc.c.obj
    [109/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/cracen.c.obj
    [110/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsassa_pkcs1v15.c.obj
    [111/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/rndinrange.c.obj
    [112/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/sicrypto/src/rsapss.c.obj
    [113/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/mac.c.obj
    [114/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/common.c.obj
    [115/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/blkcipher.c.obj
    [116/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ed25519.c.obj
    [117/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ctr_drbg.c.obj
    [118/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/lib_kmu.c.obj
    [119/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/key_management.c.obj
    [120/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/prng_pool.c.obj
    [121/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/ecdsa.c.obj
    [122/451] Building C object modules/nrf/subsys/nrf_security/src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/home/tcunha/zp/modules/crypto/oberon-psa-crypto/library/psa_crypto.c.obj
    [123/451] Building C object modules/nrf/subsys/nrf_security/src/drivers/cracen/CMakeFiles/cracen_psa_driver.dir/cracenpsa/src/kmu.c.obj
    [124/451] Linking C static library modules/nrf/subsys/nrf_security/src/drivers/cracen/libcracen_psa_driver.a
    [125/451] Linking C static library modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a
    [126/451] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [127/451] Generating include/generated/zephyr/offsets.h
    [128/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [129/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [130/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [131/451] Building C object CMakeFiles/app.dir/src/protobuf_msg/mband.pb.c.obj
    [132/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [133/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [134/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [135/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [136/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [137/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [138/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/poweroff.c.obj
    [139/451] Building C object CMakeFiles/app.dir/src/main.c.obj
    [140/451] Linking C static library app/libapp.a
    [141/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [142/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [143/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [144/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [145/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [146/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [147/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [148/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [149/451] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [150/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [151/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [152/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
    [153/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb.c.obj
    [154/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [155/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [156/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [157/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_elem_info.c.obj
    [158/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_getnext.c.obj
    [159/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_append.c.obj
    [160/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [161/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_rotate.c.obj
    [162/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [163/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [164/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/fcb/fcb_walk.c.obj
    [165/451] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [166/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
    [167/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [168/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [169/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [170/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [171/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sensirion_sts4x/sts4x.c.obj
    [172/451] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [173/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sword_ktd2026/ktd2026.c.obj
    [174/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [175/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [176/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [177/451] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [178/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/drivers/sword_ir_temp_sensor/ir_temp_sensor.c.obj
    [179/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/lib/fcb_storage_manager/fcb_storage_manager.c.obj
    [180/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/lib/boot_banner/banner.c.obj
    [181/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [182/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/lib/mband_pbcodec/mband_pbcodec.c.obj
    [183/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/hci_vs_sdc.c.obj
    [184/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/host_extensions/host_extensions.c.obj
    [185/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/grtc/grtc_handler.c.obj
    [186/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/services/cts_client.c.obj
    [187/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/ktd2026/ktd2026_app.c.obj
    [188/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/commands_ble.c.obj
    [189/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/bt_module.c.obj
    [190/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bmi270/bmi270.c.obj
    [191/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/bluetooth/sensors_ble.c.obj
    [192/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/temperature/temperature_app.c.obj
    [193/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/ppg/ppg_app.c.obj
    [194/451] Generating linker_zephyr_pre0.cmd
    [195/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/nrf/subsys/bluetooth/gatt_dm.c.obj
    [196/451] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [197/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/controller/sensor_config.c.obj
    [198/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/record_storage/record_manager.c.obj
    [199/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/pmic/pmic.c.obj
    [200/451] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [201/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/haptic/haptic_app.c.obj
    [202/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/record_storage/dispatcher.c.obj
    [203/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/interaction/interaction.c.obj
    [204/451] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [205/451] Linking C static library zephyr/arch/common/libisr_tables.a
    [206/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [207/451] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [208/451] Building C object zephyr/CMakeFiles/zephyr.dir/home/tcunha/zp/m_band/app/src/controller/asm.c.obj
    [209/451] Linking C static library zephyr/arch/common/libarch__common.a
    [210/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [211/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [212/451] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [213/451] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [214/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [215/451] Linking C static library zephyr/libzephyr.a
    [216/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [217/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [218/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [219/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [220/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [221/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [222/451] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [223/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [224/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [225/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [226/451] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [227/451] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [228/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [229/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [230/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [231/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [232/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [233/451] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [234/451] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [235/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [236/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [237/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [238/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [239/451] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [240/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [241/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [242/451] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [243/451] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [244/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [245/451] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [246/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [247/451] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [248/451] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [249/451] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [250/451] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [251/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_rram_partitions.c.obj
    [252/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [253/451] Building C object zephyr/subsys/mgmt/mcumgr/util/CMakeFiles/subsys__mgmt__mcumgr__util.dir/src/zcbor_bulk.c.obj
    [254/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/nrf54l/soc.c.obj
    [255/451] Linking C static library zephyr/subsys/mgmt/mcumgr/util/libsubsys__mgmt__mcumgr__util.a
    [256/451] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [257/451] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [258/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [259/451] Building C object zephyr/soc/soc/nrf54l15/CMakeFiles/soc__nordic.dir/common/poweroff.c.obj
    [260/451] Linking C static library zephyr/soc/soc/nrf54l15/libsoc__nordic.a
    [261/451] Building C object zephyr/lib/smf/CMakeFiles/lib__smf.dir/smf.c.obj
    [262/451] Linking C static library zephyr/lib/smf/liblib__smf.a
    [263/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj
    [264/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_util.c.obj
    [265/451] Building C object zephyr/subsys/mgmt/mcumgr/mgmt/CMakeFiles/subsys__mgmt__mcumgr__mgmt.dir/src/mgmt.c.obj
    [266/451] Linking C static library zephyr/subsys/mgmt/mcumgr/mgmt/libsubsys__mgmt__mcumgr__mgmt.a
    [267/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp.c.obj
    [268/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
    [269/451] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [270/451] Building C object zephyr/subsys/mgmt/mcumgr/smp/CMakeFiles/subsys__mgmt__mcumgr__smp.dir/src/smp.c.obj
    [271/451] Linking C static library zephyr/subsys/mgmt/mcumgr/smp/libsubsys__mgmt__mcumgr__smp.a
    [272/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_bt.c.obj
    [273/451] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_xoshiro128.c.obj
    [274/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [275/451] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [276/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt.c.obj
    [277/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/zephyr_basic/CMakeFiles/subsys__mgmt__mcumgr__grp__zephyr_basic.dir/src/basic_mgmt.c.obj
    [278/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/zephyr_basic/libsubsys__mgmt__mcumgr__grp__zephyr_basic.a
    [279/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.obj
    [280/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__os_mgmt.dir/src/os_mgmt.c.obj
    [281/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/libsubsys__mgmt__mcumgr__grp__os_mgmt.a
    [282/451] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_state.c.obj
    [283/451] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/libsubsys__mgmt__mcumgr__grp__img_mgmt.a
    [284/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
    [285/451] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_reassembly.c.obj
    [286/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
    [287/451] Linking C static library zephyr/subsys/mgmt/mcumgr/transport/libsubsys__mgmt__mcumgr__transport.a
    [288/451] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
    [289/451] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    [290/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [291/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [292/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/data.c.obj
    [293/451] Building C object zephyr/subsys/dfu/boot/CMakeFiles/subsys__dfu__boot.dir/mcuboot.c.obj
    [294/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [295/451] Linking C static library zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a
    [296/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp_null.c.obj
    [297/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [298/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [299/451] Building C object zephyr/drivers/cache/CMakeFiles/drivers__cache.dir/cache_nrf.c.obj
    [300/451] Linking C static library zephyr/drivers/cache/libdrivers__cache.a
    [301/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [302/451] Building C object zephyr/subsys/zbus/CMakeFiles/subsys__zbus.dir/zbus_iterable_sections.c.obj
    [303/451] Building C object zephyr/subsys/zbus/CMakeFiles/subsys__zbus.dir/zbus.c.obj
    [304/451] Linking C static library zephyr/subsys/zbus/libsubsys__zbus.a
    [305/451] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [306/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [307/451] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [308/451] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto.c.obj
    [309/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [310/451] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [311/451] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [312/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [313/451] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_bt_hci.c.obj
    [314/451] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [315/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [316/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [317/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf_rram.c.obj
    [318/451] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [319/451] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [320/451] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_npm1300.c.obj
    [321/451] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [322/451] Building C object zephyr/drivers/haptics/CMakeFiles/drivers__haptics.dir/drv2605.c.obj
    [323/451] Linking C static library zephyr/drivers/haptics/libdrivers__haptics.a
    [324/451] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
    [325/451] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [326/451] Building C object zephyr/drivers/mfd/CMakeFiles/drivers__mfd.dir/mfd_npm1300.c.obj
    [327/451] Linking C static library zephyr/drivers/mfd/libdrivers__mfd.a
    [328/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim_common.c.obj
    [329/451] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [330/451] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [331/451] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [332/451] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [333/451] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_common.c.obj
    [334/451] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_npm1300.c.obj
    [335/451] Linking C static library zephyr/drivers/regulator/libdrivers__regulator.a
    [336/451] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [337/451] Building C object zephyr/drivers/sensor/nordic/npm1300_charger/CMakeFiles/drivers__sensor__nordic__npm1300_charger.dir/npm1300_charger.c.obj
    [338/451] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    [339/451] Linking C static library zephyr/drivers/sensor/nordic/npm1300_charger/libdrivers__sensor__nordic__npm1300_charger.a
    [340/451] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [341/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/sword_ppg_as7058a.c.obj
    [342/451] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_grtc_timer.c.obj
    [343/451] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [344/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270_i2c.c.obj
    [345/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270_trigger.c.obj
    [346/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_extract.c.obj
    [347/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_chiplib.c.obj
    [348/451] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [349/451] Building C object modules/m_band/drivers/sword_bmi270/CMakeFiles/..__m_band__drivers__sword_bmi270.dir/bmi270.c.obj
    [350/451] Linking C static library modules/m_band/drivers/sword_bmi270/lib..__m_band__drivers__sword_bmi270.a
    [351/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/vital_signs_acc_sword_imu.c.obj
    [352/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_agc_hal.c.obj
    [353/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/as7058_extract2.c.obj
    [354/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_bioz_measurement.c.obj
    [355/451] Building C object modules/m_band/lib/sword_imu/CMakeFiles/..__m_band__lib__sword_imu.dir/sword_imu.c.obj
    [356/451] Building C object modules/m_band/lib/sword_ppg/CMakeFiles/..__m_band__lib__sword_ppg.dir/as7058a/sword_ppg_as7058a_hrm_cfg.c.obj
    [357/451] Linking C static library modules/m_band/lib/sword_imu/lib..__m_band__lib__sword_imu.a
    [358/451] Linking C static library modules/m_band/lib/sword_ppg/lib..__m_band__lib__sword_ppg.a
    [359/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_eda_scaling.c.obj
    [360/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_pd_offset_calibration.c.obj
    [361/451] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [362/451] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [363/451] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
    [364/451] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [365/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/src/internal/as7058_interface.c.obj
    [366/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/home/tcunha/zp/modules/lib/as7058a-algo-sdk/chiplib/lib/agc/src/agc.c.obj
    [367/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [368/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [369/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [370/451] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
    [371/451] Linking C static library modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
    [372/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal_wrappers.c.obj
    [373/451] Building C object modules/as7058a-algo-sdk/CMakeFiles/..__modules__lib__as7058a-algo-sdk__zephyr.dir/src/as7058_osal_chiplib_zephyr.c.obj
    [374/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_common.c.obj
    [375/451] Linking C static library modules/as7058a-algo-sdk/lib..__modules__lib__as7058a-algo-sdk__zephyr.a
    [376/451] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [377/451] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
    [378/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [379/451] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/entropy_poll.c.obj
    [380/451] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [381/451] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [382/451] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
    [383/451] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
    [384/451] Linking C static library modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a
    [385/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/mdk/system_nrf54l.c.obj
    [386/451] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [387/451] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
    [388/451] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [389/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [390/451] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [391/451] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [392/451] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [393/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_decode.c.obj
    [394/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [395/451] Building C object modules/nanopb/CMakeFiles/modules__nanopb.dir/home/tcunha/zp/modules/lib/nanopb/pb_encode.c.obj
    [396/451] Linking C static library modules/nanopb/libmodules__nanopb.a
    [397/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [398/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_grtc.c.obj
    [399/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_common.c.obj
    [400/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_rramc.c.obj
    [401/451] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/tcunha/zp/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [402/451] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [403/451] Linking C static library modules/segger/libmodules__segger.a
    [404/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [405/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_encode.c.obj
    [406/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [407/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [408/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [409/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [410/451] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/home/tcunha/zp/modules/lib/zcbor/src/zcbor_decode.c.obj
    [411/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [412/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [413/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [414/451] Linking C static library modules/zcbor/libmodules__zcbor.a
    [415/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [416/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [417/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [418/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [419/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [420/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [421/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [422/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [423/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [424/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [425/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [426/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [427/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [428/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [429/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [430/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [431/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [432/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [433/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [434/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [435/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [436/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [437/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/events.c.obj
    [438/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [439/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [440/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [441/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [442/451] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [443/451] Linking C static library zephyr/kernel/libkernel.a
    [444/451] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/tcunha/zp/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [445/451] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [446/451] Linking C executable zephyr/zephyr_pre0.elf
    [447/451] Generating linker.cmd
    [448/451] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [449/451] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [450/451] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [451/451] Linking C executable zephyr/zephyr.elf
               FLASH:      287760 B       512 KB     54.89%
                 RAM:      116828 B       188 KB     60.69%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/tcunha/zp/m_band/app/build/mcuboot_secondary_app/zephyr/zephyr.elf for board: mband
    [54/69] cd /home/tcunha/zp/m_band/app/build/_sysbuild && /home/tcunha/miniconda3/lib/python3.12/site-packages/cmake/data/bin/cmake -E true
    [55/69] Creating signature of application
    [59/69] Generating ../dfu_application.zip
    [60/69] Creating validation for zephyr.hex, storing to signed_by_b0_s1_image.hex
    [62/69] Generating ../mcuboot_secondary.hex
    [63/69] Generating ../s1.hex
    [64/69] Generating ../signed_by_mcuboot_and_b0_s1_image.bin
    [65/69] Generating ../mcuboot_secondary_1.hex
    [66/69] Generating ../signed_by_mcuboot_and_b0_s1_image.hex
    [67/69] Generating ../s0_and_s1.hex
    [68/69] Generating ../dfu_mcuboot.zip
    [69/69] Generating ../merged.hex
    Partition map:
    app:
      address: 0x2b800
      end_address: 0xac000
      region: flash_primary
    app_image:
      address: 0x2b800
      end_address: 0xab800
      span:
      - app
    b0:
      address: 0x0
      end_address: 0x10000
    b0_container:
      address: 0x0
      span:
      - b0
    bootconf:
      address: 0xffd080
      end_address: 0xffd084
      region: bootconf
    external_fcb_storage:
      address: 0x0
      end_address: 0x1000000
      region: external_flash
    external_flash:
      address: 0x0
    mcuboot:
      address: 0x10800
      end_address: 0x1d800
    mcuboot_pad:
      address: 0x2b000
      end_address: 0x2b800
    mcuboot_primary:
      address: 0x2b000
      span:
      - mcuboot_pad
      - app
    mcuboot_primary_1:
      address: 0x10000
      end_address: 0x1d000
      span:
      - s0
    mcuboot_primary_app:
      address: 0x2b800
      span:
      - app
    mcuboot_secondary:
      address: 0xac000
      end_address: 0x12c800
      span:
      - mcuboot_secondary_pad
      - mcuboot_secondary_app
    mcuboot_secondary_1:
      address: 0x1d800
      end_address: 0x2a800
      span:
      - s1
    mcuboot_secondary_app:
      address: 0xac800
      share_size:
      - mcuboot_primary_app
    mcuboot_secondary_pad:
      address: 0xac000
      end_address: 0xac800
      share_size:
      - mcuboot_pad
    otp:
      address: 0xffd960
      end_address: 0xffd9fc
      region: otp
    provision:
      address: 0xffd500
      end_address: 0xffd960
      region: otp
    s0:
      address: 0x10000
      span:
      - mcuboot
      - s0_pad
    s0_and_s1:
      address: 0x10000
      end_address: 0x3b000
      span:
      - s0
      - s1
    s0_image:
      address: 0x10800
      span:
      - mcuboot
    s0_pad:
      address: 0x10000
      end_address: 0x10800
      share_size:
      - mcuboot_pad
    s1:
      address: 0x1d800
      end_address: 0x2b000
      span:
      - s1_pad
      - s1_image
    s1_image:
      address: 0x1e000
      share_size:
      - mcuboot
    s1_pad:
      address: 0x1d800
      end_address: 0x1e000
      share_size:
      - mcuboot_pad
    settings_storage:
      address: 0x12c800
      end_address: 0x165000
    sram_primary:
      address: 0x20000000
      end_address: 0x2002f000
      region: sram_primary
    My static partitioning map:
    b0:
      address: 0x0
    b0_container:
      address: 0x0
      span: [b0]
    s0:
      address: 0x10000
      span: [mcuboot, s0_pad]
    s0_pad:
      address: 0x10000
      share_size: [mcuboot_pad]
    s0_image:
      address: 0x10800
      span: [mcuboot]
    mcuboot:
      address: 0x10800
    s1:
      address: 0x1D800
      span: [s1_pad, s1_image]
    s1_pad:
      address: 0x1D800
    s1_image:
      address: 0x1E000
      share_size: [mcuboot]
    s0_and_s1:
      address: 0x10000
      span: [s0, s1]
    mcuboot_primary:
      address: 0x2B000
      span: [mcuboot_pad, app]
    mcuboot_pad:
      address: 0x2B000
      address: 0x2B800
      span: [app]
    app_image:
      address: 0x2B800
      span: [app]
    app:
      address: 0x2B800
    mcuboot_secondary:
      address: 0xAC000
      span: [mcuboot_secondary_pad, mcuboot_secondary_app]
      address: 0xAC000
      address: 0xAC800
      share_size: [mcuboot_primary_app]
    settings_storage:
      address: 0x12C800
    external_flash:
      address: 0x00000000
      address: 0x00000000
  • Thank you. Initial glance it looks fine. All images seem to fit well within the generated partition map and the generated map seems to match the static partitioning map (i.e no misconfiguration looks to have happened during building). Build logs also matches this.
    I don't think this is the rootcause, but I spotted this warning (just an implicit declaration). Is this from any customization that you've done or does the default nsib bootloader source code trigger this warning? Curious if this warning is something we need to fix in the SDK.
    L865 in the log:
    /home/tcunha/zp/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c:62:10: warning: implicit declaration of function 'swap_erase_trailer_sectors' [-Wimplicit-function-declaration]
    62 | rc = swap_erase_trailer_sectors(state, fap_sec);
    Tcunha said:
    Adding more context, previously a bootloader system using direct-XIP with revert and a simple single-stage bootloader (MCUboot) was working perfectly. However, since the intention was to have an upgradable bootloader, we migrated from a single-stage to a two-stage bootloader setup, as described. To support this the following configuration were added:
    One thought I had here. You state that you previously had a direct-xip with revert and that you've now introduced nsib and a bootloader chain. Did you move a way from the direct-xip solution you had? I don't see SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP=y in your configuration which is why I'm asking. You only implicitely mention that you have SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP and the revert option since you state "To support this the following configuration were added:". Did you add this to the existing sysbuild.conf and mcuboot/sysbuild.conf (and maybe also sysbuild/b0.conf) or are the sysbuild.conf contents below all you have present in your files?
    Andreas
