After using the APPROTECT function, complete erasure became impossible.that right?
My customer is now unable to disable secure erasure after using the APPROTECT function. Is this correct?
Please let me know if there is another way to check this.
”nrfjprog --recover”log
PS C:\Users\hoko> nrfjprog --memrd 0x10001200 --n 4
0x10001200: FFFFFFFF |....|
PS C:\Users\hoko> nrfjprog --memrd 0x10001004 --n 4
0x10001004: FFFFFFFF |....|
PS C:\Users\hoko> nrfjprog --log --recover --clockspeed 1000
Recovering device. This operation might take 30s.
Erasing user code and UICR flash areas.
Writing image to disable ap protect.
Flash Programer Check Image.
Erase Log (Flash Programmer)
20:13:30.343   Device connected with the serial number 000483012562
20:13:52.798   Getting serial port options from the persistent store for 000483012562.pc-nrfconnect-programmer
20:13:52.799   Device connected with the serial number 000483012562
20:13:55.525   Selecting device with the serial number 000483012562
20:13:56.354   Selected device with the serial number 000483012562
20:13:56.354   Using nrfutil device to communicate with target via JLink
20:13:56.355   JLink OB firmware version J-Link OB-SAM3U128 V3 compiled Sep 13 2023 14:47:14
20:13:56.355   Device family
20:13:56.355   Device version
20:13:56.356   Board version
20:13:57.395   Reading readback protection status for Application core
20:13:57.396   Reading readback protection status for Application core 0%
20:13:57.417   Reading readback protection status for Application core 100%
20:13:57.417   Application core protection status 'NRFDL_PROTECTION_STATUS_ALL'
20:13:57.420   Reading readback protection status for Application core completed
20:13:57.551   Skipping reading core Application information as it is protected.
20:13:59.827   Reading readback protection status for Application core
20:13:59.828   Reading readback protection status for Application core 0%
20:13:59.845   Reading readback protection status for Application core 100%
20:13:59.845   Application core protection status 'NRFDL_PROTECTION_STATUS_ALL'
20:13:59.846   Reading readback protection status for Application core completed
20:13:59.991   Device is loaded and ready for further operation
20:14:03.977   Recovering Application core
20:14:03.978   Recovering Application core 0%
20:14:06.081   Recovering Application core 100%
20:14:06.082   Recovering Application core completed
20:14:06.082   Loading core information for Application core
20:14:06.083   Loading core information for Application core 0%
20:14:06.109   Loading core information for Application core 100%
20:14:06.111   Loading core information for Application core completed
20:14:09.171   Reading readback protection status for Application core
20:14:09.172   Reading readback protection status for Application core 0%
20:14:09.180   Reading readback protection status for Application core 100%
20:14:09.180   Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
20:14:09.181   Reading readback protection status for Application core completed
20:14:19.528   Reading memory for Application core
20:14:19.529   Reading memory for Application core 0%
20:14:23.133   Reading memory for Application core 100%
20:14:23.605   Reading memory for Application core completed
20:14:23.607   Parse memory regions for Application core
Thanks
Hoko
  • No, you would not have been able to read from the FLASH if readback protection was still enabled.
    PS C:\Users\hoko> nrfjprog --memrd 0x00000000 --n 16
    0x00000000: 20020000 0000057D 000
    This is the beginning of the firmware image that is loaded after the chip is erased here:
    PS C:\Users\hoko> nrfjprog --recover
    PS C:\Users\hoko> nrfjprog --rbp all --log
    Protected the device against read and debug. Only a --recover, --debugreset,
    or --pinreset operations will work from now on.
    The "recover" command will first erase the chip through the CTRL-AP then it will load a small FW binary which will do the SW unlocking of the approtect mechansim.
    Please clarify what you're trying to do or achieve.
  • OK, I see what I don't understand. Could you please show me a document that explains "This is the beginning of the firmware image that is loaded after the chip is erased here:"? I'll study it.
  • I just wanted to erase all mem, and the steps below seem to have done the trick, so I think I'll go ahead with this. Thank you so much for your support.
    PS C:\Users\hoko> nrfjprog --eraseall
    Erasing user available code and UICR flash areas.
    Applying system reset.
    0x00000000: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF |................|
