Wake up after sys_poweroff() via GPIO inconsistent
I was doing a demo code to implement a wake up triggered by motion. I was able to make it work with the integrated low power accelerometer on thingy52 but it only worked 1 time after turning off and on the board. After some research I found out that the problem might be in the internal latch of the accelerometer and it was suggested to read the register to clear that latch. I started doing that before configuring the interrupt, but the behavior is not consistent. Sometimes it works, other times not.
Here is the code I amusing:
main.c
#include "bt_service.h"
#include "accelerometer.h"
#include <zephyr/sys/poweroff.h>
LOG_MODULE_REGISTER(STATE_MACHINE, LOG_LEVEL_INF);
    init_bt_service();
    init_advertise();
    k_sleep(K_SECONDS(10));
    LOG_INF("%s system off demo\n", CONFIG_BOARD);
    init_accelerometer();
    sys_poweroff();
    return 0;
accelerometer.c
LOG_MODULE_REGISTER(ACCELEROMETER, LOG_LEVEL_INF);
const struct device *accelerometer = DEVICE_DT_GET_ANY(st_lis2dh12);
const struct gpio_dt_spec accelerometer_gpio = GPIO_DT_SPEC_GET(DT_NODELABEL(lis2dh12), irq_gpios);
const struct i2c_dt_spec accelerometer_i2c = I2C_DT_SPEC_GET(DT_NODELABEL(lis2dh12));
static void lis2dh_trigger_handler(const struct device *accelerometer, const struct sensor_trigger *trig)
    struct sensor_value xyz[3];
    if (sensor_sample_fetch(accelerometer)) {
        LOG_ERR("Failed to fetch sensor sample");
        return;
    if (sensor_channel_get(accelerometer, SENSOR_CHAN_ACCEL_XYZ, xyz)) {
        LOG_ERR("Failed to get sensor channel: accel");
        return;
    LOG_INF("Movement detected: X=%d mg, Y=%d mg, Z=%d mg",
        (int)(sensor_value_to_double(&xyz[0]) * 1000),
        (int)(sensor_value_to_double(&xyz[1]) * 1000),
        (int)(sensor_value_to_double(&xyz[2]) * 1000));
    stop_accelerometer();
static void clear_accelerometer_interrupt_line()
    uint8_t src;
    if (!device_is_ready(accelerometer_i2c.bus)) {
        LOG_ERR("I2C bus not ready to clear LIS2DH interrupt");
        return;
    if (i2c_reg_read_byte(accelerometer_i2c.bus, LIS2DH_ADDR, LIS2DH_REG_INT1_SRC, &src)) {
        LOG_ERR("Failed to read INT1_SRC");
    LOG_INF("Cleared LIS2DH interrupt, INT1_SRC=0x%02X", src);
void configure_accelerometer_wakeup_gpio() {
    if(gpio_pin_configure_dt(&accelerometer_gpio, GPIO_INPUT)) {
        LOG_INF("Could not configure accelerometer GPIO");
        return;
    if (gpio_pin_interrupt_configure_dt(&accelerometer_gpio, GPIO_INT_LEVEL_ACTIVE)) {
        LOG_INF("Could not configure accelerometer GPIO interrupt");
        return;
    NRF_GPIO->PIN_CNF[accelerometer_gpio.pin] |= (GPIO_PIN_CNF_SENSE_High << GPIO_PIN_CNF_SENSE_Pos);
void init_accelerometer(void)
    if (accelerometer == NULL) {
        LOG_ERR("Accelerometer device not found");
        return;
    if (!device_is_ready(accelerometer)) {
        LOG_ERR("Accelerometer not ready");
        return;
    clear_accelerometer_interrupt_line();
    k_sleep(K_SECONDS(1));
    double sensitivity_value = ACCELEROMETER_TRIGGER_SENSITIVITY_VALUE * GRAVITY_CONSTANT;
    struct sensor_value attr;
    attr.val1 = (int32_t)sensitivity_value;
    attr.val2 = (int32_t)((double)(sensitivity_value - (int32_t)(sensitivity_value)) * 1000000);
    if(sensor_attr_set(accelerometer, SENSOR_CHAN_ACCEL_XYZ, SENSOR_ATTR_SLOPE_TH, &attr)){
        LOG_ERR("Failed to set slope");
        return;
    struct sensor_trigger trig = {
        .type = SENSOR_TRIG_DELTA,
        .chan = SENSOR_CHAN_ACCEL_XYZ,
    if (IS_ENABLED(CONFIG_LIS2DH_ODR_RUNTIME)) {
        struct sensor_value odr = {
            .val1 = SAMPLE_FREQUENCY,
            .val2 = 0,
        if (sensor_attr_set(accelerometer, trig.chan, SENSOR_ATTR_SAMPLING_FREQUENCY, &odr)) {
            LOG_ERR("Failed to set odr");
            return;
    if (sensor_trigger_set(accelerometer, &trig, lis2dh_trigger_handler)) {
        LOG_ERR("Failed to set trigger");
        return;
    configure_accelerometer_wakeup_gpio();
    LOG_INF("Accelerometer device is ready");
void stop_accelerometer() {
        .val1 = 0,
        .val2 = 0
    if (sensor_attr_set(accelerometer, SENSOR_CHAN_ACCEL_XYZ, SENSOR_ATTR_SAMPLING_FREQUENCY, &odr)) {
        LOG_ERR("Failed to set ODR to 0");
    LOG_INF("Accelerometer stopped");
The Bluetooth initialization is standard and it's just to see when the device wakes up without needing the terminal.
    I have looked at your code. You code calls clear_accelerometer_interrupt_line() only during initialization. To improve the realibity you have to call the function inside the trigger handler also. Like the following way inside lis2dh_trigger_handler() function
     // *** Clear the interrupt latch after handling the event ***
     Then it ensures the interrupt line is properly cleared before enabling the interrupts and after each event, allowing the device to detect subsequent motion reliably.
    There is a previous case you can look at  https://devzone.nordicsemi.com/f/nordic-q-a/113782/correct-procedure-to-initialize-and-configure-lis2dh12-for-stream-mode.
    You can try the following code?
    // accelerometer.c
    // Function to clear the interrupt latch by reading INT1_SRC
        uint8_t src;
            return;
    // Trigger handler for motion event
            return;
            return;
            return;
            return;
            return;
            return;
        // *** Clear the interrupt latch during initialization ***
            return;
                .val2 = 0,
                return;
            return;
            .val1 = 0,
            .val2 = 0
  • Thank you for your help. I did extensive testing and it seems to be working now. I will continue testing during this week and the beginning of the next one and update here if I have any more problems.
  • That's great to hear. Thanks for letting me know. Yeah, you can show me the further improvement and the chang you would make on your application.
  • Sorry for the late response, I’ve been doing some testing and haven’t found any more errors or bugs. The solution seems to be working well and reliably.
    Just a heads-up: if you stop the accelerometer without initializing it first and then try to initialize it afterwards, it won’t work correctly.
    Again, thank you for your help
