Meaning of UART_ERROR_FRAMING in UART_RX_STOPPED event on nRF9161DK Asynch UART
Hello, I'm developing on an application which requires to catch high speed, variable size and bursty (~0.5 Mbit/s) data from a sensor connected to a nRF9161DK trough a UART without flow control.
This is the code of the very simple application making use of Async UART API ...
 * Copyright (c) 2019 Tavish Naruka <[email protected]>
 * Copyright (c) 2023 Nordic Semiconductor ASA
 * Copyright (c) 2023 Antmicro <www.antmicro.com>
/* Sample which uses the filesystem API and SDHC driver */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <stdlib.h>
#include <zephyr/drivers/uart.h>
LOG_MODULE_REGISTER(main);
#define UART_BUF_SIZE 512
#define UART_RX_TIMEOUT_MS 10000
// UART RX primary buffers
uint8_t uart_double_buffer[2][UART_BUF_SIZE];
uint8_t *uart_buf_next = uart_double_buffer[1];
uint8_t complete_message[UART_BUF_SIZE];
uint8_t complete_message_counter = 0;
bool currently_active_buffer = 1; // 0 - uart_double_buffer[0] is active, 1 - uart_double_buffer[1] is active
static const struct device *dev_uart;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	switch (evt->type)
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY:  received %i bytes, Offset = %i ", evt->data.rx.len,evt->data.rx.offset);
	case UART_RX_BUF_REQUEST:
		uart_rx_buf_rsp(dev_uart, uart_buf_next, UART_BUF_SIZE);
		currently_active_buffer = !currently_active_buffer;
		if (currently_active_buffer == 0)
			LOG_DBG("UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0] ");
			LOG_DBG("UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1] ");
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		uart_buf_next = evt->data.rx_buf.buf;
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		k_sem_give(&rx_disabled);
	case UART_RX_STOPPED:
		switch (evt->data.rx_stop.reason)
		case UART_ERROR_OVERRUN:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_OVERRUN");
		case UART_ERROR_PARITY:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_PARITY");
		case UART_ERROR_FRAMING:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_FRAMING");
		case UART_BREAK:
			LOG_DBG("UART_RX_STOPPED UART_BREAK");
		case UART_ERROR_COLLISION:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_COLLISION");
		case UART_ERROR_NOISE:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_NOISE");
TStationConfig StationConfig;
int app_uart_init()
	dev_uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
	if (!device_is_ready(dev_uart))
		return 0;
	int err;
	err = uart_callback_set(dev_uart, uart_cb, NULL);
	if (err)
		return err;
	LOG_DBG("UART1 RX enabled");
	uart_rx_enable(dev_uart, uart_double_buffer[0], UART_BUF_SIZE, UART_RX_TIMEOUT_MS);
	return 0;
    app_uart_init();
	while (1) {
		k_sleep(K_MSEC(10000));
	return 0;
  As long as there is data coming from the external sensor things seems to work as expected:
*** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
*** Using Zephyr OS v4.0.99-f791c49f492c ***
[00:00:00.252,868] <dbg> os: k_sched_unlock: scheduler unlocked (0x20000960:0)
[00:00:00.252,899] <dbg> main: app_uart_init: UART1 RX enabled
[00:00:00.252,929] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:00.252,929] <dbg> os: z_tick_sleep: thread 0x20000960 for 327680 ticks
[00:00:01.240,051] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:01.240,081] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:01.240,112] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:01.250,396] <dbg> main: uart_cb: UART_RX_RDY:  received 88 bytes, Offset = 0
[00:00:01.250,396] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:01.250,427] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:02.239,685] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:02.239,715] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:02.239,715] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:02.252,014] <dbg> main: uart_cb: UART_RX_RDY:  received 185 bytes, Offset = 0
[00:00:02.252,044] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:02.252,075] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:03.241,882] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:03.241,912] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:03.241,943] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:03.256,225] <dbg> main: uart_cb: UART_RX_RDY:  received 201 bytes, Offset = 0
[00:00:03.256,225] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:03.256,256] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
Instead, when I power off the external sensor and e reboot the nRF9161DK board I get the following sequence:
[00:00:00.353,332] <dbg> os: k_sched_unlock: scheduler unlocked (0x20000960:0)
[00:00:00.353,363] <dbg> main: app_uart_init: UART1 RX enabled
[00:00:00.353,393] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:00.353,424] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,424] <dbg> os: z_tick_sleep: thread 0x20000960 for 327680 ticks
[00:00:00.353,454] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,485] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,515] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,546] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,576] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:00.353,607] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:00.353,607] <dbg> main: uart_cb: UART_RX_DISABLED
[00:00:00.353,637] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
What is the meaning of UART_ERROR_FRAMING (I was expecting a timeout instead)?
What is causing UART_RX_DISABLED ?
Joel
  • nrf9161dk_nrf9161.overlay:
    &spi3 {
        cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>, /* D10 */
                   <&gpio0          20 GPIO_ACTIVE_LOW>;
        sdhc0: sd@0 { // SPI SD card
            compatible = "zephyr,sdhc-spi-slot";
            reg = <0>; // First chip select in the spi3 definition
            status = "okay";
            reg = <0>;
            spi-max-frequency = <8000000>; // 1 MHz
            mmc {
                compatible = "zephyr,sdmmc-disk";
                status = "okay";
                disk-name = "SD";
    &uart1 {
    	status = "okay";
    	current-speed = <460800>;
    	pinctrl-0 = <&uart1_default>;
    	pinctrl-1 = <&uart1_sleep>;
    prj.conf:
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_PRINTK=y
    CONFIG_MAIN_STACK_SIZE=2048
    CONFIG_DEBUG=y
    CONFIG_SPI=y
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    #CONFIG_UART_LINE_CTRL=n
    CONFIG_CPP=y
    CONFIG_REQUIRES_FULL_LIBCPP=y
    CONFIG_CBPRINTF_FP_SUPPORT=y
    CONFIG_LOG_MAX_LEVEL=4
    Joel
  • Instead, when I power off the external sensor and e reboot the nRF9161DK board I get the following sequence:
    Can you explain how to achieve this? I don't have your sensor, but I assume the behavior is the same if the sensor is powered off. I don't run into any error.
    You are not doing anything other than sleeping in main(). But even running app_uart_init() I don't get any errors.
  • Since you do not have my sensor you should always get UART_ERROR_FRAMING and then after 4 of those events the UART gets halted.
    Reading form a UART which do not has inbound data triggers UART_ERROR_FRAMING.
    Just sleep on the main and UART calback. It seems to me that instead of triggering UART_RX_RDY with a zero length which indicates a timeout the system generates UART_ERROR_FRAMING events... which is unexpected according to my understanding of the documentation.
    Joel
    Yes, agreed. But can you test this yourself? I don't get the error, but if you do then that would indicate that something might be wrong with your hardware.
