Meaning of UART_ERROR_FRAMING in UART_RX_STOPPED event on nRF9161DK Asynch UART
Hello, I'm developing on an application which requires to catch high speed, variable size and bursty (~0.5 Mbit/s) data from a sensor connected to a nRF9161DK trough a UART without flow control.
This is the code of the very simple application making use of Async UART API ...
 * Copyright (c) 2019 Tavish Naruka <[email protected]>
 * Copyright (c) 2023 Nordic Semiconductor ASA
 * Copyright (c) 2023 Antmicro <www.antmicro.com>
/* Sample which uses the filesystem API and SDHC driver */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <stdlib.h>
#include <zephyr/drivers/uart.h>
LOG_MODULE_REGISTER(main);
#define UART_BUF_SIZE 512
#define UART_RX_TIMEOUT_MS 10000
// UART RX primary buffers
uint8_t uart_double_buffer[2][UART_BUF_SIZE];
uint8_t *uart_buf_next = uart_double_buffer[1];
uint8_t complete_message[UART_BUF_SIZE];
uint8_t complete_message_counter = 0;
bool currently_active_buffer = 1; // 0 - uart_double_buffer[0] is active, 1 - uart_double_buffer[1] is active
static const struct device *dev_uart;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	switch (evt->type)
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY:  received %i bytes, Offset = %i ", evt->data.rx.len,evt->data.rx.offset);
	case UART_RX_BUF_REQUEST:
		uart_rx_buf_rsp(dev_uart, uart_buf_next, UART_BUF_SIZE);
		currently_active_buffer = !currently_active_buffer;
		if (currently_active_buffer == 0)
			LOG_DBG("UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0] ");
			LOG_DBG("UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1] ");
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		uart_buf_next = evt->data.rx_buf.buf;
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		k_sem_give(&rx_disabled);
	case UART_RX_STOPPED:
		switch (evt->data.rx_stop.reason)
		case UART_ERROR_OVERRUN:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_OVERRUN");
		case UART_ERROR_PARITY:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_PARITY");
		case UART_ERROR_FRAMING:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_FRAMING");
		case UART_BREAK:
			LOG_DBG("UART_RX_STOPPED UART_BREAK");
		case UART_ERROR_COLLISION:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_COLLISION");
		case UART_ERROR_NOISE:
			LOG_DBG("UART_RX_STOPPED UART_ERROR_NOISE");
TStationConfig StationConfig;
int app_uart_init()
	dev_uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
	if (!device_is_ready(dev_uart))
		return 0;
	int err;
	err = uart_callback_set(dev_uart, uart_cb, NULL);
	if (err)
		return err;
	LOG_DBG("UART1 RX enabled");
	uart_rx_enable(dev_uart, uart_double_buffer[0], UART_BUF_SIZE, UART_RX_TIMEOUT_MS);
	return 0;
    app_uart_init();
	while (1) {
		k_sleep(K_MSEC(10000));
	return 0;
  As long as there is data coming from the external sensor things seems to work as expected:
*** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
*** Using Zephyr OS v4.0.99-f791c49f492c ***
[00:00:00.252,868] <dbg> os: k_sched_unlock: scheduler unlocked (0x20000960:0)
[00:00:00.252,899] <dbg> main: app_uart_init: UART1 RX enabled
[00:00:00.252,929] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:00.252,929] <dbg> os: z_tick_sleep: thread 0x20000960 for 327680 ticks
[00:00:01.240,051] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:01.240,081] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:01.240,112] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:01.250,396] <dbg> main: uart_cb: UART_RX_RDY:  received 88 bytes, Offset = 0
[00:00:01.250,396] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:01.250,427] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:02.239,685] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:02.239,715] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:02.239,715] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:02.252,014] <dbg> main: uart_cb: UART_RX_RDY:  received 185 bytes, Offset = 0
[00:00:02.252,044] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:02.252,075] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:03.241,882] <dbg> main: uart_cb: UART_RX_RDY:  received 512 bytes, Offset = 0
[00:00:03.241,912] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:03.241,943] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[1]
[00:00:03.256,225] <dbg> main: uart_cb: UART_RX_RDY:  received 201 bytes, Offset = 0
[00:00:03.256,225] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:03.256,256] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
Instead, when I power off the external sensor and e reboot the nRF9161DK board I get the following sequence:
[00:00:00.353,332] <dbg> os: k_sched_unlock: scheduler unlocked (0x20000960:0)
[00:00:00.353,363] <dbg> main: app_uart_init: UART1 RX enabled
[00:00:00.353,393] <dbg> main: uart_cb: UART_RX_BUF_REQUEST: current active buffer uart_double_buffer[0]
[00:00:00.353,424] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,424] <dbg> os: z_tick_sleep: thread 0x20000960 for 327680 ticks
[00:00:00.353,454] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,485] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,515] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,546] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
[00:00:00.353,576] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:00.353,607] <dbg> main: uart_cb: UART_RX_BUF_RELEASED
[00:00:00.353,607] <dbg> main: uart_cb: UART_RX_DISABLED
[00:00:00.353,637] <dbg> main: uart_cb: UART_RX_STOPPED UART_ERROR_FRAMING
What is the meaning of UART_ERROR_FRAMING (I was expecting a timeout instead)?
What is causing UART_RX_DISABLED ?
Joel
  • Hello, sorry it is quite a while since I signaled this issue (I head to many open stuff to close).
    In the meanwhile I had to change target (from nRF9161 to nRF9151) but the issue remains the same.
    In the zip file you get all what you need to reproduce the issue.
    test_async_uart_framing_error.zip
    To make the framing error appear at start you need to disable VCOM1 using The nRF Board Configurator. Doing so I get:
    *** Booting nRF Connect SDK v3.1.0-6c6e5b32496e ***
    *** Using Zephyr OS v4.1.99-1612683d4010 ***
    UART1 RX enabled
    UART_RX_DISABLED
    This is exactly what I get when I reboot my external sensor.
    Regards, Joel
  • I guess I found what is causing the problem. As long as UART1 is driven by nRF5340 (which is the default), UART1 RX continues to be driven. When disconnecting UART1 from nRF5340 (board configurator) and there is no sensor attached, UART RX is not driven and goes to a logical 0. This seems to be the cause of the framing errors. By adding a Pull-up to UART1 RX I get rid of the framing errors when the sensor is not attached. Unfortunately when I reboot the external sensor (which is required for certain configuration changes) there is a small period of time during which UART RX is not driven or kept low. This is the causing runtime framing errors.
    Regards, Joel
