MQTT with TLS DevZone (l4_e2) fails to build
I get a bunch of errors like undefined reference to `mbedtls_ssl_free', `mbedtls_ssl_get_bytes_avail',`mbedtls_ssl_config_free', 'mbedtls_ssl_read'
 `mbedtls_ssl_set_bio' and `mbedtls_ssl_handshake'`mbedtls_ssl_get_bytes_avail'
I compare my solution to the given solution and neither build, although the solution was missing a few small configs added in the newer version of the course.
Exercise 2 - Nordic Developer Academy
thanks for your help, this is my first time.
  • Hi Noah,
    It looks like there are an error while building for the Non Secure version (which I have assumed you did). I could not immidiatly isolate the issue, but if you want a quick fix you could try building for the secure version (without trailing /ns). Also, what NCS version are you using?
  • Yes, I was doing /ns because the example says it's needed for TLS. I'm using 3.0.2..
    When I build without it, I get different errors like "undefined reference to `wifi_credentials_backend_init'"
    Are you able to get the solution to build?
  • Hi Noah,
    Apologies for the delayed response. We've had limited availability recently due to summer break.
    It looks like this exercise is missing some porting to the current version of NCS. If you are interested in a quick fix you can set these symbols in your prj.conf file and build without TF-M (without /ns).
    CONFIG_WIFI_CREDENTIALS_STATIC=y
    CONFIG_WIFI_CREDENTIALS_STATIC_SSID="ssid123"
    CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="pwd123"
    I will report this to the DevAcademy team. Thanks for pointing this out!
    Benjamin
