The peripheral_nfc_pairing sample code pairs and connects, but Android shows a "Couldn't pair" message
I have been trying to use the `nrf\samples\bluetooth\peripheral_nfc_pairing` sample code on the nRF Connect SDK v3.0.2 to connect to a Samsung Galaxy A16 5G phone.
The NFC pairing seems to work, and the connection is working. However, every time the pairing is done, after 20 seconds, I get a message pop-up toast from the Android OS saying "Couldn't pair with Nordic_NFC_pairing". See the screenshot below that shows the pop-up and the bonded connected state of the nRF Connect app. I have also tried clearing the bonded devices on both the nrf5340dk and the phone, but it looks the same.
I have seen people reporting a similar issue before:
Given that the items above are all very old. I was wondering if there are any updates on this.
How do you suggest that I hide the pop-up toast message?
  • Also, the NFC pairing sample does not allow to reconnect to the device without creating new encryption keys. Every time you tap NFC with a phone it starts a new bonding process. Instead, it would be better that with existing keys the firmware should either use direct advertising or regular and allow reconnection without the need for NFC tapping.
    This may need for unwanted consequences, e.g. failing re-pairing if bond already exists, or when trying to bond with another phone. I recommend re-flashing the device each time or making sure the bond information is erased, and "forgetting" the device, or even restarting Bluetooth, on Android before each try.
  • Thanks for the detailed description. Is there a configuration on the NFC pairing that would only do "pairing" and not start a service discovery or connection?
    Alternatively, can we simulate/fake a supported service for the Android phone so it wouldn't fail?
    Regarding the first part - it will always start a service discovery, as the system is looking for service which it may support, like HID.
    Regartding the second part - this is a very interesting question. First of all, I would search for the code that displays the error message. I found where "Couldn't pair with ..." is sent: https://cs.android.com/android/platform/superproject/main/+/main:frameworks/base/packages/SettingsLib/src/com/android/settingslib/bluetooth/BluetoothEventManager.java;l=459 (and there's a listener added to BluetoothUtils that shows a Toast if the Settings app is in background).
    This one, however, is more interesting, as it shows which service is the Android looking for:
    https://cs.android.com/android/platform/superproject/main/+/main:packages/modules/Nfc/NfcNci/src/com/android/nfc/handover/BluetoothPeripheralHandover.java;l=466?q=connect_peripheral_failed
    Seems like only for HID service, and if found, it will show a toast saying Connected (which may be better, than Cannot Connect). Try adding an empty (?) HID Service.
  • I tried adding pieces of the HIDs Keyboard sample into the NFC pairing in a way that I can see the service and its characteristics inside nrf Connect app. But sadly, the error still shows up.
    Here is my patch:
    diff --git a/samples/bluetooth/peripheral_nfc_pairing/prj.conf b/samples/bluetooth/peripheral_nfc_pairing/prj.conf
    index ad1e05fea..e4481aa6c 100644
    --- a/samples/bluetooth/peripheral_nfc_pairing/prj.conf
    +++ b/samples/bluetooth/peripheral_nfc_pairing/prj.conf
    @@ -29,6 +29,11 @@ CONFIG_BT_SMP_SC_PAIR_ONLY=n
     CONFIG_BT_PERIPHERAL=y
     CONFIG_BT_DEVICE_NAME="Nordic_NFC_pairing"
    +CONFIG_BT_HIDS=y
    +CONFIG_BT_CONN_CTX=y
    +CONFIG_BT_GATT_UUID16_POOL_SIZE=40
    +CONFIG_BT_GATT_CHRC_POOL_SIZE=20
     CONFIG_BT_DIS=y
     CONFIG_BT_DIS_MANUF_NAME=y
     CONFIG_BT_DIS_MANUF_NAME_STR="NordicSemiconductor"
    diff --git a/samples/bluetooth/peripheral_nfc_pairing/src/main.c b/samples/bluetooth/peripheral_nfc_pairing/src/main.c
    index e05510a03..1378cbb79 100644
    --- a/samples/bluetooth/peripheral_nfc_pairing/src/main.c
    +++ b/samples/bluetooth/peripheral_nfc_pairing/src/main.c
    @@ -10,6 +10,7 @@
     #include <zephyr/bluetooth/conn.h>
     #include <zephyr/bluetooth/uuid.h>
     #include <zephyr/bluetooth/gatt.h>
    +#include <bluetooth/services/hids.h>
     #include <dk_buttons_and_leds.h>
    @@ -56,9 +57,23 @@ K_MSGQ_DEFINE(bonds_queue,
     	      CONFIG_BT_MAX_PAIRED,
     	      4);
    +/* HIDS instance. */
    +#define OUTPUT_REPORT_MAX_LEN  1
    +#define INPUT_REPORT_KEYS_MAX_LEN (1 + 1 + 6)
    +#define BASE_USB_HID_SPEC_VERSION 0x0101
    +#define INPUT_REP_KEYS_IDX     0
    +#define INPUT_REP_KEYS_REF_ID  0
    +#define OUTPUT_REP_KEYS_IDX    0
    +#define OUTPUT_REP_KEYS_REF_ID 0
    +BT_HIDS_DEF(hids_obj,
    +	    OUTPUT_REPORT_MAX_LEN,
    +	    INPUT_REPORT_KEYS_MAX_LEN);
     static const struct bt_data ad[] = {
     	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
     	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    +	BT_DATA_BYTES(BT_DATA_UUID16_ALL, BT_UUID_16_ENCODE(BT_UUID_HIDS_VAL),
    +					  BT_UUID_16_ENCODE(BT_UUID_BAS_VAL))
     static struct k_poll_signal pair_signal;
    @@ -362,6 +377,124 @@ static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
     	.pairing_failed = pairing_failed
    +static void hids_outp_rep_handler(struct bt_hids_rep *rep,
    +				  struct bt_conn *conn,
    +				  bool write)
    +	if (!write) {
    +		printk("Output report read\n");
    +		return;
    +	printk("Output report has been received \n");
    +static void hids_boot_kb_outp_rep_handler(struct bt_hids_rep *rep,
    +					  bool write)
    +	if (!write) {
    +		return;
    +	printk("Boot Keyboard Output report has been received \n");
    +static void hids_pm_evt_handler(enum bt_hids_pm_evt evt,
    +				struct bt_conn *conn)
    +	printk("HIDs event received %i\n", evt);
    +static void hid_init(void)
    +	int err;
    +	struct bt_hids_init_param    hids_init_obj = { 0 };
    +	struct bt_hids_inp_rep       *hids_inp_rep;
    +	struct bt_hids_outp_feat_rep *hids_outp_rep;
    +	static const uint8_t report_map[] = {
    +		0x05, 0x01,       /* Usage Page (Generic Desktop) */
    +		0x09, 0x06,       /* Usage (Keyboard) */
    +		0xA1, 0x01,       /* Collection (Application) */
    +		/* Keys */
    +#if INPUT_REP_KEYS_REF_ID
    +		0x85, INPUT_REP_KEYS_REF_ID,
    +#endif
    +		0x05, 0x07,       /* Usage Page (Key Codes) */
    +		0x19, 0xe0,       /* Usage Minimum (224) */
    +		0x29, 0xe7,       /* Usage Maximum (231) */
    +		0x15, 0x00,       /* Logical Minimum (0) */
    +		0x25, 0x01,       /* Logical Maximum (1) */
    +		0x75, 0x01,       /* Report Size (1) */
    +		0x95, 0x08,       /* Report Count (8) */
    +		0x81, 0x02,       /* Input (Data, Variable, Absolute) */
    +		0x95, 0x01,       /* Report Count (1) */
    +		0x75, 0x08,       /* Report Size (8) */
    +		0x81, 0x01,       /* Input (Constant) reserved byte(1) */
    +		0x95, 0x06,       /* Report Count (6) */
    +		0x25, 0x65,       /* Logical Maximum (101) */
    +		0x05, 0x07,       /* Usage Page (Key codes) */
    +		0x19, 0x00,       /* Usage Minimum (0) */
    +		0x29, 0x65,       /* Usage Maximum (101) */
    +		0x81, 0x00,       /* Input (Data, Array) Key array(6 bytes) */
    +		/* LED */
    +#if OUTPUT_REP_KEYS_REF_ID
    +		0x85, OUTPUT_REP_KEYS_REF_ID,
    +#endif
    +		0x95, 0x05,       /* Report Count (5) */
    +		0x05, 0x08,       /* Usage Page (Page# for LEDs) */
    +		0x19, 0x01,       /* Usage Minimum (1) */
    +		0x29, 0x05,       /* Usage Maximum (5) */
    +		0x91, 0x02,       /* Output (Data, Variable, Absolute), */
    +				  /* Led report */
    +		0x75, 0x03,       /* Report Size (3) */
    +		0x91, 0x01,       /* Output (Data, Variable, Absolute), */
    +				  /* Led report padding */
    +		0xC0              /* End Collection (Application) */
    +	hids_init_obj.rep_map.data = report_map;
    +	hids_init_obj.rep_map.size = sizeof(report_map);
    +	hids_init_obj.info.bcd_hid = BASE_USB_HID_SPEC_VERSION;
    +	hids_init_obj.info.b_country_code = 0x00;
    +	hids_init_obj.info.flags = (BT_HIDS_REMOTE_WAKE |
    +				    BT_HIDS_NORMALLY_CONNECTABLE);
    +	hids_inp_rep =
    +		&hids_init_obj.inp_rep_group_init.reports[INPUT_REP_KEYS_IDX];
    +	hids_inp_rep->size = INPUT_REPORT_KEYS_MAX_LEN;
    +	hids_inp_rep->id = INPUT_REP_KEYS_REF_ID;
    +	hids_init_obj.inp_rep_group_init.cnt++;
    +	hids_outp_rep =
    +		&hids_init_obj.outp_rep_group_init.reports[OUTPUT_REP_KEYS_IDX];
    +	hids_outp_rep->size = OUTPUT_REPORT_MAX_LEN;
    +	hids_outp_rep->id = OUTPUT_REP_KEYS_REF_ID;
    +	hids_outp_rep->handler = hids_outp_rep_handler;
    +	hids_init_obj.outp_rep_group_init.cnt++;
    +	hids_init_obj.is_kb = true;
    +	hids_init_obj.boot_kb_outp_rep_handler = hids_boot_kb_outp_rep_handler;
    +	hids_init_obj.pm_evt_handler = hids_pm_evt_handler;
    +	err = bt_hids_init(&hids_obj, &hids_init_obj);
    +	if (err) {
    +		printk("Failed to initialize HIDs\n");
    +	} else {
    +		printk("Initialized HIDs\n");
     static void connected(struct bt_conn *conn, uint8_t err)
    @@ -385,6 +518,14 @@ static void connected(struct bt_conn *conn, uint8_t err)
     	printk("Connected %s\n", addr);
     	dk_set_led_on(CON_STATUS_LED);
    +	err = bt_hids_connected(&hids_obj, conn);
    +	if (err) {
    +		printk("Failed to notify HID service about connection\n");
    +		return;
    +	} else {
    +		printk("Notified HID service about connection\n");
     	if (conn_cnt < CONFIG_BT_MAX_CONN) {
     		advertising_start();
    @@ -737,6 +878,8 @@ int main(void)
     		return 0;
    +	hid_init();
     	err = bt_enable(NULL);
     	if (err) {
     		printk("Bluetooth init failed (err %d)\n", err);
