NRF8001 antenna tuning
Hello!
I've developed a board with NRF8001 module mounted on it. Antenna on the board is much longer than in reference designs, so I can change the length. I also can add shunt capacitor/inductor. The problem is that I don't have a network analyzer. So is it real to tune the antenna without using special instruments?
  • Hello
    I just designed a board and chanced the reference design a little bit (different component layout with chip antenna). I got respectable range of 10 meter. I made the mistake to use 6mil trace instead of the suggest 8mil in the pcb reference design. So i hope my next board will be better.
    Try to keep you're design as close as possible to the reference layout and you will do fine without network analyzer if you are happy with a near perfect range (just for hobby).
    Calculate you're trace impendance here: emclab.mst.edu/.../index.html
    My Eagle files for my homemade PCB. The board is made of FR4 0.8mm thick NRF51822.rar. Maybe you can send your files if you would like some comment on your design. I also made a new design without my errors. So don't use the layout for your design.
    Nick
  • Thank you for your answer!
    I tryed to make antenna as it is shown in reference design, but nothing changed, device didn't work...
    Can you show a part of your schematic and pcb layout, please?
    Thank you in advance.
  • Here are my schematic and PCB layout, If you need I can send full Altium projects.
    drive.google.com/.../view
  • FormerMember
    0 FormerMember
    If you don't have any range at all, it is possible that the layout is the problem. It is very important the RF part of the layout is a copy of our reference layout: It means that not only the component values should be the same as in our reference layout, but also the distance between the components and the geometry between the components.
  • Hello!
    RF part is a full copy from nRF8001-Reference Layout_Ver1_0.
1 2 3
