Retrieving Custom Firmware Version from nRF52 BLE Controller to nRF9160 Host
Product: nRF Connect SDK v2.6.0
Hardware: nRF9160 (Host) connected via UART to nRF52832 (Controller)
Controller Firmware: zephyr/samples/bluetooth/hci_uart_async
I have a custom board featuring an nRF9160 and an nRF52832, connected via UART.
  • The nRF9160 runs my main application and acts as the Bluetooth Host.
  • The nRF52832 runs the hci_uart_async sample, acting as a Bluetooth Controller.
My goal is to enable the nRF9160 to query the custom firmware version (e.g., v0.19.0-3-g4847332acd8a) from the nRF52832. This version string is correctly defined in the VERSION file of the hci_uart_async project. I need this version to send it to our backend over LTE.
Currently, when the Bluetooth stack initializes, the nRF9160 only receives standard HCI information from the controller, not the custom application version I defined.
Log output on nRF9160:
[00:00:51.820,068] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:51.820,098] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:51.820,129] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
[00:00:51.825,164] <inf> bt_hci_core: Identity: FF:1A:3E:61:5B:4B (random)
[00:00:51.825,195] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
[00:00:51.825,225] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
[00:00:51.825,225] <inf> bluetooth: Start advertising
How can I implement a mechanism for the nRF9160 to request and receive the version string of the firmware from the nRF52832 controller?
These are the CONFIGs in prj.conf on the nRF52832 side:
# hci_uart_async
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
# hci_raw (dependency of hci_uart)
CONFIG_BT=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_HCI_RAW_H4=y
CONFIG_BT_HCI_RAW_H4_ENABLE=y
# Controller configuration. Modify these for your application's needs.
CONFIG_BT_MAX_CONN=2
CONFIG_BT_BUF_ACL_RX_SIZE=255
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
CONFIG_UART_CONSOLE=n
# Enable system off mode
CONFIG_PM_DEVICE=y
CONFIG_CRC=y
CONFIG_POWEROFF=y
And these are the relevant BLE-Related CONFIGs in prj.conf on the nRF9160 side:
# Bluetooth
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
## Apperance = Generic Sensor
CONFIG_BT_DEVICE_APPEARANCE=1344
# Device Information Service
CONFIG_BT_DIS=y
CONFIG_BT_DIS_SETTINGS=y
CONFIG_BT_DIS_PNP=n
CONFIG_BT_DIS_SERIAL_NUMBER=y
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_SW_REV=y
CONFIG_BT_DIS_HW_REV=y
# increase max length to 25 to hold 22 char ICCID which is our serial number.
CONFIG_BT_DIS_STR_MAX=25
## Enable Sleep Accuracy Update Procedure
CONFIG_BT_SCA_UPDATE=y
## Disable dedicated workqueue for long running GATT requests
CONFIG_BT_LONG_WQ=n
## Buffer configuration for large & efficient link layer and ATT payloads
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=502
## Pairing and bonding
CONFIG_BT_SMP=y
CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY=y
CONFIG_BT_BONDABLE=n
# Enable HCI support
CONFIG_BT_HCI=y
CONFIG_BT_H4=y
  • On your nRF52 side you need to enable these configs as mentioned in this thread. I think the most important ones are the below
    # Enable custom Vendor-Specific HCI commands
    CONFIG_BT_HCI_VS=y
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BT_HCI_RAW_CMD_EXT=y
    When you prestine build and flash the controller with this, the controller will then respond to OCF 0x0008 with a command complete event with the payload data as below
    'Status (0x00), v0.19.0-3-g4847332acd8a \0'
    Then on host you can call bt_hci_cmd_send_sync(BT_HCI_OP_VS_READ_BUILD_INFO, NULL, &rsp); and get your version string to the LTE side.
  • Hi Susheel,
    Thanks for your response!
    As you suggested i added the following configs on the nRF52 side
    CONFIG_BT_HCI_VS=y
    And on the nRF91 side i added the following code after calling the function  be_enable()
    		err = bt_enable(NULL);
    		if (err) {
    			LOG_ERR("Bluetooth enable failed: %d", err);
    			return err;
    		ble_is_enabled = true;
    	struct net_buf *rsp;
    	// Send HCI vendor-specific command
    	err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_READ_BUILD_INFO, NULL, &rsp);
        if (err) {
            LOG_ERR("bt_hci_cmd_send_sync failed (err %d)\n", err);
            return err;
        if (rsp) {
            uint8_t *data = rsp->data;
            uint8_t status = data[0];
            LOG_WRN("VS Build Info Status: 0x%02x\n", status);
            if (rsp->len > 1) {
                const char *build_str = (const char *)&data[1];
                LOG_WRN("VS Build Info: %s\n", build_str);
            net_buf_unref(rsp);
    	LOG_INF("Start advertising");
    But what i got is this error bt_hci_cmd_send_sync failed (err -5):
    [00:01:43.091,918] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:01:43.091,949] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:01:43.091,979] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:01:43.097,137] <inf> bt_hci_core: Identity: FF:1A:3E:61:5B:4B (random)
    [00:01:43.097,167] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:01:43.097,198] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:01:43.098,052] <wrn> bt_hci_core: opcode 0xfc08 status 0x01
    [00:01:43.098,083] <err> bluetooth: bt_hci_cmd_send_sync failed (err -5)
    What could the problem be and how to solve it ?
  • Hi Tareq,
    I over estimated this support. As mentioned here and pointed to this enum sdc_hci_opcode_vs, there is no support for BT_VS_CMD_BIT_READ_BUILD_INFO  in Softdevice controller and is only supported by Zephyr controller.  Can be selected by enabling CONFIG_BT_LL_SW_SPLIT=y. Apart from this, we recommend the use of SoftDevice Controller
  • Thank you very much for your response!
    That solved my problem Slight smile
    What is the impact of using the Zephyr controller instead of the SoftDevice Controller on my application on the current consumption?
    And why do you recommend the use of the SoftDevice Controller in general ?
  • Zephyr controller is maintained by open community and the priorities of features are not focused on any one Vendor. Softdevice controller is designed and developed in Nordic and we focus and prioritize use cases and performance of that controller on our chips. So the quality of BLE and power performance of Softdevice controller is more tested than the Zephyr controller on our devices.
