nrf9160
I purchased a SIM data from ILIAD and I am trying to connect to network, but the AT command AT+CEREG? : +CEREG: 0,4  instead of 0,5 as I expect.
The lte_lc_connect_async hangs forever without errors  ..
What I should check and/or setup to get connected ?
    Have you tried running AT%XSIM command to check the SIM status? Have you checked if the SIM card requires additional activation with the provider? Are you using a custom board?
  • Hi, in the meanwhile I realized that the SIM provider does NOT support LTE-M so I guess the problem is related to that. I already purchased another SIM that officially supports LTE-M. We may leave the ticket in stand-by until I receive and test the new SIM. Do you confirm that nRF9160 DO NOT work with 'normal' LTE ?
    Thanks a lot for your response.
    Best regards
  • Hi, I tried to use the new SIM but the registration to LTE-M do not happen. The command AT%XSIM? %XSIM: 0,1 is ok. I see the message RRC connected and then RCC idle  and the cycle repeats. I Have the trace file but I don't see a way to upload it ..
    Thanks
  • Here is the log of application:
    Modem initialization ...
    Modem FW Ver: mfw_nrf9160_1.3.7
    IMEI: 350976650248609
    SIM ICCID: 8939108660005723542
    [00:00:02.575,103] <inf> amca_sample: AT+CMEE=1 : OK
    [00:00:03.589,569] <inf> amca_sample: AT+CPIN? : +CPIN: READY
    OK
    [00:00:04.605,224] <inf> amca_sample: AT%%XSIM? : %XSIM: 1
    OK
    [00:00:05.620,574] <inf> amca_sample: AT+CIMI : 222101683538474
    OK
    [00:00:06.636,413] <inf> amca_sample: AT+CEREG? : +CEREG: 0,4
    OK
    [00:00:07.652,191] <inf> amca_sample: AT%%XMONITOR : %XMONITOR: 4
    OK
    Waiting for network ...
    [00:00:08.737,579] <inf> amca_sample: RRC mode: Connected
    [00:00:10.898,498] <inf> amca_sample: RRC mode: Idle
    [00:00:21.140,869] <inf> amca_sample: RRC mode: Connected
    [00:00:23.451,141] <inf> amca_sample: RRC mode: Idle
    [00:00:33.685,852] <inf> amca_sample: RRC mode: Connected
    [00:00:35.749,237] <inf> amca_sample: RRC mode: Idle
    [00:00:45.935,485] <inf> amca_sample: RRC mode: Connected
    [00:00:47.913,360] <inf> amca_sample: RRC mode: Idle
    [00:00:58.096,099] <inf> amca_sample: RRC mode: Connected
    [00:01:00.836,059] <inf> amca_sample: RRC mode: Idle
    Yes, regular LTE is not supported.
    If you have any further problems, please submit this in a separate ticket. It seems to me that the original question has been addressed.
