pstorage example/issues
Does sample code exist for the pstorage module?
I am calling this code right before advertising_start() in the heart rate monitor application for the newest SDK. It doesn't seem to return from this function (from what I believe stem's from pstorage_clear(...)).
Can you spot any mistakes?
    static pstorage_handle_t       blockHandle;
void initFlash(void)
	uint32_t errCode;
    pstorage_handle_t       flashHandle;
    pstorage_module_param_t flashParam;
    errCode = pstorage_init();  //init the flash module API
    APP_ERROR_CHECK(errCode);
    flashParam.block_size  = PSTORAGE_MAX_BLOCK_SIZE;//sizeof(testresultstruct); //make a block the size of a test structure
    flashParam.block_count = 1;//MAX_NUMBER_OF_RESULTS; //give enough blocks to store
    flashParam.cb          = flashCallBack;
    errCode = pstorage_register(&flashParam, &flashHandle);
    errCode = pstorage_block_identifier_get( &flashHandle, 0, &blockHandle);
    errCode = pstorage_clear(&flashHandle, NULL);
  • What kind of error do you actually see? If one of the function calls fails, you'll end up in app_error_handler with an error code that will hopefully make you understand what went wrong. I'd therefore recommend you to put a breakpoint there.
  • Hi Ole,
    I am not seeing any error codes in the function I posted above, but I am getting an error code in:
    static void hrs_event_handler(ble_hrs_t * p_hrs, ble_hrs_evt_t * p_evt)
        uint32_t err_code;
        switch(p_evt->evt_type)
            case BLE_HRS_EVT_NOTIFICATION_ENABLED:     // Fall through
            case BLE_HRS_EVT_NOTIFICATION_DISABLED:
                // Try to store system attributes
                err_code = ble_bondmngr_sys_attr_store();
                if (err_code == NRF_SUCCESS)
                    // System attribute store successfully requested.
                else if (err_code == NRF_ERROR_INVALID_STATE)
                    // System attributes already updated, cannot update again.
                    APP_ERROR_HANDLER(err_code); //the error is being called from here
    I believe the reason for this is because the heart rate application uses pstorage and when I init it for my own application it messes something up with the heart rate application. I was wondering how I could integrate with the pstorage implementation in the heart rate app?
    Would you know what I have to modify?
  • You should obviously not initialize pstorage twice, so if you work with a project that already initialize pstorage, make sure to remove one of your initializations.
    If you still have problems, can you please upload your complete code, either here or in a regular support case, so that I can see what you're doing?
