GPIO interrupt configuration failed on nRF9160 with npm1300
Hi all,
I'm working on a custom board based on the nRF9160 and using nRF Connect SDK v3.0.2. We’ve developed the board in-house and integrated the npm1300 PMIC as part of our power management solution.
Everything is working well overall, but I’m facing an issue with GPIO buttons. Specifically:
  • I use the first two GPIOs from the npm1300 as buttons.
  • I also have five other buttons directly connected to GPIOs on the nRF9160, and those work fine.
  • I use GPIO 0.26 from the nRF9160 as host-int-gpio property
However, when I declare the two npm1300-based buttons in the devicetree, I get this error during application startup:
[00:00:00.382,568] <err> gpio_keys: Could not set gpio callback
[00:00:00.382,598] <err> gpio_keys: Pin 5 interrupt configuration failed: -88
Here is the relevant devicetree snippet for the npm1300:
npm1300_pmic: npm1300@6b {
		compatible = "nordic,npm1300";
		reg = <0x6b>;
		pmic-int-pin = <4>;
		host-int-gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>;
		ship-to-active-time-ms = <1008>;
		long-press-reset = "one-button";
		status = "okay";
		npm1300_gpio: npm1300_gpio {
			compatible = "nordic,npm1300-gpio";
			status = "okay";
			gpio-controller;
			#gpio-cells = <2>;
			ngpios = <5>;
		npm1300_regulators: regulators {
			compatible = "nordic,npm1300-regulator";
			status = "okay";
			npm1300_buck1: BUCK1 {
				status = "disabled";
			regulator_3v0: BUCK2 {
				regulator-min-microvolt = <3000000>;
				regulator-max-microvolt = <3000000>;
				regulator-init-microvolt = <3000000>;
				regulator-boot-on;
				regulator-always-on;
			// LDO1
			regulator_display: LDO1 {
				regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>;
				regulator-boot-on;
				status = "okay";
			// LDO2 is not used
			npm1300_ldo2: LDO2 {
		npm1300_charger: charger {
			compatible = "nordic,npm1300-charger";
			term-microvolt = <4200000>;
			term-warm-microvolt = <4000000>;
			current-microamp = <400000>;
			term-current-percent = <10>;
			dischg-limit-microamp = <1000000>;
			vbus-limit-microamp = <500000>;
			thermistor-ohms = <10000>;
			thermistor-beta = <3435>;	//3380
			charging-enable;
		npm1300_leds: leds {
			compatible = "nordic,npm1300-led";
			nordic,led0-mode = "charging";
			nordic,led1-mode = "host";
			nordic,led2-mode = "host";
		npm1300_buttons: buttons {
			compatible = "gpio-keys";
			status = "okay";
And here is the devicetree definition for the buttons :
	buttons: buttons {
		debounce-interval-ms = <100>;
        button0: button_0 {
            label = "bt0-enter";
            gpios = <&gpio0 0 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            zephyr,code = <INPUT_KEY_ENTER>;
        button1: button_1 {
            label = "bt1-up";
            gpios = <&gpio0 1 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            zephyr,code = <INPUT_KEY_UP>;
        button2: button_2 {
            label = "bt2-left";
            gpios = <&gpio0 2 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            zephyr,code = <INPUT_KEY_LEFT>;
        button3: button_3 {
            label = "bt3-down";
            gpios = <&gpio0 3 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            zephyr,code = <INPUT_KEY_DOWN>;
        button4: button_4 {
            label = "bt4-right";
            gpios = <&gpio0 4 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            zephyr,code = <INPUT_KEY_RIGHT>;
		button5: button_5 {
			label = "bt5";
			gpios = <&npm1300_gpio 0 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			zephyr,code = <INPUT_KEY_1>;
		button6: button_6 {
			label = "bt6";
			gpios = <&npm1300_gpio 1 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			zephyr,code = <INPUT_KEY_2>;
I'm really not sure what’s going wrong here. Has anyone encountered something similar when using npm1300 GPIOs as input buttons? Any ideas or pointers would be greatly appreciated!
Thanks in advance!
