"NotAvailableBecauseProtection" when attempting to flash nRF54L15
Seeing the failure below and wondering a couple things:
  1. How did the device get into this state?
  2. How do I disable AP protection? The Kconfig GUI seems to indicate that it is already disabled.
Output:
Flashing build to 852003914
west flash -d application/build --dev-id 852003914
-- west flash: rebuilding
[0/5] Performing build step for 'application'
ninja: no work to do.
[2/5] No install step for 'application'
[3/5] Completed 'application'
[4/5] cd application/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: application/build/merged.hex
Error: One or more batch tasks failed:
 - [Probe] Device is protected, code: NotAvailableBecauseProtection
The operation was unavailable for some of the devices because they had readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information.
ERROR: runners.nrfutil: Flashing failed because the target must be recovered.
  To fix, run "west flash --recover" instead.
  Note: this will recover and erase all flash memory prior to reflashing.
FATAL ERROR: command exited with status 24: nrfutil --json device x-execute-batch --batch-path application/build/generated_nrfutil_batch.json --serial-number 852003914
