Hi all
I have a project that I developed with SDK 17.0.2 in Segger Embedded Studio. It works well, but now I would like to add a GitHub Runner to compile it every time I push something to my main branch. For that, I want to build a Makefile, so it can run in an Ubuntu environment. I also experimented a bit with cmake. However, both with make and cmake, I get a successful compilation, but the code does not run. The same code compiled in SES and also using embuild.exe works fine. Here is what I tried so far:
- Build several example projects (e.g. Blinky) with the Makefile that comes with the SDK - that works flawlessly.
- Compare the emProject-file contents to the contents of my Makefile and linker script - seems to agree.
- Build and flash using the Makefile, then attach the debugger in SES - I get "Unknown function at 0xfffffffe" (the address changes sometimes when I do something with the Makefile)
- Load the files from SES and Makefile alternatively into the Programmer application from nRF Connect to compare them.
- I used some commands to compare the output files, but they appear to have a fundamentally different structure, which makes it hard to compare them (arm-none-eabi-nm -n easyoiler.out > make_symbols.txt and arm-none-eabi-objdump -d easyoiler.out > make_disasm.txt, each command for both and then compare the output)
Can you help me to figure this one out?
Here is my Makefile:
PROJECT_NAME := easyoiler TARGETS := easyoiler OUTPUT_DIRECTORY := _build SDK_ROOT := ../../../../../.. PROJ_DIR := ../../.. $(OUTPUT_DIRECTORY)/easyoiler.out: \ LINKER_SCRIPT := easyoiler_gcc_nrf52.ld # Source files common to all targets SRC_FILES += \ $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52.S \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_rtt.c \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_uart.c \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_default_backends.c \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \ $(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \ $(SDK_ROOT)/components/libraries/button/app_button.c \ $(SDK_ROOT)/components/libraries/util/app_error.c \ $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \ $(SDK_ROOT)/components/libraries/util/app_error_weak.c \ $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \ $(SDK_ROOT)/components/libraries/timer/app_timer2.c \ $(SDK_ROOT)/components/libraries/util/app_util_platform.c \ $(SDK_ROOT)/components/libraries/crc16/crc16.c \ $(SDK_ROOT)/components/libraries/timer/drv_rtc.c \ $(SDK_ROOT)/components/libraries/fds/fds.c \ $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \ $(SDK_ROOT)/components/libraries/util/nrf_assert.c \ $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \ $(SDK_ROOT)/components/libraries/atomic_flags/nrf_atflags.c \ $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \ $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \ $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \ $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \ $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \ $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \ $(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \ $(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \ $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \ $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \ $(SDK_ROOT)/components/libraries/sortlist/nrf_sortlist.c \ $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \ $(SDK_ROOT)/components/libraries/sensorsim/sensorsim.c \ $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52.c \ $(SDK_ROOT)/components/boards/boards.c \ $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \ $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \ $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \ $(SDK_ROOT)/components/libraries/bsp/bsp.c \ $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \ $(PROJ_DIR)/src/main.c \ $(PROJ_DIR)/src/ble_cus.c \ $(PROJ_DIR)/src/config.c \ $(PROJ_DIR)/src/fds_cus.c \ $(PROJ_DIR)/src/op_state.c \ $(PROJ_DIR)/src/pump.c \ $(PROJ_DIR)/src/reservoir.c \ $(PROJ_DIR)/src/status.c \ $(PROJ_DIR)/src/usage_data.c \ $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \ $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \ $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \ $(SDK_ROOT)/components/ble/peer_manager/auth_status_tracker.c \ $(SDK_ROOT)/components/ble/common/ble_advdata.c \ $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \ $(SDK_ROOT)/components/ble/common/ble_conn_params.c \ $(SDK_ROOT)/components/ble/common/ble_conn_state.c \ $(SDK_ROOT)/components/ble/common/ble_srv_common.c \ $(SDK_ROOT)/components/ble/peer_manager/gatt_cache_manager.c \ $(SDK_ROOT)/components/ble/peer_manager/gatts_cache_manager.c \ $(SDK_ROOT)/components/ble/peer_manager/id_manager.c \ $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \ $(SDK_ROOT)/components/ble/nrf_ble_qwr/nrf_ble_qwr.c \ $(SDK_ROOT)/components/ble/peer_manager/peer_data_storage.c \ $(SDK_ROOT)/components/ble/peer_manager/peer_database.c \ $(SDK_ROOT)/components/ble/peer_manager/peer_id.c \ $(SDK_ROOT)/components/ble/peer_manager/peer_manager.c \ $(SDK_ROOT)/components/ble/peer_manager/peer_manager_handler.c \ $(SDK_ROOT)/components/ble/peer_manager/pm_buffer.c \ $(SDK_ROOT)/components/ble/peer_manager/security_dispatcher.c \ $(SDK_ROOT)/components/ble/peer_manager/security_manager.c \ $(SDK_ROOT)/external/utf_converter/utf.c \ $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \ $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \ $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \ $(SDK_ROOT)/components/ble/ble_services/ble_dfu/ble_dfu.c \ $(SDK_ROOT)/components/ble/ble_services/ble_dis/ble_dis.c \ $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_ppi.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_timer.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_saadc.c \ $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_ppi.c \ $(SDK_ROOT)/components/ble/ble_services/ble_dfu/ble_dfu_unbonded.c \ # Include folders common to all targets INC_FOLDERS += \ $(SDK_ROOT)/components/nfc/ndef/generic/message \ $(SDK_ROOT)/components/nfc/t2t_lib \ $(SDK_ROOT)/components/nfc/t4t_parser/hl_detection_procedure \ $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \ $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \ $(SDK_ROOT)/components/libraries/pwm \ $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \ $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \ $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \ $(SDK_ROOT)/components/libraries/usbd/class/msc \ $(SDK_ROOT)/components/libraries/usbd/class/hid \ $(SDK_ROOT)/modules/nrfx/hal \ $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser \ $(SDK_ROOT)/components/libraries/log \ $(SDK_ROOT)/components/ble/ble_services/ble_gls \ $(SDK_ROOT)/components/libraries/fstorage \ $(SDK_ROOT)/components/nfc/ndef/text \ $(SDK_ROOT)/components/libraries/mutex \ $(SDK_ROOT)/components/libraries/gpiote \ $(SDK_ROOT)/components/libraries/bootloader \ $(SDK_ROOT)/components/libraries/bootloader/dfu \ $(SDK_ROOT)/components/libraries/bootloader/ble_dfu \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/common \ $(SDK_ROOT)/components/boards \ $(SDK_ROOT)/components/nfc/ndef/generic/record \ $(SDK_ROOT)/components/nfc/t4t_parser/cc_file \ $(SDK_ROOT)/components/ble/ble_advertising \ $(SDK_ROOT)/external/utf_converter \ $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \ $(SDK_ROOT)/modules/nrfx/drivers/include \ $(SDK_ROOT)/components/libraries/experimental_task_manager \ $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/le_oob_rec \ $(SDK_ROOT)/components/libraries/queue \ $(SDK_ROOT)/components/libraries/pwr_mgmt \ $(SDK_ROOT)/components/ble/ble_dtm \ $(SDK_ROOT)/components/toolchain/cmsis/include \ $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \ $(SDK_ROOT)/components/ble/common \ $(SDK_ROOT)/components/ble/ble_services/ble_lls \ $(SDK_ROOT)/components/nfc/platform \ $(SDK_ROOT)/components/libraries/bsp \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/ac_rec \ $(SDK_ROOT)/components/ble/ble_services/ble_bas \ $(SDK_ROOT)/components/libraries/mpu \ $(SDK_ROOT)/components/libraries/experimental_section_vars \ $(SDK_ROOT)/components/softdevice/s132/headers \ $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \ $(SDK_ROOT)/components/libraries/slip \ $(SDK_ROOT)/components/libraries/delay \ $(SDK_ROOT)/components/libraries/csense_drv \ $(SDK_ROOT)/components/libraries/memobj \ $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \ $(SDK_ROOT)/components/softdevice/common \ $(SDK_ROOT)/components/ble/ble_services/ble_ias \ $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \ $(SDK_ROOT)/components/libraries/low_power_pwm \ $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser \ $(SDK_ROOT)/components/ble/ble_services/ble_dfu \ $(SDK_ROOT)/external/fprintf \ $(SDK_ROOT)/components/libraries/svc \ $(SDK_ROOT)/components/libraries/atomic \ $(SDK_ROOT)/components \ $(SDK_ROOT)/components/libraries/scheduler \ $(SDK_ROOT)/components/libraries/cli \ $(SDK_ROOT)/components/ble/ble_services/ble_lbs \ $(SDK_ROOT)/components/ble/ble_services/ble_hts \ $(SDK_ROOT)/components/libraries/crc16 \ $(SDK_ROOT)/components/nfc/t4t_parser/apdu \ $(SDK_ROOT)/components/libraries/util \ $(PROJ_DIR)/config \ $(PROJ_DIR)/src \ $(SDK_ROOT)/components/libraries/usbd/class/cdc \ $(SDK_ROOT)/components/libraries/csense \ $(SDK_ROOT)/components/libraries/balloc \ $(SDK_ROOT)/components/libraries/ecc \ $(SDK_ROOT)/components/libraries/hardfault \ $(SDK_ROOT)/components/ble/ble_services/ble_cscs \ $(SDK_ROOT)/components/libraries/hci \ $(SDK_ROOT)/components/libraries/timer \ $(SDK_ROOT)/integration/nrfx \ $(SDK_ROOT)/components/nfc/t4t_parser/tlv \ $(SDK_ROOT)/components/libraries/sortlist \ $(SDK_ROOT)/components/libraries/spi_mngr \ $(SDK_ROOT)/components/libraries/led_softblink \ $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser \ $(SDK_ROOT)/components/libraries/sdcard \ $(SDK_ROOT)/components/nfc/ndef/parser/record \ $(SDK_ROOT)/modules/nrfx/mdk \ $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \ $(SDK_ROOT)/components/ble/ble_services/ble_nus \ $(SDK_ROOT)/components/libraries/twi_mngr \ $(SDK_ROOT)/components/ble/ble_services/ble_hids \ $(SDK_ROOT)/components/libraries/strerror \ $(SDK_ROOT)/components/libraries/crc32 \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_oob_advdata \ $(SDK_ROOT)/components/nfc/t2t_parser \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_msg \ $(SDK_ROOT)/components/libraries/usbd/class/audio \ $(SDK_ROOT)/components/libraries/sensorsim \ $(SDK_ROOT)/components/nfc/t4t_lib \ $(SDK_ROOT)/components/ble/peer_manager \ $(SDK_ROOT)/components/libraries/mem_manager \ $(SDK_ROOT)/components/libraries/ringbuf \ $(SDK_ROOT)/components/ble/ble_services/ble_tps \ $(SDK_ROOT)/components/nfc/ndef/parser/message \ $(SDK_ROOT)/components/ble/ble_services/ble_dis \ $(SDK_ROOT)/components/nfc/ndef/uri \ $(SDK_ROOT)/components/ble/nrf_ble_gatt \ $(SDK_ROOT)/components/ble/nrf_ble_qwr \ $(SDK_ROOT)/components/libraries/gfx \ $(SDK_ROOT)/components/libraries/button \ $(SDK_ROOT)/modules/nrfx \ $(SDK_ROOT)/components/libraries/twi_sensor \ $(SDK_ROOT)/integration/nrfx/legacy \ $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/ep_oob_rec \ $(SDK_ROOT)/external/segger_rtt \ $(SDK_ROOT)/components/libraries/atomic_fifo \ $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_lib \ $(SDK_ROOT)/components/libraries/crypto \ $(SDK_ROOT)/components/ble/ble_racp \ $(SDK_ROOT)/components/libraries/fds \ $(SDK_ROOT)/components/nfc/ndef/launchapp \ $(SDK_ROOT)/components/libraries/atomic_flags \ $(SDK_ROOT)/components/ble/ble_services/ble_hrs \ $(SDK_ROOT)/components/ble/ble_services/ble_rscs \ $(SDK_ROOT)/components/nfc/ndef/connection_handover/hs_rec \ $(SDK_ROOT)/components/libraries/usbd \ $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ac_rec_parser \ $(SDK_ROOT)/components/libraries/stack_guard \ $(SDK_ROOT)/components/libraries/log/src \ # Libraries common to all targets LIB_FILES += \ # Optimization flags # OPT = -O3 -g3 OPT = -O0 -g3 # Uncomment the line below to enable link time optimization #OPT += -flto # C flags common to all targets CFLAGS += $(OPT) CFLAGS += -DAPP_TIMER_V2 CFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED CFLAGS += -DBOARD_CUSTOM # CFLAGS += -DCONFIG_GPIO_AS_PINRESET CFLAGS += -DFLOAT_ABI_HARD CFLAGS += -DNRF52 CFLAGS += -DNRF52832_XXAA CFLAGS += -DNRF52_PAN_74 CFLAGS += -DNRF_SD_BLE_API_VERSION=7 CFLAGS += -DS132 CFLAGS += -DSOFTDEVICE_PRESENT CFLAGS += -DNO_VTOR_CONFIG CFLAGS += -DINITIALIZE_USER_SECTIONS CFLAGS += -mcpu=cortex-m4 CFLAGS += -mthumb -mabi=aapcs CFLAGS += -Wall #-Werror CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16 # keep every function in a separate section, this allows linker to discard unused ones CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing CFLAGS += -fno-builtin -fshort-enums CFLAGS += -DDEBUG # C++ flags common to all targets CXXFLAGS += $(OPT) # Assembler flags common to all targets ASMFLAGS += -g3 ASMFLAGS += -mcpu=cortex-m4 ASMFLAGS += -mthumb -mabi=aapcs ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16 ASMFLAGS += -DAPP_TIMER_V2 ASMFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED ASMFLAGS += -DBOARD_CUSTOM # ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET ASMFLAGS += -DFLOAT_ABI_HARD ASMFLAGS += -DNRF52 ASMFLAGS += -DNRF52832_XXAA ASMFLAGS += -DNRF52_PAN_74 ASMFLAGS += -DNRF_SD_BLE_API_VERSION=7 ASMFLAGS += -DS132 ASMFLAGS += -DSOFTDEVICE_PRESENT ASMFLAGS += -DNO_VTOR_CONFIG ASMFLAGS += -DINITIALIZE_USER_SECTIONS ASMFLAGS += -DDEBUG # Linker flags LDFLAGS += $(OPT) LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT) LDFLAGS += -mcpu=cortex-m4 LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16 # let linker dump unused sections LDFLAGS += -Wl,--gc-sections # use newlib in nano version LDFLAGS += --specs=nano.specs LDFLAGS += -Wl,-Map=easyoiler.map LDFLAGS += -u _printf_float easyoiler: CFLAGS += -D__HEAP_SIZE=8192 easyoiler: CFLAGS += -D__STACK_SIZE=8192 easyoiler: ASMFLAGS += -D__HEAP_SIZE=8192 easyoiler: ASMFLAGS += -D__STACK_SIZE=8192 # Add standard libraries at the very end of the linker input, after all objects # that may need symbols provided by these libraries. LIB_FILES += -lc -lnosys -lm .PHONY: default help # Default target - first one defined default: easyoiler # Print all targets that can be built help: @echo following targets are available: @echo easyoiler @echo flash_softdevice @echo sdk_config - starting external tool for editing sdk_config.h @echo flash - flashing binary TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc include $(TEMPLATE_PATH)/Makefile.common $(foreach target, $(TARGETS), $(call define_target, $(target))) .PHONY: flash flash_softdevice erase # Flash the program flash: default @echo Flashing: $(OUTPUT_DIRECTORY)/easyoiler.hex nrfutil device program --family nrf52 --firmware $(OUTPUT_DIRECTORY)/easyoiler.hex --options chip_erase_mode=ERASE_RANGES_TOUCHED_BY_FIRMWARE nrfutil device reset --family nrf52 # nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex --sectorerase # nrfjprog -f nrf52 --reset # Flash softdevice flash_softdevice: @echo Flashing: s132_nrf52_7.2.0_softdevice.hex nrfutil device program --family nrf52 --firmware $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_7.2.0_softdevice.hex --options chip_erase_mode=ERASE_RANGES_TOUCHED_BY_FIRMWARE nrfutil device reset --family nrf52 # nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_7.2.0_softdevice.hex --sectorerase # nrfjprog -f nrf52 --reset erase: nrfutil device erase --family nrf52 # nrfjprog -f nrf52 --eraseall SDK_CONFIG_FILE := ../config/sdk_config.h CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar sdk_config: java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
And here my linker script:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000
RAM (rwx) : ORIGIN = 0x20002288, LENGTH = 0xdd90
SECTIONS
SECTIONS
. = ALIGN(4);
.mem_section_dummy_ram :
.cli_sorted_cmd_ptrs :
PROVIDE(__start_cli_sorted_cmd_ptrs = .);
KEEP(*(.cli_sorted_cmd_ptrs))
PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
} > RAM
.fs_data :
PROVIDE(__start_fs_data = .);
KEEP(*(.fs_data))
PROVIDE(__stop_fs_data = .);
} > RAM
.log_dynamic_data :
PROVIDE(__start_log_dynamic_data = .);
KEEP(*(SORT(.log_dynamic_data*)))
PROVIDE(__stop_log_dynamic_data = .);
} > RAM
.log_filter_data :
PROVIDE(__start_log_filter_data = .);
KEEP(*(SORT(.log_filter_data*)))
PROVIDE(__stop_log_filter_data = .);
} > RAM
} INSERT AFTER .data;
SECTIONS
.mem_section_dummy_rom :
.sdh_soc_observers :
PROVIDE(__start_sdh_soc_observers = .);
KEEP(*(SORT(.sdh_soc_observers*)))
PROVIDE(__stop_sdh_soc_observers = .);
} > FLASH
.pwr_mgmt_data :
PROVIDE(__start_pwr_mgmt_data = .);
KEEP(*(SORT(.pwr_mgmt_data*)))
PROVIDE(__stop_pwr_mgmt_data = .);
} > FLASH
.sdh_ble_observers :
PROVIDE(__start_sdh_ble_observers = .);
KEEP(*(SORT(.sdh_ble_observers*)))
PROVIDE(__stop_sdh_ble_observers = .);
} > FLASH
.sdh_req_observers :
PROVIDE(__start_sdh_req_observers = .);
KEEP(*(SORT(.sdh_req_observers*)))
PROVIDE(__stop_sdh_req_observers = .);
} > FLASH
.sdh_state_observers :
PROVIDE(__start_sdh_state_observers = .);
KEEP(*(SORT(.sdh_state_observers*)))
PROVIDE(__stop_sdh_state_observers = .);
} > FLASH
.sdh_stack_observers :
PROVIDE(__start_sdh_stack_observers = .);
KEEP(*(SORT(.sdh_stack_observers*)))
PROVIDE(__stop_sdh_stack_observers = .);
} > FLASH
.nrf_queue :
PROVIDE(__start_nrf_queue = .);
KEEP(*(.nrf_queue))
PROVIDE(__stop_nrf_queue = .);
} > FLASH
.nrf_balloc :
PROVIDE(__start_nrf_balloc = .);
KEEP(*(.nrf_balloc))
PROVIDE(__stop_nrf_balloc = .);
} > FLASH
.cli_command :
PROVIDE(__start_cli_command = .);
KEEP(*(.cli_command))
PROVIDE(__stop_cli_command = .);
} > FLASH
.crypto_data :
PROVIDE(__start_crypto_data = .);
KEEP(*(SORT(.crypto_data*)))
PROVIDE(__stop_crypto_data = .);
} > FLASH
.log_const_data :
PROVIDE(__start_log_const_data = .);
KEEP(*(SORT(.log_const_data*)))
PROVIDE(__stop_log_const_data = .);
} > FLASH
.log_backends :
PROVIDE(__start_log_backends = .);
KEEP(*(SORT(.log_backends*)))
PROVIDE(__stop_log_backends = .);
} > FLASH
} INSERT AFTER .text
INCLUDE "nrf_common.ld"
And here the contents of my emProject-file.
<!DOCTYPE CrossStudio_Project_File>
<solution Name="easyoiler" target="8" version="2">
<project Name="easyoiler">
<configuration
Name="Common"
arm_architecture="v7EM"
arm_core_type="Cortex-M4"
arm_endian="Little"
arm_fp_abi="Hard"
arm_fpu_type="FPv4-SP-D16"
arm_linker_heap_size="8192"
arm_linker_process_stack_size="0"
arm_linker_stack_size="8192"
arm_linker_treat_warnings_as_errors="No"
arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
arm_target_device_name="nRF52832_xxAA"
arm_target_interface_type="SWD"
c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_CUSTOM;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52;NRF52832_XXAA;NRF52_PAN_74;NRF_SD_BLE_API_VERSION=7;S132;SOFTDEVICE_PRESENT"
c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader;../../../../../../components/libraries/bootloader/dfu;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/sensorsim;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/platform;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s132/headers;../../../../../../components/softdevice/s132/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../../../src"
debug_additional_load_file="../../../../../../components/softdevice/s132/hex/s132_nrf52_7.2.0_softdevice.hex"
debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52.svd"
debug_start_from_entry_point_symbol="No"
debug_target_connection="J-Link"
gcc_debugging_level="Level 3"
gcc_entry_point="Reset_Handler"
linker_output_format="hex"
linker_printf_fmt_level="long"
linker_printf_fp_enabled="Float"
linker_printf_width_precision_supported="Yes"
linker_scanf_fmt_level="long"
linker_section_placement_file="flash_placement.xml"
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002288;RAM_SIZE=0xdd90"
linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM1 RWX 0x20000000 0x10000"
macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
project_directory=""
project_type="Executable" />
<folder Name="Segger Startup Files">
<file file_name="$(StudioDir)/source/thumb_crt0.s" />
</folder>
<folder Name="nRF_Log">
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
</folder>
<folder Name="nRF_Libraries">
<file file_name="../../../../../../components/libraries/button/app_button.c" />
<file file_name="../../../../../../components/libraries/util/app_error.c" />
<file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
<file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
<file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
<file file_name="../../../../../../components/libraries/timer/app_timer2.c" />
<file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
<file file_name="../../../../../../components/libraries/crc16/crc16.c" />
<file file_name="../../../../../../components/libraries/timer/drv_rtc.c" />
<file file_name="../../../../../../components/libraries/fds/fds.c" />
<file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
<file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
<file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
<file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
<file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
<file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
<file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
<file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
<file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
<file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
<file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
<file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
<file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
<file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
<file file_name="../../../../../../components/libraries/sortlist/nrf_sortlist.c" />
<file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
<file file_name="../../../../../../components/libraries/sensorsim/sensorsim.c" />
<file file_name="../../../../../../components/libraries/queue/nrf_queue.c" />
</folder>
<folder Name="None">
<file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52.s" />
<file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
<file file_name="../../../../../../modules/nrfx/mdk/system_nrf52.c" />
</folder>
<folder Name="Board Definition">
<file file_name="../../../../../../components/boards/boards.c" />
</folder>
<folder Name="nRF_Drivers">
<file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
<file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
<file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
<file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_ppi.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_ppi.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_saadc.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_timer.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_lpcomp.c" />
</folder>
<folder Name="Board Support">
<file file_name="../../../../../../components/libraries/bsp/bsp.c" />
<file file_name="../../../../../../components/libraries/bsp/bsp_btn_ble.c" />
</folder>
<folder Name="src">
<file file_name="../../../config/sdk_config.h" />
<file file_name="../../../src/ble_cus.c" />
<file file_name="../../../src/ble_cus.h" />
<file file_name="../../../src/custom_board.h" />
<file file_name="../../../src/op_state.c" />
<file file_name="../../../src/op_state.h" />
<file file_name="../../../src/version.h" />
<file file_name="../../../src/usage_data.c" />
<file file_name="../../../src/usage_data.h" />
<file file_name="../../../src/main.c" />
<file file_name="../../../src/config.c" />
<file file_name="../../../src/config.h" />
<file file_name="../../../src/fds_cus.h" />
<file file_name="../../../src/status.c" />
<file file_name="../../../src/status.h" />
<file file_name="../../../src/pump.c" />
<file file_name="../../../src/pump.h" />
<file file_name="../../../src/reservoir.c" />
<file file_name="../../../src/reservoir.h" />
<file file_name="../../../src/fds_cus.c" />
</folder>
<folder Name="nRF_Segger_RTT">
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c">
<configuration Name="Debug" build_exclude_from_build="No" />
</file>
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
</folder>
<folder Name="nRF_BLE">
<file file_name="../../../../../../components/ble/peer_manager/auth_status_tracker.c" />
<file file_name="../../../../../../components/ble/common/ble_advdata.c" />
<file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
<file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
<file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
<file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
<file file_name="../../../../../../components/ble/peer_manager/gatt_cache_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/gatts_cache_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/id_manager.c" />
<file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
<file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_data_storage.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_database.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_id.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_manager_handler.c" />
<file file_name="../../../../../../components/ble/peer_manager/pm_buffer.c" />
<file file_name="../../../../../../components/ble/peer_manager/security_dispatcher.c" />
<file file_name="../../../../../../components/ble/peer_manager/security_manager.c" />
</folder>
<folder Name="UTF8/UTF16 converter">
<file file_name="../../../../../../external/utf_converter/utf.c" />
</folder>
<folder Name="nRF_SoftDevice">
<file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
<file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
<file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
</folder>
<folder Name="nRF_DFU">
<file file_name="../../../../../../components/ble/ble_services/ble_dfu/ble_dfu.c" />
<file file_name="../../../../../../components/ble/ble_services/ble_dfu/ble_dfu_bonded.c" />
<file file_name="../../../../../../components/ble/ble_services/ble_dfu/ble_dfu_unbonded.c" />
</folder>
<folder Name="nRF_SVC">
<file file_name="../../../../../../components/libraries/bootloader/dfu/nrf_dfu_svci.c" />
</folder>
<folder Name="nRF_BLE_Services">
<file file_name="../../../../../../components/ble/ble_services/ble_dis/ble_dis.c" />
</folder>
<configuration Name="Release" linker_printf_fp_enabled="Float" />
</project>
<configuration
Name="Release"
c_preprocessor_definitions="NDEBUG"
gcc_optimization_level="Optimize For Size"
link_time_optimization="No" />
<configuration
Name="Debug"
c_preprocessor_definitions="DEBUG; DEBUG_NRF"
gcc_optimization_level="None" />
</solution>
