CMake is trying to create a directory at the system root location: /boot/zephyr/
Hi !!!
Currently i am using Ncs 2.9.2 loaded with nRF Connect for Desktop and sdk-sidewalk is git clone branch 2.9.2
I'm trying to build samples for nrf52840 board to test sidewalk and lora functionality but currently i cant build because of error
I really want to build and flash successfully for nrf52840 board. I hope you will support me to fix this error successfully. Thank you all !!!
(.venv) (v2.9.2) huydf@HuyDFs-MacBook-Pro sid_end_device % west build -b nrf52840dk_nrf52840
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /Users/huydf/Library/Caches/zephyr
-- Board: nrf52840dk, qualifiers: nrf52840
Parsing /opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/Kconfig.sysbuild
Loaded configuration '/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build/_sysbuild/empty.conf'
Merged configuration '/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build/_sysbuild/empty.conf'
Configuration saved to '/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build/_sysbuild/autoconf.h'
CMake Error at /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/share/cmake/Modules/ExternalProject.cmake:1738 (file):
  file problem creating directory: /boot/zephyr/
  /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/share/cmake/Modules/ExternalProject.cmake:3652 (_ep_set_directories)
  cmake/modules/sysbuild_extensions.cmake:360 (ExternalProject_Add)
  images/bootloader/CMakeLists.txt:8 (ExternalZephyrProject_Add)
CMake Error at /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/share/cmake/Modules/ExternalProject.cmake:1740 (message):
  dir '/boot/zephyr/' does not exist after file(MAKE_DIRECTORY)
See also "/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/b8efef2ad5/opt/[email protected]/bin/python3.12 -B/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device/build -GNinja -DBOARD=nrf52840dk_nrf52840 -S/opt/nordic/ncs/v2.9.2/zephyr/share/sysbuild -DAPP_DIR:PATH=/opt/nordic/ncs/v2.9.2/sidewalk/samples/sid_end_device
