LwM2M client sample based application: Observer composite suddenly stops sending telemetry, fixes itself on registration_update
Hi
custom board using the nRF9160, toolchain version v2.6.0, mfw_v1.3.6.
Sorry I can't provide a decrypted modem trace, but I hope the screenshots are enough to show what's happening.
We have been encountering a strange issue lately.
With the composite observer set, normal behaviour is as follows:
1. (5211) When it's time to trigger the observer update (e.g. when pmax is reached), the device sends the registration update CON message,
2. (5215) receives an ACK from the server
3. (5216) Device sends all observed values in cbor format in a further confirmable message:
4. (5217) The Server acknowledges this message.
The issue now is that somehow sometimes and suddenly Steps 3 and 4 just completely stop occuring without any clear reason / indication / error code:
I have the device logs for the same issue, where the observer updates just stop without any error or anything obvious (ignore the sensor reading errors, the sensors are not connected):
[09:02:29.099,029] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:02:29.108,123] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:02:43.323,272] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:04:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:06:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 426000413
[09:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 425759136
[09:06:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 425761096
[09:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:06:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 425765108
The circuit board temperature value is: 26.540779
[09:06:41.632,781] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:06:41.632,812] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:06:41.633,026] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.956115
[09:06:41.642,822] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:06:41.642,852] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:06:41.643,066] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
DaMo sensor unit: powered on pin 14
[09:06:41.658,752] <err> SHT4X: Failed to start measurement.
[09:06:41.658,782] <err> app_sensors: Fetch sample failed (-5)
[09:06:41.658,813] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:06:41.658,813] <err> app_sensors: Failed to read sensor data
[09:06:41.658,843] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:06:41.658,874] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:06:41.659,149] <err> SHT4X: Failed to start measurement.
[09:06:41.659,149] <err> app_sensors: Fetch sample failed (-5)
[09:06:41.659,149] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:06:41.659,179] <err> app_sensors: Failed to read sensor data
[09:06:41.659,179] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:06:41.659,240] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:06:41.659,484] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:06:41.660,827] <err> ADS1015: Reading of ads1015 failed
[09:06:41.660,858] <err> app_sensors: Failed to read sensor data
[09:06:41.660,888] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:06:41.661,132] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:06:41.662,506] <err> ADS1015: Reading of ads1015 failed
[09:06:41.662,536] <err> app_sensors: Failed to read sensor data
[09:06:41.662,536] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:06:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:07:23.121,612] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 426059121
[09:07:23.124,176] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:07:23.124,481] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:07:23.136,840] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:07:23.236,450] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:07:23.236,480] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:07:23.237,060] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:07:23.237,213] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:07:23.246,276] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:07:23.322,113] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:07:23.322,326] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:07:24.881,896] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:07:24.881,958] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:07:24.882,049] <inf> net_lwm2m_rd_client: Update Done
[09:07:24.882,232] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:07:24.882,293] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:07:24.947,875] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:07:24.948,059] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:07:27.246,551] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:07:28.884,124] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:07:28.893,218] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:07:43.114,379] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:09:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:11:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.575494
[09:11:41.642,700] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:11:41.642,730] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:11:41.642,944] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.601348
[09:11:41.652,740] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:11:41.652,770] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:11:41.652,984] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:11:41.668,670] <err> SHT4X: Failed to start measurement.
[09:11:41.668,701] <err> app_sensors: Fetch sample failed (-5)
[09:11:41.668,731] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:11:41.668,731] <err> app_sensors: Failed to read sensor data
[09:11:41.668,762] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:11:41.668,792] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:11:41.669,036] <err> SHT4X: Failed to start measurement.
[09:11:41.669,067] <err> app_sensors: Fetch sample failed (-5)
[09:11:41.669,067] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:11:41.669,067] <err> app_sensors: Failed to read sensor data
[09:11:41.669,097] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:11:41.669,158] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:11:41.669,403] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:11:41.670,745] <err> ADS1015: Reading of ads1015 failed
[09:11:41.670,776] <err> app_sensors: Failed to read sensor data
[09:11:41.670,806] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:11:41.671,081] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:11:41.672,393] <err> ADS1015: Reading of ads1015 failed
[09:11:41.672,424] <err> app_sensors: Failed to read sensor data
[09:11:41.672,424] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:12:23.121,520] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 426359121
[09:12:23.124,084] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:12:23.124,389] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:12:23.136,749] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:12:23.236,358] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:12:23.236,389] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:12:23.236,968] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:12:23.237,121] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:12:23.246,185] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:12:23.313,201] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:12:23.313,415] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:12:24.824,951] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:12:24.825,042] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:12:24.825,134] <inf> net_lwm2m_rd_client: Update Done
[09:12:24.825,286] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:12:24.825,347] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:12:24.978,942] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:12:24.979,125] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:12:27.246,612] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:12:28.827,178] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:12:28.836,273] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:12:43.029,418] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:13:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:16:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:16:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 426600413
[09:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:16:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 426359136
[09:16:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 426360825
[09:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 426364836
The circuit board temperature value is: 26.628900
[09:16:41.652,587] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:16:41.652,618] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:16:41.652,832] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.208435
[09:16:41.662,628] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:16:41.662,658] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:16:41.662,872] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:16:41.678,558] <err> SHT4X: Failed to start measurement.
[09:16:41.678,588] <err> app_sensors: Fetch sample failed (-5)
[09:16:41.678,619] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:16:41.678,619] <err> app_sensors: Failed to read sensor data
[09:16:41.678,649] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:16:41.678,680] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:16:41.678,924] <err> SHT4X: Failed to start measurement.
[09:16:41.678,955] <err> app_sensors: Fetch sample failed (-5)
[09:16:41.678,955] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:16:41.678,955] <err> app_sensors: Failed to read sensor data
[09:16:41.678,985] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:16:41.679,046] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:16:41.679,290] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:16:41.680,603] <err> ADS1015: Reading of ads1015 failed
[09:16:41.680,633] <err> app_sensors: Failed to read sensor data
[09:16:41.680,694] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:16:41.680,938] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:16:41.682,312] <err> ADS1015: Reading of ads1015 failed
[09:16:41.682,312] <err> app_sensors: Failed to read sensor data
[09:16:41.682,342] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:17:23.121,398] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 426659121
[09:17:23.123,962] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:17:23.124,267] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:17:23.136,627] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:17:23.236,236] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:17:23.236,267] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:17:23.236,846] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:17:23.236,999] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:17:23.246,063] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:17:23.324,279] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:17:23.324,493] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:17:25.143,005] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:17:25.143,066] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:17:25.143,188] <inf> net_lwm2m_rd_client: Update Done
[09:17:25.143,341] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:17:25.143,402] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:17:25.219,085] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:17:25.219,268] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:17:27.245,727] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:17:29.144,287] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:17:29.153,381] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:17:43.367,401] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:18:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:20:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.495384
[09:21:41.662,506] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:21:41.662,536] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:21:41.662,750] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.657196
[09:21:41.672,546] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:21:41.672,576] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:21:41.672,790] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:21:41.688,476] <err> SHT4X: Failed to start measurement.
[09:21:41.688,507] <err> app_sensors: Fetch sample failed (-5)
[09:21:41.688,537] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:21:41.688,537] <err> app_sensors: Failed to read sensor data
[09:21:41.688,568] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:21:41.688,598] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:21:41.688,842] <err> SHT4X: Failed to start measurement.
[09:21:41.688,873] <err> app_sensors: Fetch sample failed (-5)
[09:21:41.688,873] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:21:41.688,873] <err> app_sensors: Failed to read sensor data
[09:21:41.688,903] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:21:41.688,964] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:21:41.689,208] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:21:41.690,551] <err> ADS1015: Reading of ads1015 failed
[09:21:41.690,582] <err> app_sensors: Failed to read sensor data
[09:21:41.690,612] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:21:41.690,887] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:21:41.692,230] <err> ADS1015: Reading of ads1015 failed
[09:21:41.692,230] <err> app_sensors: Failed to read sensor data
[09:21:41.692,260] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:22:23.121,337] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 426959121
[09:22:23.123,901] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:22:23.124,206] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:22:23.136,566] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:22:23.237,152] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:22:23.237,182] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:22:23.237,762] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:22:23.237,915] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:22:23.238,037] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:22:23.335,357] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:22:23.335,571] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:22:27.058,166] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:22:27.058,227] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:22:27.058,319] <inf> net_lwm2m_rd_client: Update Done
[09:22:27.058,502] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:22:27.058,563] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:22:27.151,947] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:22:27.152,099] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:22:27.247,650] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:22:31.061,157] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:22:31.070,251] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:22:45.603,698] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:23:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:25:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:26:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:26:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:26:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 427200413
[09:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:26:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 426959136
[09:26:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 426963058
[09:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 426967070
The circuit board temperature value is: 26.377889
[09:26:41.672,393] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:26:41.672,424] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:26:41.672,637] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.94528
[09:26:41.682,434] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:26:41.682,464] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:26:41.682,678] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:26:41.698,364] <err> SHT4X: Failed to start measurement.
[09:26:41.698,394] <err> app_sensors: Fetch sample failed (-5)
[09:26:41.698,425] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:26:41.698,425] <err> app_sensors: Failed to read sensor data
[09:26:41.698,455] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:26:41.698,486] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:26:41.698,730] <err> SHT4X: Failed to start measurement.
[09:26:41.698,760] <err> app_sensors: Fetch sample failed (-5)
[09:26:41.698,760] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:26:41.698,760] <err> app_sensors: Failed to read sensor data
[09:26:41.698,791] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:26:41.698,852] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:26:41.699,096] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:26:41.700,408] <err> ADS1015: Reading of ads1015 failed
[09:26:41.700,439] <err> app_sensors: Failed to read sensor data
[09:26:41.700,469] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:26:41.700,744] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:26:41.702,117] <err> ADS1015: Reading of ads1015 failed
[09:26:41.702,148] <err> app_sensors: Failed to read sensor data
[09:26:41.702,148] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:27:23.122,222] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 427259122
[09:27:23.124,786] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:27:23.125,091] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:27:23.137,451] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:27:23.238,037] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:27:23.238,067] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:27:23.238,647] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:27:23.238,800] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:27:23.238,922] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:27:23.346,466] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:27:23.346,679] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:27:24.936,248] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:27:24.936,309] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:27:24.936,401] <inf> net_lwm2m_rd_client: Update Done
[09:27:24.936,584] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:27:24.936,645] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:27:24.990,875] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:27:24.991,027] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:27:27.247,680] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:27:28.939,239] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:27:28.948,333] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:27:43.157,623] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:27:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:30:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.364538
[09:31:41.682,312] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:31:41.682,342] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:31:41.682,556] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.752563
[09:31:41.692,352] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:31:41.692,382] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:31:41.692,596] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:31:41.708,282] <err> SHT4X: Failed to start measurement.
[09:31:41.708,312] <err> app_sensors: Fetch sample failed (-5)
[09:31:41.708,343] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:31:41.708,343] <err> app_sensors: Failed to read sensor data
[09:31:41.708,374] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:31:41.708,404] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:31:41.708,648] <err> SHT4X: Failed to start measurement.
[09:31:41.708,679] <err> app_sensors: Fetch sample failed (-5)
[09:31:41.708,679] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:31:41.708,709] <err> app_sensors: Failed to read sensor data
[09:31:41.708,709] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:31:41.708,770] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:31:41.709,014] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:31:41.710,327] <err> ADS1015: Reading of ads1015 failed
[09:31:41.710,357] <err> app_sensors: Failed to read sensor data
[09:31:41.710,388] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:31:41.710,662] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:31:41.712,005] <err> ADS1015: Reading of ads1015 failed
[09:31:41.712,036] <err> app_sensors: Failed to read sensor data
[09:31:41.712,036] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:32:23.123,138] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 427559123
[09:32:23.125,701] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:32:23.126,007] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:32:23.138,336] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:32:23.238,922] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:32:23.238,952] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:32:23.239,532] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:32:23.239,685] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:32:23.248,748] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:32:23.317,596] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:32:23.317,810] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:32:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:32:25.016,326] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:32:25.016,387] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:32:25.016,479] <inf> net_lwm2m_rd_client: Update Done
[09:32:25.016,632] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:32:25.016,723] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:32:25.099,121] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:32:25.099,273] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:32:27.248,840] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:32:29.018,402] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:32:29.027,496] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:32:43.240,753] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:34:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:36:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:36:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 427800413
[09:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:36:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 427559138
[09:36:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 427561016
[09:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 427565027
The circuit board temperature value is: 26.271076
[09:36:41.692,199] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:36:41.692,230] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:36:41.692,443] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.217971
[09:36:41.702,239] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:36:41.702,270] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:36:41.702,484] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:36:41.718,170] <err> SHT4X: Failed to start measurement.
[09:36:41.718,200] <err> app_sensors: Fetch sample failed (-5)
[09:36:41.718,231] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:36:41.718,231] <err> app_sensors: Failed to read sensor data
[09:36:41.718,261] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:36:41.718,292] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:36:41.718,536] <err> SHT4X: Failed to start measurement.
[09:36:41.718,566] <err> app_sensors: Fetch sample failed (-5)
[09:36:41.718,566] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:36:41.718,566] <err> app_sensors: Failed to read sensor data
[09:36:41.718,597] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:36:41.718,658] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:36:41.718,902] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:36:41.720,306] <err> ADS1015: Reading of ads1015 failed
[09:36:41.720,306] <err> app_sensors: Failed to read sensor data
[09:36:41.720,336] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:36:41.720,611] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:36:41.721,954] <err> ADS1015: Reading of ads1015 failed
[09:36:41.721,954] <err> app_sensors: Failed to read sensor data
[09:36:41.721,984] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:37:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:37:23.124,023] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 427859123
[09:37:23.126,586] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:37:23.126,892] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:37:23.139,251] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:37:23.239,837] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:37:23.239,868] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:37:23.240,447] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:37:23.240,600] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:37:23.249,694] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:37:23.328,735] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:37:23.328,948] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:37:24.957,458] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:37:24.957,519] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:37:24.957,611] <inf> net_lwm2m_rd_client: Update Done
[09:37:24.957,794] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:37:24.957,855] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:37:25.023,529] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:37:25.023,712] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:37:27.250,183] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:37:28.959,747] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:37:28.968,841] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:37:43.179,870] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:39:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.388570
[09:41:41.702,117] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:41:41.702,148] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:41:41.702,362] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.158843
[09:41:41.712,158] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:41:41.712,188] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:41:41.712,402] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:41:41.728,088] <err> SHT4X: Failed to start measurement.
[09:41:41.728,118] <err> app_sensors: Fetch sample failed (-5)
[09:41:41.728,149] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:41:41.728,149] <err> app_sensors: Failed to read sensor data
[09:41:41.728,179] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:41:41.728,210] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:41:41.728,454] <err> SHT4X: Failed to start measurement.
[09:41:41.728,485] <err> app_sensors: Fetch sample failed (-5)
[09:41:41.728,485] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:41:41.728,485] <err> app_sensors: Failed to read sensor data
[09:41:41.728,515] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:41:41.728,576] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:41:41.728,820] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:41:41.730,163] <err> ADS1015: Reading of ads1015 failed
[09:41:41.730,194] <err> app_sensors: Failed to read sensor data
[09:41:41.730,224] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:41:41.730,499] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:41:41.731,842] <err> ADS1015: Reading of ads1015 failed
[09:41:41.731,842] <err> app_sensors: Failed to read sensor data
[09:41:41.731,872] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:41:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:42:23.123,931] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 428159123
[09:42:23.126,495] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:42:23.126,800] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:42:23.139,160] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:42:23.239,746] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:42:23.239,776] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:42:23.240,356] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:42:23.240,509] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:42:23.249,572] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:42:23.319,854] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:42:23.320,068] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:42:25.126,586] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:42:25.126,678] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:42:25.126,770] <inf> net_lwm2m_rd_client: Update Done
[09:42:25.126,922] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:42:25.127,014] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:42:25.198,394] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:42:25.198,577] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:42:27.250,122] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:42:29.128,662] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:42:29.137,756] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:42:43.364,990] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:44:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:46:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:46:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:46:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:46:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:46:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:46:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 428400413
[09:46:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:46:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428159139
[09:46:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428161126
[09:46:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:46:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428165137
The circuit board temperature value is: 26.300450
[09:46:41.712,005] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:46:41.712,036] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:46:41.712,249] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.407333
[09:46:41.722,045] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:46:41.722,076] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:46:41.722,290] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:46:41.737,976] <err> SHT4X: Failed to start measurement.
[09:46:41.738,006] <err> app_sensors: Fetch sample failed (-5)
[09:46:41.738,037] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:46:41.738,037] <err> app_sensors: Failed to read sensor data
[09:46:41.738,067] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:46:41.738,098] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:46:41.738,342] <err> SHT4X: Failed to start measurement.
[09:46:41.738,372] <err> app_sensors: Fetch sample failed (-5)
[09:46:41.738,372] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:46:41.738,372] <err> app_sensors: Failed to read sensor data
[09:46:41.738,403] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:46:41.738,464] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:46:41.738,708] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:46:41.740,051] <err> ADS1015: Reading of ads1015 failed
[09:46:41.740,051] <err> app_sensors: Failed to read sensor data
[09:46:41.740,081] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:46:41.740,356] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:46:41.741,668] <err> ADS1015: Reading of ads1015 failed
[09:46:41.741,668] <err> app_sensors: Failed to read sensor data
[09:46:41.741,699] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:47:23.123,809] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 428459123
[09:47:23.126,373] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:47:23.126,678] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:47:23.139,038] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:47:23.239,624] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:47:23.239,654] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:47:23.240,234] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:47:23.240,386] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:47:23.249,450] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:47:23.331,024] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:47:23.331,237] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:47:25.205,780] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:47:25.205,871] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:47:25.205,963] <inf> net_lwm2m_rd_client: Update Done
[09:47:25.206,115] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:47:25.206,176] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:47:25.271,789] <dbg> net_lwm2m_message_handling: notify_message_reply_cb: NOTIFY ACK type:2 code:0.0 reply_token:'c1f2becb80e894a4'
[09:47:25.271,942] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124e0 handled and removed
[09:47:27.249,450] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:47:29.208,007] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:47:29.217,102] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:47:43.427,246] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:48:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:51:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.335164
[09:51:41.721,923] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:51:41.721,954] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:51:41.722,167] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.331039
[09:51:41.731,964] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:51:41.731,994] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:51:41.732,208] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:51:41.747,894] <err> SHT4X: Failed to start measurement.
[09:51:41.747,924] <err> app_sensors: Fetch sample failed (-5)
[09:51:41.747,955] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:51:41.747,955] <err> app_sensors: Failed to read sensor data
[09:51:41.747,985] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:51:41.748,016] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:51:41.748,260] <err> SHT4X: Failed to start measurement.
[09:51:41.748,291] <err> app_sensors: Fetch sample failed (-5)
[09:51:41.748,291] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:51:41.748,291] <err> app_sensors: Failed to read sensor data
[09:51:41.748,321] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:51:41.748,382] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:51:41.748,626] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:51:41.749,938] <err> ADS1015: Reading of ads1015 failed
[09:51:41.749,938] <err> app_sensors: Failed to read sensor data
[09:51:41.749,969] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:51:41.750,244] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:51:41.751,586] <err> ADS1015: Reading of ads1015 failed
[09:51:41.751,586] <err> app_sensors: Failed to read sensor data
[09:51:41.751,617] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:52:23.123,748] <dbg> net_lwm2m_message_handling: generate_notify_message: [AUTO] NOTIFY MSG START: (Composite)) token:'c1f2becb80e894a4' [xx.xx.xx.xxx] 428759123
[09:52:23.126,312] <dbg> net_lwm2m_message_handling: generate_notify_message: NOTIFY MSG: SENT
[09:52:23.126,617] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:52:23.138,977] <dbg> app_lwm2m_client: rd_client_event: Registration update started
[09:52:23.238,586] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
[09:52:23.238,616] <dbg> net_lwm2m_engine: lwm2m_engine_connection_resume: Resume suspended connection
[09:52:23.239,196] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0x2002d618, buflen:4
[09:52:23.239,349] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [xx.xx.xx.xxx]
[09:52:23.248,413] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
[09:52:23.322,143] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:4/0/2, buf:0x200341be, len:2
[09:52:23.322,357] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 4/0/2
[09:52:27.619,964] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[09:52:27.620,056] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
[09:52:27.620,147] <inf> net_lwm2m_rd_client: Update Done
[09:52:27.620,300] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x200124f8 handled and removed
[09:52:27.620,391] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
[09:52:27.621,093] <dbg> app_lwm2m_client: rd_client_event: Queue mode RX window closed
[09:52:45.518,463] <inf> app_lwm2m_client: Modem Enter PSM, time 215983950
[09:53:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[09:55:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[09:56:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[09:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[09:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[09:56:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[09:56:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[09:56:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[09:56:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 429000413
[09:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[09:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[09:56:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[09:56:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[09:56:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.353856
[09:56:41.731,811] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[09:56:41.731,842] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[09:56:41.732,055] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.346298
[09:56:41.741,851] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[09:56:41.741,882] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[09:56:41.742,095] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[09:56:41.757,751] <err> SHT4X: Failed to start measurement.
[09:56:41.757,781] <err> app_sensors: Fetch sample failed (-5)
[09:56:41.757,812] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[09:56:41.757,812] <err> app_sensors: Failed to read sensor data
[09:56:41.757,843] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[09:56:41.757,873] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[09:56:41.758,117] <err> SHT4X: Failed to start measurement.
[09:56:41.758,148] <err> app_sensors: Fetch sample failed (-5)
[09:56:41.758,148] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[09:56:41.758,148] <err> app_sensors: Failed to read sensor data
[09:56:41.758,178] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[09:56:41.758,239] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[09:56:41.758,483] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:56:41.759,857] <err> ADS1015: Reading of ads1015 failed
[09:56:41.759,887] <err> app_sensors: Failed to read sensor data
[09:56:41.759,918] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[09:56:41.760,162] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[09:56:41.761,535] <err> ADS1015: Reading of ads1015 failed
[09:56:41.761,535] <err> app_sensors: Failed to read sensor data
[09:56:41.761,566] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[09:58:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:00:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.249713
[10:01:41.741,729] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:01:41.741,760] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:01:41.741,973] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 43.116882
[10:01:41.751,739] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:01:41.751,770] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:01:41.751,983] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:01:41.767,639] <err> SHT4X: Failed to start measurement.
[10:01:41.767,669] <err> app_sensors: Fetch sample failed (-5)
[10:01:41.767,700] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:01:41.767,700] <err> app_sensors: Failed to read sensor data
[10:01:41.767,730] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:01:41.767,761] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:01:41.768,005] <err> SHT4X: Failed to start measurement.
[10:01:41.768,035] <err> app_sensors: Fetch sample failed (-5)
[10:01:41.768,035] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:01:41.768,035] <err> app_sensors: Failed to read sensor data
[10:01:41.768,066] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:01:41.768,127] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:01:41.768,371] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:01:41.769,683] <err> ADS1015: Reading of ads1015 failed
[10:01:41.769,683] <err> app_sensors: Failed to read sensor data
[10:01:41.769,714] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:01:41.769,989] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:01:41.771,301] <err> ADS1015: Reading of ads1015 failed
[10:01:41.771,301] <err> app_sensors: Failed to read sensor data
[10:01:41.771,331] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:02:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:05:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:06:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 429600413
[10:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:06:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.89494
[10:06:41.751,617] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:06:41.751,647] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:06:41.751,861] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.695877
[10:06:41.761,627] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:06:41.761,657] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:06:41.761,871] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:06:41.777,526] <err> SHT4X: Failed to start measurement.
[10:06:41.777,557] <err> app_sensors: Fetch sample failed (-5)
[10:06:41.777,587] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:06:41.777,587] <err> app_sensors: Failed to read sensor data
[10:06:41.777,618] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:06:41.777,648] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:06:41.777,893] <err> SHT4X: Failed to start measurement.
[10:06:41.777,923] <err> app_sensors: Fetch sample failed (-5)
[10:06:41.777,923] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:06:41.777,923] <err> app_sensors: Failed to read sensor data
[10:06:41.777,954] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:06:41.778,015] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:06:41.778,259] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:06:41.779,632] <err> ADS1015: Reading of ads1015 failed
[10:06:41.779,663] <err> app_sensors: Failed to read sensor data
[10:06:41.779,693] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:06:41.779,968] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:06:41.781,311] <err> ADS1015: Reading of ads1015 failed
[10:06:41.781,341] <err> app_sensors: Failed to read sensor data
[10:06:41.781,341] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:07:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:09:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.57450
[10:11:41.761,505] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:11:41.761,535] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:11:41.761,749] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.540847
[10:11:41.771,545] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:11:41.771,606] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:11:41.771,789] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:11:41.787,445] <err> SHT4X: Failed to start measurement.
[10:11:41.787,475] <err> app_sensors: Fetch sample failed (-5)
[10:11:41.787,506] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:11:41.787,506] <err> app_sensors: Failed to read sensor data
[10:11:41.787,536] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:11:41.787,567] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:11:41.787,811] <err> SHT4X: Failed to start measurement.
[10:11:41.787,841] <err> app_sensors: Fetch sample failed (-5)
[10:11:41.787,841] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:11:41.787,841] <err> app_sensors: Failed to read sensor data
[10:11:41.787,872] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:11:41.787,933] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:11:41.788,177] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:11:41.789,489] <err> ADS1015: Reading of ads1015 failed
[10:11:41.789,489] <err> app_sensors: Failed to read sensor data
[10:11:41.789,520] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:11:41.789,794] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:11:41.791,107] <err> ADS1015: Reading of ads1015 failed
[10:11:41.791,137] <err> app_sensors: Failed to read sensor data
[10:11:41.791,168] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:12:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:14:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:16:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 430200413
[10:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:16:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:16:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 25.891889
[10:16:41.771,392] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:16:41.771,423] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:16:41.771,636] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.348205
[10:16:41.781,433] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:16:41.781,494] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:16:41.781,677] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
DaMo sensor unit: powered on pin 14
[10:16:41.797,332] <err> SHT4X: Failed to start measurement.
[10:16:41.797,363] <err> app_sensors: Fetch sample failed (-5)
[10:16:41.797,393] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:16:41.797,393] <err> app_sensors: Failed to read sensor data
[10:16:41.797,424] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:16:41.797,454] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:16:41.797,698] <err> SHT4X: Failed to start measurement.
[10:16:41.797,729] <err> app_sensors: Fetch sample failed (-5)
[10:16:41.797,729] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:16:41.797,729] <err> app_sensors: Failed to read sensor data
[10:16:41.797,760] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:16:41.797,821] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:16:41.798,065] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:16:41.799,377] <err> ADS1015: Reading of ads1015 failed
[10:16:41.799,407] <err> app_sensors: Failed to read sensor data
[10:16:41.799,468] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:16:41.799,713] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:16:41.801,086] <err> ADS1015: Reading of ads1015 failed
[10:16:41.801,086] <err> app_sensors: Failed to read sensor data
[10:16:41.801,116] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:16:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:19:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:21:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.1373
[10:21:41.781,311] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:21:41.781,341] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:21:41.781,555] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.405960
[10:21:41.791,320] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:21:41.791,381] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:21:41.791,564] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:21:41.807,220] <err> SHT4X: Failed to start measurement.
[10:21:41.807,250] <err> app_sensors: Fetch sample failed (-5)
[10:21:41.807,281] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:21:41.807,281] <err> app_sensors: Failed to read sensor data
[10:21:41.807,312] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:21:41.807,342] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:21:41.807,586] <err> SHT4X: Failed to start measurement.
[10:21:41.807,617] <err> app_sensors: Fetch sample failed (-5)
[10:21:41.807,617] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:21:41.807,647] <err> app_sensors: Failed to read sensor data
[10:21:41.807,647] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:21:41.807,708] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:21:41.807,952] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:21:41.809,295] <err> ADS1015: Reading of ads1015 failed
[10:21:41.809,326] <err> app_sensors: Failed to read sensor data
[10:21:41.809,356] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:21:41.809,631] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:21:41.810,974] <err> ADS1015: Reading of ads1015 failed
[10:21:41.810,974] <err> app_sensors: Failed to read sensor data
[10:21:41.811,004] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:23:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:26:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:26:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:26:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 430800413
[10:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:26:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:26:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:26:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.62790
[10:26:41.791,198] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:26:41.791,229] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:26:41.791,442] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.254745
[10:26:41.801,208] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:26:41.801,239] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:26:41.801,452] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:26:41.817,108] <err> SHT4X: Failed to start measurement.
[10:26:41.817,138] <err> app_sensors: Fetch sample failed (-5)
[10:26:41.817,169] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:26:41.817,169] <err> app_sensors: Failed to read sensor data
[10:26:41.817,199] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:26:41.817,230] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:26:41.817,474] <err> SHT4X: Failed to start measurement.
[10:26:41.817,504] <err> app_sensors: Fetch sample failed (-5)
[10:26:41.817,504] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:26:41.817,504] <err> app_sensors: Failed to read sensor data
[10:26:41.817,535] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:26:41.817,596] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:26:41.817,840] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:26:41.819,152] <err> ADS1015: Reading of ads1015 failed
[10:26:41.819,152] <err> app_sensors: Failed to read sensor data
[10:26:41.819,183] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:26:41.819,458] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:26:41.820,800] <err> ADS1015: Reading of ads1015 failed
[10:26:41.820,831] <err> app_sensors: Failed to read sensor data
[10:26:41.820,831] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:28:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:30:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:31:41.801,116] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:31:41.801,147] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
The circuit board humidity value is: 41.703506
[10:31:41.811,096] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:31:41.811,157] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:31:41.811,340] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:31:41.826,995] <err> SHT4X: Failed to start measurement.
[10:31:41.827,026] <err> app_sensors: Fetch sample failed (-5)
[10:31:41.827,056] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:31:41.827,056] <err> app_sensors: Failed to read sensor data
[10:31:41.827,087] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:31:41.827,117] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:31:41.827,362] <err> SHT4X: Failed to start measurement.
[10:31:41.827,392] <err> app_sensors: Fetch sample failed (-5)
[10:31:41.827,392] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:31:41.827,423] <err> app_sensors: Failed to read sensor data
[10:31:41.827,423] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:31:41.827,484] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:31:41.827,728] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:31:41.829,071] <err> ADS1015: Reading of ads1015 failed
[10:31:41.829,101] <err> app_sensors: Failed to read sensor data
[10:31:41.829,101] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:31:41.829,406] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:31:41.830,749] <err> ADS1015: Reading of ads1015 failed
[10:31:41.830,780] <err> app_sensors: Failed to read sensor data
[10:31:41.830,780] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:33:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:35:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:36:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:36:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 431400413
[10:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:36:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:36:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.263065
[10:36:41.810,760] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:36:41.810,791] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:36:41.811,004] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.151748
[10:36:41.820,983] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:36:41.821,044] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:36:41.821,228] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:36:41.836,883] <err> SHT4X: Failed to start measurement.
[10:36:41.836,914] <err> app_sensors: Fetch sample failed (-5)
[10:36:41.836,944] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:36:41.836,944] <err> app_sensors: Failed to read sensor data
[10:36:41.836,975] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:36:41.837,005] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:36:41.837,249] <err> SHT4X: Failed to start measurement.
[10:36:41.837,280] <err> app_sensors: Fetch sample failed (-5)
[10:36:41.837,280] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:36:41.837,280] <err> app_sensors: Failed to read sensor data
[10:36:41.837,310] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:36:41.837,371] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:36:41.837,615] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:36:41.838,928] <err> ADS1015: Reading of ads1015 failed
[10:36:41.838,958] <err> app_sensors: Failed to read sensor data
[10:36:41.838,989] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:36:41.839,233] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:36:41.840,576] <err> ADS1015: Reading of ads1015 failed
[10:36:41.840,606] <err> app_sensors: Failed to read sensor data
[10:36:41.840,606] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:37:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:40:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.340505
[10:41:41.820,678] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:41:41.820,709] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:41:41.820,922] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.491256
[10:41:41.830,871] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:41:41.830,902] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:41:41.831,115] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:41:41.846,771] <err> SHT4X: Failed to start measurement.
[10:41:41.846,801] <err> app_sensors: Fetch sample failed (-5)
[10:41:41.846,832] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:41:41.846,832] <err> app_sensors: Failed to read sensor data
[10:41:41.846,862] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:41:41.846,893] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:41:41.847,137] <err> SHT4X: Failed to start measurement.
[10:41:41.847,167] <err> app_sensors: Fetch sample failed (-5)
[10:41:41.847,167] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:41:41.847,167] <err> app_sensors: Failed to read sensor data
[10:41:41.847,198] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:41:41.847,259] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:41:41.847,503] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:41:41.848,815] <err> ADS1015: Reading of ads1015 failed
[10:41:41.848,846] <err> app_sensors: Failed to read sensor data
[10:41:41.848,876] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:41:41.849,151] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:41:41.850,494] <err> ADS1015: Reading of ads1015 failed
[10:41:41.850,524] <err> app_sensors: Failed to read sensor data
[10:41:41.850,524] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:42:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:44:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:46:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:46:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:46:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:46:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:46:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 432000413
[10:46:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:46:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:46:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:46:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:46:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
Battery voltage is 3031 mV
[10:46:29.920,562] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3/0/7, buf:0x200341b4, len:4
[10:46:29.920,745] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3/0/7
The circuit board temperature value is: 26.391241
[10:46:41.830,596] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:46:41.830,627] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:46:41.830,841] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.140304
[10:46:41.840,759] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:46:41.840,789] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:46:41.841,003] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:46:41.856,658] <err> SHT4X: Failed to start measurement.
[10:46:41.856,689] <err> app_sensors: Fetch sample failed (-5)
[10:46:41.856,719] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:46:41.856,719] <err> app_sensors: Failed to read sensor data
[10:46:41.856,750] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:46:41.856,781] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:46:41.857,025] <err> SHT4X: Failed to start measurement.
[10:46:41.857,055] <err> app_sensors: Fetch sample failed (-5)
[10:46:41.857,055] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:46:41.857,055] <err> app_sensors: Failed to read sensor data
[10:46:41.857,086] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:46:41.857,147] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:46:41.857,391] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:46:41.858,734] <err> ADS1015: Reading of ads1015 failed
[10:46:41.858,764] <err> app_sensors: Failed to read sensor data
[10:46:41.858,795] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:46:41.859,069] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:46:41.860,412] <err> ADS1015: Reading of ads1015 failed
[10:46:41.860,412] <err> app_sensors: Failed to read sensor data
[10:46:41.860,443] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:47:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:49:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.490043
[10:51:41.840,515] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:51:41.840,545] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:51:41.840,759] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.484161
[10:51:41.850,646] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:51:41.850,677] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:51:41.850,891] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:51:41.866,546] <err> SHT4X: Failed to start measurement.
[10:51:41.866,577] <err> app_sensors: Fetch sample failed (-5)
[10:51:41.866,607] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:51:41.866,607] <err> app_sensors: Failed to read sensor data
[10:51:41.866,638] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:51:41.866,668] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:51:41.866,912] <err> SHT4X: Failed to start measurement.
[10:51:41.866,943] <err> app_sensors: Fetch sample failed (-5)
[10:51:41.866,943] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:51:41.866,943] <err> app_sensors: Failed to read sensor data
[10:51:41.866,973] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:51:41.867,034] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:51:41.867,279] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:51:41.868,621] <err> ADS1015: Reading of ads1015 failed
[10:51:41.868,652] <err> app_sensors: Failed to read sensor data
[10:51:41.868,682] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:51:41.868,957] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:51:41.870,269] <err> ADS1015: Reading of ads1015 failed
[10:51:41.870,300] <err> app_sensors: Failed to read sensor data
[10:51:41.870,300] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:51:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:54:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[10:56:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[10:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[10:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[10:56:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[10:56:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[10:56:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[10:56:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[10:56:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 432600413
[10:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[10:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[10:56:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[10:56:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[10:56:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.351186
[10:56:41.850,402] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[10:56:41.850,433] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[10:56:41.850,646] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.985794
[10:56:41.860,504] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[10:56:41.860,565] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[10:56:41.860,748] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[10:56:41.876,403] <err> SHT4X: Failed to start measurement.
[10:56:41.876,434] <err> app_sensors: Fetch sample failed (-5)
[10:56:41.876,464] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[10:56:41.876,464] <err> app_sensors: Failed to read sensor data
[10:56:41.876,495] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[10:56:41.876,525] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[10:56:41.876,770] <err> SHT4X: Failed to start measurement.
[10:56:41.876,800] <err> app_sensors: Fetch sample failed (-5)
[10:56:41.876,800] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[10:56:41.876,800] <err> app_sensors: Failed to read sensor data
[10:56:41.876,831] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[10:56:41.876,892] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[10:56:41.877,136] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:56:41.878,448] <err> ADS1015: Reading of ads1015 failed
[10:56:41.878,479] <err> app_sensors: Failed to read sensor data
[10:56:41.878,509] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[10:56:41.878,784] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[10:56:41.880,126] <err> ADS1015: Reading of ads1015 failed
[10:56:41.880,157] <err> app_sensors: Failed to read sensor data
[10:56:41.880,157] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[10:58:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:01:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.345845
[11:01:41.860,321] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:01:41.860,351] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:01:41.860,565] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.749282
[11:01:41.870,391] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:01:41.870,422] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:01:41.870,635] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:01:41.886,291] <err> SHT4X: Failed to start measurement.
[11:01:41.886,322] <err> app_sensors: Fetch sample failed (-5)
[11:01:41.886,352] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:01:41.886,352] <err> app_sensors: Failed to read sensor data
[11:01:41.886,383] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:01:41.886,413] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:01:41.886,657] <err> SHT4X: Failed to start measurement.
[11:01:41.886,688] <err> app_sensors: Fetch sample failed (-5)
[11:01:41.886,688] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:01:41.886,688] <err> app_sensors: Failed to read sensor data
[11:01:41.886,718] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:01:41.886,779] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:01:41.887,023] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:01:41.888,336] <err> ADS1015: Reading of ads1015 failed
[11:01:41.888,366] <err> app_sensors: Failed to read sensor data
[11:01:41.888,427] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:01:41.888,671] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:01:41.890,045] <err> ADS1015: Reading of ads1015 failed
[11:01:41.890,045] <err> app_sensors: Failed to read sensor data
[11:01:41.890,075] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:03:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:05:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:06:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 433200413
[11:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:06:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:06:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.271076
[11:06:41.870,208] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:06:41.870,239] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:06:41.870,452] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.522308
[11:06:41.880,279] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:06:41.880,340] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:06:41.880,523] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:06:41.896,179] <err> SHT4X: Failed to start measurement.
[11:06:41.896,209] <err> app_sensors: Fetch sample failed (-5)
[11:06:41.896,240] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:06:41.896,240] <err> app_sensors: Failed to read sensor data
[11:06:41.896,270] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:06:41.896,301] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:06:41.896,545] <err> SHT4X: Failed to start measurement.
[11:06:41.896,575] <err> app_sensors: Fetch sample failed (-5)
[11:06:41.896,575] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:06:41.896,575] <err> app_sensors: Failed to read sensor data
[11:06:41.896,606] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:06:41.896,667] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:06:41.896,911] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:06:41.898,223] <err> ADS1015: Reading of ads1015 failed
[11:06:41.898,254] <err> app_sensors: Failed to read sensor data
[11:06:41.898,284] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:06:41.898,529] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:06:41.899,902] <err> ADS1015: Reading of ads1015 failed
[11:06:41.899,902] <err> app_sensors: Failed to read sensor data
[11:06:41.899,932] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:08:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:10:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.295109
[11:11:41.880,126] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:11:41.880,157] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:11:41.880,371] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 42.380630
[11:11:41.890,167] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:11:41.890,197] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:11:41.890,411] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:11:41.906,066] <err> SHT4X: Failed to start measurement.
[11:11:41.906,097] <err> app_sensors: Fetch sample failed (-5)
[11:11:41.906,127] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:11:41.906,127] <err> app_sensors: Failed to read sensor data
[11:11:41.906,158] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:11:41.906,188] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:11:41.906,433] <err> SHT4X: Failed to start measurement.
[11:11:41.906,463] <err> app_sensors: Fetch sample failed (-5)
[11:11:41.906,463] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:11:41.906,494] <err> app_sensors: Failed to read sensor data
[11:11:41.906,494] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:11:41.906,555] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:11:41.906,799] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:11:41.908,203] <err> ADS1015: Reading of ads1015 failed
[11:11:41.908,203] <err> app_sensors: Failed to read sensor data
[11:11:41.908,233] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:11:41.908,508] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:11:41.909,851] <err> ADS1015: Reading of ads1015 failed
[11:11:41.909,851] <err> app_sensors: Failed to read sensor data
[11:11:41.909,881] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:12:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:15:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:16:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 433800413
[11:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:16:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:16:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.452658
[11:16:41.890,014] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:16:41.890,045] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:16:41.890,258] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.763168
[11:16:41.900,054] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:16:41.900,085] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:16:41.900,299] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:16:41.915,954] <err> SHT4X: Failed to start measurement.
[11:16:41.915,985] <err> app_sensors: Fetch sample failed (-5)
[11:16:41.916,015] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:16:41.916,015] <err> app_sensors: Failed to read sensor data
[11:16:41.916,046] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:16:41.916,076] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:16:41.916,320] <err> SHT4X: Failed to start measurement.
[11:16:41.916,351] <err> app_sensors: Fetch sample failed (-5)
[11:16:41.916,351] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:16:41.916,351] <err> app_sensors: Failed to read sensor data
[11:16:41.916,381] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:16:41.916,442] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:16:41.916,687] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:16:41.917,999] <err> ADS1015: Reading of ads1015 failed
[11:16:41.918,029] <err> app_sensors: Failed to read sensor data
[11:16:41.918,090] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:16:41.918,334] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:16:41.919,708] <err> ADS1015: Reading of ads1015 failed
[11:16:41.919,708] <err> app_sensors: Failed to read sensor data
[11:16:41.919,738] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:17:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:19:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.506065
[11:21:41.899,932] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:21:41.899,963] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:21:41.900,177] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.489883
[11:21:41.909,942] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:21:41.909,973] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:21:41.910,186] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:21:41.925,842] <err> SHT4X: Failed to start measurement.
[11:21:41.925,872] <err> app_sensors: Fetch sample failed (-5)
[11:21:41.925,903] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:21:41.925,903] <err> app_sensors: Failed to read sensor data
[11:21:41.925,933] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:21:41.925,964] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:21:41.926,208] <err> SHT4X: Failed to start measurement.
[11:21:41.926,239] <err> app_sensors: Fetch sample failed (-5)
[11:21:41.926,239] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:21:41.926,239] <err> app_sensors: Failed to read sensor data
[11:21:41.926,269] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:21:41.926,330] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:21:41.926,574] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:21:41.927,917] <err> ADS1015: Reading of ads1015 failed
[11:21:41.927,917] <err> app_sensors: Failed to read sensor data
[11:21:41.927,947] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:21:41.928,222] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:21:41.929,534] <err> ADS1015: Reading of ads1015 failed
[11:21:41.929,534] <err> app_sensors: Failed to read sensor data
[11:21:41.929,565] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:22:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:24:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:26:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:26:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 434400413
[11:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:26:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:26:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.514076
[11:26:41.909,820] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:26:41.909,851] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:26:41.910,064] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.911941
[11:26:41.919,830] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:26:41.919,860] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:26:41.920,074] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:26:41.935,729] <err> SHT4X: Failed to start measurement.
[11:26:41.935,760] <err> app_sensors: Fetch sample failed (-5)
[11:26:41.935,791] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:26:41.935,791] <err> app_sensors: Failed to read sensor data
[11:26:41.935,821] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:26:41.935,852] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:26:41.936,096] <err> SHT4X: Failed to start measurement.
[11:26:41.936,126] <err> app_sensors: Fetch sample failed (-5)
[11:26:41.936,126] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:26:41.936,157] <err> app_sensors: Failed to read sensor data
[11:26:41.936,157] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:26:41.936,218] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:26:41.936,462] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:26:41.937,835] <err> ADS1015: Reading of ads1015 failed
[11:26:41.937,866] <err> app_sensors: Failed to read sensor data
[11:26:41.937,896] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:26:41.938,171] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:26:41.939,514] <err> ADS1015: Reading of ads1015 failed
[11:26:41.939,514] <err> app_sensors: Failed to read sensor data
[11:26:41.939,544] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:26:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:29:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:31:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.441977
[11:31:41.919,708] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:31:41.919,738] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:31:41.919,952] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.597229
[11:31:41.929,718] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:31:41.929,779] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:31:41.929,962] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:31:41.945,617] <err> SHT4X: Failed to start measurement.
[11:31:41.945,648] <err> app_sensors: Fetch sample failed (-5)
[11:31:41.945,678] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:31:41.945,678] <err> app_sensors: Failed to read sensor data
[11:31:41.945,709] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:31:41.945,739] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:31:41.945,983] <err> SHT4X: Failed to start measurement.
[11:31:41.946,014] <err> app_sensors: Fetch sample failed (-5)
[11:31:41.946,014] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:31:41.946,044] <err> app_sensors: Failed to read sensor data
[11:31:41.946,044] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:31:41.946,105] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:31:41.946,350] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:31:41.947,662] <err> ADS1015: Reading of ads1015 failed
[11:31:41.947,692] <err> app_sensors: Failed to read sensor data
[11:31:41.947,753] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:31:41.948,028] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:31:41.949,340] <err> ADS1015: Reading of ads1015 failed
[11:31:41.949,340] <err> app_sensors: Failed to read sensor data
[11:31:41.949,371] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:33:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:36:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:36:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:36:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 435000413
[11:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:36:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:36:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:36:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.439307
[11:36:41.929,595] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:36:41.929,626] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:36:41.929,840] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.761260
[11:36:41.939,605] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:36:41.939,636] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:36:41.939,849] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:36:41.955,505] <err> SHT4X: Failed to start measurement.
[11:36:41.955,535] <err> app_sensors: Fetch sample failed (-5)
[11:36:41.955,566] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:36:41.955,566] <err> app_sensors: Failed to read sensor data
[11:36:41.955,596] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:36:41.955,627] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:36:41.955,871] <err> SHT4X: Failed to start measurement.
[11:36:41.955,902] <err> app_sensors: Fetch sample failed (-5)
[11:36:41.955,902] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:36:41.955,902] <err> app_sensors: Failed to read sensor data
[11:36:41.955,932] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:36:41.955,993] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:36:41.956,237] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:36:41.957,550] <err> ADS1015: Reading of ads1015 failed
[11:36:41.957,580] <err> app_sensors: Failed to read sensor data
[11:36:41.957,611] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:36:41.957,855] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:36:41.959,228] <err> ADS1015: Reading of ads1015 failed
[11:36:41.959,228] <err> app_sensors: Failed to read sensor data
[11:36:41.959,259] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:38:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:40:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.500724
[11:41:41.939,514] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:41:41.939,544] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:41:41.939,758] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.828018
[11:41:41.949,523] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:41:41.949,584] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:41:41.949,768] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:41:41.965,423] <err> SHT4X: Failed to start measurement.
[11:41:41.965,454] <err> app_sensors: Fetch sample failed (-5)
[11:41:41.965,484] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:41:41.965,484] <err> app_sensors: Failed to read sensor data
[11:41:41.965,515] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:41:41.965,545] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:41:41.965,789] <err> SHT4X: Failed to start measurement.
[11:41:41.965,820] <err> app_sensors: Fetch sample failed (-5)
[11:41:41.965,820] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:41:41.965,820] <err> app_sensors: Failed to read sensor data
[11:41:41.965,850] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:41:41.965,911] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:41:41.966,156] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:41:41.967,498] <err> ADS1015: Reading of ads1015 failed
[11:41:41.967,529] <err> app_sensors: Failed to read sensor data
[11:41:41.967,559] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:41:41.967,834] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:41:41.969,177] <err> ADS1015: Reading of ads1015 failed
[11:41:41.969,177] <err> app_sensors: Failed to read sensor data
[11:41:41.969,207] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:43:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:45:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:46:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:46:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:46:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:46:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:46:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:46:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 435600413
[11:46:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:46:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:46:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:46:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:46:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.575494
[11:46:41.949,401] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:46:41.949,432] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[11:46:41.949,645] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.831832
[11:46:41.959,411] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:46:41.959,442] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:46:41.959,655] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:46:41.975,311] <err> SHT4X: Failed to start measurement.
[11:46:41.975,341] <err> app_sensors: Fetch sample failed (-5)
[11:46:41.975,372] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:46:41.975,372] <err> app_sensors: Failed to read sensor data
[11:46:41.975,402] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:46:41.975,433] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:46:41.975,677] <err> SHT4X: Failed to start measurement.
[11:46:41.975,708] <err> app_sensors: Fetch sample failed (-5)
[11:46:41.975,708] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:46:41.975,708] <err> app_sensors: Failed to read sensor data
[11:46:41.975,738] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:46:41.975,799] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:46:41.976,043] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:46:41.977,355] <err> ADS1015: Reading of ads1015 failed
[11:46:41.977,386] <err> app_sensors: Failed to read sensor data
[11:46:41.977,447] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:46:41.977,691] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:46:41.979,064] <err> ADS1015: Reading of ads1015 failed
[11:46:41.979,064] <err> app_sensors: Failed to read sensor data
[11:46:41.979,095] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:47:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:50:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:51:41.959,320] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:51:41.959,350] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
The circuit board humidity value is: 40.654449
[11:51:41.969,299] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:51:41.969,329] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:51:41.969,543] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[11:51:41.985,198] <err> SHT4X: Failed to start measurement.
[11:51:41.985,229] <err> app_sensors: Fetch sample failed (-5)
[11:51:41.985,260] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:51:41.985,260] <err> app_sensors: Failed to read sensor data
[11:51:41.985,290] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:51:41.985,321] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:51:41.985,565] <err> SHT4X: Failed to start measurement.
[11:51:41.985,595] <err> app_sensors: Fetch sample failed (-5)
[11:51:41.985,595] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:51:41.985,595] <err> app_sensors: Failed to read sensor data
[11:51:41.985,626] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:51:41.985,687] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:51:41.985,931] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:51:41.987,243] <err> ADS1015: Reading of ads1015 failed
[11:51:41.987,243] <err> app_sensors: Failed to read sensor data
[11:51:41.987,274] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:51:41.987,548] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:51:41.988,861] <err> ADS1015: Reading of ads1015 failed
[11:51:41.988,861] <err> app_sensors: Failed to read sensor data
[11:51:41.988,891] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:52:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:54:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[11:56:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[11:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[11:56:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[11:56:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[11:56:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[11:56:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[11:56:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 436200413
[11:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[11:56:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[11:56:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[11:56:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[11:56:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
[11:56:41.968,963] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[11:56:41.968,994] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
The circuit board humidity value is: 40.614395
[11:56:41.979,187] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[11:56:41.979,217] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[11:56:41.979,431] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
DaMo sensor unit: powered on pin 14
[11:56:41.995,086] <err> SHT4X: Failed to start measurement.
[11:56:41.995,117] <err> app_sensors: Fetch sample failed (-5)
[11:56:41.995,147] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[11:56:41.995,147] <err> app_sensors: Failed to read sensor data
[11:56:41.995,178] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[11:56:41.995,208] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[11:56:41.995,452] <err> SHT4X: Failed to start measurement.
[11:56:41.995,483] <err> app_sensors: Fetch sample failed (-5)
[11:56:41.995,483] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[11:56:41.995,483] <err> app_sensors: Failed to read sensor data
[11:56:41.995,513] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[11:56:41.995,574] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[11:56:41.995,819] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:56:41.997,131] <err> ADS1015: Reading of ads1015 failed
[11:56:41.997,131] <err> app_sensors: Failed to read sensor data
[11:56:41.997,161] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[11:56:41.997,436] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[11:56:41.998,779] <err> ADS1015: Reading of ads1015 failed
[11:56:41.998,779] <err> app_sensors: Failed to read sensor data
[11:56:41.998,809] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[11:57:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[11:59:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.604867
[12:01:41.978,637] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:01:41.978,668] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:01:41.978,881] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.904312
[12:01:41.989,074] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:01:41.989,105] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:01:41.989,318] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:01:42.004,974] <err> SHT4X: Failed to start measurement.
[12:01:42.005,004] <err> app_sensors: Fetch sample failed (-5)
[12:01:42.005,035] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:01:42.005,035] <err> app_sensors: Failed to read sensor data
[12:01:42.005,065] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:01:42.005,096] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:01:42.005,340] <err> SHT4X: Failed to start measurement.
[12:01:42.005,371] <err> app_sensors: Fetch sample failed (-5)
[12:01:42.005,371] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:01:42.005,371] <err> app_sensors: Failed to read sensor data
[12:01:42.005,401] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:01:42.005,462] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:01:42.005,706] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:01:42.007,019] <err> ADS1015: Reading of ads1015 failed
[12:01:42.007,049] <err> app_sensors: Failed to read sensor data
[12:01:42.007,080] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:01:42.007,354] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:01:42.008,697] <err> ADS1015: Reading of ads1015 failed
[12:01:42.008,728] <err> app_sensors: Failed to read sensor data
[12:01:42.008,728] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:01:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:04:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:06:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[12:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[12:06:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[12:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[12:06:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[12:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[12:06:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[12:06:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 436800413
[12:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[12:06:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[12:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[12:06:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[12:06:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.548790
[12:06:41.988,525] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:06:41.988,555] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:06:41.988,769] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.803222
[12:06:41.998,962] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:06:41.999,023] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:06:41.999,206] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:06:42.014,862] <err> SHT4X: Failed to start measurement.
[12:06:42.014,892] <err> app_sensors: Fetch sample failed (-5)
[12:06:42.014,923] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:06:42.014,923] <err> app_sensors: Failed to read sensor data
[12:06:42.014,953] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:06:42.014,984] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:06:42.015,228] <err> SHT4X: Failed to start measurement.
[12:06:42.015,258] <err> app_sensors: Fetch sample failed (-5)
[12:06:42.015,258] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:06:42.015,258] <err> app_sensors: Failed to read sensor data
[12:06:42.015,289] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:06:42.015,350] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:06:42.015,594] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:06:42.016,906] <err> ADS1015: Reading of ads1015 failed
[12:06:42.016,937] <err> app_sensors: Failed to read sensor data
[12:06:42.016,998] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:06:42.017,242] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:06:42.018,615] <err> ADS1015: Reading of ads1015 failed
[12:06:42.018,615] <err> app_sensors: Failed to read sensor data
[12:06:42.018,646] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:08:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:11:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.618219
[12:11:41.998,443] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:11:41.998,474] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:11:41.998,687] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.753631
[12:11:42.008,850] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:11:42.008,911] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:11:42.009,094] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:11:42.024,749] <err> SHT4X: Failed to start measurement.
[12:11:42.024,780] <err> app_sensors: Fetch sample failed (-5)
[12:11:42.024,810] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:11:42.024,810] <err> app_sensors: Failed to read sensor data
[12:11:42.024,841] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:11:42.024,871] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:11:42.025,115] <err> SHT4X: Failed to start measurement.
[12:11:42.025,146] <err> app_sensors: Fetch sample failed (-5)
[12:11:42.025,146] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:11:42.025,146] <err> app_sensors: Failed to read sensor data
[12:11:42.025,177] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:11:42.025,238] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:11:42.025,482] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:11:42.026,794] <err> ADS1015: Reading of ads1015 failed
[12:11:42.026,794] <err> app_sensors: Failed to read sensor data
[12:11:42.026,824] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:11:42.027,099] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:11:42.028,411] <err> ADS1015: Reading of ads1015 failed
[12:11:42.028,411] <err> app_sensors: Failed to read sensor data
[12:11:42.028,442] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:13:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:15:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
[12:16:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[12:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[12:16:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[12:16:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[12:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[12:16:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[12:16:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 437400413
[12:16:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[12:16:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[12:16:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[12:16:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[12:16:24.413,513] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.631570
[12:16:42.008,331] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:16:42.008,361] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:16:42.008,575] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.362625
[12:16:42.018,737] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:16:42.018,768] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:16:42.018,981] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:16:42.034,637] <err> SHT4X: Failed to start measurement.
[12:16:42.034,667] <err> app_sensors: Fetch sample failed (-5)
[12:16:42.034,698] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:16:42.034,698] <err> app_sensors: Failed to read sensor data
[12:16:42.034,729] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:16:42.034,759] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:16:42.035,003] <err> SHT4X: Failed to start measurement.
[12:16:42.035,034] <err> app_sensors: Fetch sample failed (-5)
[12:16:42.035,034] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:16:42.035,034] <err> app_sensors: Failed to read sensor data
[12:16:42.035,064] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:16:42.035,125] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:16:42.035,369] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:16:42.036,743] <err> ADS1015: Reading of ads1015 failed
[12:16:42.036,743] <err> app_sensors: Failed to read sensor data
[12:16:42.036,773] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:16:42.037,048] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:16:42.038,391] <err> ADS1015: Reading of ads1015 failed
[12:16:42.038,391] <err> app_sensors: Failed to read sensor data
[12:16:42.038,421] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:18:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:20:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.676966
[12:21:42.018,249] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:21:42.018,280] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:21:42.018,493] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.913848
[12:21:42.028,594] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:21:42.028,625] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:21:42.028,839] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:21:42.044,494] <err> SHT4X: Failed to start measurement.
[12:21:42.044,525] <err> app_sensors: Fetch sample failed (-5)
[12:21:42.044,555] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:21:42.044,555] <err> app_sensors: Failed to read sensor data
[12:21:42.044,586] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:21:42.044,616] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:21:42.044,860] <err> SHT4X: Failed to start measurement.
[12:21:42.044,891] <err> app_sensors: Fetch sample failed (-5)
[12:21:42.044,891] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:21:42.044,891] <err> app_sensors: Failed to read sensor data
[12:21:42.044,921] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:21:42.044,982] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:21:42.045,227] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:21:42.046,569] <err> ADS1015: Reading of ads1015 failed
[12:21:42.046,600] <err> app_sensors: Failed to read sensor data
[12:21:42.046,630] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:21:42.046,905] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:21:42.048,217] <err> ADS1015: Reading of ads1015 failed
[12:21:42.048,248] <err> app_sensors: Failed to read sensor data
[12:21:42.048,248] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:22:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:25:04.309,417] <inf> hw_watchdog: feeding hw_watchdog
[12:26:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[12:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[12:26:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[12:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[12:26:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[12:26:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[12:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 438000413
[12:26:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[12:26:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[12:26:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[12:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[12:26:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.770428
[12:26:42.028,137] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:26:42.028,167] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:26:42.028,381] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.426940
[12:26:42.038,452] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:26:42.038,482] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:26:42.038,696] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:26:42.054,351] <err> SHT4X: Failed to start measurement.
[12:26:42.054,382] <err> app_sensors: Fetch sample failed (-5)
[12:26:42.054,412] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:26:42.054,412] <err> app_sensors: Failed to read sensor data
[12:26:42.054,443] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:26:42.054,473] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:26:42.054,718] <err> SHT4X: Failed to start measurement.
[12:26:42.054,748] <err> app_sensors: Fetch sample failed (-5)
[12:26:42.054,748] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:26:42.054,748] <err> app_sensors: Failed to read sensor data
[12:26:42.054,779] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:26:42.054,840] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:26:42.055,084] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:26:42.056,396] <err> ADS1015: Reading of ads1015 failed
[12:26:42.056,396] <err> app_sensors: Failed to read sensor data
[12:26:42.056,427] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:26:42.056,701] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:26:42.058,013] <err> ADS1015: Reading of ads1015 failed
[12:26:42.058,013] <err> app_sensors: Failed to read sensor data
[12:26:42.058,044] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:27:24.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:29:44.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.719691
[12:31:42.038,055] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:31:42.038,085] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:31:42.038,299] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 39.244903
[12:31:42.048,309] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:31:42.048,339] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:31:42.048,553] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:31:42.064,208] <err> SHT4X: Failed to start measurement.
[12:31:42.064,239] <err> app_sensors: Fetch sample failed (-5)
[12:31:42.064,270] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:31:42.064,270] <err> app_sensors: Failed to read sensor data
[12:31:42.064,300] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:31:42.064,331] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:31:42.064,575] <err> SHT4X: Failed to start measurement.
[12:31:42.064,605] <err> app_sensors: Fetch sample failed (-5)
[12:31:42.064,605] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:31:42.064,605] <err> app_sensors: Failed to read sensor data
[12:31:42.064,636] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:31:42.064,697] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:31:42.064,941] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:31:42.066,253] <err> ADS1015: Reading of ads1015 failed
[12:31:42.066,284] <err> app_sensors: Failed to read sensor data
[12:31:42.066,314] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:31:42.066,558] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:31:42.067,901] <err> ADS1015: Reading of ads1015 failed
[12:31:42.067,932] <err> app_sensors: Failed to read sensor data
[12:31:42.067,932] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:32:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:34:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
[12:36:24.413,269] <dbg> app_lwm2m_client: debug_connection_work_cb: current custom_mode: 2
[12:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 3
[12:36:24.413,299] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100
[12:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 10
[12:36:24.413,330] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 1
[12:36:24.413,360] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 1
[12:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 438600413
[12:36:24.413,391] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 398457190
[12:36:24.413,421] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 428759138
[12:36:24.413,452] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update_complete: 428763620
[12:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_disconnect: 376851459
[12:36:24.413,482] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 428763621
The circuit board temperature value is: 26.628900
[12:36:42.047,943] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:36:42.047,973] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:36:42.048,187] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 40.282516
[12:36:42.058,166] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:36:42.058,197] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:36:42.058,410] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:36:42.074,066] <err> SHT4X: Failed to start measurement.
[12:36:42.074,096] <err> app_sensors: Fetch sample failed (-5)
[12:36:42.074,127] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:36:42.074,127] <err> app_sensors: Failed to read sensor data
[12:36:42.074,157] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:36:42.074,188] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:36:42.074,432] <err> SHT4X: Failed to start measurement.
[12:36:42.074,462] <err> app_sensors: Fetch sample failed (-5)
[12:36:42.074,462] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:36:42.074,462] <err> app_sensors: Failed to read sensor data
[12:36:42.074,493] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:36:42.074,554] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:36:42.074,798] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:36:42.076,141] <err> ADS1015: Reading of ads1015 failed
[12:36:42.076,171] <err> app_sensors: Failed to read sensor data
[12:36:42.076,202] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:36:42.076,477] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:36:42.077,789] <err> ADS1015: Reading of ads1015 failed
[12:36:42.077,819] <err> app_sensors: Failed to read sensor data
[12:36:42.077,819] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:36:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:39:04.309,448] <inf> hw_watchdog: feeding hw_watchdog
[12:41:24.309,417] <inf> hw_watchdog: feeding hw_watchdog
The circuit board temperature value is: 26.741054
[12:41:42.057,861] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0x200341a0, len:8
[12:41:42.057,891] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5518, buf:0x20034110, len:8
[12:41:42.058,105] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3303/0/5700
The circuit board humidity value is: 41.926666
[12:41:42.068,054] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5700, buf:0x200341a0, len:8
[12:41:42.068,084] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/0/5518, buf:0x20034110, len:8
[12:41:42.068,298] <dbg> net_lwm2m_observation: lwm2m_notify_observer_path: NOTIFY EVENT 3304/0/5700
[12:41:42.083,953] <err> SHT4X: Failed to start measurement.
[12:41:42.083,984] <err> app_sensors: Fetch sample failed (-5)
[12:41:42.084,014] <err> app_sensors: Reading of rake temperature sensor failed (-5)
[12:41:42.084,014] <err> app_sensors: Failed to read sensor data
[12:41:42.084,045] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5700, buf:0x20034190, len:8
[12:41:42.084,075] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/1/5518, buf:0x20034100, len:8
[12:41:42.084,320] <err> SHT4X: Failed to start measurement.
[12:41:42.084,350] <err> app_sensors: Fetch sample failed (-5)
[12:41:42.084,350] <err> app_sensors: Reading of rake humidity sensor failed (-5)
[12:41:42.084,381] <err> app_sensors: Failed to read sensor data
[12:41:42.084,381] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5700, buf:0x20034190, len:8
[12:41:42.084,442] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3304/1/5518, buf:0x20034100, len:8
[12:41:42.084,686] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:41:42.085,998] <err> ADS1015: Reading of ads1015 failed
[12:41:42.085,998] <err> app_sensors: Failed to read sensor data
[12:41:42.086,029] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/0/5700, buf:0x200341a0, len:8
[12:41:42.086,303] <err> ADS1015: Failed to write to I2C device address 48 at Register 1
[12:41:42.087,615] <err> ADS1015: Reading of ads1015 failed
[12:41:42.087,615] <err> app_sensors: Failed to read sensor data
[12:41:42.087,646] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3316/1/5700, buf:0x200341a0, len:8
[12:43:44.309,448] <inf> hw_watchdog: feeding hw_watchdog
The issue then fixes itself when CONFIG_LWM2M_UPDATE_PERIOD runs out: The device performs a registration update and the fully reregisters with the server, resetting the observer.
As a fix, we're just dynamically setting the CONFIG_LWM2M_UPDATE_PERIOD in the application to closely follow the pmax period, so we don't have big gaps in our data reporting, but of course this shouldn't be the permanent solution.
Is this known behaviour or is there something we're missing? Any insights or instincts would be appreciated.
Also happy to provide more info if necessary.
best regards
Alan
  • Hi Seppo,
    Thanks for looking into this.
    That's correct, we do have have a very short listening time configured (CONFIG_LWM2M_QUEUE_MODE_UPTIME=4), after which the device goes back to sleep. The thing is that we're not waiting for or expecting any command from the server. Even if it listened for another minute, we wouldn't expect the server to send anything. It acknowledged the registration update and that's it. What we'd expect is just the device sending the observer telemetry like in the other 100+ transmissions.
    The reason I find it strange and made this ticket is that nothing is timing out, the registration update is successful and acknowledged, but then the device for some reason just doesn't send the next message. Do you think it's a timeout issue or something else?
  • You're right, this is very badly worded.
    My colleague modified the toolchain to where instead of the update period being set to CONFIG_LWM2M_UPDATE_PERIOD, the application waits for the pmin and pmax on our resource of interest to be set and then sets the update period to pmax + 1 minute or so. This was done because we'd get massive gaps in telemetry whenever the titular bug happened (e.g. pmax = 1h, original update period = 24h). This would also mean that our device was unreachable for very long periods of time, so the fix was to dynamically set the update period close to pmax, in order to ensure regular reachability of our devices.
    But of course a longer registration update period should never really be relevant as long as an observer with a shorter pmax is set, because every time the observer sends a telemetry update, the registration is also updated. I'm not sure this fix has anything to do with the core issue, but let me know if you have any further questions relating to the problem. Please also keep in mind that this was implemented as a workaround for the issue, so the issue existed before this fix was applied.
    pmax is set through the server sending an `update attributes` command to our most interesting telemetry value at registration time.
  • The reason I find it strange and made this ticket is that nothing is timing out, the registration update is successful and acknowledged, but then the device for some reason just doesn't send the next message. Do you think it's a timeout issue or something else?
    I took a look at the LwM2M engine and I can confirm that there is a corner case on this.
    If RD client state machine may enter the QUEUE_RX_OFF state even if there is some CoAP messages pending for Ack packet. This blocks the sending of the retried CoAP transmission.
    On the log, you can see that the last [AUTO] NOTIFY MSG START message did not have "NOTIFY ACK", which means that the Ack message did not arrive in 4 seconds.
    I'll start working for the bugfix for upstream Zephyr on this. In the mean time, try those mentioned workarounds.
    Also, in case you want to follow the socket state, there is an application callback https://github.com/zephyrproject-rtos/zephyr/blob/9c2421444ba51c812eaa579e8f7a859e73b78bfa/include/zephyr/net/lwm2m.h#L324C9-L324C25 and if its called with LWM2M_SOCKET_STATE_NO_DATA parameter, then it really means that engine is not waiting for anything from the network. We use that information on our SDK to control the RAI option for modem https://github.com/nrfconnect/sdk-nrf/blob/396c16d54f4549f6cd4b84150f89768c3f51c977/subsys/net/lib/lwm2m_client_utils/lwm2m/lwm2m_rai.c#L104-L156
  • Thanks for the quick analysis!
    Looking forward to the fix. Out of curiosity: how long does it usually take for zephyr upstream PRs to come to the nrf sdk?
    One more question:
    In the modem trace msg no. 5253 (first failure to send the observer telemetry), the Ack for the registration update arrives within ~0.24 seconds. Is this consistent with your diagnosis of the issue or are we still missing something?
  • In the modem trace msg no. 5253 (first failure to send the observer telemetry), the Ack for the registration update arrives within ~0.24 seconds. Is this consistent with your diagnosis of the issue or are we still missing something?
    That is a strange.
    It looks like the observation is not send at all. How are you able to release the connection so fast? What kind of eDRX or PSM configurations do you use?
    There is a possibility that the network connection is released even before the CoAP message gets out. So when the applications call `send()` the UDP packet only enters the outgoing buffers on the modem's IP stack. Then it might take a while for lower layers to be able to send the packet on the air.
    You might also want to try if CONFIG_LWM2M_CLIENT_UTILS_RAI helps, as it gives hints to the modem if there is more traffic to be expected.
