nRF51 problem with micor-esb library RX and TX and S110
Hi, i have a problem with nRF51 an nRF24LU1+. I use S110 and micro-esb library. I can switch beatween poroperty RF and bluetooh ( never run both in the same time ). When I choose property RF for only sending data, everything works very well ( nRF24LU1+ recive all data), but when I want to recive some data form nRF24LU1+ I cant't recive any byte. When I work in property RF I don't use soft device and it's disable.
Here is my micro-esb callback:
void uesb_event_handler()
    static uint32_t rf_interrupts;
    static uint32_t tx_attempts;
 // PIN_NEG(LED_GREEN);
    uesb_get_clear_interrupts(&rf_interrupts);
    if(rf_interrupts & UESB_INT_TX_SUCCESS_MSK)
    if(rf_interrupts & UESB_INT_TX_FAILED_MSK)
        uesb_flush_tx();
    if(rf_interrupts & UESB_INT_RX_DR_MSK)
        uesb_read_rx_payload(&rx_payload);
        PIN_NEG(LED_BLUE);
    uesb_get_tx_attempts(&tx_attempts);
and initliazation:
uesb_config_t uesb_config       = UESB_DEFAULT_CONFIG;
uesb_config.rf_channel          = 1;
uesb_config.crc                 = UESB_CRC_8BIT;
uesb_config.retransmit_count    = 15;
uesb_config.retransmit_delay    = 500;
uesb_config.dynamic_ack_enabled = 1;
uesb_config.protocol            = UESB_PROTOCOL_ESB_DPL;
uesb_config.bitrate             = UESB_BITRATE_2MBPS;
uesb_config.event_handler       = uesb_event_handler;
uesb_config.mode								=	1;
tx_payload.length  							= 32;
tx_payload.pipe    							= 0;
rx_payload.length  							= 32;
  uesb_init(&uesb_config);
  uesb_set_address(UESB_ADDRESS_PIPE0, ADDRESS_1);
  uesb_set_address(UESB_ADDRESS_PIPE1, ADDRESS_2);
  uesb_start_rx();
in nRF24LU1+: function for sending:
static void send_rf_buf()
  CE_LOW();
  hal_nrf_set_operation_mode(HAL_NRF_PTX);
  hal_nrf_write_tx_payload_noack(rf_out_buf, 32);
  radio_busy = true;
  CE_PULSE();
  while(radio_busy);
  hal_nrf_set_operation_mode(HAL_NRF_PRX);
  CE_HIGH();
and initizlization:
static void rf_init()
  // Enable radio SPI and clock
  RFCTL = 0x10;
  RFCKEN = 1;
  // Set payload width to 32 bytes
  hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE0, 32);
  hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE1, 32);
	actualize_addr_chan();
hal_nrf_set_address(HAL_NRF_PIPE0, current_address);
hal_nrf_set_address(HAL_NRF_TX, current_address);
//  Clear and flush radio state
  hal_nrf_get_clear_irq_flags();
  hal_nrf_flush_rx();
  hal_nrf_flush_tx();
  CE_LOW();
  packet_received = false;
  // Power up radio
//	hal_nrf_set_rf_channel(1);
	hal_nrf_set_output_power(HAL_NRF_0DBM);
  hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
  // Enable RF interrupt
  RF = 1;
	CE_HIGH();
