Hi:
I can't compile the program.
Please tell me the solution.
I used with Toolchain&SDK: 3.0.2&3.0.2; 3.0.0&3.0.0 and 2.8.0&2.8.0.
VS Code Winwdows 11, Processor 11th Gen Intel(R) Core(TM) i7-11390H @ 3.40GHz, 3418 Mhz, 4 Core(s), 8 Logical Processor(s).
KIT nRF52DK
# Copyright (c) 2024 Nordic Semiconductor
#cmake_minimum_required(VERSION 3.20.0)
#find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
#project(fra_test_sleep_toggle)
project(nrf_connect_sdk_fundamentals)
Executing task: nRF Connect: Generate config nrf52dk/nrf52832 for c:\myfw\FRA\ver1 Building ver1 C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/myfw/FRA/ver1/build c:/myfw/FRA/ver1 --pristine --board nrf52dk/nrf52832 -- -DCONF_FILE=prj.conf" -- west build: generating a build system Loading Zephyr module(s) (Zephyr base): sysbuild_default -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter -- Cache files will be written to: C:/ncs/v3.0.2/zephyr/.cache -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52dk, qualifiers: nrf52832 Parsing C:/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig Loaded configuration 'C:/myfw/FRA/ver1/build/_sysbuild/empty.conf' Merged configuration 'C:/myfw/FRA/ver1/build/_sysbuild/empty.conf' Configuration saved to 'C:/myfw/FRA/ver1/build/zephyr/.config' Kconfig header saved to 'C:/myfw/FRA/ver1/build/_sysbuild/autoconf.h' -- ************************** * Running CMake for ver1 * ************************** Loading Zephyr default modules (Zephyr base). -- Application: C:/myfw/FRA/ver1 -- CMake version: 3.21.0 -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter -- Cache files will be written to: C:/ncs/v3.0.2/zephyr/.cache -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52dk, qualifiers: nrf52832 -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk) -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk) -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found BOARD.dts: C:/ncs/v3.0.2/zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts -- Generated zephyr.dts: C:/myfw/FRA/ver1/build/ver1/zephyr/zephyr.dts -- Generated pickled edt: C:/myfw/FRA/ver1/build/ver1/zephyr/edt.pickle -- Generated zephyr.dts: C:/myfw/FRA/ver1/build/ver1/zephyr/zephyr.dts -- Generated devicetree_generated.h: C:/myfw/FRA/ver1/build/ver1/zephyr/include/generated/zephyr/devicetree_generated.h -- Including generated dts.cmake file: C:/myfw/FRA/ver1/build/ver1/zephyr/dts.cmake warning: PM (defined at C:/ncs/v3.0.2/zephyr/soc/silabs\silabs_s2\efr32bg22\Kconfig.defconfig:10, C:/ncs/v3.0.2/zephyr/soc/silabs\silabs_s2\efr32mg21\Kconfig.defconfig:10, C:/ncs/v3.0.2/zephyr/soc/silabs\silabs_s2\efr32mg24\Kconfig.defconfig:10, C:/ncs/v3.0.2/zephyr/soc/silabs\silabs_s2\efr32zg23\Kconfig.defconfig:10, C:/ncs/v3.0.2/zephyr/soc/renesas/smartbond\da1469x\Kconfig.defconfig:39, C:/ncs/v3.0.2/zephyr/soc/realtek/ec\rts5912\Kconfig.defconfig.rts5912:10, C:/ncs/v3.0.2/zephyr/soc/nordic\nrf54h\Kconfig.defconfig.nrf54h20_cpurad:14, subsys/pm/Kconfig:13) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: (SOC_SERIES_EFR32BG22 || SOC_SERIES_EFR32MG21 || SOC_SERIES_EFR32MG24 || SOC_SERIES_EFR32ZG23 || (SOC_SERIES_DA1469X && SOC_FAMILY_RENESAS_SMARTBOND) || (REALTEK_RTS5912_RTMR && SOC_RTS5912 && SOC_SERIES_RTS5912 && SOC_FAMILY_REALTEK_EC) || (SOC_NRF54H20_CPURAD && SOC_SERIES_NRF54HX && SOC_FAMILY_NORDIC_NRF) || (SYS_CLOCK_EXISTS && HAS_PM)) (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM and/or look up PM in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. Parsing C:/ncs/v3.0.2/zephyr/Kconfig Loaded configuration 'C:/ncs/v3.0.2/zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832_defconfig' Merged configuration 'C:/myfw/FRA/ver1/prj.conf' Merged configuration 'C:/myfw/FRA/ver1/build/ver1/zephyr/.config.sysbuild' Configuration saved to 'C:/myfw/FRA/ver1/build/ver1/zephyr/.config' Kconfig header saved to 'C:/myfw/FRA/ver1/build/ver1/zephyr/include/generated/zephyr/autoconf.h' -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe -- Configuring done CMake Error at C:/ncs/v3.0.2/zephyr/cmake/modules/extensions.cmake:457 (add_library): No SOURCES given to target: app Call Stack (most recent call first): C:/ncs/v3.0.2/zephyr/cmake/modules/kernel.cmake:218 (zephyr_library_named) C:/ncs/v3.0.2/zephyr/cmake/modules/zephyr_default.cmake:142 (include) C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:12 (find_package) CMake Generate step failed. Build files cannot be regenerated correctly. CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message): CMake configure failed for Zephyr project: ver1 Location: C:/myfw/FRA/ver1 Call Stack (most recent call first): cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake) cmake/modules/sysbuild_default.cmake:21 (include) C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include) C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) C:/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include) template/CMakeLists.txt:10 (find_package) -- Configuring incomplete, errors occurred! See also "C:/myfw/FRA/ver1/build/CMakeFiles/CMakeOutput.log". FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-Bc:\myfw\FRA\ver1\build' -GNinja -DBOARD=nrf52dk/nrf52832 -DCONF_FILE=prj.conf '-SC:\ncs\v3.0.2\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\myfw\FRA\ver1' * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "win32",
"osVersion": "Windows 11 Home",
"osKernel": "10.0.26100",
"vscode": "1.102.1",
"electron": "35.6.0",
"node": "v22.15.1"
"system": {
"date": "2025-07-22T00:42:13.044Z",
"vscodeRoot": "c:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
"vscodeUptime": "00:02:14",
"osUptime": "146:18:50",
"cpu": "11th Gen Intel(R) Core(TM) i7-11390H @ 3.40GHz"
"workspace": {
"name": "ver1",
"workspaceFile": null,
"folders": [
"c:\\myfw\\FRA\\ver1"
"sdks": [
"version": "v3.0.2",
"path": "c:\\ncs\\v3.0.2"
"version": "v3.0.0",
"path": "c:\\ncs\\v3.0.0"
"version": "v2.8.0",
"path": "c:\\ncs\\v2.8.0"
"apps": [
"workspace": "c:\\myfw\\FRA\\ver1",
"uri": "c:\\myfw\\FRA\\ver1",
"buildConfigurations": []
"toolchains": [
"version": "3.0.2",
"path": "c:\\ncs\\toolchains\\0b393f9e1b"
"version": "3.0.0",
"version": "2.8.0",
"path": "c:\\ncs\\toolchains\\2d382dcd92"
"connectedDevices": [],
"tools": {
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
"C:\\Program Files\\SEGGER\\JLink_V840\\JLink.exe": "8.40",
"C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
"C:\\NORDIC\\nordic_tools\\nrfutil.exe": "8.0.0",
"C:\\ncs\\toolchains\\0b393f9e1b\\cmake": "3.21.0",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Scripts\\west.exe": "1.2.0",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\python.exe": "3.12.4",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\ninja.exe": "1.10.2",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\gperf.exe": "3.1",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\dtc.exe": "1.4.7",
"C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\gn.exe": "2223",
"C:\\ncs\\toolchains\\0b393f9e1b\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
"arm-gdbPath": "c:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
"riscv-gdbPath": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
"nrfutil": {
"nrfutil-device": {
"version": "2.8.8",
"binPath": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
"jlinkInfo": {
"description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
"expectedVersion": {
"version": "JLink_V8.18",
"versionFormat": "string"
"name": "JlinkARM",
"version": "JLink_V8.40",
"nrfutil-sdk-manager": {
"version": "1.3.0",
"binPath": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\bin\\nrfutil-sdk-manager"
"environment": {
"westEnv": {
"HOME": "C:\\Users\\LMIRANDA",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\LMIRANDA",
"PATH": "C:\\ncs\\toolchains\\0b393f9e1b;C:\\ncs\\toolchains\\0b393f9e1b\\mingw64\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\lib\\nrfutil-sdk-manager;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files\\HP\\HP One Agent;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\NORDIC\\nordic_tools;C:\\Users\\LMIRANDA\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;C:\\Spark\\spark-3.5.0-bin-hadoop3\\bin;C:\\Program Files\\Java\\jdk-1.8\\bin;C:\\Spark\\spark-3.5.0-bin-hadoop3/hadoop\\bin;C:\\Program Files\\JetBrains\\PyCharm Community Edition 2023.2.3\\bin;;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
"ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk",
"PYTHONPATH": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Lib;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Lib\\site-packages"
"inherited": {
"HOMEDRIVE": "C:",
"Path": "C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files\\HP\\HP One Agent;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\NORDIC\\nordic_tools;C:\\Users\\LMIRANDA\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Spark\\spark-3.5.0-bin-hadoop3\\bin;C:\\Program Files\\Java\\jdk-1.8\\bin;C:\\Spark\\spark-3.5.0-bin-hadoop3/hadoop\\bin;C:\\Program Files\\JetBrains\\PyCharm Community Edition 2023.2.3\\bin;;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
"PATH": "C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files\\HP\\HP One Agent;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\NORDIC\\nordic_tools;C:\\Users\\LMIRANDA\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Spark\\spark-3.5.0-bin-hadoop3\\bin;C:\\Program Files\\Java\\jdk-1.8\\bin;C:\\Spark\\spark-3.5.0-bin-hadoop3/hadoop\\bin;C:\\Program Files\\JetBrains\\PyCharm Community Edition 2023.2.3\\bin;;C:\\Users\\LMIRANDA\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": true,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2025.5.152",
"path": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64",
"isActive": true
"version": "2024.9.14",
"path": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2025.4.22",
"path": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2025.4.22",
"isActive": true
"version": "2025.4.26",
"path": "c:\\Users\\LMIRANDA\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2025.4.26",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.26.3",
"ms-vscode.js-debug": "1.102.0",
"ctenbrinke.vscode-tsv": "0.2.2",
"dracula-theme.theme-dracula": "2.25.1",
"GitHub.remotehub": "0.64.0",
"ms-python.debugpy": "2025.10.0",
"ms-python.python": "2025.10.1",
"ms-python.vscode-pylance": "2025.6.2",
"ms-python.vscode-python-envs": "1.0.0",
"ms-toolsai.jupyter": "2025.6.0",
"ms-toolsai.jupyter-keymap": "1.1.2",
"ms-toolsai.jupyter-renderers": "1.3.0",
"ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
"ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
"ms-vscode-remote.remote-containers": "0.422.1",
"ms-vscode.azure-repos": "0.40.0",
"ms-vscode.cmake-tools": "1.21.36",
"ms-vscode.cpptools-extension-pack": "1.3.1",
"ms-vscode.remote-repositories": "0.42.0",
"Solorzano-JuanJose.git-clone-with-submodules": "1.5.6",
"trond-snekvik.gnu-mapfiles": "1.1.0"
Regards
Luiz
