Problem with switching off Wi-Fi interface on nrf7002-DK using SoftAP example
Hello everybody,
                         now, I am solving problem with switching off Wi-Fi interface on nrf7002-DK. I am runnig SoftAP example on my nrf7002-DK board. So my board behaves like AP. I wanna make function, that will be able to switch off (or close) Wi-Fi network running on my board. I wanna be able to re-open Wi-Fi network, but with another configuration (another parameters, like another CCID, PSWD etc.)
I trie to use net_if_down() function, but i get two errors.
[00:00:53.440,002] <inf> wifi_supplicant: Network interface 1 (0x20001268) down
[00:00:53.440,521] <inf> wpa_supp: wlan0: interface state ENABLED->DISABLED
[00:00:53.440,643] <err> wpa_supp: wpa_drv_zep_send_mlme: send_mlme op failed: -1
[00:00:53.440,765] <inf> wpa_supp: wlan0: AP-DISABLED
[00:00:53.441,375] <err> wpa_supp: wpa_drv_zep_deinit_ap: deinit_ap op failed: -1
[00:00:53.441,650] <inf> wpa_supp: wlan0: CTRL-EVENT-DISCONNECTED bssid=f4:ce:36:00:18:64 reason=3 locally_generated=1
What is correct procedure how to switch-off Wi-Fi? What is correct procedure how to re-open Wi-Fi?
Kind regards
Jaroslav Havel
  • Hi
    To get started with The nRF7002 DK and Wi-Fi development, I strongly recommend you begin with the DevAcademy Wi-Fi Fundamentals course that should take you through all the basics when working with a Nordic Wi-Fi device.
    Due to the summer holiday in Norway we're currently very short on staff, so delayed replies must be expected.
    Simon
  • Thank you Simon
    I have to explain what I want to do. My idea is close Wi-Fi network in idea of changing its parametrs. Now, i am trying to disable AP mode on nrf7002-DK via command. My code is:
    struct net_if *iface = net_if_get_default();
    struct wifi_iface_status status;
    ret = net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &status, sizeof(status));
         if (ret == 0)
           LOG_INF("Wi-Fi state: %d", status.state);
    ret = net_mgmt(NET_REQUEST_WIFI_AP_STA_DISCONNECT, iface, NULL, 0);
         if (ret)
           LOG_ERR("Disconnect selhal: %d", ret);
    ret = net_mgmt(NET_REQUEST_WIFI_AP_ENABLE, iface, NULL,0);
    	 if (ret)
    	   LOG_ERR("AP mode disabled failed: %s", strerror(-ret));
    	   LOG_INF("AP režim uspesnw vypnut \n");
                                                 I got these errors:
    [00:02:33.297,454] <err> softap: Disconnect selhal: -22
    [00:02:33.297,546] <err> wpa_supp: Interface wlan is not in disconnected state
    [00:02:33.297,637] <err> softap: AP mode disabled failed: Device or resource busy
    I thing that i have bad parametrs in net_mgmt() functions.
    Is procedure that I am trying to do correct?
    Kind regards
    Jaroslav Havel
  • Hi
    Here it seems like you're trying to disconnect a device that is already disconnected, as the -22 error you're seeing means an invalid argument was set in NET_REQUEST_WIFI_AP_STA_DISCONNECT() on your end.
    Simon
