Matter + BLE custom service
It is nRF54L15 + SDK 3.0 + Matter application.
I have developed a custom BLE service that is based on  Nordic's proprietary NUS BLE service.  The BLE custom service is enabled at start up, connects to a BLE App  for configuration and after that the App tells the product to join the matter network.
I have looked at the NUS services from door lock example.
1. When the button is pressed in DK, ButtonEventHandler in  sdk/nrf/samples/matter/common/src/board/board.cpp calls StartBLEAdvertisementHandler(action) (line 225).
2. StartLEAdvertisement calls  StartBLEAdvertisement()
Based on the above, in my application,
1. At startup,  Nrf::Matter::PrepareServer()) is called. The BLE service (is identical to NUS) is called. It uses the below to start the BLE service.
PlatformMgr().LockChipStack();
CHIP_ERROR ret = BLEAdvertisingArbiter::InsertRequest(mAdvertisingRequest);
PlatformMgr().UnlockChipStack();
2. The BLE app connects for configuration.
3. The BLE App asks Matter application to start the Matter server.   Nrf::Matter::StartServer() is called.
4. After completion, stop the BLE server
BLEAdvertisingArbiter::CancelRequest(mAdvertisingRequest);
5. Disconnect the BLE App. Then start  Nrf::Board::StartBLEAdvertisement();
The CHIP BLE service fails. see below error.
I: 11008675 [DIS]Updating services using commissioning mode 1
E: 11008681 [DIS]Failed to remove advertised services: 3
I: 11008687 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
E: 11008698 [DIS]Failed to advertise commissionable node: 3
E: 11008704 [DIS]Failed to finalize service update: 3
[2418774876] MTI BLE Advertising stopped
I: 11008714 [DL]Advertising start failed, will retry once connection is released
E: 11008722 [DL]Failed to start CHIPoBLE advertising: -12
I: 11008727 [DL]CHIPoBLE advertising already stopped
E: 11008733 [DL]Could not start CHIPoBLE service due to error: 200000c
Observation:
Although Step #4 stops the custom BLE service, the customer BLE service is restarted automatically and the advertisement begins. I tried to stop the custom adv after step 4 and before step #5 but  without any success.
However,  matter commissioning works, if  BLE App is not connected. For clarity,
1. Step #1 is the same as above - At startup,  Nrf::Matter::PrepareServer()) is called.
2. Then BLE custom service is initialized.  BLE custom service is advertised. App is not connected.
3. Start Matter server - Nrf::Matter::StartServer() is called.
4. Stop the BLE server.
5. Then start  Nrf::Board::StartBLEAdvertisement();
Please let me know.
Thanks
Subu
  • Hi Subu,
    In bt_nus_service.cpp for the NUSService::StopServer() function, there is a check that mIsStarted is false before calling the functions to stop the Bluetooth LE Service. Have you added a similar flag and check for your service?
    The log and your description of your implementation indicate that there are some states which are not implemented in your application.
    Good that you are using the Door lock application as a reference. Have you also looked at the guide for adding Bluetooth LE services to a Matter application? It uses the Door lock sample as an example for how to implement the steps the guide describe.
    Maria
