mpsl_init: MPSL ASSERT: 112, 2223 - NCS v2.5.2
I am trying to port the DTM example to our board, 52833 based but when DTM is initialised I get about 1400ms of CW then:
00> *** Booting nRF Connect SDK v2.5.2 ***
00> [00:00:00.170,837] <err> mpsl_init: MPSL ASSERT: 112, 2223
00> [00:00:00.170,837] <err> os: ***** HARD FAULT *****
00> [00:00:00.170,867] <err> os: Fault escalation (see below)
00> [00:00:00.170,867] <err> os: ARCH_EXCEPT with reason 3
00>
00> [00:00:00.170,898] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000000
00> [00:00:00.170,898] <err> os: r3/a4: 0x00000000 r12/ip: 0x200039f0 r14/lr: 0x00033f93
00> [00:00:00.170,928] <err> os: xpsr: 0x41000011
00> [00:00:00.170,928] <err> os: Faulting instruction address (r15/pc): 0x00033fa0
00> [00:00:00.170,959] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
00> [00:00:00.170,989] <err> os: Fault during interrupt handling
00>
00> [00:00:00.171,020] <err> os: Current thread: 0x200039f0 (unknown)
00> [00:00:00.680,297] <err> fatal_error: Resetting system
It's worth noting that the BLE stack is still compiled in, though in this example I'm not calling bt_enable(). That said I'm hoping I might be able to have it start in BLE until a characteristic write happens then stop BLE and switch to DTM.
Anyway hoping someone can shed some light on the ASSERT.
Thanks!
    The assert is raised because the RADIO interrupt was triggered outside of a timeslot allocated by the MPSL. The solution may be to request a long continuous timeslot after entering DTM mode.
    Vidar
  • Thanks very much Vidar.
    I'm guessing something is still configured during Zephyr startup even though I haven't actually started using the radio other than via the DTM code? It's just I don't see anything in the sample about timeslots.
    I'm not sure I understand what that means. I tried adding:
    static mpsl_timeslot_request_t timeslot_request_earliest = {
            .request_type = MPSL_TIMESLOT_REQ_TYPE_EARLIEST,
            .params.earliest.hfclk = MPSL_TIMESLOT_HFCLK_CFG_NO_GUARANTEE,
            .params.earliest.priority = MPSL_TIMESLOT_PRIORITY_NORMAL,
            .params.earliest.length_us = 100000,
            .params.earliest.timeout_us = 100000000
    static mpsl_timeslot_signal_return_param_t signal_callback_return_param = {
        .callback_action=MPSL_TIMESLOT_SIGNAL_ACTION_EXTEND,
        .params.extend.length_us=100000
    static mpsl_timeslot_signal_return_param_t *mpsl_timeslot_callback(
            mpsl_timeslot_session_id_t session_id,
            uint32_t signal_type)
        //LOG_INF("callback %d", signal_type);
        return &signal_callback_return_param;
        dtm_init(&dtm_iq_report_callback);
        int err = mpsl_timeslot_session_open(mpsl_timeslot_callback, &session_id);
        if (err) {
                LOG_ERR("Timeslot session open error: %d", err);
        err = mpsl_timeslot_request(session_id, &timeslot_request_earliest);
        if (err) {
                LOG_ERR("Timeslot request error: %d", err);
        dtm_test_transmit(5, 1, DTM_PACKET_VENDOR);
    But depending on the ordering - before or after dtm_test_transmit() - I either get the CPU on continuously (based on power) but no Tx or no difference (Tx for 1.5 sec with the same crash)
    Since you mentioned interrupts I also tried irq_disable(RADIO_IRQn) after both dtm_init() and dtm_test_transmit() but that made no difference either.
    Thanks!
  • Hi Vidar,
    Actually I made a mistake and put the 2nd irq_disable in the wrong place.
    This DOES work, and if I do this at the top of main() with a k_sleep() after it I get a solid CW and then it'll even continue on to starting BLE, which works for me since I can then use DFU to put the real firmware back after we're done.
    So maybe that'd be enough, but still it'd be better for me if I could use the BLE trigger since I'd like to use the char write to pick the frequency. That still doesn't work - I still get the same MPSL ASSERT. Note that in this case the char write handler is setting a flag that causes the main thread to do:
    bt_disable();
    irq_disable(RADIO_IRQn);
    k_sleep(K_MSEC(500));
    NVIC_ClearPendingIRQ(RADIO_IRQn);
    Any ideas? I thought maybe there's an interrupt pending so that the crash is happening as soon dtm_init() enables the interrupt, but haven't got much evidence to back that up.
    Thanks!
    Glad to hear you've made progress on this. We currently do not have any samples demonstrating how to combine DTM and BLE in a single firmware image.
    Please check if the return value from bt_disable() is zero and not a negative error code. As an alternative (a 'hack'), you could use one of the retention registers (GPREGRET – 1 byte each) to store the DTM configuration or mode you want to use, and then call sys_reboot() (equivalent to NVIC_SystemReset) so you can enter DTM on subsuequent boot before enabling the BLE stack.
