I have shifted from silicon labs for BLE project. In Si labs we have burn BLE bootloader and BLE application separately. Do i need to do the same here in nrf controller? If yes, which project i need to import for bootloader and BLE application.
Hi SHubham,
We have two SDKs - nRF5 SDK (which is the old one) and the nRF Connect SDK (which is the new SDK and recommended for new designs)
In the nRF5SDK the bootloader, the SofDevice and the BLE application are typically flashed separately.
In the nRF Connect SDK, this is based on the Zephyr RTOS so you don't need a separate SoftDevice, i.e. the BLE stack is built-in.
Also here, the Bootloader is based on MCUboot and it comes as part of the build system and you just need to enable it in the config file. So, when you enable MCUboot in your application (CONFIG_BOOTLOADER_MCUBOOT=y), MCUboot is automatically built as a child image, and the system handles the integration.
n other words, you are just doing one build, but internally , the mcuboot is build as a separate image, then your application is being built and then they are combined appropriately.
Please take a look at the following to get a clear undestanding:
https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples
-Priyanka
Thanks Priyanka
