I am running into a secure fault when I set the NVS_SECTOR_COUNT to >= 7,
not sure how to proceed.
it fails at nvs_mount(&fs)
#define MAX_RECORDS 400U
#define NVS_SECTOR_SIZE 4096U
#define NVS_SECTOR_COUNT 8U
#define NVS_TOTAL_SIZE NVS_SECTOR_SIZE*NVS_SECTOR_COUNT
/* NVS instance */
static struct nvs_fs fs;
/* Write and read pointers */
static size_t next_record_index = 1;
static size_t current_record_index = 0;
/* Temporary buffer for reads */
static record_t temp_record;
/* Mount NVS and recover next_record_index */
void record_buffer_init(void)
fs.flash_device = FIXED_PARTITION_DEVICE(storage);
fs.offset = FIXED_PARTITION_OFFSET(storage);
fs.sector_size = NVS_SECTOR_SIZE;
fs.sector_count = NVS_SECTOR_COUNT;
int rc = nvs_mount(&fs);
if (rc) {
LOG_ERR("NVS mount failed: %d", rc);
return;
LOG_INF("NVS mounted at offset 0x%x, size %u bytes",fs.offset, fs.sector_size * fs.sector_count);
LOG_INF("Max allowable record = %d", (NVS_TOTAL_SIZE/sizeof(record_t))-1);
if (sizeof(record_t)*MAX_RECORDS > NVS_TOTAL_SIZE)
LOG_ERR("Max record %d > allowable record %d", MAX_RECORDS, (NVS_TOTAL_SIZE/sizeof(record_t) - 1));
/* Recover next_record_index */
size_t highest = 0;
record_t dummy;
for (size_t key = 1; key <= MAX_RECORDS; key++) {
rc = nvs_read(&fs, key, &dummy, sizeof(dummy));
if (rc > 0) {
highest = key;
if (highest == 0) {
} else {
next_record_index = (highest % MAX_RECORDS) + 1;
LOG_INF("Recovered next_record_index: %u", next_record_index);
I have added a nvs_storage partitation in pm_static.yml
# Reserve for NVS storage
nvs_storage:
address: 0xE8000
size: 0x18000 # Last 96 KB of
memory map shows no overlap
