ABOUT ZIGBEE OF NRF54L15
Hi Nordic:
    We are currently testing Zigbee on the nRF54L15 platform using the Zigbee R23-add-on-V1.0.0 SDK. It has been observed that when a low-power node disconnects from the gateway, it cannot enter low-power mode until it successfully rejoins the network. Are there any solutions to address this issue?
Regard Best
Jermi
  • Yes, only a few modifications were made to the light switch example.If possible, could you help test the power consumption using the official development board?3487.light_switch.zip
  • This is what I see using the unmodified light_switch sample:
    The chunk in the middle is when I removed the coordinator, and when I powered it back on, it went down to normal current consumption (which is a bit high in this case, but logging was turned on, keeping the HFCLK running at all times).
    I will test your application tomorrow (I spent a bit too long getting the Zigbee addon up and running, so didn't have time for it today)
    Edvin
  • Your application also goes down after it rejoins the network:
    You can see that I disconnected the coordinator in the middle, but then turned it back on. In the marked section (the greyed out) you can see that it goes back into low power mode, with an average of 392µA (I turned on UART logging, so it will be lower if this is disabled).
    What are you using to measure the current consumption? And what does it look like before you disconnect it from the network? What is the current consumption then?
    Edvin
  • We use Otii to measure the device’s power consumption.
    Before disconnect, the device can enter low-power mode, consuming around 3-4uA. However, if the rejoin fails or the gateway is never powered on, the device will never enter low-power mode (I tested for about 30 minutes), and it will continuously consume 3.8mA.
  • If it is not called already, you should call stop_network_rejoin() after a given amount of time. That amount of time is something you decide in your application.
    I thought this would be called automatically, after CONFIG_ZIGBEE_DEV_REJOIN_TIMEOUT_MS (default 200 seconds).
    If start_network_rejoin() is called, then it will start this timer. This iystem is a bit confusing, since it tries to send a beacon every 2^n seconds. So first after 1 second, 2 seconds, 4 seconds, 8 seconds, etc. and all of these will restart the timer.
    But when this reaches 200 seconds, you will see in the log:
    "TC Rejoin was not successful (status: -1)". You will see that line being printed in ncs-zigbee\subsys\lib\zigbee_app_utils\zigbee_app_utils.c, in the zigbee_default_signal_handler(), in the ZB_BDB_SIGNAL_TC_REJOIN_DONE event.
    You can use this event to enter system off mode, if that is what you prefer. In this mode, it can be woken up by a button press.
    You can use sys_poweroff() to enter system off mode, and you need to include:
    #include <zephyr/sys/poweroff.h>
    And CONFIG_POWEROFF=y
    Edvin
