ABOUT ZIGBEE OF NRF54L15
Hi Nordic:
    We are currently testing Zigbee on the nRF54L15 platform using the Zigbee R23-add-on-V1.0.0 SDK. It has been observed that when a low-power node disconnects from the gateway, it cannot enter low-power mode until it successfully rejoins the network. Are there any solutions to address this issue?
Regard Best
Jermi
  • Thank you very much—system off mode does indeed solve my problem. At the same time, could you please provide sample code that wakes up periodically from system off mode?
  • You can use the GRTC to wake up from system off, then keep trying for a while, then go back to system off. Please note that this is only possible on the nRF54L series, not the nRF52 series or the nRF53. When using these, you need to use system on (a lighter sleep).
    But since you are using the nRF54L platform, you can enter System off, and use a timer to wake up. For this check out the NCS\zephyr\samples\boards\nordic\system_off sample, and add
    CONFIG_GRTC_WAKEUP_ENABLE=y
    to that application's prj.conf. Then you should see it waking up every 2 seconds.
    What it does is enabling this snippet in main.c:
    #if defined(CONFIG_GRTC_WAKEUP_ENABLE)
    	int err = z_nrf_grtc_wakeup_prepare(DEEP_SLEEP_TIME_S * USEC_PER_SEC);
    	if (err < 0) {
    		printk("Unable to prepare GRTC as a wake up source (err = %d).\n", err);
    	} else {
    		printk("Entering system off; wait %u seconds to restart\n", DEEP_SLEEP_TIME_S);
    So in your application, include this file:
    #include <zephyr/drivers/timer/nrf_grtc_timer.h>
    and use z_nrf_grtc_wakeup_prepare() to set the amount of time you want it to be in system_off.
    Edvin
  • 1、The compilation fails with the error "CONFIG_GRTC_WAKEUP_ENABLE is not defined."
    2、If I use the code below directly, it still won't wake up.
    	LOG_INF("Starting system...");
    // #if defined(CONFIG_GRTC_WAKEUP_ENABLE)
    #if 1
    	int err = z_nrf_grtc_wakeup_prepare(10 * USEC_PER_SEC);
    	if (err < 0) {
    	} else {
    		printk("Entering system off; wait %u seconds to restart\n", 10);
    	k_msleep(5000);
    	sys_poweroff();
  • Sorry that I didn't specify. CONFIG_GRTC_WAKEUP_ENABLE is specific for the sample NCS\zephyr\samples\boards\nordic\system_off.
    You can test that sample and see if it wakes up. Add this in your main file to keep track of the uptime:
    printk("Uptime: %d\n", k_uptime_get_32());
    Does it build? What does it print? "Entering system off..." or "Unable to prepare GRTC..."?
    BR,
    Edvin
  • This is the log. It is not waking up every 10 second as expected; instead, it keeps restarting continually.
    This is my test project code.
    3124.system_off.zip
