COMMUNICATE WİTH TWO NRF52820 USING ESB DOESN'T WORK
Hello, I have 2 PCBs for drone communication using nRF52820 and nRF21540 FEM module. I'm using the ESB protocol to communicate via radio. There are ready-made esb_prx and esb_ptx codes provided by nRF Connect. Additionally, my PCB has an external 32MHz clock. I'm providing all my code below: DTS, prjconfig, main. Currently, I cannot establish communication.What is the problem?
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/drivers/clock_control.h>
#include <zephyr/drivers/clock_control/nrf_clock_control.h>
#if defined(NRF54L15_XXAA)
#include <hal/nrf_clock.h>
#endif /* defined(NRF54L15_XXAA) */
#include <zephyr/irq.h>
#include <nrf.h>
#include <esb.h>
#include <zephyr/device.h>
#include <zephyr/kernel.h>
#include <zephyr/types.h>
#include <dk_buttons_and_leds.h>
#if defined(CONFIG_CLOCK_CONTROL_NRF2)
#include <hal/nrf_lrcconf.h>
LOG_MODULE_REGISTER(esb_ptx, CONFIG_ESB_PTX_APP_LOG_LEVEL);
static bool ready = true;
static struct esb_payload rx_payload;
static struct esb_payload tx_payload = ESB_CREATE_PAYLOAD(0,
	0x01, 0x00, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08);
#define _RADIO_SHORTS_COMMON                                                   \
	(RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_DISABLE_Msk |         \
	 RADIO_SHORTS_ADDRESS_RSSISTART_Msk |                                  \
	 RADIO_SHORTS_DISABLED_RSSISTOP_Msk)
void event_handler(struct esb_evt const *event)
	ready = true;
	switch (event->evt_id) {
	case ESB_EVENT_TX_SUCCESS:
		LOG_DBG("TX SUCCESS EVENT");
	case ESB_EVENT_TX_FAILED:
		LOG_DBG("TX FAILED EVENT");
	case ESB_EVENT_RX_RECEIVED:
		while (esb_read_rx_payload(&rx_payload) == 0) {
			LOG_DBG("Packet received, len %d : "
				"0x%02x, 0x%02x, 0x%02x, 0x%02x, "
				"0x%02x, 0x%02x, 0x%02x, 0x%02x",
				rx_payload.length, rx_payload.data[0],
				rx_payload.data[1], rx_payload.data[2],
				rx_payload.data[3], rx_payload.data[4],
				rx_payload.data[5], rx_payload.data[6],
				rx_payload.data[7]);
#if defined(CONFIG_CLOCK_CONTROL_NRF)
int clocks_start(void)
	int err;
	int res;
	struct onoff_manager *clk_mgr;
	struct onoff_client clk_cli;
	clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
	if (!clk_mgr) {
		LOG_ERR("Unable to get the Clock manager");
		return -ENXIO;
	sys_notify_init_spinwait(&clk_cli.notify);
	err = onoff_request(clk_mgr, &clk_cli);
	if (err < 0) {
		LOG_ERR("Clock request failed: %d", err);
		return err;
	do {
		err = sys_notify_fetch_result(&clk_cli.notify, &res);
		if (!err && res) {
			LOG_ERR("Clock could not be started: %d", res);
			return res;
	} while (err);
	/* MLTPAN-20 */
	nrf_clock_task_trigger(NRF_CLOCK, NRF_CLOCK_TASK_PLLSTART);
	LOG_DBG("HF clock started");
	return 0;
#elif defined(CONFIG_CLOCK_CONTROL_NRF2)
	int err;
	int res;
	const struct device *radio_clk_dev =
		DEVICE_DT_GET_OR_NULL(DT_CLOCKS_CTLR(DT_NODELABEL(radio)));
	struct onoff_client radio_cli;
	/** Keep radio domain powered all the time to reduce latency. */
	nrf_lrcconf_poweron_force_set(NRF_LRCCONF010, NRF_LRCCONF_POWER_DOMAIN_1, true);
	sys_notify_init_spinwait(&radio_cli.notify);
	err = nrf_clock_control_request(radio_clk_dev, NULL, &radio_cli);
	do {
		err = sys_notify_fetch_result(&radio_cli.notify, &res);
		if (!err && res) {
			return res;
	} while (err == -EAGAIN);
	nrf_lrcconf_clock_always_run_force_set(NRF_LRCCONF000, 0, true);
	nrf_lrcconf_task_trigger(NRF_LRCCONF000, NRF_LRCCONF_TASK_CLKSTART_0);
	return 0;
#else
BUILD_ASSERT(false, "No Clock Control driver");
#endif /* defined(CONFIG_CLOCK_CONTROL_NRF2) */
int esb_initialize(void)
	int err;
	/* These are arbitrary default addresses. In end user products
	 * different addresses should be used for each set of devices.
	uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
	uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
	uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8};
	struct esb_config config = ESB_DEFAULT_CONFIG;
	config.protocol = ESB_PROTOCOL_ESB_DPL;
	config.retransmit_delay = 600;
	config.bitrate = ESB_BITRATE_2MBPS;
	config.event_handler = event_handler;
	config.mode = ESB_MODE_PTX;
	config.selective_auto_ack = true;
	if (IS_ENABLED(CONFIG_ESB_FAST_SWITCHING)) {
		config.use_fast_ramp_up = true;
	err = esb_init(&config);
	if (err) {
		return err;
	err = esb_set_base_address_0(base_addr_0);
	if (err) {
		return err;
	err = esb_set_base_address_1(base_addr_1);
	if (err) {
		return err;
	err = esb_set_prefixes(addr_prefix, ARRAY_SIZE(addr_prefix));
	if (err) {
		return err;
	return 0;
static void leds_update(uint8_t value)
	uint32_t leds_mask =
		(!(value % 8 > 0 && value % 8 <= 4) ? DK_LED1_MSK : 0) |
		(!(value % 8 > 1 && value % 8 <= 5) ? DK_LED2_MSK : 0) |
		(!(value % 8 > 2 && value % 8 <= 6) ? DK_LED3_MSK : 0) |
		(!(value % 8 > 3) ? DK_LED4_MSK : 0);
	dk_set_leds(leds_mask);
	int err;
	LOG_INF("Enhanced ShockBurst ptx sample");
	err = clocks_start();
	if (err) {
		return 0;
	err = dk_leds_init();
	if (err) {
		LOG_ERR("LEDs initialization failed, err %d", err);
		return 0;
	err = esb_initialize();
	if (err) {
		LOG_ERR("ESB initialization failed, err %d", err);
		return 0;
	LOG_INF("Initialization complete");
	LOG_INF("Sending test packet");
	tx_payload.noack = false;
	while (1) {
		if (ready) {
			ready = false;
			esb_flush_tx();
			leds_update(tx_payload.data[1]);
			err = esb_write_payload(&tx_payload);
			if (err) {
				LOG_ERR("Payload write failed, err %d", err);
			tx_payload.data[1]++;
		k_sleep(K_MSEC(100));
#include <nrf.h>
#include <esb.h>
LOG_MODULE_REGISTER(esb_prx, CONFIG_ESB_PRX_APP_LOG_LEVEL);
	0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17);
		if (esb_read_rx_payload(&rx_payload) == 0) {
			leds_update(rx_payload.data[1]);
		} else {
			LOG_ERR("Error while reading rx packet");
	int err;
	int res;
	if (!clk_mgr) {
		return -ENXIO;
	if (err < 0) {
		return err;
	do {
		if (!err && res) {
			return res;
	} while (err);
	/* MLTPAN-20 */
	return 0;
	int err;
	int res;
	do {
		if (!err && res) {
			return res;
	return 0;
#else
	int err;
	config.mode = ESB_MODE_PRX;
	if (err) {
		return err;
	if (err) {
		return err;
	if (err) {
		return err;
	if (err) {
		return err;
	return 0;
	int err;
	LOG_INF("Enhanced ShockBurst prx sample");
	if (err) {
		return 0;
	if (err) {
		return 0;
	if (err) {
		return 0;
	if (err) {
		LOG_ERR("Write payload, err %d", err);
		return 0;
	LOG_INF("Setting up for packet receiption");
	err = esb_start_rx();
	if (err) {
		LOG_ERR("RX setup failed, err %d", err);
		return 0;
	/* return to idle thread */
	return 0;
/dts-v1/;
#include <nordic/nrf52820_qdaa.dtsi>
#include "TST-pinctrl.dtsi"
	model = "testing";
	compatible = "BY,TST";
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,console = &cdc_acm_uart0;
		zephyr,shell-uart = &cdc_acm_uart0;
		zephyr,uart-mcumgr = &cdc_acm_uart0;
	nrf_radio_fem: nrf21540_fem {
		compatible = "nordic,nrf21540-fem";
		tx-en-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
		rx-en-gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
		pdn-gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
		mode-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
		spi-if = <&nrf_radio_fem_spi>;
		supply-voltage-mv = <3300>;
		tx-en-settle-time-us = <13>;
		rx-en-settle-time-us = <13>;
		pdn-settle-time-us = <18>;
		trx-hold-time-us = <5>;
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
			label = "Green LED 0";
		led1: led_1 {
			gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
			label = "Green LED 1";
	aliases {
		led0 = &led0;
		led1 = &led1;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 DT_SIZE_K(48)>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000c000 DT_SIZE_K(92)>;
		slot1_partition: partition@23000 {
			label = "image-1";
			reg = <0x00023000 DT_SIZE_K(92)>;
		storage_partition: partition@3a000 {
			label = "storage";
			reg = <0x0003a000 DT_SIZE_K(24)>;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&clock {
	status = "okay";
zephyr_udc0: &usbd {
	compatible = "nordic,nrf-usbd";
	status = "okay";
&usbd {
	cdc_acm_uart0: cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
		label = "CDC_ACM_0";
&spi1 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	cs-gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
	nrf_radio_fem_spi: nrf21540_fem_spi@0 {
		compatible = "nordic,nrf21540-fem-spi";
		status = "okay";
		reg = <0>;
		spi-max-frequency = <8000000>;
		spi-cpol;
		spi-cpha;
&radio {
	fem = <&nrf_radio_fem>;
	status = "okay";
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_ESB=y
CONFIG_DK_LIBRARY=y
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_DEFAULT_LEVEL=2
