Max output power in BLE direct test mode
we are using the direct test mode example of NCS with an nRF5340.
Now we got a question from the testlab, about the transmit power parameter.
The setting in the GUI is in dBm and goes up to 8 dBm, but the nRF5340 has 3 dBm max. TX power.
Now, just to cross-check, my question is what is the correct setting to achieve the max. TX power? Everything larger or equal 3 dBm or something else?
Many thanks for your answers in advance.
Christian
    Max TX power is +3dBm so set the UI to +3 dBm, adjusting the slider higher should still leave the TX power at largest possible value, but I have not tested this so can not confirm.
    What you can do is read the TXPOWER register to see what value it has.
    Jonathan
    sorry for the stupid question, but how to access the TXPOWER and VREQCTRL correctly from the application or network core of the nRF5340?
    Many thanks and kind regards,
    Christian
    I can confirm that higher TXPOWER values than +3 dBm in the GUI are simply ignored (the old setting persists).
    To get the highest output power with the nRF5340, + 3dBm must be selected, which results in:
    TXPOWER = 0x0 and
    VREQCTRL = 0x1.
    Just to explain:
    VREQCTRL = 0x1 enables +3 dBm output
    TXPOWER is typically interpreted as negative value.
    So, e.g. -2 dBm can be achieved with
    VREQCTRL = 0x1 (3 dBm)
    and
    TXPOWER = 0xFF (-1)
    Christian
     PS: Unfortunately, the ignoring of unsupported high power values is not reflected in the GUI. The GUI shows a bar with 8 dBm for the nRF5340 if the slider is set to 8 dBm. A error message would be highly appreciated here.
  • You can use the following nrfutil command:
    nrfutil device x-read --address <address> --direct --core Network
    Base address network RADIO
    0x41008000
    TXPOWER
    0x50C
    Base address network VREQCTRL
    0x41004000
    VREGRADIO.VREQH
    0x500
    VREGRADIO.VREQHREADY
    0x508
    So example:
    C:\>nrfutil device x-read --address 0x4100850C --direct --core Network
    1050053641
    0x4100850C: 00000000
    So did test and if you set the TX power to more then 3 dBm in the DTM app then it actually sets the power to -8dBm. So dont do that.
    Jonathan
