I often see the following warning when requesting a GNSS location: "<wrn> location: PSM is configured, but modem did not enter PSM in 2 minutes. Starting GNSS anyway." - what is this warning? Is this a setup issue or expected behavior?
  • be nice to have 'edit' feature to fix title for the ticket creator as I've had some challenges submitting tickets in DevZone
    Please make another separate ticket, explain your challenges when submitting tickets and elaborate on your feature request.
    Does this happen using the same application and on the same network? What are network conditions?
    You can read about PSM usage in the documentation.
    Dejan
    Dejan
  • same application, same network (Conexa SIM roaming on AT&T network). Cell info:
    LTE params: mcc: 310, mnc: 410, band: 12, snr: 16, rsrp: 37, rsrq: 3
    Can you provide more information about your application? Is it based on any of existing samples?
    Can you show your PSM configuration?
    How often do you see this warning?
    Dejan
  • I see the warning almost every time I request GNSS position.
    It is based on 'Cellular IoT Fundamentals', Lesson 6 - Exercise 2, thought there are some modifications related to my application.
    CONFIG_LTE_LC_EDRX_MODULE=y
    CONFIG_LTE_LC_PSM_MODULE=y
    CONFIG_LTE_PSM_REQ=y
    CONFIG_LTE_EDRX_REQ=y
    # Request PSM active time of 8 seconds.
    CONFIG_LTE_PSM_REQ_RAT="00000100"
    Can you show your complete application log?
    Dejan
  • NOTE 1: The location timeout is as expected since I am collecting this log while inside a building.
    NOTE 2: see time [00:02:23.381,591]
    [00:00:00.669,464] <inf> PWLS: Connecting to LTE network
    [00:00:00.669,525] <inf> PWLS: Register GPS callback function
    [00:00:00.669,525] <inf> PWLS: GpsInit()
    %XMODEMSLEEP: 4
    %XMODEMSLEEP: 4,0
    +CEREG: 2,"6A25","08111911",7
    [00:00:02.913,452] <inf> PWLS: NOT CONNECTED
    +CSCON: 1
    [00:00:06.818,023] <inf> PWLS: RRC mode: Connected
    +CEREG: 5,"6A25","08111911",7,,,"00100011","11100000"
    [00:00:08.607,330] <inf> PWLS: Network registration status: Connected - roaming
    [00:00:08.607,421] <inf> PWLS: LTE CONNECTED...
    [00:00:08.607,452] <inf> PWLS: COMMS - while(1)
    +CEDRXP: 4,"1001","1001","0001"
    [00:00:08.707,336] <inf> PWLS: LTE_LC_EVT_EDRX_UPDATE: 7
    %XTIME: "0A","5280502123100A","01"
    [00:00:08.807,800] <inf> PWLS: CommsDateTimeEvtHandler()
    [00:00:08.807,830] <inf> PWLS: Local time: 1754397121000
    [00:00:08.808,227] <inf> PWLS: LTE_LC_EVT_PSM_UPDATE: tau: 1800, active_time: 180
    +CSCON: 0
    [00:00:11.083,099] <inf> PWLS: RRC mode: Idle
    %XMODEMSLEEP: 2,143312
    [00:00:21.367,889] <inf> PWLS: IOButtonPressedISR(): ioPins: 0x00040000, Value: 0x0C080300, AND: 0x00000000
    [00:00:21.367,919] <inf> PWLS: TimerStart(), 0x00040000
    [00:00:21.367,950] <inf> PWLS: TEST_BUTTON
    [00:00:23.367,980] <inf> PWLS: ISR: Test Button Timer Expired
    [00:00:23.368,041] <inf> PWLS: EVENT: 18
    [00:00:23.368,072] <inf> PWLS: GpsLocationGet()
    [00:00:23.377,319] <inf> PWLS: Requesting GNSS location, 4 min timeout
    [00:00:24.994,995] <inf> PWLS: IOButtonPressedISR(): ioPins: 0x00040000, Value: 0x0C0C0300, AND: 0x00040000
    [00:00:24.995,025] <inf> PWLS: TimerStop(), 0x00040000
    [00:00:24.995,025] <inf> PWLS: TEST_BUTTON
    [00:02:23.381,591] <wrn> location: PSM is configured, but modem did not enter PSM in 2 minutes. Starting GNSS anyway.
    %XMODEMSLEEP: 5,0
    %XMODEMSLEEP: 2,0
    [00:05:00.402,984] <inf> PWLS: uptime: 300
    [00:05:23.377,563] <inf> location: Timeout for entire location request expired
    [00:05:23.377,593] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
    [00:05:23.378,021] <inf> PWLS: location_event_handler()
    [00:05:23.378,021] <inf> PWLS: Getting location timed out
    %XMODEMSLEEP: 1,1487600
    [00:05:23.497,467] <inf> PWLS: LTE params: err: 0, mcc: 310, mnc: 410, band: 12, snr: 28, rsrp: 48, rsrq: 20
    [00:05:23.497,528] <inf> PWLS: Network Status: Connected - ROAMING
    [00:05:23.497,528] <inf> PWLS: ServerResolve()
    %XMODEMSLEEP: 1,0
    +CSCON: 1
    [00:05:23.882,720] <inf> PWLS: RRC mode: Connected
    [00:05:24.714,050] <inf> PWLS: IPv4 Address found 20.82.16.164
    [00:05:24.714,080] <inf> PWLS: ServerConnect()
    [00:05:24.714,721] <inf> PWLS: ServerConnect() - Successfully connected to s_server
    [00:05:24.714,752] <inf> PWLS: dateTime: 1754397436906
    [00:05:24.714,782] <inf> PWLS: Length: 52
    Message: [00:05:24.715,667] <inf> PWLS: CommsMsgSend(): msg: 00.01.00.01.0A.54.45.53.54.20.31.32.33.34.35.02.01.12.03.08.EA.6B.3C.7A.98.01.00.00.04.01.32.05.06.36.01.9A.01.30.00.06.01.28., len: 126
    [00:05:24.716,247] <inf> PWLS: token: 0x0000C079
    [00:05:24.716,278] <inf> PWLS: CoAP packet: 0x62 0x03 0x9C 0xBE 0x79 0xC0 0x01 0x20
    [00:05:24.716,339] <inf> PWLS: Request: hrd: 6 max:200 off: 9 Olen: 2 delta: 12 data: by
    [00:05:24.716,400] <inf> PWLS: View CoAP Packet
    [00:05:24.716,400] <inf> PWLS: CoAP PUT request sent: Token 0xC079
    [00:05:24.717,254] <inf> PWLS: Successfully sent message
    [00:05:24.717,254] <inf> PWLS: CommsMsgReceive()
    [00:05:25.175,201] <inf> PWLS: Data received from the s_server: len: 161, msg: (Time: 2025-08-05 12:37:18 Message: 00.01.00.01.0A.54.45.53.54.20.31.32.33.34.35.02.01.12.03.08.EA.6B.3C.7A.98.01.00.00.04.01.32.05.06.36.01.9A.01.30.00.06.01.28.)
    [00:05:25.175,262] <inf> PWLS: COMMS - while(1)
    +CSCON: 0
    [00:05:28.614,868] <inf> PWLS: RRC mode: Idle
    %XMODEMSLEEP: 2,153452
