Difficulties with agnss in nrf cloud library - nrf_cloud_agnss: Cannot parse schema version: 72
I've been trying to use the NRF Cloud A-GNSS capabilities using the location library. However, after carefully checking the documentation, I am still unable to do it.
Calling this function:
static void get_and_process_agnss_nrf_cloud_data(void)
    int err;
	char response[4096];
	struct nrf_cloud_rest_context rest_context;
	char agnss_buf[4096]; // Buffer for A-GNSS data
    rest_context = (struct nrf_cloud_rest_context){
		.connect_socket = -1, // Use default socket
		.auth = NULL, // Must be NULL!
		.response = response,
		.response_len = sizeof(response),
		.total_response_len = sizeof(response),
		.rx_buf = agnss_buf,
		.rx_buf_len = sizeof(agnss_buf),
		.fragment_size = 0, // Use default fragment size
		.timeout_ms = 10000, // Set a timeout for the request
		.nrf_err = NRF_CLOUD_ERROR_NONE,
	struct nrf_cloud_rest_agnss_request request = {
		.type = NRF_CLOUD_REST_AGNSS_REQ_ASSISTANCE,
		.agnss_req = NULL, // Not used for this request type
		.net_info = NULL, // Not used for this request type
		.filtered = false, // Not filtering the data
		.mask_angle = NRF_CLOUD_AGNSS_MASK_ANGLE_NONE, // No angle
	struct nrf_cloud_rest_agnss_result result = {
		.buf = agnss_buf,
		.buf_sz = sizeof(agnss_buf),
		.agnss_sz = 0, // Will be set by the function
    printk("Requesting A-GNSS data from nRF Cloud...\n");
    err = nrf_cloud_rest_agnss_data_get(&rest_context, &request, &result);
    if (err > 0) {
        printk("Buffer too small: %d bytes needed\n", err);
        return;
    } else if (err < 0) {
        printk("Failed to get A-GNSS data: %d\n", err);
        return;
    printk("A-GNSS data received (%zu bytes), processing...\n", result.agnss_sz);
    err = nrf_cloud_agnss_process(result.buf, result.agnss_sz);
    if (err) {
        printk("Failed to process A-GNSS data: %d\n", err);
    } else {
        printk("A-GNSS data processed successfully\n");
Results in
A-GNSS data received (3179 bytes), processing...
[00:00:18.806,030] <err> nrf_cloud_agnss: Cannot parse schema version: 72
Failed to process A-GNSS data: -77
Which I just can't comprehend - where am I making a mistake? Or is that a bug in nrf cloud?
Full log:
*** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
*** Using Zephyr OS v4.0.99-f791c49f492c ***
Location sample started
Connecting to LTE...
Waiting for LTE connection
PSM enabled
+CEREG: 2,"04CF","01C9D101",7
LTE event received: 0
Network registration status: 2
LTE event received: 4
LTE event received: 5
+CSCON: 1
LTE event received: 3
+CEREG: 5,"04CF","01C9D101",7,,,"11100000","11100000"
Network registration status: 5
Connected to LTE
Connected to LTE
LTE connected
Waiting for current time
LTE event received: 1
%XTIME: "80","52801091335480","01"
Current time updated
Location library initialized, error: 0
[00:00:13.803,222] <inf> nrf_cloud_info: Device ID: nrf-359404230094402
[00:00:13.810,852] <inf> nrf_cloud_info: IMEI:      359404230094402
%XTIME: ,"52801091335480","01"
[00:00:13.940,826] <inf> nrf_cloud_info: UUID:      50343956-3037-4b5e-8071-240adfc896e8
[00:00:13.949,829] <inf> nrf_cloud_info: Modem FW:  mfw_nrf91x1_2.0.2
[00:00:13.956,634] <inf> nrf_cloud_info: Protocol:          REST
[00:00:13.963,043] <inf> nrf_cloud_info: Download protocol: HTTPS
[00:00:13.969,512] <inf> nrf_cloud_info: Sec tag:           16842753
[00:00:13.976,287] <inf> nrf_cloud_info: Host name:         api.nrfcloud.com
Requesting low accuracy GNSS location...
%NCELLMEAS: 0,"01C9D101","23002","04CF",104,6300,111,38,24,17478,6300,257,26,2,0,17411
LTE event received: 7
I am also providing a link to the repository with the full code - it is a modified Location nordic sample. I am using SDK 3.0.2
github.com/.../location
    It seems that the buffers in rest_context are set incorrectly.
    response, response_len and total_response_len should not be initialized by the caller. Instead, they must be initialized with zeros. Values are set using nrf_cloud_rest_agnss_data_get() call. In addition, the same buffer must not be used  for rest_context.rx_buf and result.buf.
    rest_context.rx_buf should be set to response and rest_context.rx_buf_len to sizeof(response).
    Dejan
