We are working with Nordic’s official peripheral_esl (https://github.com/NordicPlayground/nrf-esl-bluetooth/tree/main/samples/peripheral_esl)sample application for Electronic Shelf Labels (ESL), using the nRF5340DK with SDK and Toolchain version 3.0.2. Our setup targets the application core (nonsecure), and our goal is to integrate a UC8151D-based 296×128 E-Paper display connected to SPI2. The intent is for the ESL peripheral to receive image updates via Bluetooth PAwR from the central and display them on the e-paper screen.
Attempt 1: Using ssd16xx.c with mipi_dbi_spi.c (solomon,ssd1680 binding)
Integrated the display using the
solomon,ssd1680compatible via Zephyr’sssd16xx.candmipi_dbi_spi.cdrivers. -
Used SPI2 in full-duplex 8-bit mode.
All SPI buffers were aligned using
__aligned(4)and placed in.noinitto ensure DMA-safe memory access. -
Applied
sys_cache_data_flush_range()before all chunked SPI writes. -
Manually controlled chip select (CS) using
gpio_pin_set_dt()instead of assigning.csinsidespi_config. -
All required GPIOs (
busy,dc,reset,cs) were validated and configured properly.
The secure fault was resolved by avoiding the .cs field in spi_config and managing CS through GPIO directly.
Issue: Despite successful command-only transfers, spi_write() consistently hangs when the command includes a nonzero data length (len > 0). For example:
ssd16xx_write_cmd(dev, 0x32, data, 30)hangs after sending the command. -
ssd16xx_write_cmd(dev, 0x01, data, 3)hangs. -
ssd16xx_write_cmd(dev, 0x12, NULL, 0)works as expected.
This occurs even with correct buffer alignment, SPI configuration, and GPIO toggling. The driver initialization progresses until the point where command+data SPI transfers begin.
Attempt 2: Migrated to uc81xx.c driver with ultrachip,uc8151 binding
To isolate the problem from the mipi_dbi infrastructure, we migrated to Zephyr’s native uc81xx.c driver and the ultrachip,uc8151 compatible:
The device is defined using
DEVICE_DT_DEFINE()with correct.quirks,.profiles, and SPI configuration. -
Used
SPI_CS_GPIOS_DT_SPEC_GET(...)for defining CS and assigned.csinsidespi_cfg. -
All GPIOs (
dc,reset,busy,cs) are configured and ready. -
The display is connected via SPI2, and the SPI configuration is consistent with the datasheet for UC8151D.
New Issue: After shifting to uc81xx.c, we encountered a secure fault during the first spi_write() call (command-only, len = 1):
This occurs even before reaching any data transfer, during the initial command send sequence in uc81xx_write_cmd().
TrustZone Configuration (SPIM2):
All required TrustZone and partition configuration steps have been applied:
CONFIG_TFM_NS_DEVICE_SPIM2=yis set intfm.conf. -
CONFIG_TFM_PERIPHERALS_DEFAULT_NS_ACCESS_LIST="SPIM2"is set insysbuild.conf. -
The
spi2node is markedsecure = <0>in the devicetree overlay. -
Full
west build --pristine --sysbuildwas performed, and both cores were flashed.
Despite this, the secure fault persists when using spi_cfg.cs, unlike in the previous setup where CS was managed manually via GPIO and .cs was left null.
We are seeking input on:
Correct and complete setup for allowing nonsecure access to SPIM2 with
.csused insidespi_config. -
Whether CS GPIO control must always be done manually (i.e., not using
.cs) to avoid secure faults on nRF5340. -
Known issues or workarounds for using
spi_write()from the nonsecure application core in combination with DMA and Zephyr SPI driver on this SoC. -
Any confirmed integration examples of UC8151D or SSD1680-based e-paper displays with Zephyr on nRF5340 (especially inside
peripheral_esl).
We appreciate any insights or recommendations from the community and Nordic support regarding this issue.
Thankyou
[00:00:00.572,387] <err> os: ***** SECURE FAULT ***** [00:00:00.572,631] <err> os: Address: 0x0 [00:00:00.572,814] <err> os: Attribution unit violation [00:00:00.573,028] <err> os: r0/a1: 0x0002451c r1/a2: 0x00000001 r2/a3: 0x00000001 [00:00:00.573,364] <err> os: r3/a4: 0x00000000 r12/ip: 0xffffffff r14/lr: 0x000213e9 [00:00:00.573,699] <err> os: xpsr: 0x01000000 [00:00:00.573,913] <err> os: Faulting instruction address (r15/pc): 0x000213ba [00:00:00.574,188] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0 [00:00:00.574,493] <err> os: Current thread: 0x20012d78 (main) [00:00:00.574,737] <err> os: Halting system
