Multi reflector channel sounding
I am trying to do trilateration using one initiator and 3 reflectors. For now I am just trying to get 2 reflectors to work.
Sadly I cannot get the initiator to work like I want it to.
The reflector is running zephyr/samples/bluetooth/channel_sounding/cs_test/reflector, but the advertised names are "channel reflector 1" and "channel reflector 2"
The initiator was modified from zephyr/samples/bluetooth/channel_sounding/cs_test/initiator to use those 2 reflectors.
How can I get this to work?
 * Copyright (c) 2024 Nordic Semiconductor ASA
#include <math.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/cs.h>
#include <zephyr/bluetooth/att.h>
#include <zephyr/bluetooth/gatt.h>
#include "distance_estimation.h"
#include "common.h"
#include "cs_test_params.h"
static K_SEM_DEFINE(sem_results_available, 0, 1);
static K_SEM_DEFINE(sem_test_complete,     0, 1);
static K_SEM_DEFINE(sem_connected,         0, 1);
static K_SEM_DEFINE(sem_disconnected,      0, 1);
static K_SEM_DEFINE(sem_data_received,     0, 1);
static ssize_t on_attr_write_cb(struct bt_conn *conn, const struct bt_gatt_attr *attr, const void *buf, uint16_t len, uint16_t offset, uint8_t flags);
static struct bt_conn *connection;
static uint8_t  n_ap;
static uint8_t  latest_num_steps_reported;
static uint16_t latest_step_data_len;
static uint16_t latest_peer_steps_len;
static uint8_t  latest_local_steps[STEP_DATA_BUF_LEN];
static uint8_t  latest_peer_steps[STEP_DATA_BUF_LEN];
static struct bt_gatt_attr gatt_attributes[] =
    BT_GATT_PRIMARY_SERVICE(&step_data_svc_uuid),
    BT_GATT_CHARACTERISTIC(&step_data_char_uuid.uuid, BT_GATT_CHRC_WRITE,
        BT_GATT_PERM_WRITE | BT_GATT_PERM_READ, NULL, on_attr_write_cb, NULL),
static struct bt_gatt_service step_data_gatt_service = BT_GATT_SERVICE(gatt_attributes);
static const char reflector1_str[] = "channel reflector 1";
static const char reflector2_str[] = "channel reflector 2";
/* Round-robin state */
static int current_reflector_index = 0;
static const char* reflector_names[] = {reflector1_str, reflector2_str};
static const int num_reflectors = 2;
    if (flags & BT_GATT_WRITE_FLAG_PREPARE)
        return 0;
    if (offset)
        return BT_GATT_ERR(BT_ATT_ERR_INVALID_OFFSET);
    if (len > sizeof(latest_local_steps))
        return BT_GATT_ERR(BT_ATT_ERR_INVALID_ATTRIBUTE_LEN);
    if (flags & BT_GATT_WRITE_FLAG_EXECUTE)
        uint8_t *data = (uint8_t *)buf;
        memcpy(latest_peer_steps, &data[offset], len);
        latest_peer_steps_len = len;
        k_sem_give(&sem_data_received);
    return len;
static void subevent_result_cb(struct bt_conn_le_cs_subevent_result *result)
    latest_num_steps_reported = result->header.num_steps_reported;
    n_ap = result->header.num_antenna_paths;
    if (result->step_data_buf)
        if (result->step_data_buf->len <= STEP_DATA_BUF_LEN)
            memcpy(latest_local_steps, result->step_data_buf->data,
                   result->step_data_buf->len);
            latest_step_data_len = result->step_data_buf->len;
            printk("Not enough memory to store step data. (%d > %d)\n",
                   result->step_data_buf->len, STEP_DATA_BUF_LEN);
            latest_num_steps_reported = 0;
    if (result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_COMPLETE ||
        result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_ABORTED)
        k_sem_give(&sem_results_available);
static void end_cb(void)
    k_sem_give(&sem_test_complete);
static void mtu_exchange_cb(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
    printk("MTU exchange %s (%u)\n", err == 0U ? "success" : "failed", bt_gatt_get_mtu(conn));
static void connected_cb(struct bt_conn *conn, uint8_t err)
    (void)bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr));
    printk("Connected to %s (err 0x%02X)\n", addr, err);
    __ASSERT(connection == conn, "Unexpected connected callback");
    if (err)
        bt_conn_unref(conn);
        connection = NULL;
    static struct bt_gatt_exchange_params mtu_exchange_params = {.func = mtu_exchange_cb};
    err = bt_gatt_exchange_mtu(connection, &mtu_exchange_params);
    if (err)
        printk("%s: MTU exchange failed (err %d)\n", __func__, err);
    k_sem_give(&sem_connected);
static void disconnected_cb(struct bt_conn *conn, uint8_t reason)
    printk("Disconnected (reason 0x%02X)\n", reason);
    connection = NULL;
    k_sem_give(&sem_disconnected);
static bool data_cb(struct bt_data *data, void *user_data)
    char *name = user_data;
    uint8_t len;
    switch (data->type)
    case BT_DATA_NAME_SHORTENED:
    case BT_DATA_NAME_COMPLETE:
        len = MIN(data->data_len, NAME_LEN - 1);
        memcpy(name, data->data, len);
        name[len] = '\0';
        return false;
        return true;
static void device_found(const bt_addr_le_t *addr, int8_t rssi, uint8_t type, struct net_buf_simple *ad)
    char addr_str[BT_ADDR_LE_STR_LEN];
    char name[NAME_LEN] = {};
    int err;
    if (connection)
        return;
    /* We're only interested in connectable events */
    if (type != BT_GAP_ADV_TYPE_ADV_IND && type != BT_GAP_ADV_TYPE_ADV_DIRECT_IND)
        return;
    bt_data_parse(ad, data_cb, name);
    /* Check if this is the reflector we're looking for in round-robin */
    const char *target_name = reflector_names[current_reflector_index];
    if (strcmp(name, target_name))
        return;
    if (bt_le_scan_stop())
        return;
    printk("Found target reflector %d: %s, connecting...\n", current_reflector_index + 1, name);
    err = bt_conn_le_create(addr, BT_CONN_LE_CREATE_CONN, BT_LE_CONN_PARAM_DEFAULT,
                            &connection);
    if (err)
        printk("Create conn to %s failed (%u)\n", addr_str, err);
BT_CONN_CB_DEFINE(conn_cb) =
    .connected    = connected_cb,
    .disconnected = disconnected_cb,
    int err;
    struct bt_le_cs_test_param test_params;
    printk("Starting Multi-Reflector Channel Sounding Demo\n");
    /* Initialize the Bluetooth Subsystem */
    err = bt_enable(NULL);
    if (err)
        printk("Bluetooth init failed (err %d)\n", err);
        return 0;
    struct bt_le_cs_test_cb cs_test_cb =
        .le_cs_test_subevent_data_available = subevent_result_cb,
        .le_cs_test_end_complete            = end_cb,
    err = bt_le_cs_test_cb_register(cs_test_cb);
    if (err)
        printk("Failed to register callbacks (err %d)\n", err);
        return 0;
    err = bt_gatt_service_register(&step_data_gatt_service);
    if (err)
        printk("bt_gatt_service_register() returned err %d\n", err);
        return 0;
    while (true)
        printk("\n=== Starting new CS round ===\n");
        /* Original working logic: Run CS test first */
        while (true)
            k_sleep(K_SECONDS(2));
            test_params = test_params_get(BT_CONN_LE_CS_ROLE_INITIATOR);
            err = bt_le_cs_start_test(&test_params);
            if (err)
                printk("Failed to start CS test (err %d)\n", err);
                return 0;
            k_sem_take(&sem_results_available, K_SECONDS(5));
            err = bt_le_cs_stop_test();
            if (err)
                printk("Failed to stop CS test (err %d)\n", err);
                return 0;
            k_sem_take(&sem_test_complete, K_FOREVER);
            if (latest_num_steps_reported > NUM_MODE_0_STEPS)
        /* Original working logic: Scan and connect with timeout */
        printk("Scanning for reflector %d: %s\n", current_reflector_index + 1, reflector_names[current_reflector_index]);
        err = bt_le_scan_start(BT_LE_SCAN_ACTIVE_CONTINUOUS, device_found);
        if (err)
            printk("Scanning failed to start (err %d)\n", err);
            return 0;
        /* Wait for connection with timeout */
        err = k_sem_take(&sem_connected, K_SECONDS(10));
        if (err)
            printk("Timeout waiting for reflector %d, moving to next\n", current_reflector_index + 1);
            bt_le_scan_stop();
            current_reflector_index = (current_reflector_index + 1) % num_reflectors;
            continue;
        k_sem_take(&sem_data_received, K_FOREVER);
        /* Calculate distance using actual peer steps length */
        estimate_distance(
            latest_local_steps, latest_step_data_len, latest_peer_steps,
            latest_peer_steps_len,
            n_ap, BT_CONN_LE_CS_ROLE_INITIATOR);
        bt_conn_disconnect(connection, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
        k_sem_take(&sem_disconnected, K_FOREVER);
        /* Move to next reflector in round-robin */
        printk("Next target: reflector %d (%s)\n", current_reflector_index + 1, reflector_names[current_reflector_index]);
        printk("Re-running CS test...\n");
    return 0;
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_AUTO_PHY_UPDATE=n
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_BT_ATT_PREPARE_COUNT=3
CONFIG_BT_CHANNEL_SOUNDING=y
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_MAX_PAIRED=4
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_BT_CHANNEL_SOUNDING_TEST=y
CONFIG_CONSOLE=y
I am on nRF Connect SDK v3.0.2
Any help would be much appreciated.
Regards
    Did you test the NCS\nrf\samples\bluetooth\channel_sounding_ras_initiator and channel_sounding_ras_reflector? These use an algorithm that gives a bit better accuracy.
    But your question remains the same: "How to do measurements on different devices?"
    What do you observe when you try to introduce the second reflector? Does your log say anything?
    Edvin
  •   I used the channel_sounding_ras_reflector and a modified version of channel_sounding_ras_initiator to support 2 reflectors.
    channel_sounding_ras_initiator main.c :
    /** @file
     *  @brief Channel Sounding Initiator with Ranging Requestor sample
    #include <math.h>
    #include <zephyr/kernel.h>
    #include <zephyr/types.h>
    #include <zephyr/sys/reboot.h>
    #include <zephyr/bluetooth/conn.h>
    #include <bluetooth/scan.h>
    #include <bluetooth/services/ras.h>
    #include <bluetooth/gatt_dm.h>
    #include <bluetooth/cs_de.h>
    #include <dk_buttons_and_leds.h>
    LOG_MODULE_REGISTER(app_main, LOG_LEVEL_INF);
    #define CON_STATUS_LED               DK_LED1
    #define CS_CONFIG_ID                 0
    #define NUM_MODE_0_STEPS             3
    #define PROCEDURE_COUNTER_NONE       (-1)
    #define DE_SLIDING_WINDOW_SIZE       (10)
    #define MAX_AP                       (CONFIG_BT_RAS_MAX_ANTENNA_PATHS)
    #define IFFT_RUNNING_AVERAGE_SIZE    5
    #define MAX_REFLECTORS               2
    #define LOCAL_PROCEDURE_MEM                                                     \
        ((BT_RAS_MAX_STEPS_PER_PROCEDURE * sizeof(struct bt_le_cs_subevent_step)) + \
         (BT_RAS_MAX_STEPS_PER_PROCEDURE * BT_RAS_MAX_STEP_DATA_LEN))
    static K_SEM_DEFINE(sem_remote_capabilities_obtained, 0, 1);
    static K_SEM_DEFINE(sem_config_created, 0, 1);
    static K_SEM_DEFINE(sem_cs_security_enabled, 0, 1);
    static K_SEM_DEFINE(sem_discovery_done, 0, 1);
    static K_SEM_DEFINE(sem_mtu_exchange_done, 0, 1);
    static K_SEM_DEFINE(sem_security, 0, 1);
    static K_SEM_DEFINE(sem_local_steps, 1, 1);
    static K_MUTEX_DEFINE(distance_estimate_buffer_mutex);
    static struct bt_conn *connections[MAX_REFLECTORS];
    static uint8_t active_connections = 0;
    static bt_addr_le_t connected_devices[MAX_REFLECTORS];
    static bt_addr_le_t failed_devices[10]; // Track up to 10 failed devices
    static uint8_t failed_device_count = 0;
    NET_BUF_SIMPLE_DEFINE_STATIC(latest_local_steps, LOCAL_PROCEDURE_MEM);
    NET_BUF_SIMPLE_DEFINE_STATIC(latest_peer_steps, BT_RAS_PROCEDURE_MEM);
    static int32_t most_recent_local_ranging_counter = PROCEDURE_COUNTER_NONE;
    static int32_t dropped_ranging_counter = PROCEDURE_COUNTER_NONE;
    static uint8_t buffer_index;
    static uint8_t buffer_num_valid;
    static cs_de_dist_estimates_t distance_estimate_buffer[MAX_REFLECTORS][MAX_AP][DE_SLIDING_WINDOW_SIZE];
    // Running average buffer for IFFT distances
    static float ifft_running_average_buffer[MAX_REFLECTORS][MAX_AP][IFFT_RUNNING_AVERAGE_SIZE];
    static uint8_t ifft_running_average_index[MAX_REFLECTORS][MAX_AP];
    static uint8_t ifft_running_average_count[MAX_REFLECTORS][MAX_AP];
    static void store_distance_estimates(uint8_t reflector_index, cs_de_report_t *p_report)
        int lock_state = k_mutex_lock(&distance_estimate_buffer_mutex, K_FOREVER);
        __ASSERT_NO_MSG(lock_state == 0);
        for (uint8_t ap = 0; ap < p_report->n_ap; ap++)
            memcpy(&distance_estimate_buffer[reflector_index][ap][buffer_index],
                   &p_report->distance_estimates[ap], sizeof(cs_de_dist_estimates_t));
        buffer_index = (buffer_index + 1) % DE_SLIDING_WINDOW_SIZE;
        if (buffer_num_valid < DE_SLIDING_WINDOW_SIZE)
            buffer_num_valid++;
        k_mutex_unlock(&distance_estimate_buffer_mutex);
    static cs_de_dist_estimates_t get_distance(uint8_t reflector_index, uint8_t ap)
        cs_de_dist_estimates_t averaged_result = {};
        uint8_t num_ifft = 0;
        uint8_t num_phase_slope = 0;
        uint8_t num_rtt = 0;
        for (uint8_t i = 0; i < buffer_num_valid; i++)
            if (isfinite(distance_estimate_buffer[reflector_index][ap][i].ifft))
                num_ifft++;
                averaged_result.ifft += distance_estimate_buffer[reflector_index][ap][i].ifft;
            if (isfinite(distance_estimate_buffer[reflector_index][ap][i].phase_slope))
                num_phase_slope++;
                averaged_result.phase_slope += distance_estimate_buffer[reflector_index][ap][i].phase_slope;
            if (isfinite(distance_estimate_buffer[reflector_index][ap][i].rtt))
                num_rtt++;
                averaged_result.rtt += distance_estimate_buffer[reflector_index][ap][i].rtt;
        if (num_ifft)
            averaged_result.ifft /= num_ifft;
        if (num_phase_slope)
            averaged_result.phase_slope /= num_phase_slope;
        if (num_rtt)
            averaged_result.rtt /= num_rtt;
        return averaged_result;
    static float update_ifft_running_average(uint8_t reflector_index, uint8_t ap, float new_ifft_value)
        float sum = 0.0f;
        // Add new value to the buffer
        ifft_running_average_buffer[reflector_index][ap][ifft_running_average_index[reflector_index][ap]] = new_ifft_value;
        ifft_running_average_index[reflector_index][ap] = (ifft_running_average_index[reflector_index][ap] + 1) % IFFT_RUNNING_AVERAGE_SIZE;
        // Update count if buffer not full yet
        if (ifft_running_average_count[reflector_index][ap] < IFFT_RUNNING_AVERAGE_SIZE)
            ifft_running_average_count[reflector_index][ap]++;
        // Calculate running average
        for (uint8_t i = 0; i < ifft_running_average_count[reflector_index][ap]; i++)
            sum += ifft_running_average_buffer[reflector_index][ap][i];
        return sum / ifft_running_average_count[reflector_index][ap];
    static void ranging_data_get_complete_cb(struct bt_conn *conn, uint16_t ranging_counter, int err)
        // Find which reflector this connection belongs to
        uint8_t reflector_index = 0;
        for (uint8_t i = 0; i < active_connections; i++)
            if (connections[i] == conn)
                reflector_index = i;
        if (err)
            LOG_ERR("Error when getting ranging data with ranging counter %d (err %d)",
                    ranging_counter, err);
            return;
        LOG_DBG("Ranging data get completed for ranging counter %d from reflector %d",
                ranging_counter, reflector_index);
        /* This struct is static to avoid putting it on the stack (it's very large) */
        static cs_de_report_t cs_de_report;
        cs_de_populate_report(&latest_local_steps, &latest_peer_steps, BT_CONN_LE_CS_ROLE_INITIATOR,
                              &cs_de_report);
        net_buf_simple_reset(&latest_local_steps);
        net_buf_simple_reset(&latest_peer_steps);
        k_sem_give(&sem_local_steps);
        cs_de_quality_t quality = cs_de_calc(&cs_de_report);
        if (quality == CS_DE_QUALITY_OK)
            for (uint8_t ap = 0; ap < cs_de_report.n_ap; ap++)
                if (cs_de_report.tone_quality[ap] == CS_DE_TONE_QUALITY_OK)
                    store_distance_estimates(reflector_index, &cs_de_report);
    static void subevent_result_cb(struct bt_conn *conn, struct bt_conn_le_cs_subevent_result *result)
        if (dropped_ranging_counter == result->header.procedure_counter)
            return;
        if (most_recent_local_ranging_counter != bt_ras_rreq_get_ranging_counter(result->header.procedure_counter))
            int sem_state = k_sem_take(&sem_local_steps, K_NO_WAIT);
            if (sem_state < 0)
                dropped_ranging_counter = result->header.procedure_counter;
                LOG_DBG("Dropped subevent results due to unfinished ranging data request.");
                return;
                bt_ras_rreq_get_ranging_counter(result->header.procedure_counter);
        if (result->header.subevent_done_status == BT_CONN_LE_CS_SUBEVENT_ABORTED)
            /* The steps from this subevent will not be used. */
        else if (result->step_data_buf)
            if (result->step_data_buf->len <= net_buf_simple_tailroom(&latest_local_steps))
                uint16_t len = result->step_data_buf->len;
                uint8_t *step_data = net_buf_simple_pull_mem(result->step_data_buf, len);
                net_buf_simple_add_mem(&latest_local_steps, step_data, len);
                LOG_ERR("Not enough memory to store step data. (%d > %d)",
                        latest_local_steps.len + result->step_data_buf->len,
                        latest_local_steps.size);
                return;
        if (result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_COMPLETE)
        else if (result->header.procedure_done_status == BT_CONN_LE_CS_PROCEDURE_ABORTED)
            LOG_WRN("Procedure %u aborted", result->header.procedure_counter);
    static void ranging_data_ready_cb(struct bt_conn *conn, uint16_t ranging_counter)
        LOG_DBG("Ranging data ready %i", ranging_counter);
        if (ranging_counter == most_recent_local_ranging_counter)
            int err = bt_ras_rreq_cp_get_ranging_data(conn, &latest_peer_steps,
                                                      ranging_counter,
                                                      ranging_data_get_complete_cb);
            if (err)
                LOG_ERR("Get ranging data failed (err %d)", err);
    static void ranging_data_overwritten_cb(struct bt_conn *conn, uint16_t ranging_counter)
        LOG_INF("Ranging data overwritten %i", ranging_counter);
        if (err)
            LOG_ERR("MTU exchange failed (err %d)", err);
            return;
        LOG_INF("MTU exchange success (%u)", bt_gatt_get_mtu(conn));
        k_sem_give(&sem_mtu_exchange_done);
    static void discovery_completed_cb(struct bt_gatt_dm *dm, void *context)
        int err;
        LOG_INF("The discovery procedure succeeded");
        struct bt_conn *conn = bt_gatt_dm_conn_get(dm);
        bt_gatt_dm_data_print(dm);
        err = bt_ras_rreq_alloc_and_assign_handles(dm, conn);
        if (err)
            LOG_ERR("RAS RREQ alloc init failed (err %d)", err);
        err = bt_gatt_dm_data_release(dm);
        if (err)
            LOG_ERR("Could not release the discovery data (err %d)", err);
        k_sem_give(&sem_discovery_done);
    static void discovery_service_not_found_cb(struct bt_conn *conn, void *context)
        LOG_INF("The service could not be found during the discovery, disconnecting");
        bt_conn_disconnect(conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
    static void discovery_error_found_cb(struct bt_conn *conn, int err, void *context)
        LOG_INF("The discovery procedure failed (err %d)", err);
    static struct bt_gatt_dm_cb discovery_cb = {
        .completed = discovery_completed_cb,
        .service_not_found = discovery_service_not_found_cb,
        .error_found = discovery_error_found_cb,
    static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err)
        if (err)
            LOG_ERR("Security failed: %s level %u err %d %s", addr, level, err,
                    bt_security_err_to_str(err));
            return;
        LOG_INF("Security changed: %s level %u", addr, level);
        k_sem_give(&sem_security);
    static bool le_param_req(struct bt_conn *conn, struct bt_le_conn_param *param)
        /* Ignore peer parameter preferences. */
        return false;
        LOG_INF("Connected to %s (err 0x%02X)", addr, err);
        if (err)
            return;
        // Store the connection in the array
        if (active_connections < MAX_REFLECTORS)
            connections[active_connections] = bt_conn_ref(conn);
            // Store the device address
            bt_addr_le_copy(&connected_devices[active_connections], bt_conn_get_dst(conn));
            LOG_INF("Stored connection for reflector %d", active_connections);
            active_connections++;
            // Continue scanning if we haven't found all reflectors yet
                LOG_INF("Continuing to scan for more reflectors (%d/%d found)",
                        active_connections, MAX_REFLECTORS);
                int err = bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
                if (err)
                    LOG_ERR("Failed to restart scanning (err %d)", err);
                LOG_INF("All reflectors found, stopping scan");
                bt_scan_stop();
        dk_set_led_on(CON_STATUS_LED);
        LOG_INF("Disconnected (reason 0x%02X)", reason);
        // Find and remove the connection from our array
                bt_conn_unref(connections[i]);
                connections[i] = NULL;
                LOG_INF("Removed connection for reflector %d", i);
        dk_set_led_off(CON_STATUS_LED);
        sys_reboot(SYS_REBOOT_COLD);
    static void remote_capabilities_cb(struct bt_conn *conn,
                                       uint8_t status,
                                       struct bt_conn_le_cs_capabilities *params)
        ARG_UNUSED(conn);
        ARG_UNUSED(params);
        if (status == BT_HCI_ERR_SUCCESS)
            LOG_INF("CS capability exchange completed.");
            k_sem_give(&sem_remote_capabilities_obtained);
            LOG_WRN("CS capability exchange failed. (HCI status 0x%02x)", status);
    static void config_create_cb(struct bt_conn *conn,
                                 uint8_t status,
                                 struct bt_conn_le_cs_config *config)
        ARG_UNUSED(conn);
            LOG_INF("CS config creation complete. ID: %d", config->id);
            k_sem_give(&sem_config_created);
            LOG_WRN("CS config creation failed. (HCI status 0x%02x)", status);
    static void security_enable_cb(struct bt_conn *conn, uint8_t status)
        ARG_UNUSED(conn);
            LOG_INF("CS security enabled.");
            k_sem_give(&sem_cs_security_enabled);
            LOG_WRN("CS security enable failed. (HCI status 0x%02x)", status);
    static void procedure_enable_cb(struct bt_conn *conn,
                                    uint8_t status,
                                    struct bt_conn_le_cs_procedure_enable_complete *params)
        ARG_UNUSED(conn);
            if (params->state == 1)
                LOG_INF("CS procedures enabled:\n"
                        " - config ID: %u\n"
                        " - antenna configuration index: %u\n"
                        " - TX power: %d dbm\n"
                        " - subevent length: %u us\n"
                        " - subevents per event: %u\n"
                        " - subevent interval: %u\n"
                        " - event interval: %u\n"
                        " - procedure interval: %u\n"
                        " - procedure count: %u\n"
                        " - maximum procedure length: %u",
                        params->config_id, params->tone_antenna_config_selection,
                        params->selected_tx_power, params->subevent_len,
                        params->subevents_per_event, params->subevent_interval,
                        params->event_interval, params->procedure_interval,
                        params->procedure_count, params->max_procedure_len);
                LOG_INF("CS procedures disabled.");
            LOG_WRN("CS procedures enable failed. (HCI status 0x%02x)", status);
    static bool is_device_already_connected(const bt_addr_le_t *addr)
            if (bt_addr_le_cmp(&connected_devices[i], addr) == 0)
                return true;
        return false;
    static bool is_device_already_failed(const bt_addr_le_t *addr)
        for (uint8_t i = 0; i < failed_device_count; i++)
            if (bt_addr_le_cmp(&failed_devices[i], addr) == 0)
                return true;
        return false;
    static void scan_filter_match(struct bt_scan_device_info *device_info,
                                  struct bt_scan_filter_match *filter_match, bool connectable)
        char device_name[32] = {0};
        bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
        // Check if we've already connected to this device
        if (is_device_already_connected(device_info->recv_info->addr))
            LOG_INF("Skipping already connected device: %s", addr);
            return;
        // Check if we've already failed to connect to this device
        if (is_device_already_failed(device_info->recv_info->addr))
            LOG_INF("Skipping failed device: %s", addr);
            return;
        // Try to get device name from scan data
        const uint8_t *data = device_info->adv_data->data;
        uint8_t len = device_info->adv_data->len;
        for (int i = 0; i < len;)
            uint8_t field_len = data[i];
            uint8_t field_type = data[i + 1];
            if (field_type == BT_DATA_NAME_COMPLETE)
                if (field_len > 1 && (i + 2 + field_len - 1) <= len)
                    memcpy(device_name, &data[i + 2], field_len - 1);
                    device_name[field_len - 1] = '\0';
            i += field_len + 1;
        LOG_INF("Filters matched. Address: %s, Name: %s, connectable: %d (current connections: %d/%d)",
                addr, device_name[0] ? device_name : "Unknown", connectable, active_connections, MAX_REFLECTORS);
    static void scan_connecting_error(struct bt_scan_device_info *device_info)
        LOG_INF("Connecting failed to %s, adding to failed list", addr);
        // Add to failed devices list if we have space
        if (failed_device_count < 10)
            bt_addr_le_copy(&failed_devices[failed_device_count], device_info->recv_info->addr);
            failed_device_count++;
            LOG_INF("Added %s to failed devices list (total failed: %d)", addr, failed_device_count);
        // Only restart scanning if we haven't found all reflectors yet
            LOG_INF("Restarting scanning for more reflectors");
            // Add a small delay before restarting scan to avoid overwhelming the device
            k_sleep(K_MSEC(1000));
            if (err)
                LOG_ERR("Failed to restart scanning (err %i)", err);
    static void scan_connecting(struct bt_scan_device_info *device_info, struct bt_conn *conn)
        LOG_INF("Attempting to connect to %s", addr);
    BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, scan_connecting_error, scan_connecting);
    static int scan_init(void)
        int err;
        struct bt_scan_init_param param = {
            .scan_param = NULL, .conn_param = BT_LE_CONN_PARAM_DEFAULT, .connect_if_match = 1};
        bt_scan_init(&param);
        bt_scan_cb_register(&scan_cb);
        err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_RANGING_SERVICE);
        if (err)
            LOG_ERR("Scanning filters cannot be set (err %d)", err);
            return err;
        err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
        if (err)
            LOG_ERR("Filters cannot be turned on (err %d)", err);
            return err;
        return 0;
        .le_param_req                            = le_param_req,
        .security_changed                        = security_changed,
        .le_cs_read_remote_capabilities_complete = remote_capabilities_cb,
        .le_cs_config_complete                   = config_create_cb,
        .le_cs_security_enable_complete          = security_enable_cb,
        .le_cs_procedure_enable_complete         = procedure_enable_cb,
        .le_cs_subevent_data_available           = subevent_result_cb,
    static void setup_reflector_connection(struct bt_conn *conn, uint8_t reflector_index)
        int err;
        LOG_INF("Setting up reflector connection %d", reflector_index);
        err = bt_conn_set_security(conn, BT_SECURITY_L2);
        if (err)
            LOG_ERR("Failed to encrypt connection (err %d)", err);
            return;
        k_sem_take(&sem_security, K_FOREVER);
        bt_gatt_exchange_mtu(conn, &mtu_exchange_params);
        k_sem_take(&sem_mtu_exchange_done, K_FOREVER);
        err = bt_gatt_dm_start(conn, BT_UUID_RANGING_SERVICE, &discovery_cb, NULL);
        if (err)
            LOG_ERR("Discovery failed (err %d)", err);
            return;
        k_sem_take(&sem_discovery_done, K_FOREVER);
        const struct bt_le_cs_set_default_settings_param default_settings = {
            .enable_initiator_role = true,
            .enable_reflector_role = false,
            .cs_sync_antenna_selection = BT_LE_CS_ANTENNA_SELECTION_OPT_REPETITIVE,
            .max_tx_power = BT_HCI_OP_LE_CS_MAX_MAX_TX_POWER,
        err = bt_le_cs_set_default_settings(conn, &default_settings);
        if (err)
            LOG_ERR("Failed to configure default CS settings (err %d)", err);
            return;
        err = bt_ras_rreq_rd_overwritten_subscribe(conn, ranging_data_overwritten_cb);
        if (err)
            LOG_ERR("RAS RREQ ranging data overwritten subscribe failed (err %d)", err);
            return;
        err = bt_ras_rreq_rd_ready_subscribe(conn, ranging_data_ready_cb);
        if (err)
            LOG_ERR("RAS RREQ ranging data ready subscribe failed (err %d)", err);
            return;
        err = bt_ras_rreq_on_demand_rd_subscribe(conn);
        if (err)
            LOG_ERR("RAS RREQ On-demand ranging data subscribe failed (err %d)", err);
            return;
        err = bt_ras_rreq_cp_subscribe(conn);
        if (err)
            LOG_ERR("RAS RREQ CP subscribe failed (err %d)", err);
            return;
        err = bt_le_cs_read_remote_supported_capabilities(conn);
        if (err)
            LOG_ERR("Failed to exchange CS capabilities (err %d)", err);
            return;
        k_sem_take(&sem_remote_capabilities_obtained, K_FOREVER);
        struct bt_le_cs_create_config_params config_params =
            .id                     = CS_CONFIG_ID,
            .main_mode_type         = BT_CONN_LE_CS_MAIN_MODE_2,
            .sub_mode_type          = BT_CONN_LE_CS_SUB_MODE_1,
            .min_main_mode_steps    = 2,
            .max_main_mode_steps    = 5,
            .main_mode_repetition   = 0,
            .mode_0_steps           = NUM_MODE_0_STEPS,
            .role                   = BT_CONN_LE_CS_ROLE_INITIATOR,
            .rtt_type               = BT_CONN_LE_CS_RTT_TYPE_AA_ONLY,
            .cs_sync_phy            = BT_CONN_LE_CS_SYNC_1M_PHY,
            .channel_map_repetition = 3,
            .channel_selection_type = BT_CONN_LE_CS_CHSEL_TYPE_3B,
            .ch3c_shape             = BT_CONN_LE_CS_CH3C_SHAPE_HAT,
            .ch3c_jump              = 2,
        bt_le_cs_set_valid_chmap_bits(config_params.channel_map);
        err = bt_le_cs_create_config(conn, &config_params,
                                     BT_LE_CS_CREATE_CONFIG_CONTEXT_LOCAL_AND_REMOTE);
        if (err)
            LOG_ERR("Failed to create CS config (err %d)", err);
            return;
        k_sem_take(&sem_config_created, K_FOREVER);
        err = bt_le_cs_security_enable(conn);
        if (err)
            LOG_ERR("Failed to start CS Security (err %d)", err);
            return;
        k_sem_take(&sem_cs_security_enabled, K_FOREVER);
        const struct bt_le_cs_set_procedure_parameters_param procedure_params =
            .config_id                     = CS_CONFIG_ID,
            .max_procedure_len             = 1000,
            .min_procedure_interval        = 10,
            .max_procedure_interval        = 10,
            .max_procedure_count           = 0,
            .min_subevent_len              = 60000,
            .max_subevent_len              = 60000,
            .tone_antenna_config_selection = BT_LE_CS_TONE_ANTENNA_CONFIGURATION_A1_B1,
            .phy                           = BT_LE_CS_PROCEDURE_PHY_1M,
            .tx_power_delta                = 0x80,
            .preferred_peer_antenna        = BT_LE_CS_PROCEDURE_PREFERRED_PEER_ANTENNA_1,
            .snr_control_initiator         = BT_LE_CS_SNR_CONTROL_NOT_USED,
            .snr_control_reflector         = BT_LE_CS_SNR_CONTROL_NOT_USED,
        err = bt_le_cs_set_procedure_parameters(conn, &procedure_params);
        if (err)
            LOG_ERR("Failed to set procedure parameters (err %d)", err);
            return;
        struct bt_le_cs_procedure_enable_param params = {
            .enable = 1,
        err = bt_le_cs_procedure_enable(conn, &params);
        if (err)
            LOG_ERR("Failed to enable CS procedures (err %d)", err);
            return;
        LOG_INF("Reflector connection %d setup complete", reflector_index);
        int err;
        LOG_INF("Starting Channel Sounding Initiator Sample");
        dk_leds_init();
        if (err)
            LOG_ERR("Bluetooth init failed (err %d)", err);
            return 0;
        err = scan_init();
        if (err)
            LOG_ERR("Scan init failed (err %d)", err);
            return 0;
        if (err)
            LOG_ERR("Scanning failed to start (err %i)", err);
            return 0;
        // Wait for all reflector connections
        LOG_INF("Waiting for %d reflector connections...", MAX_REFLECTORS);
        // Add a timeout mechanism - wait up to 30 seconds for all connections
        int timeout_count = 0;
        const int max_timeout = 300;   // 30 seconds at 100ms intervals
        const int retry_interval = 50; // Retry failed devices every 5 seconds
        while (active_connections < MAX_REFLECTORS && timeout_count < max_timeout)
            // Wait for connection with timeout
            if (k_sem_take(&sem_connected, K_MSEC(100)) == 0)
                LOG_INF("Connected to reflector %d (%d/%d total)",
                        active_connections - 1, active_connections, MAX_REFLECTORS);
                timeout_count++;
                // Clear failed devices list periodically to allow retrying
                if (timeout_count % retry_interval == 0 && failed_device_count > 0)
                    LOG_INF("Clearing failed devices list to retry connections");
                if (timeout_count % 100 == 0)
                { // Log every 10 seconds
                    LOG_INF("Still waiting for reflectors... (%d/%d found, timeout: %d/%d, failed devices: %d)",
                            active_connections, MAX_REFLECTORS, timeout_count, max_timeout, failed_device_count);
            LOG_WRN("Timeout waiting for all reflectors. Only found %d/%d",
            if (active_connections == 0)
                LOG_ERR("No reflectors found! Check if reflector devices are advertising properly.");
                return 0;
            LOG_INF("Proceeding with available reflectors...");
        LOG_INF("Setup complete for %d reflectors, starting ranging", active_connections);
        // Setup each reflector connection
            setup_reflector_connection(connections[i], i);
        while (true)
            k_sleep(K_MSEC(1000)); // Faster update rate: 100ms instead of 500ms
            // Process distance estimates for all reflectors
            for (uint8_t reflector = 0; reflector < active_connections; reflector++)
                if (buffer_num_valid != 0)
                    for (uint8_t ap = 0; ap < MAX_AP; ap++)
                        cs_de_dist_estimates_t distance_on_ap = get_distance(reflector, ap);
                        // Update running average for IFFT distance
                        float ifft_running_avg = update_ifft_running_average(reflector, ap, distance_on_ap.ifft);
                        LOG_INF("Reflector %d - Distance estimates on antenna path %u: ifft: %f (avg: %f), "
                                "phase_slope: %f, rtt: %f",
                                reflector, ap, (double)distance_on_ap.ifft, (double)ifft_running_avg,
                                (double)distance_on_ap.phase_slope,
                                (double)distance_on_ap.rtt);
            LOG_INF("Sleeping for 1000 ms...");
        return 0;
    channel_sounding_ras_initiator prj.conf :
    # Copyright (c) 2024 Nordic Semiconductor ASA
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_DK_LIBRARY=y
    CONFIG_BT=y
    CONFIG_BT_SMP=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_MAX_CONN=4
    CONFIG_BT_BONDABLE=n
    CONFIG_BT_RAS=y
    CONFIG_BT_RAS_RREQ=y
    CONFIG_BT_SCAN=y
    CONFIG_BT_SCAN_FILTER_ENABLE=y
    CONFIG_BT_SCAN_UUID_CNT=1
    # The Ranging Profile recommends a MTU of at least 247 octets.
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # This reduces RAM usage. Additional RAM is needed to support optional
    # features such as mode 3 or multiantenna. Change or remove these if
    # using those features
    CONFIG_BT_RAS_MODE_3_SUPPORTED=n
    CONFIG_BT_RAS_MAX_ANTENNA_PATHS=1
    CONFIG_BT_CTLR_SDC_CS_MAX_ANTENNA_PATHS=1
    CONFIG_BT_CTLR_SDC_CS_NUM_ANTENNAS=1
    CONFIG_BT_CTLR_SDC_CS_STEP_MODE3=n
    # This size assumes the largest step size is mode 2 with one antenna path:
    # 12 bytes * 160 steps in a subevent. Change or remove this if using mode 3
    # or multiantenna.
    CONFIG_BT_CHANNEL_SOUNDING_REASSEMBLY_BUFFER_SIZE=1920
    # This allows CS and ACL to use different PHYs
    CONFIG_BT_TRANSMIT_POWER_CONTROL=y
    # This improves the performance of floating-point operations
    CONFIG_FPU=y
    CONFIG_FPU_SHARING=y
    CONFIG_BT_CS_DE=y
    CONFIG_BT_CS_DE_512_NFFT=y
    The logs on initiator side :
    (you will notice that one of the reflectors always shows 0 in distance)
    *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
    *** Using Zephyr OS v4.0.99-f791c49f492c ***
    I: Starting Channel Sounding Initiator Sample
    I: SoftDevice Controller build revision:
    I: 89 9a 50 8a 95 01 9c 58 |..P....X
    I: fc 39 d2 c1 10 04 ee 02 |.9......
    I: 64 ce 25 be             |d.%.
    I: HW Platform: Nordic Semiconductor (0x0002)
    I: HW Variant: nRF54Lx (0x0005)
    I: Firmware: Standard Bluetooth controller (0x00) Version 137.20634 Build 2617349514
    I: Identity: C6:41:B0:37:C1:9F (random)
    I: HCI: version 6.0 (0x0e) revision 0x30f3, manufacturer 0x0059
    I: LMP: version 6.0 (0x0e) subver 0x30f3
    I: Waiting for 2 reflector connections...
    I: Filters matched. Address: F6:01:EA:F1:47:51 (random), Name: Reflector-1, connectable: 1 (current connections: 0/2)
    I: Attempting to connect to F6:01:EA:F1:47:51 (random)
    I: Connected to F6:01:EA:F1:47:51 (random) (err 0x00)
    I: Stored connection for reflector 0
    I: Continuing to scan for more reflectors (1/2 found)
    I: Connected to reflector 0 (1/2 total)
    I: Filters matched. Address: FF:E7:7D:64:BC:8B (random), Name: Reflector-2, connectable: 1 (current connections: 1/2)
    I: Attempting to connect to FF:E7:7D:64:BC:8B (random)
    I: Connected to FF:E7:7D:64:BC:8B (random) (err 0x00)
    I: Stored connection for reflector 1
    I: All reflectors found, stopping scan
    I: Connected to reflector 1 (2/2 total)
    I: Setup complete for 2 reflectors, starting ranging
    I: Setting up reflector connection 0
    I: Security changed: F6:01:EA:F1:47:51 (random) level 2
    I: MTU exchange success (498)
    I: The discovery procedure succeeded
    I: CS capability exchange completed.
    I: CS config creation complete. ID: 0
    I: CS security enabled.
    I: Reflector connection 0 setup complete
    I: Setting up reflector connection 1
    E: Failed to encrypt connection (err -12)
    I: CS procedures enabled:
     - config ID: 0
     - antenna configuration index: 0
     - TX power: 0 dbm
     - subevent length: 28198 us
     - subevents per event: 1
     - subevent interval: 0
     - event interval: 2
     - procedure interval: 10
     - procedure count: 0
     - maximum procedure length: 1000
    I: Sleeping for 1000 ms...
    I: Ranging data overwritten 4
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.049362 (avg: 2.049362), phase_slope: 3.913533, rtt: 7.974549
    I: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.561703 (avg: 2.305533), phase_slope: 3.693789, rtt: 8.000714
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.342128 (avg: 2.317731), phase_slope: 3.664881, rtt: 7.925765
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.383952 (avg: 2.334286), phase_slope: 3.921384, rtt: 7.724940
    I: Ranging data overwritten 17
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.383952 (avg: 2.344220), phase_slope: 3.861651, rtt: 7.836896
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.383952 (avg: 2.411137), phase_slope: 3.861651, rtt: 7.836896
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.268937 (avg: 2.352584), phase_slope: 3.997900, rtt: 7.880391
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.268937 (avg: 2.337946), phase_slope: 3.997900, rtt: 7.880391
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.268937 (avg: 2.314943), phase_slope: 3.997900, rtt: 7.880391
    I: Ranging data overwritten 27
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.179481 (avg: 2.274049), phase_slope: 4.024032, rtt: 7.867682
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.305533 (avg: 2.258365), phase_slope: 3.985970, rtt: 7.882163
    I: Ranging data overwritten 31
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.305533 (avg: 2.265684), phase_slope: 3.985970, rtt: 7.882163
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.216657 (avg: 2.255228), phase_slope: 4.044756, rtt: 7.828835
    I: Ranging data overwritten 35
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.098157 (avg: 2.221072), phase_slope: 4.178952, rtt: 7.812559
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.873703 (avg: 2.159916), phase_slope: 4.159396, rtt: 7.735431
    I: Ranging data overwritten 40
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.873703 (avg: 2.073550), phase_slope: 4.159396, rtt: 7.735431
    I: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.049362 (avg: 2.022316), phase_slope: 4.244737, rtt: 7.811957
    Logs from reflector 1:
    I: Starting Channel Sounding Reflector Sample:  ================== Reflector-1 ==================
    I: Identity: F6:01:EA:F1:47:51 (random)
    I: Connected to C6:41:B0:37:C1:9F (random) (err 0x00)
    I: CS procedures enabled.
    Logs from reflector 2:
    I: Starting Channel Sounding Reflector Sample:  ================== Reflector-2 ==================
    I: Identity: FF:E7:7D:64:BC:8B (random)
    You will notice that in reflector 2, the channel sounding logs are missing. And it's not always reflector 2, sometimes reflector 2 works and reflector 1 doesn't. Whichever connects first works.
    Thanks for the help.
    Usman
  • Hello Usman,
    ranging_data_get_complete_cb(), does that ever trigger for the device that returns distance = 0?
    Edvin
  • Hi
    Sorry for the late reply. I printed the extra logs and it looks like ranging_data_get_complete_cb() is not triggering for the reflector returning 0.
    [00:00:00.008,853] <inf> app_main: Starting Channel Sounding Initiator Sample
    [00:00:00.016,653] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                89 9a 50 8a 95 01 9c 58  fc 39 d2 c1 10 04 ee 02 |..P....X .9......
                                                64 ce 25 be                                      |d.%.
    [00:00:00.046,083] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.054,020] <inf> bt_hci_core: HW Variant: nRF54Lx (0x0005)
    [00:00:00.060,816] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 137.20634 Build 2617349514
    [00:00:00.072,776] <inf> bt_hci_core: Identity: C6:41:B0:37:C1:9F (random)
    [00:00:00.080,208] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x30f3, manufacturer 0x0059
    [00:00:00.089,748] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x30f3
    [00:00:00.097,904] <inf> app_main: Waiting for 2 reflector connections...
    [00:00:00.118,260] <inf> app_main: Filters matched. Address: FF:E7:7D:64:BC:8B (random), Name: Reflector-2, connectable: 1 (current connections: 0/2)
    [00:00:00.133,078] <inf> app_main: Attempting to connect to FF:E7:7D:64:BC:8B (random)
    [00:00:00.226,570] <inf> app_main: Connected to FF:E7:7D:64:BC:8B (random) (err 0x00)
    [00:00:00.235,124] <inf> app_main: Stored connection for reflector 0
    [00:00:00.242,159] <inf> app_main: Continuing to scan for more reflectors (1/2 found)
    [00:00:00.251,569] <inf> app_main: Connected to reflector 0 (1/2 total)
    [00:00:00.661,267] <inf> app_main: Filters matched. Address: F6:01:EA:F1:47:51 (random), Name: Reflector-1, connectable: 1 (current connections: 1/2)
    [00:00:00.676,037] <inf> app_main: Attempting to connect to F6:01:EA:F1:47:51 (random)
    [00:00:00.769,638] <inf> app_main: Connected to F6:01:EA:F1:47:51 (random) (err 0x00)
    [00:00:00.778,036] <inf> app_main: Stored connection for reflector 1
    [00:00:00.785,108] <inf> app_main: All reflectors found, stopping scan
    [00:00:00.792,741] <inf> app_main: Connected to reflector 1 (2/2 total)
    [00:00:00.799,908] <inf> app_main: Setup complete for 2 reflectors, starting ranging
    [00:00:00.808,246] <inf> app_main: Setting up reflector connection 0
    [00:00:01.628,047] <inf> app_main: Security changed: FF:E7:7D:64:BC:8B (random) level 2
    [00:00:01.728,026] <inf> app_main: MTU exchange success (498)
    [00:00:02.128,032] <inf> app_main: The discovery procedure succeeded
    [00:00:02.278,169] <inf> app_main: CS capability exchange completed.
    [00:00:02.428,070] <inf> app_main: CS config creation complete. ID: 0
    [00:00:02.628,029] <inf> app_main: CS security enabled.
    [00:00:02.634,239] <inf> app_main: Reflector connection 0 setup complete
    [00:00:02.641,644] <inf> app_main: Setting up reflector connection 1
    [00:00:02.878,146] <inf> app_main: CS procedures enabled:
    - config ID: 0
    - TX power: 0 dbm
    - event interval: 2
    [00:00:03.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 0
    [00:00:03.385,550] <inf> app_main: Security changed: F6:01:EA:F1:47:51 (random) level 2
    [00:00:03.485,529] <inf> app_main: MTU exchange success (498)
    [00:00:03.628,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 0 from reflector 0
    [00:00:03.828,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 1
    [00:00:03.885,535] <inf> app_main: The discovery procedure succeeded
    [00:00:04.085,672] <inf> app_main: CS capability exchange completed.
    [00:00:04.128,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 1 from reflector 0
    [00:00:04.285,573] <inf> app_main: CS config creation complete. ID: 0
    [00:00:04.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 2
    [00:00:04.485,531] <inf> app_main: CS security enabled.
    [00:00:04.491,621] <wrn> bt_hci_core: opcode 0x2094 status 0x07
    [00:00:04.498,188] <err> app_main: Failed to enable CS procedures (err -5)
    [00:00:04.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 2 from reflector 0
    [00:00:04.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 3
    [00:00:05.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 3 from reflector 0
    [00:00:05.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 4
    [00:00:05.505,779] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.003325 (avg: 2.003325), phase_slope: 2.329631, rtt: 0.000000
    [00:00:05.520,180] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:05.534,714] <inf> app_main: Sleeping for 1000 ms...
    [00:00:05.724,374] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:05.735,838] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 4 from reflector 0
    [00:00:05.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 5
    [00:00:06.228,024] <inf> app_main: Ranging data overwritten 5
    [00:00:06.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 6
    [00:00:06.541,043] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.003325 (avg: 2.003325), phase_slope: 2.516117, rtt: 0.000000
    [00:00:06.555,453] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:06.569,876] <inf> app_main: Sleeping for 1000 ms...
    [00:00:06.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 6 from reflector 0
    [00:00:06.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 7
    [00:00:07.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 7 from reflector 0
    [00:00:07.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 8
    [00:00:07.576,084] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.895426 (avg: 1.967359), phase_slope: 2.641607, rtt: 0.000000
    [00:00:07.590,986] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:07.605,402] <inf> app_main: Sleeping for 1000 ms...
    [00:00:07.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 8 from reflector 0
    [00:00:07.878,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 9
    [00:00:08.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 9 from reflector 0
    [00:00:08.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 10
    [00:00:08.611,604] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.813937 (avg: 1.929003), phase_slope: 2.587863, rtt: 0.000000
    [00:00:08.626,014]  <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 10 from reflector 0
    [1;32m<inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:08.655,077] <inf> app_main: Sleeping for 1000 ms...
    [00:00:08.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 11
    [00:00:09.128,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 11 from reflector 0
    [00:00:09.328,412] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 12
    [00:00:09.661,301] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.626813 (avg: 1.868565), phase_slope: 2.730412, rtt: 0.000000
    [00:00:09.675,705] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:09.690,352] <inf> app_main: Sleeping for 1000 ms...
    [00:00:09.724,362] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:09.735,841] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 12 from reflector 0
    [00:00:09.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 13
    [00:00:10.228,025] <inf> app_main: Ranging data overwritten 13
    [00:00:10.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 14
    [00:00:10.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 14 from reflector 0
    [00:00:10.696,565] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.624049 (avg: 1.792710), phase_slope: 2.836699, rtt: 0.000000
    [00:00:10.711,517] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:10.727,319] <inf> app_main: Sleeping for 1000 ms...
    [00:00:10.828,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 15
    [00:00:11.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 15 from reflector 0
    [00:00:11.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 16
    [00:00:11.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 16 from reflector 0
    [00:00:11.733,653] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.570854 (avg: 1.706216), phase_slope: 2.872743, rtt: 0.000000
    [00:00:11.748,200] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:11.762,607] <inf> app_main: Sleeping for 1000 ms...
    [00:00:11.828,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 17
    [00:00:12.224,275] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:12.235,748] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 17 from reflector 0
    [00:00:12.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 18
    [00:00:12.728,024] <inf> app_main: Ranging data overwritten 18
    [00:00:12.768,821] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.633772 (avg: 1.653885), phase_slope: 2.778327, rtt: 0.000000
    [00:00:12.783,522] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:12.798,097] <inf> app_main: Sleeping for 1000 ms...
    [00:00:12.878,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 19
    [00:00:13.224,548] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:13.278,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 19 from reflector 0
    [00:00:13.804,516] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.701904 (avg: 1.631479), phase_slope: 2.778607, rtt: 0.000000
    [00:00:13.819,901] <inf> app_main: Reflector 1 - Distance estimates on antenna path [00:00:13.828,029] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 21
    [00:00:13.842,562] <inf> app_main: Sleeping for 1000 ms...
    [00:00:14.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 21 from reflector 0
    [00:00:14.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 22
    [00:00:14.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 22 from reflector 0
    [00:00:14.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 23
    [00:00:14.848,759] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.701904 (avg: 1.646497), phase_slope: 2.802526, rtt: 0.000000
    [00:00:14.863,167] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:14.877,630] <inf> app_main: Sleeping for 1000 ms...
    [00:00:15.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 23 from reflector 0
    [00:00:15.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 24
    [00:00:15.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 24 from reflector 0
    [00:00:15.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 25
    [00:00:15.884,213] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.832022 (avg: 1.688091), phase_slope: 2.726507, rtt: 0.000000
    [00:00:15.898,809] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:15.913,224] <inf> app_main: Sleeping for 1000 ms...
    [00:00:16.128,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 25 from reflector 0
    [00:00:16.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 26
    [00:00:16.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 26 from reflector 0
    [00:00:16.878,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 27
    [00:00:16.919,447] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.766963 (avg: 1.727313), phase_slope: 2.604568, rtt: 0.000000
    [00:00:16.933,934] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:16.948,524] <inf> app_main: Sleeping for 1000 ms...
    [00:00:17.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 27 from reflector 0
    [00:00:17.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 28
    [00:00:17.724,450] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:17.735,930] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 28 from reflector 0
    [00:00:17.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 29
    [00:00:17.954,741] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.766963 (avg: 1.753951), phase_slope: 2.604568, rtt: 0.000000
    [00:00:17.969,141] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:17.983,719] <inf> app_main: Sleeping for 1000 ms...
    [00:00:18.278,024] <inf> app_main: Ranging data overwritten 29
    [00:00:18.428,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 30
    [00:00:18.724,275] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:18.878,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 30 from reflector 0
    [00:00:18.990,101] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.766963 (avg: 1.766963), phase_slope: 2.604568, rtt: 0.000000
    [00:00:19.004,506] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:19.018,920] <inf> app_main: Sleeping for 1000 ms...
    [00:00:19.478,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 32
    [00:00:19.724,625] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:19.978,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 32 from reflector 0
    [00:00:20.025,143] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.766963 (avg: 1.779975), phase_slope: 2.604568, rtt: 0.000000
    [00:00:20.039,953] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:20.054,363] <inf> app_main: Sleeping for 1000 ms...
    [00:00:20.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 34
    [00:00:20.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 34 from reflector 0
    [00:00:20.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 35
    [00:00:21.060,565] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.736890 (avg: 1.760949), phase_slope: 2.587095, rtt: 0.000000
    [00:00:21.074,982] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:21.090,610] <inf> app_main: Sleeping for 1000 ms...
    [00:00:21.224,450] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:21.235,931] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 35 from reflector 0
    [00:00:21.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 36
    [00:00:21.728,025] <inf> app_main: Ranging data overwritten 36
    [00:00:21.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 37
    [00:00:22.096,821] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.779429 (avg: 1.763442), phase_slope: 2.625187, rtt: 0.000000
    [00:00:22.111,226] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:22.125,644] 00:00:22.128,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 37 from reflector 0
    2m<inf> app_main: Sleeping for 1000 ms...
    [00:00:22.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 38
    [00:00:22.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 38 from reflector 0
    [00:00:22.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 39
    [00:00:23.128,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 39 from reflector 0
    [00:00:23.146,455] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.738612 (avg: 1.757771), phase_slope: 2.770703, rtt: 0.000000
    [00:00:23.160,856] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:23.175,274] <inf> app_main: Sleeping for 1000 ms...
    [00:00:23.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 40
    [00:00:23.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 40 from reflector 0
    [00:00:23.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 41
    [00:00:24.128,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 41 from reflector 0
    [00:00:24.181,813] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.797165 (avg: 1.763812), phase_slope: 2.887904, rtt: 0.000000
    [00:00:24.196,397] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:24.211,343] <inf> app_main: Sleeping for 1000 ms...
    [00:00:24.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 42
    [00:00:24.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 42 from reflector 0
    [00:00:24.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 43
    [00:00:25.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 43 from reflector 0
    [00:00:25.217,630] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.847561 (avg: 1.779931), phase_slope: 2.934223, rtt: 0.000000
    [00:00:25.233,488] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:25.248,100] <inf> app_main: Sleeping for 1000 ms...
    [00:00:25.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 44
    [00:00:25.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 44 from reflector 0
    [00:00:25.828,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 45
    [00:00:26.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 45 from reflector 0
    [00:00:26.254,325] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.906115 (avg: 1.813776), phase_slope: 3.203472, rtt: 0.000000
    [00:00:26.268,733] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:26.283,407] <inf> app_main: Sleeping for 1000 ms...
    [00:00:26.428,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 46
    [00:00:26.724,635] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:26.828,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 46 from reflector 0
    [00:00:27.289,781] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.894822 (avg: 1.836855), phase_slope: 3.298077, rtt: 0.000000
    [00:00:27.304,478] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:27.319,769] <inf> app_main: Sleeping for 1000 ms...
    [00:00:27.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 48
    [00:00:27.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 48 from reflector 0
    [00:00:27.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 49
    [00:00:28.178,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 49 from reflector 0
    [00:00:28.325,975] 00:00:28.328,028] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 50
    1;32m<inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.980858 (avg: 1.885304), phase_slope: 3.248099, rtt: 0.000000
    [00:00:28.348,575] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:28.362,986] <inf> app_main: Sleeping for 1000 ms...
    [00:00:28.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 50 from reflector 0
    [00:00:28.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 51
    [00:00:29.128,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 51 from reflector 0
    [00:00:29.328,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 52
    [00:00:29.369,207] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.990888 (avg: 1.924049), phase_slope: 3.137689, rtt: 0.000000
    [00:00:29.384,058] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:29.398,607] <inf> app_main: Sleeping for 1000 ms...
    [00:00:29.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 52 from reflector 0
    [00:00:29.878,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 53
    [00:00:30.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 53 from reflector 0
    [00:00:30.378,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 54
    [00:00:30.404,823] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.020164 (avg: 1.958569), phase_slope: 3.274416, rtt: 0.000000
    [00:00:30.419,230] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:30.434,119] <inf> app_main: Sleeping for 1000 ms...
    [00:00:30.724,276] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:30.735,748] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 54 from reflector 0
    [00:00:30.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 55
    [00:00:31.228,025] <inf> app_main: Ranging data overwritten 55
    [00:00:31.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 56
    [00:00:31.440,469] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.969768 (avg: 1.971300), phase_slope: 3.263761, rtt: 0.000000
    [00:00:31.454,871] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:31.469,286] <inf> app_main: Sleeping for 1000 ms...
    [00:00:31.678,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 56 from reflector 0
    [00:00:31.878,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 57
    [00:00:32.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 57 from reflector 0
    [00:00:32.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 58
    [00:00:32.475,477] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.969768 (avg: 1.986289), phase_slope: 3.192044, rtt: 0.000000
    [00:00:32.490,809] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:32.505,222] <inf> app_main: Sleeping for 1000 ms...
    [00:00:32.628,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 58 from reflector 0
    [00:00:32.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 59
    [00:00:33.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 59 from reflector 0
    [00:00:33.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 60
    [00:00:33.511,445] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.940491 (avg: 1.978216), phase_slope: 3.137436, rtt: 0.000000
    [00:00:33.525,848] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:33.541,388] <inf> app_main: Sleeping for 1000 ms...
    [00:00:33.628,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 60 from reflector 0
    [00:00:33.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 61
    [00:00:34.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 61 from reflector 0
    [00:00:34.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 62
    [00:00:34.547,605] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.973975 (avg: 1.974833), phase_slope: 3.165542, rtt: 0.000000
    [00:00:34.562,012] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:34.576,433] <inf> app_main: Sleeping for 1000 ms...
    [00:00:34.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 62 from reflector 0
    [00:00:34.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 63
    [00:00:35.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 63 from reflector 0
    [00:00:35.328,411] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 64
    [00:00:35.583,093] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.876115 (avg: 1.946023), phase_slope: 3.266909, rtt: 0.000000
    [00:00:35.597,695] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:35.612,113] <inf> app_main: Sleeping for 1000 ms...
    [00:00:35.628,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 64 from reflector 0
    [00:00:35.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 65
    [00:00:36.178,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 65 from reflector 0
    [00:00:36.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 66
    [00:00:36.618,325] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 1.876115 ([00:00:36.628,037] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 66 from reflector 0
    avg: 1.927293), phase_slope: 3.258581, rtt: 0.000000
    [00:00:36.647,348] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:36.661,759] <inf> app_main: Sleeping for 1000 ms...
    [00:00:36.828,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 67
    [00:00:37.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 67 from reflector 0
    [00:00:37.328,026] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 68
    [00:00:37.628,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 68 from reflector 0
    [00:00:37.667,959] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.004985 (avg: 1.934336), phase_slope: 3.175309, rtt: 0.000000
    [00:00:37.682,665] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:37.697,230] <inf> app_main: Sleeping for 1000 ms...
    [00:00:37.828,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 69
    [00:00:38.128,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 69 from reflector 0
    [00:00:38.428,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 70
    [00:00:38.703,808] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.004985 (avg: 1.947235), phase_slope: 3.175362, rtt: 0.000000
    [00:00:38.718,371] <inf> app_main: Reflector 1 -[00:00:38.724,277] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:38.745,227] <inf> app_main: Sleeping for 1000 ms...
    [00:00:38.928,035] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 70 from reflector 0
    [00:00:39.528,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 72
    [00:00:39.724,538] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:39.751,446] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.004985 (avg: 1.953437), phase_slope: 3.175362, rtt: 0.000000
    [00:00:39.765,860] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:39.780,453] <inf> app_main: Sleeping for 1000 ms...
    [00:00:40.224,188] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:40.428,034] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 72 from reflector 0
    [00:00:40.786,805] <inf> app_main: Reflector 0 - Distance estimates on antenna path 0: ifft: 2.004985 (avg: 1.979211), phase_slope: 3.175362, rtt: 0.000000
    [00:00:40.801,449] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:40.816,761] <inf> app_main: Sleeping for 1000 ms...
    [00:00:40.928,025] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 75
    [00:00:41.224,450] <dbg> app_main: subevent_result_cb: Dropped subevent results due to unfinished ranging data request.
    [00:00:41.278,036] <dbg> app_main: ranging_data_get_complete_cb: Ranging data get completed for ranging counter 75 from reflector 0
    [00:00:41.822,967] <inf> app_main: Reflector 0 - [00:00:41.828,027] <dbg> app_main: ranging_data_ready_cb: Ranging data ready 77
    Distance estimates on antenna path 0: ifft: 2.004985 (avg: 2.004985), phase_slope: 3.175362, rtt: 0.000000
    [00:00:41.845,601] <inf> app_main: Reflector 1 - Distance estimates on antenna path 0: ifft: 0.000000 (avg: 0.000000), phase_slope: 0.000000, rtt: 0.000000
    [00:00:41.860,016] <inf> app_main: Sleeping for 1000 ms...
    But it's not even initiating channel sounding with the second reflector. Only one of the reflectors initiates channel sounding. Is this an SDK limitation?
    Usman
  • See if it reacts the same in NCS v3.1.0. There were some issues with multiple connections and channel sounding in NCS v3.0.2.
    Edvin
