app_update.bin isn't created
I am trying to make a FOTA to update the firmware of the nrf9151 using the command AT#XFOTA, the issue I am having is that I am unable to have the app_update.bin file generated, at least I a unable to find it inside the build/zephyr folder.
I have enabled "CONFIG_BUILD_OUTPUT_BIN=y "  and "CONFIG_BOOTLOADER_MCUBOOT=y".
Here is the build log:
Building nrf9151
west build --build-dir /nrf9151/build_1 /nrf9151 --pristine --board nrf9151dk/nrf9151/ns --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=prj.conf;overlay-native_tls.conf -DEXTRA_DTC_OVERLAY_FILE=boards/nrf9151dk_nrf9151_ns.overlay -DBOARD_ROOT=/nrf9151
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /Users/user/Library/Caches/zephyr
-- Board: nrf9151dk, qualifiers: nrf9151/ns
Parsing /opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild/Kconfig
Loaded configuration '/nrf9151/build_1/_sysbuild/empty.conf'
Merged configuration '/nrf9151/sysbuild.conf'
Configuration saved to '/nrf9151/build_1/zephyr/.config'
Kconfig header saved to '/nrf9151/build_1/_sysbuild/autoconf.h'
   * Running CMake for mcuboot *
-- Application: /opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151.dts
-- Found devicetree overlay: /nrf9151/sysbuild/mcuboot/app.overlay
-- Generated zephyr.dts: /nrf9151/build_1/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /nrf9151/build_1/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /nrf9151/build_1/mcuboot/zephyr/dts.cmake
warning: MBEDTLS_CFG_FILE (defined at
/opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig:385,
/opt/nordic/ncs/v2.9.1/nrf/subsys/nrf_security/Kconfig:66, modules/mbedtls/Kconfig:58,
modules/mbedtls/Kconfig:58) was assigned the value 'mcuboot-mbedtls-cfg.h' but got the value ''.
Check these unsatisfied dependencies: (MBEDTLS || NRF_SECURITY || (MBEDTLS_BUILTIN && MBEDTLS) ||
(MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_CFG_FILE and/or look up
MBEDTLS_CFG_FILE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
Parsing /opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151_defconfig'
Merged configuration '/nrf9151/sysbuild/mcuboot/prj.conf'
Merged configuration '/opt/nordic/ncs/v2.9.1/nrf/modules/mcuboot/tfm.conf'
Merged configuration '/opt/nordic/ncs/v2.9.1/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration '/nrf9151/build_1/mcuboot/zephyr/.config.sysbuild'
Configuration saved to '/nrf9151/build_1/mcuboot/zephyr/.config'
Kconfig header saved to '/nrf9151/build_1/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Setting build type to 'MinSizeRel' as none was specified.
-- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
CMake Warning at /opt/nordic/ncs/v2.9.1/zephyr/CMakeLists.txt:952 (message):
  No SOURCES given to Zephyr library: drivers__console
  Excluding target from build.
MCUBoot bootloader key file: /opt/nordic/ncs/v2.9.1/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /nrf9151/build_1/mcuboot
   * Running CMake for nrf9151 *
-- Application: /nrf9151
-- Found BOARD.dts: /opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151_ns.dts
-- Found devicetree overlay: /nrf9151/boards/nrf9151dk_nrf9151_ns.overlay
-- Found devicetree overlay: boards/nrf9151dk_nrf9151_ns.overlay
-- Generated zephyr.dts: /nrf9151/build_1/nrf9151/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /nrf9151/build_1/nrf9151/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /nrf9151/build_1/nrf9151/zephyr/dts.cmake
warning: Deprecated symbol MBEDTLS_LEGACY_CRYPTO_C is enabled.
warning: Deprecated symbol POSIX_CLOCK is enabled.
warning: Deprecated symbol NET_SOCKETS_POSIX_NAMES is enabled.
warning: Experimental symbol TFTP_LIB is enabled.
Parsing /nrf9151/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151_ns_defconfig'
Merged configuration '/nrf9151/prj.conf'
Merged configuration '/nrf9151/overlay-native_tls.conf'
Merged configuration '/nrf9151/build_1/nrf9151/zephyr/.config.sysbuild'
Configuration saved to '/nrf9151/build_1/nrf9151/zephyr/.config'
Kconfig header saved to '/nrf9151/build_1/nrf9151/zephyr/include/generated/zephyr/autoconf.h'
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Including signing script: /opt/nordic/ncs/v2.9.1/nrf/cmake/sysbuild/image_signing.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: /nrf9151/build_1/nrf9151
CMake Warning at /opt/nordic/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:106 (message):
        --- WARNING: Using a bootloader without pm_static.yml.            ---
        --- There are cases where a deployed product can consist of       ---
        --- multiple images, and only a subset of these images can be     ---
        --- upgraded through a firmware update mechanism. In such cases,  ---
        --- the upgradable images must have partitions that are static    ---
        --- and are matching the partition map used by the bootloader     ---
        --- programmed onto the device.                                   ---
  /opt/nordic/ncs/v2.9.1/nrf/cmake/sysbuild/partition_manager.cmake:634 (partition_manager)
  /opt/nordic/ncs/v2.9.1/nrf/sysbuild/CMakeLists.txt:703 (include)
  cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
  cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
  cmake/modules/sysbuild_images.cmake:23 (sysbuild_module_call)
  cmake/modules/sysbuild_default.cmake:20 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  /opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
Loaded configuration '/nrf9151/build_1/nrf9151/zephyr/.config'
No change to configuration in '/nrf9151/build_1/nrf9151/zephyr/.config'
No change to Kconfig header in '/nrf9151/build_1/nrf9151/zephyr/include/generated/zephyr/autoconf.h'
-- Configuring done
-- Generating done
[1/431] Preparing syscall dependency handling
[6/431] Generating include/generated/zephyr/version.h
-- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.1/zephyr), build: v3.7.99-ncs2-1
[11/431] Generating ../../tfm/CMakeCache.txt
CMake Warning at cmake/version.cmake:31 (message):
  TFM_VERSION_MANUAL mismatches to actual TF-M version.  Please update
  TFM_VERSION_MANUAL in cmake/version.cmake
  CMakeLists.txt:13 (include)
-- Found Git: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/git (found version "2.37.3")
-- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found version "3.12.4") found components: Interpreter
-- Configuring done
-- Generating done
-- Build files have been written to: /nrf9151/build_1/nrf9151/tfm
[139/143] Linking C executable bin/tfm_s.axf
           FLASH:       31536 B      32256 B     97.77%
             RAM:       11852 B        32 KB     36.17%
[18/431] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_ioctl_core_api.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/config_nordic_nrf_spe.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/driver/Driver_Common.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/driver/Driver_Flash.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/driver/Driver_USART.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/startup.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/startup_nrf91.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/nrfx_glue.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/pal_plat_test.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/pal_plat_test.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/startup.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/target_cfg.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/nrfx_config.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/CMakeLists.txt
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/native_drivers
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/native_drivers/spu.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/native_drivers/spu.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/cmsis_drivers
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_USART.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_Flash.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common/nrf-pinctrl.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common/nrfx_glue.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common/nrfx_log.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common/cmsis.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/common/tfm_hal_platform_common.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/nrfx/nrfx.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/include
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/include/tfm_ioctl_core_api.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/include/tfm_platform_hal_ioctl.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/src
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/src/tfm_platform_hal_ioctl.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_ns_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_s_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/tests
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/core/tests/tfm_tests_config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/linker_scripts/tfm_common_ns.ld
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/nrfx_config_nrf91.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/CMakeLists.txt
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/tests
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/tests/psa_arch_tests_config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/partition
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/partition/flash_layout.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf91/partition/region_defs.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/CMakeLists.txt
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/cpuarch.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/common/nrf9120/cpuarch.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/../common/config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/tests
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/tests/tfm_tests_config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/tests/psa_arch_tests_config.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin/tfm_s.axf
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin/tfm_s.bin
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin/tfm_s.hex
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin/tfm_s.elf
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/bin/tfm_s.map
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/lib/s_veneers.o
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/client.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/error.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa_manifest/sid.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/config_impl.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_veneers.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_ns_interface.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_ns_client_ext.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/config_tfm.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/config_base.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_psa_call_pack.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/framework_feature.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/build_info.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_adjust_auto_enabled.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_adjust_config_key_pair_types.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_adjust_config_synonyms.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_compat.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_driver_common.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_driver_contexts_composites.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_driver_contexts_key_derivation.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_driver_contexts_primitives.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_extra.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_legacy.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_platform.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_se_driver.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_sizes.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_struct.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_types.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto_values.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/psa/crypto.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/mbedtls/build_info.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/mbedtls/config_psa.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/nrf-config.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/nrf-psa-crypto-config.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/tfm_platform_api.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/os_wrapper
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/os_wrapper/common.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/include/os_wrapper/mutex.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/os_wrapper
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_bare_metal.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_rtos.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/tfm_crypto_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/interface/src/tfm_platform_api.c
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/config/cp_check.cmake
----- Installing platform NS -----
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm85.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_gcc_m.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_iccarm_m.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_mpu.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_cachel1.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_pmu.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_clang_m.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_tiarmclang_m.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_mpu.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv81m_pac.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_armclang_m.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm7.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/tz_context.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm3.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/cmsis_compiler.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm35p.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm4.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm0.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_ca.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_sc000.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm55.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm1.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_sc300.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/cmsis_version.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm23.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm52.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm33.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_cm0plus.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/core_starmc1.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_armclang_a.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_iccarm_a.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_gcc_a.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/irq_ctrl.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_cp15.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_clang_a.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_config.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_rotpk.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_defs.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_ns.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_crypto_nv_seed.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_nv_counters.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_ps.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_test.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/mbedtls_entropy_nv_seed_config.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_device_header.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_isolation.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_device_id.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_multi_core.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_platform.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/fatal_error.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_its_encryption.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/cmsis_override.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_attest_hal.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_interrupt.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_mailbox.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_defs.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/boot_hal.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/exception_info.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_otp.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_crypto_keys.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/region.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_hal_its.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_platform_system.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_boot_seed.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/tfm_plat_provisioning.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/CMakeLists.txt
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/cmake/toolchain_ns_GNUARM.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/cmake/toolchain_ns_ARMCLANG.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/cmake/toolchain_ns_IARARM.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/platform/include/fih.h
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/cmake/spe_export.cmake
-- Installing: /nrf9151/build_1/nrf9151/tfm/api_ns/cmake/set_extensions.cmake
[291/431] Building C object CMakeFiles/app.dir/src/main.c.obj
/nrf9151/src/main.c:598:13: warning: 'check_app_fota_status' defined but not used [-Wunused-function]
  598 | static void check_app_fota_status(void)
/nrf9151/src/main.c:153:19: warning: 'private_key' defined but not used [-Wunused-const-variable=]
  153 | static const char private_key[] = "-----BEGIN RSA PRIVATE KEY-----\n\
/nrf9151/src/main.c:132:19: warning: 'device_cert' defined but not used [-Wunused-const-variable=]
  132 | static const char device_cert[] = "-----BEGIN CERTIFICATE-----\n\
[293/431] Building C object CMakeFiles/app.dir/src/slm_at_commands.c.obj
/nrf9151/src/slm_at_commands.c: In function 'download_callback':
/nrf9151/src/slm_at_commands.c:185:56: warning: pointer of type 'void *' used in arithmetic [-Wpointer-arith]
  185 |                                    event->fragment.buf + bytes_to_end,
[431/431] Linking C executable zephyr/zephyr.elf
           FLASH:      369468 B       416 KB     86.73%
             RAM:      191234 B     211608 B     90.37%
        IDT_LIST:          0 GB        32 KB      0.00%
Generating files from /nrf9151/build_1/nrf9151/zephyr/zephyr.elf for board: nrf9151dk
image.py: sign the payload
[1/185] Preparing syscall dependency handling
[8/185] Generating include/generated/zephyr/version.h
[185/185] Linking C executable zephyr/zephyr.elf
           FLASH:       31126 B        48 KB     63.33%
             RAM:       16360 B        32 KB     49.93%
Generating files from /nrf9151/build_1/mcuboot/zephyr/zephyr.elf for board: nrf9151dk
[20/20] Generating ../merged.hex
