Switching from TX to RX mode
Dear Nordic support service,
I am currently using nRF21540 with nRF52840 and nRF5_SDK_17.1.0.
I am able to transmit and receive, but I am not able to switch from RX to TX mode.
Checking the code, I see that when a TX is needed, the following routine is called:
ret_code_t nrf21540_tx_set(uint32_t user_trigger_event, nrf21540_execution_mode_t mode)
that  calls the routine:
static ret_code_t trx_set(nrf21540_trx_t dir, uint32_t trigger_event,
that generates an error on this check:
// at the moment we are not able to switch direction on the fly.
// @todo switching between RXEN and TXEN.
NRF21540_ERROR_CHECK(device_state_get() == NRF21540_STATE_RX);
i.e. if the nRF21540 is in RX mode it can't switch on the fly to TX mode.
I wonder what is the correct way to handle the switch; if you e.g. have a link to a code snippet or to a related issue, it would be very useful.
I looked into the devzone but I was not able to find useful info.
Many thanks again for your help!
Best regards
Michele Sponchiado
